Old 14th June 2012, 15:42   #41  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
@Mr. Monte thanks it should work now.
ozok is offline   Reply With Quote
Old 15th June 2012, 16:57   #42  |  Link
rexdeymond
! sorry my english bad ! i like using your tx264 gui this like minicoder (discontinued and not update)
I can be a little problem when using 0.7.2 Tx264 up, when I convert the movie anime all went smoothly with no problems, but when I do not find a complete description of the file earlier in the output folder (my ouput in " D:\ ")
I am using win 7 x64
rexdeymond is offline   Reply With Quote
Old 15th June 2012, 17:40   #43  |  Link
ozok
ozok's Avatar
Can you send me the log?
If you are using mp4 as container and your windows (or system's temp folder) is located at a driver other than "D:\" that can cause the problem.
Old 15th June 2012, 19:12   #44  |  Link
rexdeymond
If you are using mp4 as container and your windows (or system's temp folder) is installed at a driver other than "D:\" that can cause the problem.
where the log, i tired make ouput in D: or c: or oher folder or default output, I convert the movie with the number 5 to the above, the results are only movie in queue 1 and queue 2 looks better then 3 and so on always succeed but the file does not exist in the output folder, if I use the Run as administrator in the first queue file to run properly hereinafter queue 2 and the subsequent experiencing the same issue with both using mp4 or mkv
EDIT:
I think window system's temp folder problem, in log tell temp cannot delete or merge something like that, you have solution to fix it
Old 15th June 2012, 19:17   #45  |  Link
fantasmanegro
post it!
fantasmanegro is offline   Reply With Quote
Old 15th June 2012, 19:19   #46  |  Link
ozok
ozok's Avatar
@rexdeymond on main window at the bottom-left there is a button labeled "Logs/Outputs", click on it and from the new window click "Save" then send me the saved txt file. also you can send me screenshots or info about problematic files.
Old 15th June 2012, 19:29   #47  |  Link
rexdeymond
@ ozok
I have some questions about the features present, can you give details about the features of the present, I used to use the medium, but when I use a very fast computer I always die alone instead of a BSOD, but what if I use the fast and the quality convet faster than convert what better or worse than the medium, you have recommendation what must i use for fast and good quality
edit:
my hadware
[url]http://valid.canardpc.com/show_oc.php?id=2406735[url]
Old 15th June 2012, 19:44   #48  |  Link
fantasmanegro
@rexdeymond...
could you just copy / paste text ?...
Old 15th June 2012, 19:59   #49  |  Link
rexdeymond
Originally Posted by fantasmanegro View Post
@rexdeymond...
[16/06/2012 1:22:44] Started deleting temp files...
[16/06/2012 1:22:44] Deleted 0 file(s).
[16/06/2012 1:22:44] Finished deleting temp files.
[16/06/2012 1:24:16] Started deleting temp files...
[16/06/2012 1:24:16] Deleted 1 file(s).
[16/06/2012 1:24:16] Finished deleting temp files.
[16/06/2012 1:24:16] Starting encoding process
[16/06/2012 1:24:16] Command lines:
--pass 1 --bitrate 250 --profile high --preset medium --tune animation --stats "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].stats" --output NUL "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv"
--pass 2 --bitrate 250 --profile high --preset medium --tune animation --stats "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].stats" --output "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv"
-y -i "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" -vn -f wav -map 0:1 "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav"
-br 48000 -if "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav" -of "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].aac"
chapters -s "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv"
tracks "D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" 2:"C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass" 3:"C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt"
--chapters "C:\Users\SLim\AppData\Local\Temp\TX264\\chapters.txt" -o "D:\D A T A ~ C O N V E T E R\TX264(0.7.4.1523)\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv" "C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].aac"
[16/06/2012 1:27:57] Done video encoding with x264
ffms [info]: 640x480p 1:1 @ 2187/91 fps (vfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT
x264 [info]: profile Main, level 3.0
x264 [info]: frame I:442 Avg QP:23.65 size: 18147
x264 [info]: frame P:14654 Avg QP:27.77 size: 2940
x264 [info]: frame B:26269 Avg QP:30.36 size: 158
x264 [info]: consecutive B-frames: 12.6% 20.7% 7.4% 10.2% 9.5% 39.5%
x264 [info]: mb I I16..4: 49.8% 0.0% 50.2%
x264 [info]: mb P I16..4: 8.0% 0.0% 0.0% P16..4: 26.0% 0.0% 0.0% 0.0% 0.0% skip:66.0%
x264 [info]: mb B I16..4: 0.2% 0.0% 0.0% B16..8: 3.3% 0.0% 0.0% direct: 0.9% skip:95.7% L0:45.4% L1:47.1% BI: 7.5%
x264 [info]: final ratefactor: 27.84
x264 [info]: coded y,uvDC,uvAC intra: 31.7% 36.4% 11.3% inter: 3.4% 2.7% 0.1%
x264 [info]: i16 v,h,dc,p: 57% 22% 16% 5%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 15% 23% 4% 7% 5% 4% 6% 6%
x264 [info]: i8c dc,h,v,p: 58% 16% 22% 3%
x264 [info]: Weighted P-Frames: Y:4.0% UV:2.7%
x264 [info]: kb/s:256.87
encoded 41365 frames, 202.28 fps, 256.87 kb/s
[16/06/2012 1:34:16] Done video encoding with x264
x264 [info]: profile High, level 3.0
x264 [info]: frame I:442 Avg QP:22.71 size: 18084
x264 [info]: frame P:14654 Avg QP:26.21 size: 2832
x264 [info]: frame B:26269 Avg QP:31.93 size: 165
x264 [info]: mb I I16..4: 33.0% 31.2% 35.7%
x264 [info]: mb P I16..4: 3.1% 3.4% 1.7% P16..4: 19.5% 6.9% 3.1% 0.0% 0.0% skip:62.3%
x264 [info]: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 7.3% 0.4% 0.1% direct: 0.1% skip:92.1% L0:41.2% L1:57.1% BI: 1.7%
x264 [info]: 8x8 transform intra:38.7% inter:56.9%
x264 [info]: coded y,uvDC,uvAC intra: 30.2% 44.9% 17.3% inter: 2.8% 3.6% 0.2%
x264 [info]: i16 v,h,dc,p: 60% 22% 10% 8%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 9% 50% 4% 3% 4% 2% 4% 3%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 13% 23% 6% 7% 8% 5% 7% 4%
x264 [info]: i8c dc,h,v,p: 56% 17% 22% 4%
x264 [info]: ref P L0: 58.5% 8.0% 14.6% 7.1% 5.0% 5.3% 1.5% 0.0%
x264 [info]: ref B L0: 80.0% 12.5% 4.9% 1.9% 0.7%
x264 [info]: ref B L1: 95.1% 4.9%
x264 [info]: kb/s:250.20
encoded 41365 frames, 111.00 fps, 250.21 kb/s
[16/06/2012 1:34:24] Done audio decoding
ffmpeg version N-41416-g718607b Copyright (c) 2000-2012 the FFmpeg developers
built on Jun 8 2012 12:49:40 with gcc 4.6.3
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --ena libavutil 51. 56.100 / 51. 56.100
libavcodec 54. 25.100 / 54. 25.100
libavformat 54. 6.101 / 54. 6.101
libavdevice 54. 0.100 / 54. 0.100
libavfilter 2. 78.101 / 2. 78.101
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 15.100 / 0. 15.100
libpostproc 52. 0.100 / 52. 0.100
Input #0, matroska,webm, from 'D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].mkv':
Metadata:
creation_time : 2006-09-30 23:29:50
Duration: 00:28:43.70, start: 0.000000, bitrate: 1612 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 640x480, SAR 1:1 DAR 4:3, 23.98 fps, 23.98 tbr, 1k tbn, 59.94 tbc (default)
Metadata:
title : bible black - episode 3: black sacrifice
Stream #0:1(jpn): Audio: vorbis, 48000 Hz, stereo, s16 (default)
Metadata:
title : vorbis (stereo)
Stream #0:2(eng): Subtitle: ssa (default)
Metadata:
title : .ass (styled)
Stream #0:3(eng): Subtitle: text
Metadata:
title : .srt (plain)
Stream #0:4: Attachment: ttf
Metadata:
filename : 39 Smooth.ttf
mimetype : application/x-truetype-font
Stream #0:5: Attachment: ttf
Metadata:
filename : KALLAMAR.TTF
Stream #0:6: Attachment: ttf
Metadata:
filename : KALLI___.TTF
Stream #0:7: Attachment: ttf
Metadata:
filename : KALLS___.TTF
Output #0, wav, to 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN].wav':
Metadata:
encoder : Lavf54.6.101
Stream #0:0(jpn): Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16, 1536 kb/s (default)
Metadata:
Stream mapping:
Stream #0:1 -> #0:0 (vorbis -> pcm_s16le)
Press [q] to stop, [?] for help
size= 323194kB time=00:28:44.23 bitrate=1535.5kbits/s
video:0kB audio:323194kB global headers:0kB muxing overhead 0.000014%
[16/06/2012 1:35:13] Done audio encoding with neroaac
* Nero AAC Encoder *
* Copyright 2009 Nero AG *
* All Rights Reserved Worldwide *
* Package build date: Feb 18 2010 *
* Package version: 1.5.4.0 *
* See -help for a complete list of available parameters. *
Processed 1723 seconds...
[16/06/2012 1:35:14] Done extracting chapters from mkv
[16/06/2012 1:35:20] Done extracting subtitle from mkv
Extracting track 2 with the CodecID 'S_TEXT/ASS' to the file 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass'. Container format: SSA/ASS text subtitles
Extracting track 3 with the CodecID 'S_TEXT/UTF8' to the file 'C:\Users\SLim\AppData\Local\Temp\TX264\\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt'. Container format: SRT text subtitles
Progress: 100%
[16/06/2012 1:35:20] Done muxing to mkv
mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Error: Unknown chapter file format in 'C:\Users\SLim\AppData\Local\Temp\TX264\\chapters.txt'. It does not contain a supported chapter format.
[16/06/2012 1:35:20] Started deleting temp files...
[16/06/2012 1:35:20] Can't delete: Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]1.ass
[16/06/2012 1:35:20] Can't delete: Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP03.[ENG.SUBS].[UNCEN]2.srt
[16/06/2012 1:35:20] Deleted 8 file(s).
[16/06/2012 1:35:20] Finished deleting temp files.
Old 15th June 2012, 20:22   #50  |  Link
ozok
ozok's Avatar
looks like something is wrong with chapter extraction. everything else seems to be working without a problem. try unchecking "Copy chapter info from source". Also send me info about that file by right clicking the file on the list "Info">"Save". Mkv file might be corrupted.
You can ignore "can't delete" warningsē
Old 15th June 2012, 21:43   #51  |  Link
rexdeymond
File info, please answer my question about fitur " present"
General
Unique ID : 229945979227156434504248381857017017353 (0xACFDFC153379096883397FFD3046B409)
Complete name : D:\D A T A ~ V I D E O\{ = X ! X = }\T0428-701781\Bible.Black.EP01-06.[ENG.SUBS].[UNCEN]_Bible.Black.EP01.[ENG.SUBS].[UNCEN].mkv
Format : Matroska
Format version : Version 1
File size : 331 MiB
Duration : 28mn 1s
Overall bit rate mode : Variable
Overall bit rate : 1 650 Kbps
Encoded date : UTC 2006-09-17 00:42:37
Writing application : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library : libebml v0.7.7 + libmatroska v0.8.0
Attachment : Yes / Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 28mn 1s
Bit rate : 1 489 Kbps
Nominal bit rate : 1 885 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Original frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.202
Stream size : 299 MiB (90%)
Title : bible black - episode 1: school of black magic
Writing library : x264 core 50 svn-557M
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=0 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1885 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Default : Yes
Forced : No
Audio
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 28mn 1s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 25.7 MiB (8%)
Title : vorbis (stereo)
Writing library : libVorbis 1.1.1/1.1.2 (UTC 2005-03-04)
Language : Japanese
Default : Yes
Forced : No
Writing application : Made with BeSweet v1.5b31
Encoded_Application/Url : http://DSPguru.doom9.org
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : .ass (styled)
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : .srt (plain)
Language : English
Default : No
Forced : No
Old 15th June 2012, 22:00   #52  |  Link
ozok
ozok's Avatar
Looks like TX264 detects chapters even though file hasn't got any.
About presets, from http://mewiki.project357.com/wiki/X264_Settings:
preset
Default: medium
Change options to trade off compression efficiency against encoding speed. If you specify a preset, the changes it makes will be applied before all other parameters are applied.
You should generally set this option to the slowest you can bear.
Values available: ultrafast, superfast, veryfast, faster, fast, medium, slow, slower, veryslow, placebo.
Note the bold parts.
Old 15th June 2012, 22:50   #53  |  Link
fantasmanegro
please!......
use common chars in folder name, it is recommended not to use names like "D:\D A T A ~ V I D E O\{ = X ! X = }" for example...
Old 15th June 2012, 23:11   #54  |  Link
rexdeymond
@ozok thanks I've fixed the problem by unchecking the mux chapter, Can you make a feature file size, because I'm too lazy to calculate birate file if I convert a lot of movies
Old 16th June 2012, 12:17   #55  |  Link
ozok
ozok's Avatar
@rexdeymond i'll look into file size thing.
Old 17th June 2012, 08:53   #56  |  Link
rexdeymond
@ozok : I can be the same problem with the first, but with a different file and I feel TX264 (0.7.4.1523) runs with no good to use subtitle files with style
Note: I tried to use MKV or MP4 as the container still has the same problem
Old 17th June 2012, 14:45   #57  |  Link
Mr. Monte
Download works now. Just ran for first time. I get a can't find neroaac file error. I'm assuming your download does not include this file. I have it. Where do I stick it. If there are anymore files I need to complete full functionality..please advise. BTW, might want to put this in a FAQ text file with the download.
Mr. Monte is offline   Reply With Quote
Old 17th June 2012, 14:51   #58  |  Link
ozok
ozok's Avatar
@Mr. Monte place it in the Tools folder. You can disable that warning by following "Other Options">"Do not warn if neroaacenc is not present", if you don't want to have neroaacenc. All other files are there. I was not sure whether it'd cause problems if i had added it to the package. FAQ sound like a good idea thx.
Old 17th June 2012, 20:37   #59  |  Link
@rexdeymond
No discussion of torrent downloads is allowed per forum rule 6. Strikes can follow further violations.
http://forum.doom9.org/forum-rules.htm
@all
No further help on this issue is to be given.
Old 23rd June 2012, 20:57   #60  |  Link
Ronin-7
Very nice UI ozok, any chance of Flac audio encoding support being added in the future ?
Ronin-7 is offline   Reply With Quote
faac, mkv, mp4, neroaacenc, x264
