28th April 2010, 08:01 | #8001 | Link | |
Former Kanenite
Hmm, my log is too long, I'll have to upload a txt document. |
28th April 2010, 19:39 | #8002 | Link |
I’ve just done a full backup of Apocalypto to bd25 with one HD audio track selected and in the work files folder there is two audio tracks, one at 3.99GB and the other 2.68GB, both are 00001._4352 wav. Is this normal, the film has 3 tracks LPMC, 5.1 and stereo. The main file that BD Rebuilder created has only one audio track.
28th April 2010, 19:46 | #8003 | Link | |
28th April 2010, 20:07 | #8004 | Link | |
great program, can't wait for the pro version |
28th April 2010, 22:09 | #8005 | Link |
Repost
I have made copies of Avatar, made 2 copies each in BD5 and BD9. Neither of th BD9's would play on my stand alone, yet played on the computer. I have a Panasonic B60, the BD 5's played on both, Used Verbatim 2.4X disks on the BD 9's Ty02's on the BD5's. Any ideas? Also one copy of each was full movie and one movie only.Again neither worked On BD9, both did work on BD5. T.I.A.
28th April 2010, 22:49 | #8006 | Link | |
29th April 2010, 01:04 | #8008 | Link |
@unrox, @jdobbs
Hi! I believe "multiAVCHD" has (and has had for some time now) some special settings for dealing with such known idiosyncrasies of Panasonic standalone players... BTW - Verbatims (DVD5s and DVD9s) are no longer a "sure thing", ever since they added manufacturing facilities in places such as India and the United Arab Emirates... |
29th April 2010, 01:53 | #8009 | Link | |
29th April 2010, 04:36 | #8011 | Link | |
29th April 2010, 05:18 | #8012 | Link | |
29th April 2010, 07:52 | #8013 | Link |
If I remember correctly, that information (or how to implement it) should be in the following thread:
http://forum.doom9.org/showthread.php?t=146602 |
30th April 2010, 01:01 | #8014 | Link |
I've been having trouble recently, I keed getting "Encode Failed". I have been encoding for quite a while so something has changed since the "Automatic Quality" version was introduced that I keep gettings these problems that weren't there for me before.
----------------------- [19:23:40] BD Rebuilder v0.33.06 (beta) - Source: RED_BIRD_2D_WW - Input BD size: 43.00 GB - Approximate total content: [02:42:25.736] - Target BD size: 23.14 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:23:40] PHASE ONE, Encoding - [19:23:40] Extracting A/V streams [VID_00002] - [19:49:06] Reencoding: VID_00002 (1 of 2) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.06 (beta) - Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok [19:49:18] - Failed video encode, aborted |
30th April 2010, 03:33 | #8015 | Link | |
- Source: RED_BIRD_2D_WW (AVATAR) i was trying the rip with dvdfab. I've got two m2ts file has been converted, And i burn it and can't play at my bluray player. Ive ripp in iSO the original decrypted BD but samething. I was thinking that the decryption has been corrupted. AnyDVD HD don't have the solution for this movie for the version "_WW". I wait for the new version to test it back. Also: Post the entire log from bd rebuilder. we have only one INSPECTOR value.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
30th April 2010, 03:53 | #8016 | Link | |
have convert it to BD-9 with no problem @jdobbs any chance having pause button for the next versions ? |
30th April 2010, 04:10 | #8017 | Link |
@Johnny B. Good, @8ternity
With AnyDVDHD running in the background, try simply copying the disc to your hard drive. I believe you'll see it fail. Presently, all three significant "players" in the BluRay decryption arena (DVDFab, MakeMKV, AnyDVDHD) are still having all sorts of difficulty with the unbelievably complex and multiple protection schemes (including different schemes for different countries within the same region protection schemes!). Each of the three is at a different stage of success. At this time, I'd suggest you try DVDFab v.7.45 (with AnyDVD turned COMPLETELY off)... |
30th April 2010, 04:41 | #8018 | Link | |
BD-5 & BD-9 burns: Book Type must be "Normal" not "DVD-ROM"
Make sure your burner drive & DVD+R/+R DL disc's Book Type are set to "Normal" and not "DVD-ROM". Many standalone B-R players cannot read BD-5 (DVD+R) & BD-9 (DVD+R DL) discs with a Book Type of "DVD-ROM". In ImgBurn, to check & change Book Type, go to > Tools > Drive > Change Book Type. This fixed all my playback issues regardless of what brand DVD+R/+R DL I burned on (although I only recommend Verbatim and Taiyo Yuden media). Good luck! |
30th April 2010, 05:36 | #8020 | Link |
@All
Until the issues with Avatar are settled at the decrypting end -- please refrain from posting any bug reports related to that title. This is a BD Rebuilder bug thread and the problems with that title currently shouldn't be considered bugs in BD-RB. If, after the dust settles on the AnyDVD and DVDFab fronts related to that title, there still seem to be issues, we'll readdress. But right not it's just not fruitful to discuss a problem that may or may not have anything to do with BD Rebuilder. |
