Old 9th August 2018, 06:24   #52021  |  Link
chros
chros's Avatar
It's working here with BE using the latest beta (always worked).
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 9th August 2018, 06:54   #52022  |  Link
Originally Posted by XTrojan View Post
Obviously DXVA2 Copyback is superior than software if image quality is equal between them, the question is if it is, I heard some people getting more artifacts with DXVA2 copy-back
they are bit identical for codecs like h264 and newer.
i still don't see dxva2 as obviously superior but let'S leave it at this.
Old 9th August 2018, 15:08   #52023  |  Link
ajp_anton
ajp_anton's Avatar
How does the smooth motion on/off logic work?
"only if there would be motion judder without it..." - Smooth motion is turned off on VFR video, how can madVR think there won't be judder?
"... or if the display refresh rate is an exact multiple of the movie frame rate" - Isn't this a good example of when SM is *not* needed?
ajp_anton is offline   Reply With Quote
Old 9th August 2018, 15:41   #52024  |  Link
XTrojan
I meant that it's superior since it doesn't consume massive amounts of CPU when decoding large HEVC files. This is assuming MadVR doesn't hog 99% of the GPU already, but I doubt it requires more than 5% GPU power on my 1080 TI with DXVA2 Copy-back.
XTrojan is offline   Reply With Quote
Old 9th August 2018, 17:16   #52025  |  Link
Ver Greeneyes
IIRC DXVA is done on a separate chip (or a dedicated section of logic on the main chip) so it shouldn't use the rest of the GPU (except for copying data back and forth).
Old 9th August 2018, 17:49   #52026  |  Link
Clammerz
Originally Posted by Schwartz View Post
When madVR can't connect to the internet (ethernet working, internet offline), it takes several seconds longer to start up and also produces ~6 seconds of black before the video shows properly.
Are you sure that's madVR causing the delay?
It seems like it may be either Windows SmartScreen checking, or your media player (perhaps version or other telemetry checking).
The last time I checked madVR doesn't attempt any network connection unless you have the LAN option set (which isn't impacted by internet connectivity).
Clammerz is offline   Reply With Quote
Old 9th August 2018, 18:26   #52027  |  Link
brazen1
Isn't madVR using a network connection to send crash reports which is the telemetry of your system?
W10 1903 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5
65JS8500 UHD HDR 3D
Old 9th August 2018, 18:43   #52028  |  Link
Only if it crashes and only if you actually press the Send button. This would not interact with playback at all.
Old 9th August 2018, 19:32   #52029  |  Link
brazen1
That's good to know. Thank you nevcairiel.
65JS8500 UHD HDR 3D
Old 9th August 2018, 19:55   #52030  |  Link
e-t172
The madVR options thread should have the answers to your questions.
Old 10th August 2018, 09:12   #52031  |  Link
it is doing 4:2:0 -> 4:2:2 -> 4:4:4 with "simple" scaler.
why this is the case well i guess you have to ask madshi.
doing it in 1 shader should be faster if i remember it correctly Shiandow was testing this.
Old 10th August 2018, 10:55   #52032  |  Link
Asmodian
madVR makes this decision at startup and will use whatever value for the frame rate it is told by LAV, it doesn't analyze timestamps.
madVR options explained
Old 10th August 2018, 11:35   #52033  |  Link
Weirdo
Originally Posted by thighhighs View Post
You have all Windows 10 focus assist features disabled? It fix "frozen video" for me.
You were right, thanks. It's strange because Focus Assist was supposedly disabled, but problem went away only after unticking all options.
Win 10 Pro x64
Weirdo is offline   Reply With Quote
Old 10th August 2018, 19:20   #52034  |  Link
Asmodian
Yes, focus assist seems oddly behaved. It needs to be completely disabled or it damages performance even if it is not supposed to be doing anything.
Old 10th August 2018, 19:44   #52035  |  Link
Stereodude
Can we get the ability to go negative (below 0) in custom video levels in madVR? For example, being able to go to -16 would fix incorrectly encoded black levels on a laptop or PC system that maps 0 to black and 255 to white.
Old 10th August 2018, 20:14   #52036  |  Link
control+alt+shift+i
maybe there is a tag name too
Old 11th August 2018, 04:42   #52037  |  Link
Stereodude
control+alt+shift+i
That affects both ends though right? From my quick test it seems to. I've seen content where the peak white levels are correct, only the blacks are mis-mapped. Hence the request.
Old 11th August 2018, 05:20   #52038  |  Link
Clammerz
Have you tried:
Originally Posted by changelog.txt
* added tag "blacklevel=%value%", value range [-50, +50]
If you CTRL+F for "tag" in the changelog you'll see others that may be of use.
Old 12th August 2018, 16:54   #52039  |  Link
oldpainlesskodi
Hi fellows,
I'm sure I am not the only one following progress over on the AVS forum....waiting patiently.
Can anyone else with a HDR set confirm at this stage that madVRhdrTestFinalColor4.zip is producing a picture with far more depth, contrast, and better tone mapping than the latest version (today)? Maybe I am misunderstanding the latest builds in terms of what it is trying to achieve - are the latest builds purely about trying to restore detail, or is Madshi, using the results of Color test builds, and now on to restore details?
Forgive me if it's a stupid question, but on a HDR set, madVRhdrTestFinalColor4.zip is producing the best image of all test HDR to SDR builds to date (100, 100, 100, 75, 50, 25, off, off)
K
Sapphire RX 5700 XT , Win 10 x64 (1903), Quad Core @ 4.4ghz, Silverstone LC13B-E, Pioneer SC-LX501 Elite D3, Samsung UE55KS8000, YAMAHA NSF51 speakers, Kodi Dsplayer 17.6 X64
Old 12th August 2018, 18:05   #52040  |  Link
KoKlusz
Latest 3 test builds are only making changes to the detail restoration algorithm, the rest of tonemapping pipeline is not affected, as far as i know.
KoKlusz is offline   Reply With Quote
