Old 21st November 2017, 16:46   #4861  |  Link
Zinglar
Originally Posted by v0lt View Post
Did you want to say a quiet sound? Try turning on the option "Auto volume control".
It is turned on. There is difference for the worse if I turn it off. By comparison the audio level is significantly higher with VLC. The problem does not arise with mp4 files, but only with mkv files.
Zinglar is offline   Reply With Quote
Old 21st November 2017, 18:51   #4862  |  Link
v0lt
@Zinglar
You can also try to enable the option "Mix channels to: Stereo".
Old 21st November 2017, 18:54   #4863  |  Link
Zinglar
@Zinglar
Thank you! There is a noticeable improvement.
Old 22nd November 2017, 14:56   #4864  |  Link
ResCogitans
Is the "Reopen File" command still supposed to work? I can find it in Options -> Player -> Keys (assigned to Ctrl + E by default), but it doesn't work for me.
In case it's relevant, I'm running 1.5.1 (build 2985).
ResCogitans is offline   Reply With Quote
Old 23rd November 2017, 08:24   #4865  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Working.
Old 23rd November 2017, 09:37   #4866  |  Link
ResCogitans
Thanks for the reply, Aleksoid1978. I just noticed it works as long as one doesn't exit the player, e.g. "Ctrl + C" followed by "Ctrl + E" works as expected.
But after closing and re-opening the player "Ctrl + E" does nothing, for me at least. (This is not the behavior I was used to in MPC-HC, where it works in this case.)
Old 23rd November 2017, 11:13   #4867  |  Link
Aleksoid1978
Set "Remember last playlist" in Options -> Player.
Old 23rd November 2017, 11:37   #4868  |  Link
Knocks
Originally Posted by Aleksoid1978 View Post
2 - if you use as in old version from menu "Video frame" - it's work temporary, only for current session. Global setting move to Options -> Video -> Framing -> Default mode.
This worked perfectly. Thank you!
Knocks is offline   Reply With Quote
Old 24th November 2017, 09:24   #4869  |  Link
ResCogitans
Thank you very much, this solved it. (I seldom use the playlist explicitly, and it just didn't occur to me it is used implicitly.)
Old 24th November 2017, 22:08   #4870  |  Link
beter
Although I hate the new Daemon tools lite, and have rolled back to the old version, I have a small question
Is Daemon tools 4.49 the last version supported by MPC-BE's "Open ISO" option on Windows 7?
beter is offline   Reply With Quote
Old 25th November 2017, 00:52   #4871  |  Link
have you tried to install the windows version so you get the same functionality as windows 8+?
Old 25th November 2017, 01:18   #4872  |  Link
beter
I guess you mean this one
https://www.microsoft.com/en-us/down....aspx?id=38780
I'm not reporting bug, I understand it is not a good idea to continue supporting a software that keep changing its mechanism. And I'm just asking a question. No one would like to install multiple softwares that do the same thing.
I'm asking it because the Daemon tool lite 5.0.1 is using the old UI(unlike 10.0+), but the "Open ISO" option disappeared when I updated my Daemon Tool lite from 4.46.1 to that version. After I downgraded it to 4.49.1, it is shown again.
Old 25th November 2017, 01:55   #4873  |  Link
amayra
Quality Checker
amayra's Avatar
1 - try latest SVN version.
which version this change started i update to the nightly latest every week or so i can't remember
I love Doom9
Old 25th November 2017, 04:14   #4874  |  Link
beter
I have problem when playing several mp3 files
one of them: https://www.sendspace.com/file/u7j38s
It was normal in 1.5.1 stable.
In recent builds (not sure from which build) the player keeps showing "opening..." and eating the cpu resources.
Old 25th November 2017, 09:13   #4875  |  Link
Aleksoid1978
Thanks - fixed.
Old 25th November 2017, 11:26   #4876  |  Link
v0lt
In r2808.
Old 27th November 2017, 11:48   #4877  |  Link
v0lt
Beta release MPC-BE 1.5.2 (build 3148) (SourceForge.net) with a digital signature.
Old 27th November 2017, 17:39   #4878  |  Link
JarrettH
Are there changes anywhere for the beta? It only says updated libraries inside the 7zip.
Old 27th November 2017, 17:49   #4879  |  Link
chros
chros's Avatar
Thanks guys, as always, I'll use it from this evening.
Old 27th November 2017, 19:03   #4880  |  Link
v0lt
We do not write a complete history for beta releases.
Short. VSFilter, DXVA decoders, renderer subtitles and YUV to RGB fixes. Optimization of DVD and BD LPCM decoder, extended support for DVD-Audio LPCM. Updated support for YouTube, MPCAPI_COMMAND. Interface fixes. And another thing I could not remember.
