Old 21st November 2019, 04:11   #29001  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by Mike-uk View Post
noticed when encoding its using the 32bit version of x264 ?? why is it not using 64 bit
also how do you add stuff to the avisynth script, i want to enable the MT mode ?
I've noticed that, and I've wondered why "it's" not doing it also. The rest is redundant.
Old 21st November 2019, 23:10   #29002  |  Link
Michi
Error on Wizard of OZ:
[11.21.19] BD Rebuilder v0.60.29
[19:50:51] Source:  WIZARD_OF_OZ
  - Input BD size: 77,81 GB
  - Approximate total content: [02:46:04.245]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[19:50:51] PHASE ONE, Encoding
 - [19:50:51] Processing: VID_00000 (1 of 9)
 - [19:50:51] Extracting A/V streams [VID_00000]
 - [19:50:55] Reencoding video [VID_00000]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 23,976fps, 486 frames
   - Bitrate: 12.895 Kbs
 - [19:50:55] Reencoding: VID_00000, Pass 1 of 1
 - [19:51:23] Video Encode complete
 - [19:51:23] Processing audio tracks
 - [19:51:23] Multiplexing M2TS
 - [19:51:27] Processing: VID_00001 (2 of 9)
 - [19:51:27] Extracting A/V streams [VID_00001]
 - [19:51:31] Reencoding video [VID_00001]
   - Rate/Length: 23,976fps, 457 frames
   - Bitrate: 5.393 Kbs
 - [19:51:31] Reencoding: VID_00001, Pass 1 of 1
 - [19:51:57] Video Encode complete
 - [19:51:57] Processing audio tracks
 - [19:51:57] Multiplexing M2TS
 - [19:52:00] Processing: VID_00002 (3 of 9)
 - [19:52:01] Extracting A/V streams [VID_00002]
 - [19:53:56] Reencoding video [VID_00002]
   - Source Video: HEVC, 1920x1080
   - Rate/Length: 23,976fps, 74.301 frames
   - Bitrate: 32.449 Kbs
 - [19:53:56] Reencoding: VID_00002, Pass 1 of 1
 - [20:13:41] Video Encode complete
 - [20:13:41] Processing audio tracks
 - [20:13:41] Multiplexing M2TS
 - [20:18:53] Processing: VID_00004 (4 of 9)
 - [20:18:53] Extracting A/V streams [VID_00004]
 - [20:19:00] Reencoding video [VID_00004]
   - Rate/Length: 23,976fps, 8.160 frames
   - Bitrate: 8.020 Kbs
 - [20:19:00] Reencoding: VID_00004, Pass 1 of 1
 - [20:26:27] Video Encode complete
 - [20:26:27] Processing audio tracks
 - [20:26:27] Multiplexing M2TS
 - [20:26:39] Processing: VID_00007 (5 of 9)
 - [20:26:39] Extracting A/V streams [VID_00007]
 - [20:31:17] Reencoding video [VID_00007]
   - Rate/Length: 23,976fps, 146.383 frames
   - Bitrate: 35.000 Kbs
 - [20:31:17] Reencoding: VID_00007, Pass 1 of 1
 - [22:56:20] Video Encode complete
 - [22:56:20] Processing audio tracks
   - Track 4354 (deu): Keeping original audio
 - [22:56:20] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00007.meta
 - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information.
[22:56:44] - Failed to build structure, aborted
Michi is offline   Reply With Quote
Old 22nd November 2019, 02:12   #29003  |  Link
Alleycat
I rebuilt a concert blu-ray which had 720 x 480i mpeg 2 source with a 16:9 display aspect ratio. I noticed that the rebuilt version has small black bars at the top and bottom and the picture was of reduced height (slightly squashed) compared to the original. When I used the hidden option show_encoder=1, x264 reported the following: "lav [info]: 720x480i 32:27 @ 30000/101 fps (cfr)"
I could see that bd-rb was then telling x264 to use SAR=40/33 when doing the re-code, which I believe is the cause of this problem. Is there a way of forcing bd-rb to preserve the original SAR value?
Alleycat is offline   Reply With Quote
Old 22nd November 2019, 07:51   #29004  |  Link
prologic
Tried to remux Game of thrones S8 disc1(BLURAY) , Bd rebuilder came back with , error reading disc .. went back to version 60.04 and all read ok
prologic is offline   Reply With Quote
Old 22nd November 2019, 17:36   #29005  |  Link
Ch3vr0n
Now how about you post the encoding log of the build that fails, so @jdobbs actually has something to work with and maybe fix?
Old 22nd November 2019, 18:21   #29006  |  Link
Yeah. Especially since "error reading disc" isn't an error from within BD-RB.
Old 24th November 2019, 10:24   #29007  |  Link
Michi
Muxing Error on RED 2:
[11.24.19] BD Rebuilder v0.60.29
[09:54:01] Source:  RED_2
  - Input BD size: 59,23 GB
  - Approximate total content: [03:02:05.879]
[09:54:03] PHASE ONE, Encoding
 - [09:54:03] Processing: VID_00000 (1 of 8)
 - [09:54:03] Extracting A/V streams [VID_00000]
 - [09:58:45] Reencoding video [VID_00000]
 - [09:58:45] Keeping original video (no reencode)
 - [09:58:45] Processing audio tracks
   - Track 4352 (deu): Keeping original audio
 - [09:58:45] Multiplexing M2TS
 - [10:07:08] Processing: VID_00001 (2 of 8)
 - [10:07:08] Extracting A/V streams [VID_00001]
   - Extracting video streams [VID_00001]
   - Extracting audio/subtitle streams [VID_00001]
 - Network Optix tsMuxeR.  Version 2.6.12. www.networkoptix.com
   - Extracting audio streams [VID_00001]
 - Error in attempt to extract audio.
[10:09:20] - Failed to retrieve audio, aborted
Old 24th November 2019, 10:40   #29008  |  Link
ggtop
SourceCheck() 0006 2503
when opening the source path to a mounted ISO I get an error message "Error Condition" "BD Rebuilder experienced an error 2503 [timestamp] SourceCheck() 0006 2503".
It's a Multi Part BluRay interesstingly it only happens in Movie Only Mode. Switching to Full Backup mode lets BDRB show the stream overview as expected.
As a workaround I used TSMuxer to create a new structure (ISO) with the desired MPLS and used that which worked so far as I can say.
What kind of "illegal source" is this error indicating?
Glad to help and Thank you in advance,
ggtop
Old 26th November 2019, 14:06   #29009  |  Link
Originally Posted by ggtop View Post
ggtop
It wasn't necessarily an illegal source. It looks like BD-RB experienced an overflow error while doing a source check. Can you provide the log? I'm kinda flying blind without it.
Old 29th November 2019, 17:37   #29010  |  Link
terrykuntz
CPU question?
Will an 8 core CPU be able to complete a bd rebuild twice as fast as an 4 core CPU? Would it be better to get an 8 core intel processor than an 16 core AMD processor?
terrykuntz is offline   Reply With Quote
Old 29th November 2019, 23:39   #29011  |  Link
x264 and x265 can utilize more than 8 cores so buying Intel CPU makes zero sense.
Old 30th November 2019, 13:49   #29012  |  Link
An 8 core CPU will likely complete faster than a 4 core -- but not twice as fast. That's not how multiprocessing works.
Old 30th November 2019, 20:28   #29013  |  Link
SquallMX
Special SeeD
Sometimes the gains are even bigger. Going from an 8 core Ryzen 1700x to a 12 core Ryzen 3900 I got a 2X speed boost with only 50% more cores, something to do with optimizations for AVX instruction sets.
SquallMX is offline   Reply With Quote
Old 3rd December 2019, 16:18   #29014  |  Link
gg72
Is there any option to disable the 4-way splitting in DirectShow mode?
gg72 is offline   Reply With Quote
Old 3rd December 2019, 17:34   #29015  |  Link
Ch3vr0n
Not "just" for DS mode no. There is a general one, disable multiprocess in bdrebuilder.ini (either comment out the line with # in front of it, or just delete it entirely). That's the only possibility
Old 3rd December 2019, 18:00   #29016  |  Link
The default is no splitting. The only way it has 4 way splitting is if you've (at some point) set MULTIPROCESS=4 in your INI file or MULTIPROCESS=1 in your INI file and you have 6 (or more) processors.
Old 3rd December 2019, 18:14   #29017  |  Link
Thought I'd share an interesting point I discovered. I recently got a UHD television and have been experimenting with playback with different 2160p files. Then I decided to disable 4K upscaling on my Sony UBP-X800 so I could make sure I am really getting UHD.
I was a little shocked to find that many of the reencoded UHD MKV/MP4 files weren't actually playing in UHD -- they were playing in 1080p and were being upscaled. Some experimenting showed that only the files I'd reencoded with BD-RB (ALTERNATE mode), or original BD files, were actually playing in true 2160p. My guess is that the player requires the files to be encoded with settings that are uhd-bd compatible (which BD-RB does via X265) and many downloads are not encoded that way.
Just thought I'd pass that on as food for thought. It may be peculiar to my player, I don't know, but I think there are possibly people out there who think they are getting 2160p output when they are actually only getting 1080p upscaled to 2160p on reencoded MKV/MP4 UHD files.
Old 3rd December 2019, 18:23   #29018  |  Link
That's pretty cool.
Old 3rd December 2019, 19:53   #29019  |  Link
gg72
Thanks jdobbs & Ch3vr0n ;-)
Old 4th December 2019, 07:37   #29020  |  Link
MrVideo
MrVideo's Avatar
[...]but I think there are possibly people out there who think they are getting 2160p output when they are actually only getting 1080p upscaled to 2160p on downloaded UHD files.
Are you saying that some 2160p files are being reduced to 1080p by your player before being sent to the display? If so, that player, IMHO, is seriously flawed.
