19th October 2019, 08:25 | #23661 | Link |
Take a look at the links of this post.
4th November 2019, 16:20 | #23662 | Link |
Thanks Chros, that helps a lot.
One more question... It seems that the vast majority of desktops and laptops nowadays have some form of DXVA2 hardware acceleration. But the LAV Video Decoder installation default for Hardware Acceleration is "None", so inexperienced users are stuck with software decoding from the start (unless they investigate and change the setting). Wouldn't it be better for the installation default to be DXVA2 copy-back instead? If there was any problem it would drop back to software (none) anyway. It just seems that basic/inexperienced users are missing out on the hardware acceleration that their PC is capable of because they are set up with software decoding from the start. Any thoughts on this? |
4th November 2019, 17:03 | #23663 | Link |
I don't believe "unexperienced" users should actually install LAV Filters themselves. They should just get MPC-HC or another player, which bundle everything they need, and players can also pre-configure it to how they see their user-base.
5th November 2019, 20:13 | #23664 | Link |
It is a bad idea. The "copy-back" feature is redundant for most real systems (this will only increase power consumption). And on some systems (with integrated graphics) there will be problems with the frame output speed (50/60 fps will become unattainable).
11th November 2019, 08:25 | #23665 | Link |
just a small heads up that arm based windows notebooks/tables and such are now are now starting to show up.
one example is the surface pro x not a small product and important that it is from microsoft showing once more there commitment to arm. |
11th November 2019, 16:36 | #23667 | Link |
well yes but we talked about this before and nev was thinking about an arm build software decoding is important and the copy operation is as far as i know SIMD optimised.
the emulation is really slow. not a good video but better then nothing: https://www.youtube.com/watch?v=oR0x_yx-6Rg real world test with native x86 vs a emulated x86 is at ~11:20. working is not always good enough... and just to be clear not saying that this device is enough to justify an ARM build or even making it close to important but just look at the name of the processor this is mostly not the last one. the surface 2? had a tegra too but newer devices used an intel CPU. |
11th November 2019, 21:47 | #23668 | Link | |
I am worried more about raw CPU performance. Cinebench chart is not looking promising.. Is that really possible that emualted Windows gonna win with native arm Android system and even (nonexistent anymore) WinRT? Or other linux distro? |
12th November 2019, 06:26 | #23669 | Link |
i mean the chrome test the emulated x86 on arm is not competitive at all but edge which was native arm vs native x86 was competitive.
beware these are pretty bad controlled test but they still hint that native ARM code is much faster then emulated code. windows 10 is native ARM or with other words it has an ARM build. |
27th November 2019, 09:14 | #23670 | Link |
Hi Guys,
Not sure if anyone can shed any light for me? I have some videos with a aac 5.1 sound track, if I let Lav Audio handle the playback, the sound is as flat as a pancake (tried with saneer, with all the options on and off, no difference, and tried without saneer, again no difference). However, if I remove Lav audio from the chain, the sound is deep and high, and expansive. My windows audio (HDMI) device is set to 7.1 192 khz, so windows is doing the up sampling (or whatever the term is), but no matter what settings i use if I use Lav Audio, it still sounds flat (tried with mixing, and no mixing options on etc). Maybe I have missed something obvious? I would have thought that using non-exclusive mode, they should sound the same?
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 27th November 2019 at 13:08. |
27th November 2019, 18:31 | #23671 | Link |
What is 'saneer'?
For the most accurate audio in LAV: - enable all output formats - disable DRC - disable mixing (should not be needed if you use 7.1) When you say "if I remove Lav audio from the chain", what decoder is used in that case? If the audio renderer is the same then that other decoder is probably applying processing to the audio that makes it sound different from the accurate decoding of LAV.
28th November 2019, 08:59 | #23673 | Link |
Thanks for correcting my spelling error Huhn.
@ el Filou - yep, did all that (all the obvious stuff). I can use any other service to render (ffdshow) with all options disabled/inactive, and as I said, the sound is completely different. Maybe Nev can shed some light.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 28th November 2019 at 10:16. |
28th November 2019, 13:49 | #23674 | Link |
"flat" audio is not a technical description that allows any kind of diagnosis. LAV decodes all audio as accurately as possible.
28th November 2019, 14:09 | #23675 | Link |
Did you try decoding a track to a WAV using something like ffmpeg or eac3to and then playing that WAV file to see if it's closer to what ffdshow or LAV outputs?
If you look on the Web for "WavDest", you can also try and get a WAV file output of both playback chains to find out what exactly is different in the sound, but you need to use GraphStudio. LAV was mainly designed to be a simple and accurate decoder, while ffdshow is more a full-blown audio processing framework which increases the chances of 'doing something wrong' even unintentionally. If the sound is different between them, the most probable cause would be ffdshow modifying it rather than LAV not decoding it correctly.
28th November 2019, 19:04 | #23677 | Link |
The most likely case is that your AAC audio file decodes to a different channel layout then you might expect, since LAV actually tries to obey the layout information in the file, while older decoders like ffdshow just ignored such info and put it in a generic 5.1. That may be a case of a badly encoded audio stream, or just needing some tweaking in the audio renderer configuration to map it to the speakers you actually have.
Without a file at hand or some info I can actually go on (like maybe the output pin info of both LAV Audio and another decoder), its impossible to say anything else however.
29th November 2019, 08:53 | #23678 | Link |
ok thanks Nev, will do a bit more digging.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
13th December 2019, 00:41 | #23679 | Link |
If a an mkv file have seeking issues (it seeks but it acts like an flv file and has to go through the entire file).
Is that the LAV Splitter that's the "problem", or is it the video decoder? (I am using LAV obviously). I basically have this issue with certain produced mkv files, but VLC if i recall doesn't, so while the files might be odd, or perhaps wrong in some way, it can at least be handled. And i would like to know what the problem is, and hopefully have it solved if possible. But i need to know what handles the seeking first, and then perhaps give some sample (this might be hard though if you want to see it being slow, as then the file has to be very big, but if it's just a sample that has the issue and you can look at it's data somehow, that's easy enough). Thanks! |
13th December 2019, 09:11 | #23680 | Link |
Try to remultiplex the file to a new MKV with MKVToolnix or ffmpeg; if the problem persists, it's more probably the content for this file.
Anyway, different media players may use differently robust techniques (one may fail in case of issues where another may be able to skip). If you use LAV Filters with a generic media player, the DirectShow API may be the culprit; MPC-HC (and probably MPC-BE too) uses LAV Filters with another native API. And VLC uses the same core libraries but with an own "playback engine". |
