Old 22nd March 2018, 01:02   #49721  |  Link
seiyafan
Is 3GB card enough for upscaling to 1440p? I am thinking of getting a 1060 instead of 1050TI but the 6GB version is too expensive right now. Not sure if 1050TI is enough for upscaling to 1440 though.
seiyafan is offline   Reply With Quote
Old 22nd March 2018, 01:31   #49722  |  Link
You'll be fine with 3GB, yeah 1060 all the way.. great card.
Old 22nd March 2018, 09:35   #49723  |  Link
bran
As I've said in previous posts, there is a lot more noticeable banding when sending "12-bit" to current-gen TVs compared to 10bit. Regardless of madVR or standalone UHD-players. So padded zeros or not - the result is more banding.
For example check out threads regarding Panasonics UB700/900 players - people were getting banding until Pana released new firmware enabling 10bit.
I myself got a lot less banding outputting 10bit from AMD compared to nvidias 12bit (Samsung JS9505).
HTPC: Samsung 65JS9505, Yamaha A2070, Sonus Faber, RX580
bran is offline   Reply With Quote
Old 22nd March 2018, 10:38   #49724  |  Link
So.. maybe if Nvidia had a 10bit mode we'd be peachy?
Old 22nd March 2018, 10:42   #49725  |  Link
Or those crappy TVs should stop accepting 12-bit if they can't properly deal with it, then.
The fault clearly lies with the device that advertises support for a mode that it can't process properly.
Old 22nd March 2018, 10:49   #49726  |  Link
ashlar42
This. So much this.
I long for a world where companies open a special section of their website, dedicated to enthusiasts, with all information relative to what's necessary to defeat the so-called "enhancements" that they introduce to satisfy undiscerning eyes.
Old 22nd March 2018, 12:52   #49727  |  Link
Manni
Sure, but that doesn’t mean that projectors like my JVC which do support 12bits from input to panel shouldn’t benefit from it.
Zero banding in the Allied clip here, and same results with NV HDR and OS HDR.
What is sure is that people should test whether their display supports 12bits or not before enabling it. 8bits is a safer option unless 12bits support is confirmed.
Win10 Pro x64 b1809 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 398.11 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25PR2
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 22nd March 2018, 13:03   #49728  |  Link
el Filou
el Filou's Avatar
While you're right on TVs, I still don't get why NVIDIA won't give the option of 10-bit HDMI output.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 22nd March 2018, 14:14   #49729  |  Link
mclingo
and native 23,976
Old 22nd March 2018, 14:29   #49730  |  Link
Razoola
The solution here is Nvidia offering 10bit and 12bit support in divers for TV's that support both bit depths.
Razoola is offline   Reply With Quote
Old 22nd March 2018, 14:41   #49731  |  Link
Warner306
Originally Posted by BatKnight View Post
I believe that when playing a 2160p 10bit HDR 23.976fps video and having madVR set up to output 10 bit, that all is going the best way possible.
What I don't understand is why when sending the HDR metadata, that results on NV HDR, I get banding and when not sending the HDR metadata, and manually enabling the OS HDR, I get perfect image and no banding... Why is OS HDR behaving differently than NV HDR for the same settings?
I think the problem here is the metadata. When the OS HDR toggle is enabled, it is my understanding Windows sends the color gamut and transfer function to the display, but not the metadata. The gamut and transfer function is enough for the display to enter its HDR mode. Tone and gamut mapping are done at the PC level. In fact, in the next update, Windows is releasing a calibration tool to change how HDR looks on your display. This is why HDR is always on.
When the Nvidia private API is used, the metadata is passed to the display untouched. The display uses its own processing to complete the tone and gamut mapping, not Windows. This would imply your display has issues processing a 10-bit HDR input. It's tone and gamut mapping is not of the highest-quality. This would explain why banding does not show for Manni on his display.
I could be wrong, but maybe a display is not the best at handling HDR processing? If true, I should delete my posts from yesterday.
Warner306 is online now   Reply With Quote
Old 22nd March 2018, 14:42   #49732  |  Link
Warner306
But he said most 12-bit input is fine. It is only HDR that is the problem. And 12-bit with the OS HDR toggle is also fine. It has something to do with the HDR tone mapping.
Old 22nd March 2018, 16:07   #49733  |  Link
brazen1
I have a couple more things to add since some keen interest is popular at the moment: I have no intentions of introducing any sort of Ad nauseam.
Early drivers offered 8,10, and 12bit. The 10bit option was removed in recent drivers for RGB afaik. So now it's just 8bit or 12bit to select.
When using RGB 4:4:4 12bit @23Hz (matching old faithful Allied 2160p HDR test refresh rate) understanding this is a one shot deal since it's going to revert to 8bit after a reboot with newer drivers:
Manni has pointed out his display accepts 12bit and dithers to 10bit correctly with no banding and retains after a reboot. If I'm not mistaken, Manni is also using a custom 3Dlut and not passing HDR through.
It should also be noted, no amount of madVR processing to reduce banding artifacts has any affect at all. Nor does the dithering algorithm used.
When using YCbCr 4:2:2 10/12bit @23Hz there is NO banding.
When using YCbCr 4:4:4 10/12bit @23Hz there IS banding.
When using RGB 4:4:4 12bit @23Hz there IS banding.
When using RGB 4:4:4 8bit @23Hz there is NO banding.
So, is it better to lose 10bit using RGB 4:4:4 8bit @23Hz
or
use YCbCr 4:2:2 10/12bit @23Hz and gain back 10bit once the 12bit dithers down or when using 10bit? I don't mind recalibrating since YCbCr is limited only and no full.
At some point, I may work my way backwards in driver versions to find RGB that still offered 8,10, and 12bit choices so I can select 10 and see if banding is present or if I must still select 8bit to cure it. I'm not looking forward to doing that anytime soon though.
Lastly, Allied is a 2160p HDR title. Testing an SDR 1080p title, no amount of anything eliminates or reduces banding. A good example is 47 Meters Down 2017 at scene 42:00
W10 1903 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5
65JS8500 UHD HDR 3D
Old 22nd March 2018, 17:17   #49734  |  Link
Manni
Early drivers offered 8,10, and 12bit. The 10bit option was removed in recent drivers afaik. So now it's just 8bit or 12bit to select.
When using YCbCr 4:2:2 12bit @23Hz there is NO banding.
When using YCbCr 4:4:4 12bit @23Hz there IS banding.
or
use YCbCr 4:2:2 12bit @23Hz and gain back 10bit once the 12bit dithers down? I don't mind recalibrating since YCbCr is limited only and no RGB.
Nope, this is not what is happening here.
I use MadVR in HDR passthrough mode, so MadVR sends 10bits, the GPU sends 12 (padded or "interpolated") and the display does no additional dithering because it's a 12bits native projector (12bits path from inputs to panels). So 12bits is actually the best option for me, as my cables are all able to handle the full HDMI 2.0 bandwidth and my display handles 12bits natively.
I do not use a 3DLUT for HDR, I pass it through to the display and I use custom ST2084 gamma curves to display it properly (the native HDR mode of my model is very poor, so I use the Vertex to disable it and I handle the HDR conversion with my own curves). The Metadata goes to the Vertex (and is displayed on its OSD for monitoring/testing when necessary) but it's not sent on in order to prevent the JVC from switching to its crappy HDR mode automatically. The PJ is calibrated to HDR BT2020 when I display 4K23p HDR content. The native HDR mode on more recent JVCs is better than on my model, but still not as good as a few well-designed custom curves (until MadVR's HDR to SDR conversion works better with projectors).
In my case, the best mode for HDR (or SDR) content at 23p is 4K23p RGB 4:4:4 12bits (MadVR dithering to 10bits). For 60p content, it's 4K60p RGB 4:4:4 8bits (MadVR dithering 8bits). For others, it might be different.
I wouldn't use 4:2:2 unless I had to (poor cables, non-optimal display). I'd rather have MadVR chroma upscaling goodness all the way, but that means cables able to handle 445Mhz in 4K23p@12bits and 600Mhz in 4K60p@8bits.
Old 22nd March 2018, 17:47   #49735  |  Link
Warner306
or
Bit depths were covered yesterday.
Remember, 10-bit RGB > 8-bit RGB > 10-bit YCbCr 4:2:2 > 10-bit YCbCr 4:2:0. That is a quote from madshi.
Given the problem your display has with 12-bit HDR, 8-bit and 10-bit are not equal, as 8-bit is actually better. So your choice is easy. Going from RGB in madVR to YCbCr 4:2:2 would destroy the chroma upscaling done by madVR.
Given that 4:2:2 corrects the HDR issue, maybe your display has trouble with the higher bandwidth of a 12-bit 4:4:4 HDR signal as RGB and YCbCr seem not to matter. It sounds like a poorly-implemented HDR mode by the display. Perhaps, an epic failure by the display if banding is created. For some reason, for one user, Windows OS HDR does a better job. The output from Windows would still be 12-bits HDR, but it doesn't have banding. That sounds like poor tone mapping or gamut mapping.
Does the 1080p title only band at 10-bits? It is not uncommon for 1080p Blu-rays to have some banding in the source.
Old 22nd March 2018, 18:00   #49736  |  Link
brazen1
Got it. I made the wrong assumption about you and a 3Dlut. I'm not familiar with Vertex? I assume it's some sort of expensive additional device add to your HDMI cables to overcome some sort of problem? Anyway, I don't use a Vertex and I don't think I have any need one, and I don't think most people use one. I'm just sort of the common, regular ol' user that uses madVR, an AVR, and a display. I too would like madVR goodness all the way. I'm pretty sure my display is optimal and my cables are of little importance since all of them are no longer than 6' but maybe I'm mistaken. I'm not smart enough to know if your setup that works for you translates into mine should as well even though my setup is more primitive or perhaps in no need of more external configuration like yours. From the expert knowledge I see here, a general rule of thumb is always use RGB full. That limited adds extra processing. Except now I am met with a decision I have no expertise and rely on others here, including you. Which is preferred? RGB full at 8bit only or YCbCr limited at 10bit? I know what you use. I am asking about myself. It comes down to accept banding or live without 10bit or switch to YCbCr limited. I have no idea which of those 3 choices is the wisest?
Warner, let me digest all that. I need to run a few tests and look up some specs. Thank you.
65JS8500 UHD HDR 3D
Old 22nd March 2018, 18:03   #49737  |  Link
Manni
RGB Full 4:4:4 8bits with MadVR dithering to 8bits in your case. No question.
You don't need a Vertex, and most people don't need one either. It's an advanced diagnostic/testing/HDMI problem solving tool. I was simply explaining my chain as you stated quite a few wrong assumptions.
Old 22nd March 2018, 19:18   #49738  |  Link
el Filou
el Filou's Avatar
Originally Posted by mclingo View Post
and native 23,976
But that can still be achieved with custom resolutions, while there is just no way to output 10 bpc over HDMI. I just don't get the reasoning behind allowing 12 bpc and not 10 bpc.
Old 22nd March 2018, 19:34   #49739  |  Link
it should still be possible to force nvidia to output 10 bit with a custom edid.
and seriously 12 bit processing is not rocket science at all. even an old cheap Phillips TV was able to do 16 bit driver 12 bit GPU and showed no banding at all...
Old 22nd March 2018, 20:09   #49740  |  Link
bran
For myself, and what I've gathered from various threads - the banding happens in UHD HDR titles with 12bit enabled.
