Old 26th February 2012, 09:12   #61  |  Link
oreons
MkvToMp4 author
Program can't make autocrop.
For audio tracks, can select only the quality (0.05 - 1.0)
for nero 1.0 = 400kbps
for qaac 1.0 = True VBR mode 127 (see http://forum.doom9.org/showthread.php?t=154233)
oreons is offline   Reply With Quote
Old 16th March 2012, 17:19   #62  |  Link
Balthazar2k4
Ran into another problem converting a DTS-HD track that is 24-bit/96khz to AC3. Eac3To keeps terminating prematurely. MKVToMP4 does convert to AAC correctly though.
Edit: Need to add -resampleTo48000 for DTS/TrueHD tracks that exceed 48khz.
Balthazar2k4 is offline   Reply With Quote
Old 17th March 2012, 21:00   #63  |  Link
oreons
MkvToMp4 author
Balthazar2k4,
Thanks, I'll test that.
Old 18th March 2012, 04:15   #64  |  Link
Mike_111
Originally Posted by oreons View Post
Yes, in the tags settings you can set the MP4 optimization checkbox.
Feature requests:
It would be great if you could
1) save the "MP4 optimization" setting as a default.
2) jump to the next file from within the "edit tags" window (previous/next).
3) reorder the file list
4) pause the queue in some way (at least after the current file is done)
5) enable tags by default
6) export all your settings/parameters/tags for one or more file
7) expand the "Tags" info (at the bottom) to show all checked tags
8) jump from "TV Season" tag to "TV Episode" via TAB
9) save the "TV Season" tag in the xml
Keep up the good work!
Mike_111 is offline   Reply With Quote
Old 18th March 2012, 07:19   #65  |  Link
Cephas
Tool is very handy. Thanks.
I want to make an m4v version of my mkv files that has the original AC3 audio as the 1st track, and the new AAC audio as the 2nd track.
This is to get a version that will play the 5.1 by default under XBMC, but can be transferred to my iPad and still work.
Is there a script I can edit to change the default behaviour?
Cephas is offline   Reply With Quote
Old 18th March 2012, 20:49   #66  |  Link
oreons
MkvToMp4 author
Mike_111,
Need for some mp4 files. For repacked mkv optimization is not needed. Maybe I will make in the settings.
It is useful, but difficult to implement now.
Probably will be in future versions.
Difficult to implement now.
For mkv tag empty when loading files. If you load tags from xml, they be switched on.
Save and load tags is already in the program
Parameters are also preserved.
To display the tags is a button Text
ok
see item 6
Cephas
If the first track AC3, then iTunes will not load the film to the iPad.
Old 18th March 2012, 21:50   #67  |  Link
Mike_111
Thanks for your response! MkvToMp4 is a fantastic tool! Makes it so much easier for me to convert my mkvs for my iOS devices!
Yes, but I'm often fine with just the automatically checked HD tag and the name tag. In this case I still have to manually switch them on for every file instead of just hitting start.
"Save" tags doesn't seem to work for me. Or at least not everything is saved. E.g. "Mp4 Optimization", "Name", "TV Season" and "TV Episode" are missing or won't get restored. And this "save" only saves the tag information for one file, not the files I have added, their order etc. Ideally I want to be able to highlight some files and export all their information via a context menu entry so that at a later point in time I can only import this one exported file and hit start.
I meant so that I can see all the tags without needing to open another window and easily switch between files to compare/double check them.
see item 6
See item 6
Old 19th March 2012, 09:58   #68  |  Link
oreons
MkvToMp4 author
Mike_111,
Maybe will add an option on the settings.
"Mp4 Optimization" is not a tag.
These tags are not specifically saved for the TV Show, to be able to load them and do not mess up the numbering and the name of the episode.
You can give the name episode sXXeYY for automatic substitution of these values to tags.
For example Fringe.S01E02.mkv - Season 1, Episode 2
I'll think about it.
Old 26th March 2012, 14:45   #69  |  Link
Mr. Monte
oreons,
I have to say I love this for repacking my MKV's to iOS devices.
Thanks !
Mr. Monte is offline   Reply With Quote
Old 2nd April 2012, 13:16   #70  |  Link
BuddyRich
Is there a way to both convert a DTS track to dd5.1!AC3 and keep a copy of the original dts in the same MP4 as a 2nd audio track?
Otherwise I love this program. Are there any plans to implement automated metadata lookup against tvdb, imdb or moviedb?
This is lacking for MP4s on the windows side (only metax) whereas osx has a few options (iVI, Subler, iflicks, metax/metaz)
BuddyRich is offline   Reply With Quote
Old 2nd April 2012, 19:43   #71  |  Link
oreons
MkvToMp4 author
BuddyRich,
Saving DTS in MP4 not supported by Mp4Box. DTS can be converted to DD5.1.
Yes, support tvdb and moviedb will be in future versions. IMDB does not have an API for integration and will not be supported.
Old 3rd April 2012, 03:25   #72  |  Link
Mr. Monte
I'm getting this error during eac3to demuxing
The ArcSoft and Sonic decoders don't seem to work, will use libav instead
How do I fix this please. Do I install Arcsoft, or is there a directory I can put the files into?
TIA
Old 3rd April 2012, 08:42   #73  |  Link
oreons
MkvToMp4 author
Mr. Monte,
To install Arcsoft dts decoder:
1. Put arcsoft files into dir windows\system32
2. Run from command prompt: regsvr32 ASAudioHD.ax
I can tell you more in private messages.
Old 5th April 2012, 22:12   #74  |  Link
planter88
Can somebody provide an alternate Download Link?
MediaFire is down for me
planter88 is offline   Reply With Quote
Old 7th April 2012, 18:29   #75  |  Link
oreons
MkvToMp4 author
planter88,
https://rapidshare.com/files/8584949...oMp4_0.219.zip
Old 8th April 2012, 20:04   #76  |  Link
cabala420
Apple iPad mp4 formats question
I recently muxed together some ripped tv show DVDs into mp4 format for use on the new iPad and I have some questions concerning the subtitles and chapter files. I muxed everything together using MEgui as I didn't know about this program at the time.
Subtitles are in .srt format and chapter files are in .ogg directly from DVD decrypter. The iPad doesn't recognize either. Once I use mkvtomp4 and use the optimize button the subtitles work at least. Still no luck on chapters. Any suggestions? Maybe a different format? I cant seem to determine what formats for chapters apple uses or what atom information is.
What is mkvtomp4 doing to the .srt subtitle file for it to work?
Thanks for any help.
cabala420 is offline   Reply With Quote
Old 9th April 2012, 08:57   #77  |  Link
oreons
MkvToMp4 author
MkvToMp4 can load the chapters only from mp4 or mkv file. Then you can copy them to another file.
For correct playback subs on Apple devices, the program makes a correction to mp4 atoms. You can load your mp4 file to MkvToMp4 and press start. This program will make the correction of the atoms.
Old 11th April 2012, 21:43   #78  |  Link
roidy
This is a great program that has saved me loads of time, however I'm having volume problems when converting AC3 to AAC if I use the default Quicktime 7.7.0 codec option the resulting AAC audio volume is far to low and if I use Nero or CoreAudio codecs then the volume is far to loud
roidy is offline   Reply With Quote
Old 12th April 2012, 08:30   #79  |  Link
oreons
MkvToMp4 author
QuickTime and CoreAudio uses a different version of Qaac, possibly because of the difference in volume.
Try Sox for dynamic compression of sound.
Old 12th April 2012, 18:04   #80  |  Link
roidy
I've fixed it, my fault, I had Normalize turned off for some reason, turned it back on and everythings good. Thanks.
mkv, mkvtomp4, mp4, repack, video
