Old 19th June 2021, 23:48   #6981  |  Link
kedautinh12
FLAC v1.3.3-Git-2021-03-15-27c6157
https://www.mediafire.com/file/glymd...GCC103.7z/file
MKVToolNix v58.0.0
https://mkvtoolnix.download/windows/releases/58.0.0/
x264 0.164.3065 ae03d92
https://www.mediafire.com/file/zwwv4...GCC103.7z/file
x265 v3.5+10-82786fccc
https://www.mediafire.com/file/1b70d...GCC103.7z/file
MP4Box v1.1.0-DEV-rev1000-gfc4293194
https://www.mediafire.com/file/yffb8...GCC103.7z/file
Old 27th June 2021, 16:49   #6982  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
kedautinh12: .
LouieChuckyMerry is offline   Reply With Quote
Old 29th June 2021, 06:59   #6983  |  Link
MrBonk
I've been having some issues recently.
Trying to use Avisynth to point scale a 1080p video to 2160p x265 which I have done so in the past with zero issues.
However after recent updates I can never get this to complete. It always gives me some variation of this error
-[Information] [6/28/2021 10:06:33 PM] Started handling job
--[Information] [6/28/2021 10:06:33 PM] Using cached update config and server: http://megui.org/auto/stable/
--[Information] [6/28/2021 10:06:33 PM] There is 1 package which can be updated: x265
--[Information] [6/28/2021 10:06:33 PM] updating package x265 as it is missing or outdated
--[Information] [6/28/2021 10:06:44 PM] Preprocessing
-[NoImage] global MeGUI_darx = 16
-[NoImage] global MeGUI_dary = 9
-[NoImage] SetFilterMTMode("DEFAULT_MT_MODE", 2)
-[NoImage] LoadPlugin("G:\OS Symlinks\Desktop\Miscellaneous Things\Video Encoding and AVISynth\MEGUI2\tools\lsmash\LSMASHSource.dll")
-[NoImage] LWLibavVideoSource("B:\tdck4hln.3mw\2021-06-14 22-44-02.mkv.lwi")
-[NoImage] #crop
-[NoImage] #resize
-[NoImage] PointResize(3840,2160)
-[NoImage] Prefetch(6)
--[Information] [6/28/2021 10:06:44 PM] AviSynth input script
--[Information] [6/28/2021 10:06:46 PM] resolution: 3840x2160
--[Information] [6/28/2021 10:06:46 PM] frame rate: 60056/1001
--[Information] [6/28/2021 10:06:46 PM] frames: 30126
--[Information] [6/28/2021 10:06:46 PM] length: 00:08:22.133
--[Information] [6/28/2021 10:06:46 PM] aspect ratio (avs): 16:9 (1.778)
--[Information] [6/28/2021 10:06:46 PM] color space: I420
--[Information] [6/28/2021 10:06:46 PM] Job command line: "cmd.exe" /c ""G:\OS Symlinks\Desktop\Miscellaneous Things\Video Encoding and AVISynth\MEGUI2\tools\ffmpeg\ffmpeg.exe" -loglevel level+error -i "B:\tdck4hln.3mw\2021-06-14 22-44-02.mkv.avs" -strict -1 -f yuv4mpegpipe - | "G:\OS Symlinks\Desktop\Miscellaneous Things\Video Encoding and AVISynth\MEGUI2\tools\x265\x64\x265.exe" --preset slow --tune ssim --crf 16.0 --sar 1:1 --output "B:\tdck4hln.3mw\2021-06-14 22-44-02_Video.hevc" --frames 30126 --y4m -"
--[Information] [6/28/2021 10:06:46 PM] Process started
--[Information] [6/28/2021 10:06:46 PM] Standard output stream
--[Information] [6/28/2021 10:06:46 PM] Standard error stream
---[Information] [6/28/2021 10:06:49 PM] y4m [info]: 3840x2160 fps 60056/1001 i420p8 sar 1:1 unknown frame count
---[Information] [6/28/2021 10:06:49 PM] raw [info]: output file: B:\tdck4hln.3mw\2021-06-14 22-44-02_Video.hevc
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: HEVC encoder version 3.0_Au+4-dcbec33bfb0f
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: build info [Windows][GCC 8.2.1][64 bit] 8bit+10bit+12bit
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Main profile, Level-5.1 (Main tier)
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Thread pool created using 12 threads
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Slices : 1
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: frame threads / pool features : 3 / wpp(34 rows)
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: References / ref-limit cu / depth : 4 / on / on
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: Rate Control / qCompress : CRF-16.0 / 0.60
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: tools: rect limit-modes rd=4 rdoq=2 rskip signhide tmvp
---[Information] [6/28/2021 10:06:49 PM] x265 [info]: tools: strong-intra-smoothing lslices=4 deblock sao
---[Information] [6/28/2021 10:07:25 PM] [error] av_interleaved_write_frame(): Broken pipe
---[Information] [6/28/2021 10:07:25 PM] [error] Error writing trailer of pipe:: Broken pipe
--[Error] [6/28/2021 10:07:26 PM] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
--[Information] [6/28/2021 10:07:26 PM] Job completed
Any ideas?
I've gotten some inklings recently that my RAM timings may be unstable, but I only seem to get errors with x265
MrBonk is offline   Reply With Quote
Old 29th June 2021, 07:44   #6984  |  Link
jlw_4049
Any ideas?
Try to shorten or change filename/also change location of file or directory.
Sent from my SM-G986U1 using Tapatalk
Old 30th June 2021, 05:48   #6985  |  Link
MrBonk
Tried that, all seemed to be going well then same thing
[Error] [6/29/2021 9:16:39 PM] Process exits with error: 0xC0000096 STATUS_PRIVILEGED_INSTRUCTION (-1073741674)
Old 30th June 2021, 06:39   #6986  |  Link
jlw_4049
Is this the only file it happens to? Have you tried another with similar settings?
Old 30th June 2021, 14:35   #6987  |  Link
tebasuna51
tebasuna51's Avatar
The 'pipe' is when frames are send by RAM from AviSynth to x265 encoder then maybe this is the problem.
BTW some test over a BD source clip (H264,01:04.857, Bitrate 14984) with your avs:
LWLibavVideoSource("D:\Temp\t\00003.mkv.lwi")
#nnedi3_rpow2(rfactor=2, cshift=spline36)
Prefetch(6)
First a AvsMeter over the avs (using Prefetch or not and using PointResize or nnedi3_rpow2), and after the 4 options encoded with x265:
AVSMeter 3.0.7.0 AviSynth+ 3.5 (r3106, 3.5, x86_64) 1555 frames, 00:01:04.856
avs                             PointR.Prefetch(6)   only PointResize    nnedi3 Prefetch(6)   only nnedi3
Frames processed:               ------------------   -----------------   ------------------   -----------------
FPS (min | max | average):      28.66|148967|234.7   14.04|104.7|96.48   1.447|319602|23.68   6.916|21.04|17.03
Process memory usage (max):     508 MiB              173 MiB             859 MiB              247 MiB
Thread count:                   35                   29                  44                   38
CPU usage (average):            79.2%                17.4%               72.4%                48.4%
Time (elapsed):                 00:00:06.625         00:00:16.117        00:01:05.673         00:01:31.322
x265 --crf 20 --output-depth 10
FPS                             2.57                 2.59                2.24                 2.24
Time                            00:10:05.920         00:10:01.220        00:11:35.530         00:11:35.140
Avg QP                          23.47                23.47               23.38                23.38
Bitrate                         33170.66             33170.66            27039.24             27039.24
1) About MT, with Prefetch
You can see in AvsMeter, when only the avs is evaluated, there are better times using Prefetch. But when encode the avs the time are similar or even better without Prefetch.
That means than the avs process only need a thread to do their job and is useless try to assign more threads to it, the x265 encoder need all CPU power.
Try without Prefetch (maybe less RAM required).
2) About the resizer
For me upsize is waste time and space, all TV's 4K make a upsize on the fly when play 1080 sources.
At least use a better upsizer to do the job.
I'm sure than the TV's upsizer is better than PointResizer (only put 4 identical pixels for each one in the source) see the images (amplified 400% to see pixels).
Using nnedi3 at least you have a true 2160 with only a 14% more time
The video size with nnedi3 is 180% the size of the 1080 and the PointResize is 221%
Old 1st July 2021, 08:01   #6988  |  Link
MrBonk
Tried 2 other videos same problem. Think it may be an x265 problem actually. As transcoding without an avisynth script has the same error. Transcoding with x264 seems to work fine. Anywhere I can get a link to roll back the build of x265 I have maybe?
Old 1st July 2021, 09:33   #6989  |  Link
tebasuna51
tebasuna51's Avatar
I recommend you use the development update server
Megui -> Options -> Extended -> Auto Update -> Use development update server -> Save
Megui -> Tools -> Update -> Show all packages -> Enable all packages -> Update
That change the x265 3.0 (2019-02-16) to 3.4 (2020-09-27)
Or manually to x265 v3.5+10-82786fccc
Old 5th July 2021, 07:01   #6990  |  Link
MrBonk
So i've been able to complete the encode I was trying to make with x264 with no issue. But I need x265 to work with the device i'm targeting.
Still get the same
or
STATUS_ILLEGAL_INSTRUCTION
errors.
I tried using an older build of MEGUI and still no luck.
Old 5th July 2021, 08:59   #6991  |  Link
tebasuna51
tebasuna51's Avatar
The problem can't be MeGUI (is only a GUI), your crash is when:
ffmpeg -> pipe video data by RAM to -> x265
Must be ffmpeg, x265 or your RAM.
Are you using recent versions of ffmpeg/x265?
Are you still using Prefetch()?
Old 5th July 2021, 22:22   #6992  |  Link
MrBonk
Thank you for writing back.
I did try a slightly older of MEGUI and tried pulling x265 from another build of that. Is there somewhere else I can find compiled x265 binaries to swap in?
I haven't tried different versions of FFMPEG. Just what is bundled in.
I'll try playing with my ram timings some more too.
Old 5th July 2021, 23:27   #6993  |  Link
tebasuna51
tebasuna51's Avatar
http://msystem.waw.pl/x265/
and https://www.gyan.dev/ffmpeg/builds/ for ffmpeg.
Old 6th July 2021, 06:08   #6994  |  Link
MrBonk
Thank you, I tried replacing x265 and I was able to get it to encode once without an AVS script. But trying again didn't work, and trying with a script gave another error. Replacing FFMPEG and x265 I started getting a new errors like this
[Error] [7/5/2021 10:05:59 PM] Standard error stream
-[Information] [7/5/2021 10:05:59 PM] [fatal] G:\OS Symlinks\Desktop\1fbhzvyx.ukp\taa.mkv.avs: could not find codec parameters
-[Error] [7/5/2021 10:05:59 PM] x265 [error]: unable to open input file <->
I tried using the oldest builds of both I could find.
Tried another video on another hard drive and eliminating my G drive completely
[Error] [7/5/2021 10:10:12 PM] Standard error stream
-[Information] [7/5/2021 10:10:12 PM] [1;36m[davs2 info]: davs2: 1.6.205 b06d7585620f4e90.8, 2020-11-03 18:36:09[0m
-[Information] [7/5/2021 10:10:12 PM] [1;36m[davs2 info]: CPU Capabilities:  none! 0x0[0m
-[Information] [7/5/2021 10:10:12 PM] [1;36m[davs2 info]: Manager 29cfe0: using 1 thread(s): 1(frame/AEC)+0(pool/REC), 2 tasks[0m
-[Information] [7/5/2021 10:10:12 PM] [1;31m[davs2 error]: Manager 29cfe0: Invalid input Byte-Stream, not start code: 676c6f[0m
-[Error] [7/5/2021 10:10:12 PM] [libdavs2 @ 0029ca80] [error] Decoder error: can't read packet
-[Information] [7/5/2021 10:10:12 PM] [1;33m[davs2 warn]: Manager 9b40060: Max number of thread reached, forcing to be 8
-[Information] [7/5/2021 10:10:12 PM] [0m
-[Information] [7/5/2021 10:10:12 PM] [1;36m[davs2 info]: Manager 9b40060: using 8 thread(s): 8(frame/AEC)+0(pool/REC), 9 tasks[0m
-[Information] [7/5/2021 10:10:12 PM] [1;31m[davs2 error]: Manager 9b40060: Invalid input Byte-Stream, not start code: 676c6f[0m
-[Error] [7/5/2021 10:10:12 PM] [libdavs2 @ 00292f40] [error] Decoder error: can't read packet
-[Information] [7/5/2021 10:10:12 PM] [error] Error while decoding stream #0:0: Generic error in an external library
-[Information] [7/5/2021 10:10:12 PM] [error] Cannot determine format of input stream 0:0 after EOF
-[Information] [7/5/2021 10:10:12 PM] [fatal] Error marking filters as finished
-[Error] [7/5/2021 10:10:12 PM] x265 [error]: unable to open input file <->
Tried tweaking my ram, running it through an error checking tool outside of windows and everything seemed fine.
Old 6th July 2021, 10:44   #6995  |  Link
tebasuna51
tebasuna51's Avatar
I need the full logs (zip and upload the files in MEGUI2\logs) to understand the error messages than does not make sense for me:
Old 10th July 2021, 06:09   #6996  |  Link
MrBonk
Here are the logs from all the attempts I made on the 5th from 2 different installed versions of MEGUI with various different x265 versions and combinations of using built in Avisynth or the Avisynth included. Thank you for taking a look.
Old 10th July 2021, 13:34   #6997  |  Link
tebasuna51
tebasuna51's Avatar
I can reproduce some of your errors using long command lines.
The same file is encoded fine:
Job command line: "cmd.exe" /c ""C:\Portable\megui\tools\ffmpeg\ffmpeg.exe" -loglevel level+error -i "D:\Temp\t\00003.mkv_zz.avs" -strict -1 -f yuv4mpegpipe - | "C:\Portable\megui\tools\x265\x64\x265.exe" --crf 20.0 --sar 1:1 --output "D:\Temp\t\00003.mkv_zz86.hevc" --frames 100 --y4m -"
---[Information] [10/07/2021 13:37:36] encoded 100 frames in 28.40s (3.52 fps), 22039.39 kb/s, Avg QP:23.02
Or with errors:
Job command line: "cmd.exe" /c ""C:\Portable\megui\tools\ffmpeg\ffmpeg.exe" -loglevel level+error -i "D:\Temp\t\00003.mkv_zz.avs" -strict -1 -f yuv4mpegpipe - | "C:\Portable\megui\tools\x265\x64\x265.exe" --preset slow --crf 20.0 --deblock=-3:-3 --psy-rd 1.0 --bframes 7 --level-idc 4.1 --vbv-bufsize 40000 --vbv-maxrate 40000 --aq-strength 1.4 --rc-lookahead 40 --subme 4 --sar 1:1 --output "D:\Temp\t\00003.mkv_zz.hevc" --frames 100 --y4m -"
---[Information] [10/07/2021 12:57:54] [error] av_interleaved_write_frame(): Broken pipe
---[Information] [10/07/2021 12:57:54] [error] Error writing trailer of pipe:: Broken pipe
--[Error] [10/07/2021 12:57:54] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
Checked 2 times, work with short x265 parameters, crash with long x265 parameters.
In theory 'cmd' must support until 8191 characters but I can't know other explanation for the difference.
Try using short path to install MeGUI.
I use C:\Portable\megui
You use now G:\OS Symlinks\Desktop\Miscellaneous Things\Video Encoding and AVISynth\MeGUI-2913-32 - Copy
Old 12th July 2021, 06:27   #6998  |  Link
MrBonk
Or with errors:
Ah, ok. I will give this a shot and report back! Thank you
Edit: Tried putting it all in the root of one drive.(different builds) Still got similar error. Attached log.
Old 12th July 2021, 14:31   #6999  |  Link
tebasuna51
tebasuna51's Avatar
I don't see the log, but if this is not the problem maybe I can't help you.
Sorry, I don't know for what crash.
Old 17th July 2021, 07:00   #7000  |  Link
MrBonk
Sorry, I swore it uploaded the log. Here's one of them.
Thanks for trying to help anyway. I'm not sure what the problem is.
It's not super critical, but it does put a damper on some tests I was trying to run for 4k TVs. I'll keep trying perhaps.
