Old 22nd March 2008, 02:31   #201  |  Link
dragongodz
dragongodz's Avatar
It is a DGZ's decision in order to speed up QuEnc multithread development without modifing the GUI
yes the idea was so people could try and test the threaded change with existing programs easily.
do not blame me
of course.
however maybe a little more information that that change was part of the QuEnc alpha may have saved any confusion and encouraged people to try it.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1)
dragongodz is offline   Reply With Quote
Old 22nd March 2008, 13:31   #202  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
DGZ, you are clearly right.
You know, when I have a new release ready to be uploaded, I do never spend enough time in writing documentation and changes log...
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 11th April 2008, 14:59   #203  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A beta release of AVStoDVD 2.0.0 is available to download and test (...only for the brave )
Change log (quite long):
- GUI redesigned
- Added possibility to add more titles to one DVD
- Added log activity window in main form
- Mouse right-click menus enabled in main form
- Added a new more configurable 'Title Edit' form
- New and configurable Video Encoding Profiles setup (see Help for more details)
- Added CQ prediction calculation and 1-pass VBR encoding with HCenc
- Added support to SubRip (srt) text-based subtitles (using "SubtitleCreator", included in AVStoDVD installer package)
- Added possibility to hard-encode subtitles (using "VobSub" AviSynth plugin (VSFilter.dll), included in AVStoDVD installer package)
- Added 'AudioAmplify' shortcut in 'AviSynth Script Edit' window (now in 'Title Edit' form)
- Added split between 'temporary process' and 'AVStoDVD working' files classification
- Added check on m2v output filesize. If bigger than target, added a transcoding step using ReJig
- Added audio AC3 fixing step when AC3 track is demuxed from the original input file (using "AC3Fix", included in AVStoDVD installer package)
- Added prompt to save project when exiting from AVStoDVD
- Added possibility to make PayPal donations
- AVStoDVD settings are now stored in the Windows Registry (removed AVStoDVD.ini configuration file)
- MediaInfo updated to 0.7.6.2
- ImgBurn updated to 2.4.0.0
As usual, comments and suggestions are welcome.
Bye
MrC
AVStoDVD Homepage
Old 11th April 2008, 15:02   #204  |  Link
rendez2k
rendez2k's Avatar
Thanks Mr C - will be testing when I get home!
Does "Added possibility to add more titles to one DVD" mean that menus have now been added?
rendez2k is offline   Reply With Quote
Old 11th April 2008, 15:22   #205  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Unfortunately not. It simply means that more than one title can be authored on a dvd.
Bye
MrC
AVStoDVD Homepage
Old 12th April 2008, 03:15   #206  |  Link
MysticE
Why? Do folks really need more hooks in their systems?
MysticE is offline   Reply With Quote
Old 12th April 2008, 08:10   #207  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@MsticE
Because registry is simpler to manage that ini files
Most popular and well known sw (MPC, QuEnc, AviSynth, ImgBurn, etc.) use this method.
It is only one registry key (HKEY_LOCAL_MACHINE\SOFTWARE\AVStoDVD) and it will be possibile to remove it using the uninstall procedure that will come with installer package.
Bye
MrC
AVStoDVD Homepage
Old 12th April 2008, 15:27   #208  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
New build (with installer and sorce code) loaded on SourceForge
Bye
MrC
AVStoDVD Homepage
Old 14th April 2008, 18:36   #209  |  Link
wg
Hi MrC,
Using the Noinstall version of your new beta I have converted 2 separate project, Xvid files with srt subs, both encoded using Hcenc 2 pass vbr, both seem fine. What's happened to the jobs list for batch encoding?, I hope you have not permanently removed this feature, as I think the ability to do batch encodes really made AVStoDVD stand out from many others.
Cheers!
wg is offline   Reply With Quote
Old 15th April 2008, 07:45   #210  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by wg View Post
Hi MrC,
Cheers!
Since 2.0.0 beta it is possible to load more than one input file and then select output type (separate streams, one dvd structure, one iso, one burned dvd). I have thought batch encoding would be redundant.
The only output setup not covered now is batch encoding of multiple dvd structures (or iso). Is that setup what you mean?
Let me know and we will manage it somehow.
Bye
MrC
AVStoDVD Homepage
Old 15th April 2008, 20:04   #211  |  Link
wg
The only output setup not covered now is batch encoding of multiple dvd structures (or iso). Is that set-up what you mean?
Bye
MrC
That's exactly the set-up I mean, the ability to batch-encode separate dvd structures, i.e. one full movie per disc, exactly as you could do with version 1.2.3 using the jobs list. The beauty of this is you can set it to create multiple discs overnight & the next day they are ready to be burned to disc, classic batch encoding.
Cheers!
Old 15th April 2008, 22:33   #212  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Just so you know, ImgBurn is on 2.4.1.0.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 16th April 2008, 12:57   #213  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Cheers!
Ok, got it. You do have a really big big hard drive!!!
What about an option button to toggle on if you want to create multiple DVD structures?
Bye
MrC
AVStoDVD Homepage
Old 16th April 2008, 12:58   #214  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks, I will update it
Bye
MrC
AVStoDVD Homepage
Old 16th April 2008, 18:51   #215  |  Link
wg
Sounds good to me, also the option to turn off pc after 'all' jobs completed(There is a bug in 1.2.3 that if you have say 2 jobs in the queue & have turn off pc selected it will do this after the 1st job & won't even start the 2nd job).
Thanks in advance.
Old 19th April 2008, 14:55   #216  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A new beta build of AVStoDVD 2.0.0 is available to download and test.
Change log:
- GUI improved
- ImgBurn updated to 2.4.1.0
- Added built-in Preview form (no more external preview player)
- Added customizable skins
@wg
JobList batch encoding is coming back...
Bye
MrC
AVStoDVD Homepage
Old 20th April 2008, 14:45   #217  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD Skins available to download on SourceForge:
Right now, only one skin added... Any contributions are welcomed!
Bye
MrC
AVStoDVD Homepage
Old 21st April 2008, 17:45   #218  |  Link
wg
@wg
Cheers!
Old 25th April 2008, 15:25   #219  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Change log:
- Some bugs fixed
- MediaInfo updated to 0.7.6.3
- Batch encoding (Jobs list) has come back
Bye
MrC
AVStoDVD Homepage
Old 27th April 2008, 08:44   #220  |  Link
wg
Thanks for the update & the return of batch encoding, will try out soon.
Cheers!
[IMG] code is Off
