Old 27th June 2018, 10:10   #51541  |  Link
Aleksoid1978
Aleksoid1978's Avatar
You say that latest nvidia drivers support 23.976 "from box" ??
Old 27th June 2018, 10:10   #51542  |  Link
madjock
Originally Posted by Crimson Wolf View Post
A while back I always had issues with custom res, and stopped using it. Once madshi stated nvidia would be releasing a new driver which would fix the 23.976hz issue, I removed all traces of custom res, used DDU, and just tried the default 23hz 12-bit full-RGB. Now my frame drop is days or never. I never have to touch custom again. I do not get any issues anymore.
I had hoped for the same, but unsure if it is because I bitstream, even though yes the composition rate was now at 23.976, it was not allowing for the HDMI audio clock (I think thats whats happening), so was no better off.
Old 27th June 2018, 11:21   #51543  |  Link
madjock
Well they definitely changed something in last two drivers as the composition rate is sat at 23.976 now.
398.36 Standard
https://postimg.cc/image/lmhzclp5n/
This is the latest 398.36 and as can be seen, no custom created and it runs at 23.976, but personally it is not working for me as the frame repeats can be bettered with older drivers and custom res, I did get lucky and created one. I found I had to create and not modify and save. Then modify, I tried a movie and it was no different from initial install. I then looked at the custom I created and it had went back to Automatic, so its not saving modified settings.
390.77 Standard
https://postimg.cc/image/wnq8hfarx/
As can be seen the defualt is 23.970
390.77 Custom
https://postimg.cc/image/cgcsp75lp/
What I need to use and get a custom res that sticks and a good frame repeat number.
Old 27th June 2018, 11:25   #51544  |  Link
mclingo
if NVIDA now supports native 23,976 can someone check to see if they've fixed the MVC 3D dropped frames, if they fix this I might switch to my 1050 card as it should be better than my RX 460
Old 27th June 2018, 11:40   #51545  |  Link
madjock
I think Manni tried the previous drivers that had this fix, he said there was an improvement in the 3D side as well. I assume it is carried across to the latest driver.
https://forum.doom9.org/showthread.p...55#post1843855
- 3D (1080p23FP) timings improved (same as 397.93, around 13-14min for a frame repeat vs every 3min with any of the former drivers)
Old 27th June 2018, 11:54   #51546  |  Link
mclingo
An improvement but sadly i cant deal with any skips at all, just ruins the immersion for me with 3D, i'll stick with my RX for now then.
Cheers.
Old 27th June 2018, 13:43   #51547  |  Link
SirSwede
Originally Posted by SirSwede View Post
Yeah, but 50 fps wouldn't accept those recommendations unfortunately.
Ah I see, yes the GT740 is a very weak card. Hmm.. you might need to stick to the defaults for 50 fps, maybe try Spline or Lanczos 3 for chroma and image upscaling.
I meant that it wouldn't do the previous recommendations you gave me for scaling or running 25 fps. It will do Jinc or super-xbr for 50 fps however, but not NGU or Error Diffusion.
Is the sharpness shown in the green sharpness bar, for super-xbr, the sharpness set to 100?
SirSwede is offline   Reply With Quote
Old 27th June 2018, 16:43   #51548  |  Link
Warner306
Try super-xbr100 in both cases. It is a little faster than Jinc and sharper. If not, drop down to Lanczos3 + AR. super-xbr150 is a lot sharper, but it will produce quite a bit more ringing.
Old 27th June 2018, 18:18   #51549  |  Link
HillieSan
rx 480 and rx 580 are identical cards.
They are not 100% identical. The RX 580 fixed a performance issue with multi-monitor. The RX 580 has some more refinements on 14 nm process enabling better overclocking and better stability at a high clock speed. Overall the RX 580 is 10% faster than the RX 480. The RX 580 is a revision of the RX 480 and AMD applied rebranding.
HillieSan is offline   Reply With Quote
Old 27th June 2018, 18:36   #51550  |  Link
Mike-uk
A few questions
HI, new to Madvr, my usage is 1080p Blu-ray backups and 4k hdr backups
the reason for me using madvr is for the 4k HDR passthrough
my question is, if using madvr for 4k hdr am I right in thinking that a lot of processing is happening to the video ?, surely 4k video don't need any processing as its high resolution and bit rate already, and is it actualy degrading it in any way by using Madvr for 4k ??
or am I getting it wrong and madvr makes 4k even better ??
if madvr don't make 4k any better, would a option to turn of all prossesing and passthrough video and HDR to tv ??
should I be using madvr if I only ever watch 1080p and 4k, but I need HDR passthrough to TV
Mike-uk is offline   Reply With Quote
Old 27th June 2018, 18:41   #51551  |  Link
madVR doesn't do any unnecessary processing by default.
chroma is upscaled everytime and this is unavoidable.
Old 27th June 2018, 21:31   #51552  |  Link
Asmodian
Yes. There are some steps that must be done to get the video from the file to your TV and madVR does them in higher quality than anything else.
Chroma upscaling
Conversation to RGB
Dithering to the output bitdepth
All of these steps must happen to get 4K video on a 4K TV.
madVR options explained
Old 28th June 2018, 03:28   #51553  |  Link
Also madvr's HDR tone mapping is set to get a boost in quality with the next version, likely surpassing many HDR television manufacturers own algorithms. So yes you will want to use madVR for 4K HDR.
Old 28th June 2018, 16:41   #51554  |  Link
mytbyte
I couldn't find this covered before so here it is: I'm trying to calibrate a SDR UHD TV to MadVR HDR->SDR conversion by using HCFR and rendering via MADTPG to avoid advancing the HDR patterns manually from disk but it seems MADTPG outputs regular gamma style curve i.e. patterns are not HDR encoded, even though I have HDR->SDR conversion activated in MadVR settings. Is it possible that MADTPG doesn't work with MadVR's own HDR processing options but only when a HDR TV is connected? Are there plans to allow MADTPG generate HDR patterns without a HDR display connected and pass them through HDR->SDR processing? Madshi?
mytbyte is offline   Reply With Quote
Old 28th June 2018, 16:48   #51555  |  Link
HDRT -> SDR conversation is a conversation to "gamma" there is no point in sending HDR pattern and there is no need for a different calibration if your SDR is calibrated.
Old 28th June 2018, 18:42   #51556  |  Link
mytbyte
You have the point...in theory. But my SDR gamma is pretty much spot on 2.2 all the way but the measures from manual Masciola's patterns don't track as close to BT.2390 roll off as I'd like so I like to tweak it more while looking at the BT.2390 curve which would be much easier going back and forth with automatic patterns.
Old 28th June 2018, 19:00   #51557  |  Link
Asmodian
I am not sure what you mean by "patterns are not HDR encoded", do you mean they do not go through madVR's HDR -> SDR conversion path? How would madTPG know HCFR was sending patches it should treat as HDR? I don't think madTPG looks for flags from software telling it HDR metadata, I don't think there are any standards around metadata attached to test patches so it would have to be something worked out between HCFR (Argyllcms) and madVR.
An option in madTPG to set the input HDR metadata, similar to how we can set the output metadata, would be cool.
Old 28th June 2018, 19:04   #51558  |  Link
HDR pattern without HDR are pointless.
Old 28th June 2018, 19:33   #51559  |  Link
Manni
MadTPG suports HDR, at least with Calman. You simply have to specify the metadata for the content (max brightness etc) and the software indicates this to MadTPG and switches to HDR. This has been the case for a while. It’s only useful if calibrating in HDR (passthrough), not if you’re doing a conversion, in which case you want the display to be calibrated to sdr rec-709 or P3 or BT2020 with a power gamma (2.4 recommended) and you don’t need/want MadTPG to be in HDR mode.
HCFR should be supporting this, best would be to ask Zoyd on AVS in the HCFR thread.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 28th June 2018, 20:24   #51560  |  Link
mytbyte
Your text in bold, that's what I meant and thought was implemented from the go since it comes from the same author. Viewing the PQ curve tells the whole story, can't tell how close it actually tracks from SDR luminance curve measures.
I asked, no reply so far. Why do you think 2.4 gamma is recommended, i.e. why does it matter any if we can select the gamma a display is calibrated to in MadVR?
