Old 16th December 2020, 12:09   #981  |  Link
glc650
I've noticed on my Oppo UDP-203 that BDMV folders that are remuxed to ts or m2ts with tsmuxer playback fine initially but the very next movie (any file type, HDR or SDR, even the same ts/m2ts file that was just played) results in a pink/green/purple screen (the DV banner still flashes & audio is fine, just the video is a problem). Only way to fix this (besides rebooting the Oppo) is to play a movie from a BDMV folder (full rip or even one that tsmuxer has rexmuxed) which will result in the same scrambled screen but the very next movie will play correctly (until a ts/m2ts file generated by tsmuxer is played again).
glc650 is offline   Reply With Quote
Old 19th December 2020, 21:55   #982  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Could be unrelated to tsmuxeR, I had the same sometimes:
After successful play of any pressed BD-ROM on returning to Player menu HDMI is negotiated new.
If user-set player preferences dictate negotiating maxed-out HDMI connection AND no content negotiates its own preferences
AND HDMI cable is not prime (mine wasn't until 3 months ago)
4k60p connection might fail,
but no fallback from Oppo players in such case (player won't notice anyway), instead garbled picture on screen
Setting player's user preference to 4k24p helped in such case, until I went for a prime HDMI cable.
Old 19th December 2020, 22:04   #983  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
@glc650,
After creating your 'Blu-ray Folder' muxes, are you remembering to place the 'BDMV and CERTIFICATE' folders within an (manually created) AVCHD folder prior to playback?
Old 19th December 2020, 23:01   #984  |  Link
glc650
Originally Posted by SeeMoreDigital View Post
@glc650,
Yes I have to in order to even get the oppo to play them.
Old 19th December 2020, 23:03   #985  |  Link
glc650
If it was unrelated to tsmuxer I would think this would happen with other content but it only happens when the file is a ts/m2ts and was created by tsmuxer. None of my MKVs or BDMV folders do this.
Old 19th December 2020, 23:58   #986  |  Link
SeeMoreDigital
In that case...
I'm unable to replicate your issue with my OPPO UDP-203. And all my HDMI leads are Premium Certified
Old 20th December 2020, 00:14   #987  |  Link
glc650
In that case...
I'm using the default txmuxer settings. Did you change any of them when remuxing from BDMV to m2ts?
Old 20th December 2020, 03:35   #988  |  Link
Emulgator
Emulgator's Avatar
You may still show your playback preferences from Oppo setup menu to rule out any HDMI switching to 4k60.
Old 20th December 2020, 05:36   #989  |  Link
glc650
Output Resolution = Source Direct; Color Space and Depth = auto (but I also tried 4:2:0 and 4:2:2 and all 3 depths)
I'm using all Monoprice 8K Ultra High Speed 48Gbps cables @ 6 ft
Old 20th December 2020, 13:28   #990  |  Link
Emulgator
Emulgator's Avatar
That should work then for the HDMI side of things.
Old 20th December 2020, 13:56   #991  |  Link
SeeMoreDigital
Just so you know...
The most recent (Dolby Vision) 4K UHD disc I backed-up was last week using MakeMKV in backup mode and TSmuxer GUI git-999c472 in Blu-ray folder mode.
My OPPO's video output settings are as follows: -
HDR Settings: -
HDR: Auto
Target Luminance: 300 nits
HDR to SDR Mode: Mode 1
Dolby Vision Processing: TV-led
Output Resolution: Source Direct
Custom Resolution: UHD Auto
Color Space: Auto
Color Depth: Auto
Cheers
Old 20th December 2020, 15:17   #992  |  Link
imhh11
Sounds exactly like the same issue I'm having with the Sony x700 when I play ts/m2ts Dolby vision file created by tsMuxer.
This issue only caused by DV content right ? HDR10 and SDR file are ok? definitely a tsMuxer related problem. Unfortunately, @a5180007 tried a lot of things to fix the issue but nothing worked.
Old 20th December 2020, 20:31   #993  |  Link
glc650
I only use the oppo for DV so I haven't tested that but its possible.
Old 24th December 2020, 13:45   #994  |  Link
bairradino
TsMuxer muxing blu-ray iso
Hi.
I tried to get a Blu-ray iso from my UHD-HLG mp4 video file but when starting muxing I get "tsMuxer finished with error code -1073741819" error.
What am I doing wrong? Here the characteristics of my video file:
General
Complete name : E:\Blu-Ray\Casamento_UHD.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 16.2 GiB
Duration : 38 min 22 s
Overall bit rate mode : Variable
Overall bit rate : 60.4 Mb/s
Encoded date : UTC 2020-12-22 23:06:54
Tagged date : UTC 2020-12-22 23:06:54
Video
Format : HEVC
Format profile : Main@L5@High
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 60.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.290
Stream size : 16.1 GiB (100%)
Language : English
Encoded date : UTC 2020-12-22 23:07:04
Tagged date : UTC 2020-12-22 23:07:04
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 192 kb/s
Maximum bit rate : 521 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 52.0 MiB (0%)
Language : English
bairradino is offline   Reply With Quote
Old 27th December 2020, 00:35   #995  |  Link
Emulgator
Emulgator's Avatar
Might be unrelated, but for UHD Blu-ray 3840x2160x25fps only 10bit HEVC is legal.
And AAC LC also is no blu-ray-legal audio stream.
Old 30th December 2020, 13:36   #996  |  Link
KingLir
Hi all, I hope someone here can help me with an issue I encounter.
When I input tsMuxer an mp4 file with DV Profile 5 like the following:
Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
The .ts file muxed changed to Profile 7:
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Shouldn't at least be an option in tsMuxer to keep the original profile 5 ? As I assume it's not best to make this the default behavior.
KingLir is offline   Reply With Quote
Old 30th December 2020, 17:34   #997  |  Link
imhh11
your original mp4 is in the wrong DV profile. Profile 5 is for single layer DV (for streaming services)and not for UHD-BD rip.
P7 is the correct profile for a file containing an HDR10 BL with an EL+RPU.
If what you want is a single layer file BL+RPU only, then the correct profile you are looking for is p8. you can find tools to convert your dual layer file here:
https://www.makemkv.com/forum/viewto...rt=2970#p96282
Old 31st December 2020, 21:27   #998  |  Link
KingLir
Let me examine.
I got this mp4 file since I am trying to convert UHD-BD to DV Profile 5 (for playback on Apple TV 4K which only supports Profile 5).
And indeed the new single layer profile 5 mp4 file works with DV on Apple TV 4K and I can't detect issues with the video.
But now I am trying to mux in TrueHD Atmos track, which I reached tsMuxer for.
Can you point me on how to achieve this ?
Old 31st December 2020, 22:54   #999  |  Link
imhh11
There's an edited version of tsMuxer out there that will keep your file in profile 5 but keep in mind that its not in the DV specs and it may not produce an accurate image because your TV & AppleTV are expecting a different colorspace for that type of DV.
you can ask if someone still has that edited version on the makemkv link I posted in my previous reply.
On the AppleTV, all you will get out of TrueHD is LPCM right? no bitstreaming.
if you can't find the edited tsMuxer version., you can demux the atmos track to lpcm and remux in a profile 5 MP4. this should work as well.
https://mrmc.tv/forum/viewtopic.php?...3776&start=310
Old 1st January 2021, 17:27   #1000  |  Link
a5180007
Originally Posted by bairradino View Post
Hi.
@bairradino please confirm that the issue has been fixed with latest bintray nightly.
Happy new year to you all.
a5180007 is offline   Reply With Quote
