Old 12th September 2012, 05:40   #1  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic - BE Win32/x64
Media Player Classic - BE is a free and open source audio and video player for Windows.
MPC-BE is based on the original "Media Player Classic" project (Gabest) and "Media Player Classic Home Cinema" project (Casimir666), contains additional features and bug fixes.
Supported Operating Systems:
* Windows 7, Windows 8 32bit/64bit, Windows 8.1 32bit/64bit, Windows 10 32bit/64bit, Windows 11 64bit
System Requirements:
* An SSE2 capable CPU. (Starting from version 1.5.1 build 2631 beta a CPU with SSE2 is required.)
* The latest DirectX 9.0c runtime (June 2010). Install it regardless of the operating system, they all need it.
DirectX End-User Runtime Web Installer
Links:
Project Page
Changes in release 1.7.0:
Build in Visual Studio 2017 is no longer supported.
The names of methods in the IExFilterConfig interface have been changed without losing compatibility.
MpegSplitter
Added support for VVC(H.266) video.
MP4Splitter
Improved file search for some audio tracks.
Fixed hang on corrupted Vorbis streams.
OggSplitter
Improved file search.
RawVideoSplitter
MpaDecFilter
Added support for USAC / xHE-AAC.
MPCVideoDec
Added support for D3D12 copy back mode.
Added support for VVC(H.266) video decoding.
Added AVS3 support for external filter.
Expanded support for hardware decoding for full range video and H.264 Baseline profile.
Added support for additional HEVC Intel decoders for D3D11 copy back mode.
Fixed "Skip B-frames" setting for H.264 and HEVC.
YouTube
Improved YouTube support in the built-in parser.
Fixed work with youtube-dl.
Audio tracks with DRC will now be ignored.
Player
Added the ability to open the folder of the currently playing file using a hotkey.
Do not show zero hours when displaying time.
Changed the logic of frame offset relative to the center of the window.
Improvements to opening long paths and paths starting with "\\?".
Fixed the operation of the "On Top" setting.
The ability to add supported video renderers to the list of external filters has been removed. Supported video renderers are selected in the Video settings panel.
Checking for updates now uses the GitHub API.
Improved display of external audio tracks in subfolders.
Added the ability to enable video preview for URLs.
Fixed priority of HTTP filters for Ace Stream.
"MPC Audio Renderer" is now the default audio renderer.
The "Global Media Keys" setting is disabled by default.
The operation of global multimedia keys has been fixed.
Various interface fixes.
Installer
MPC Video Renderer 0.7.3 is included in the installer.
New installations will not have "x64" appended to the folder name.
Updated French translation (by rhahgleuhargh).
Updated Italian translation (by mapi68).
Updated Korean translation (by Hackjjang).
Updated Chinese (Simplified) translation (by wushantao and WanderMax).
Updated Spanish translation (by IPeluchito).
Updated Turkish translation (by cmhrky).
Updated Japanese translation (by tsubasanouta).
Updated Hungarian translation (by mickey).
Updated German translation (by Klaus1189).
Updated Dutch and Chinese (Traditional) translation (by beter).
Updated Romanian translation (by Andrei Miloiu)
Updated libraries:
dav1d git-1.4.1-14-ge27b451;
fdk-aac git-v2.0.3;
ffmpeg git-n7.1-dev-220-gd307aca184;
Little-CMS git-lcms2.16-43-g4635588;
MediaInfo git-v24.03-g83b52779;
nanosvg git-93ce879;
Speex-1.2.1-20-g3693431;
rapidjson git-v1.1.0-748-g3f73edae;
ZenLib git-v0.4.41-12-g26b4aa1;
zlib 1.3.1.
Media Player Classic - BE 1.7.0 x64 (Stable release):
Media Player Classic - BE 1.7.0 x64 (with installer)
Standalone Filters Media Player Classic - BE 1.7.0 x64
Media Player Classic - BE 1.7.0 Win32 (Stable release):
Media Player Classic - BE 1.7.0 x86 (with installer)
Standalone Filters Media Player Classic - BE 1.7.0 x86
Nightly Builds:
Nightly Builds
Report a problem.
Frequently Asked Questions about the GNU Licenses
alexins is offline   Reply With Quote
Old 12th September 2012, 06:20   #2  |  Link
Hypernova
At long last! I saw the "leak" has the seekbar preview. Gotta try this right away.
Edit: Request: Can you make the filename's font inside the seekbar respect cleartype setting?
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10.
Hypernova is offline   Reply With Quote
Old 12th September 2012, 10:12   #3  |  Link
cyberbeing
Broadband Junkie
Unchecking "Auto-load Subtitles" doesn't disable the internal subtitle renderer or gray out the Subtitles context menu during playback.
Unchecking "Enable built-in audio switcher filter" and restarting MPC-BE doesn't gray out the Audio context menu during playback.
Old 12th September 2012, 11:25   #4  |  Link
Aleksoid1978
Aleksoid1978's Avatar
"Auto-load Subtitles" - it's for auto-load external subtitle.
"Enable built-in audio switcher filter" & Audio Context Menu - they are different things, they have nothing in common.
Old 12th September 2012, 11:41   #5  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by alexins View Post
MPC-BE
Very
Many
Old 12th September 2012, 11:59   #6  |  Link
cyberbeing
Broadband Junkie
So you're saying those are intentional changes you've made to MPC-BE compared to MPC-HC?
I don't care so much about Audio menu, but there should be a way to completely disable the internal subtitle renderer from loading any subtitles, which also prevents it from being enabled via context menus or hotkeys during playback. In MPC-HC the "Auto-load subtitles" check-box has that function, but it doesn't seem to have been replaced anywhere in MPC-BE.
Old 12th September 2012, 12:19   #7  |  Link
Aleksoid1978
I don't care how it's work in MPC-HC. But - it's work in MPC-BE. If you uncheck "Auto-load subtitle" - there is no Menu with subtitle list. In popup menu you can show only sub-menu with Subtitle Options.
Old 12th September 2012, 12:32   #8  |  Link
cyberbeing
Broadband Junkie
The problem is that having the Subtitle menu accessible when it's non-functional will lead to confusion when VSFilter or some other subtitle filter is used.
Old 12th September 2012, 13:39   #9  |  Link
Aleksoid1978
No. It's sub-menu does not interfere VSFilter or other subtitle filter.
Old 12th September 2012, 14:29   #10  |  Link
fairchild
Thanks, will give this a go and report any problems that I experience if any.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 12th September 2012, 15:57   #11  |  Link
wanezhiling
http://i.imgur.com/QEu3s.png
http://i.imgur.com/tpzgY.png
Where is ** ?
Old 12th September 2012, 18:01   #12  |  Link
clsid
Why isn't there a public source repository so we can view individual changes?
Is there a list of changes and bugfixes compared to MPC-HC?
MPC-HC 2.2.1
Old 12th September 2012, 18:24   #13  |  Link
ney2x
I'm glad there's an official thread here for MPC-BE. I already switched player from MPC-HC to MPC-BE. I like the icons / GUI very much! I hope you replace the default Subtitle Filter to xy-VSFilter. Thanks!
ney2x is offline   Reply With Quote
Old 12th September 2012, 18:50   #14  |  Link
alexins
MPC-BE DEV
alexins's Avatar
The next three months, the source repository is not available for free access. After a time, we may make the transition from a closed cycle development to the open.
Personally for you, I can grant access because you always acted like a gentleman.
At the present moment, the ChangeLog is available in Russian language only.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
Old 12th September 2012, 19:00   #15  |  Link
alexins
MPC-BE DEV
alexins's Avatar
At the current stage of development, it is not included in our top-priority tasks. Maybe later...
Old 12th September 2012, 21:27   #16  |  Link
turbojet
Thanks for this, I really like that it's darker, less distracting then the old BE mod and putting the time counter on the status bar is a great idea.
One issue is preventing me from switching to it from BE 4360 is save window size and/or position is unreliable, works maybe 50% of the time. I like to watch in full window mode but half the time it's opening as a window with the same resolution of the video. Any chance for a fix?
Also a few requests:
- Use a wider font or bold for time so it's easier to read.
- Option to auto hide title bar, Splayer has this, and while frame only with no borders has some effect, it breaks save window size/position on old be mod and it's also nice to have access to the title bar on demand.
- Option to hide toolbars in window mode, could work just like fullscreen mode hiding.
Old 12th September 2012, 22:41   #17  |  Link
cyberbeing
Broadband Junkie
That doesn't make it any less confusing to users.
Old 13th September 2012, 00:40   #18  |  Link
Aleksoid1978
Why did you decide that we have SVN?
We upload to public source code for project.
Old 13th September 2012, 02:32   #19  |  Link
Superb
Well, it does say "SVN Build: 1122" in the About window... :P
EDIT:
- Love the seekbar preview feature. Nice touch there! But "Use the preview in the search"? How about something like "Show video preview on the seekbar" (or something similar)?
- MPC-HC's "Output" settings tab looks better.
- Any chance for a "Lite" version?
- Any chance to change the default subtitle rendering resolution to "Desktop"?
- Why doesn't the window auto-resizes to the video's resolution when you open a file? Changed defaults? How do I make it act like it did in MPC-HC?
- Program's icon looks great.
- "Logo" settings tab can be removed IMO.
Superb is offline   Reply With Quote
Old 13th September 2012, 04:14   #20  |  Link
Aleksoid1978
There is no Lite version be.
