Old 14th January 2016, 20:31   #7941  |  Link
Music Fan
Cool, but that's the opposite of what I had to do to make it work a few years ago, I had to uncheck it.
Music Fan is offline   Reply With Quote
Old 16th January 2016, 22:09   #7942  |  Link
Jijital
multiAVCHD - Menu's background image and other settings frozen!
Hello again,
It was too good to be true! Until yesterday, multiAVCH was warking like a charm and suddenly is "misbehaving". No matter which project, or settings I load, the Menu's background (image) won't change at all and also, I cannot modify some settings like, for example, the name of the "Title List", which I successfully modified to "Extras", until yesterday! I tried the following: resetting all by default, rebooting my PC, removing and re-installing the program (also with the previous version and then again with v. 771). I even removed and re-installed the required haali (recommended version) and ffdshow, but nothing! So frustrating, but of course, it's not the end of the world.
Has anybody elese encountered the same issue?
Thanks again in advance,
Jiji
Jijital is offline   Reply With Quote
Old 21st January 2016, 15:32   #7943  |  Link
Jijital
Hi everyone!
I finally, found out why that was happening and it was caused by me! Let me share it in case someone bumped in the same problem:
In order to make sure that the the playback returned to the main menu, I checked in "Media/Properties" the option "Action after playback" to "Menu/Custom" and pressed "OK". Doing so, the Main Menu gets blocked for editing! All it took was to select "Menu/Default", instead, to be able to edit the menus again.
Hope this helps!
Jiji
Old 4th February 2016, 19:21   #7944  |  Link
skank
Hi
Planning to make my own bluray demo disc
Does this software supports :
3d iso
HD-audio?
Is it possible to tell the program not to touch the movie files?
So no transcoding
skank is offline   Reply With Quote
Old 4th March 2016, 02:38   #7945  |  Link
LowDead
Elit Amans
Are there a new update? 771+?? O_o
Old 4th March 2016, 17:54   #7946  |  Link
ukendt
I don't know really, although the proggy keeps saying there is a "+" update. This happened like every time I start the program but nothing happens...Maybe Dean is planning to develop this program further?
ukendt is offline   Reply With Quote
Old 4th March 2016, 23:20   #7947  |  Link
LowDead
Elit Amans
I hope so. This is a often used program and I love it. Surely in need of some updates though
//LD
Old 5th March 2016, 12:26   #7948  |  Link
Ghitulescu
Ghitulescu's Avatar
There is a long time since I have heard something from Dean, 3 or 4 years now IIRC maybe more.
Born in the USB (not USA)
Old 6th March 2016, 06:27   #7949  |  Link
buffalofloyd
My update doesn't seem to work as well. It says downloading, then the program restarts and prompts for the update again. I would love if this program was updated. It's one of my most used even in it's current form.
buffalofloyd is offline   Reply With Quote
Old 6th March 2016, 13:22   #7950  |  Link
ukendt
And now the "+" seems to be gone...
Old 31st March 2016, 11:08   #7951  |  Link
AVCHDfreak
Hi all,
Anyone know if multiAVCHD can create a proper AVCHD structure for Panasonic Lumix cameras (specifically DMC-TZ series)? I tried to force multiAVCHD to do so using the "Panasonic Lumix" structure preset but it hasn't worked. Also, why does multiAVCHD's output always have "35.5 Mbps" for "Maximum overall bit rate" when the .MTS video file is analyzed with MediaInfo?
Thanks in advance.
AVCHDfreak is offline   Reply With Quote
Old 9th April 2016, 13:59   #7952  |  Link
joubel
multiAVCHD have not processing the main movie
Hi!
Could somebody please help me with this issue?
My multiAVCHD have not processing the main movie sometimes, the authored disc does not containing the main movie.
I trying a specific disc today to compress the bonus content, and throw out the unnecessary dubs from the movie. Unfortunatelly, it has 3 playlists for the (single m2ts) movie, but when i tried to keep the "original", and blank the others, multiAVCHD only processed the bonus content and the menus, but not the movie. Tried to blank this, and keep the other two, but the outcome was the same: no movie, only bonus...
joubel is offline   Reply With Quote
Old 25th April 2016, 17:05   #7953  |  Link
frodawgg
Audio conversion/Not importing THD
I'm new to the program, and I've encountered a few issues when trying to create my Blu-ray.
I want to retain lossless audio, but it keeps downconverting my PCM to AC3, even though I uncheck all of the conversion boxes.
I then attempted to do it using the source TrueHD file, but it won't even import it into the project, even though it's listed in one of the conversion options.
Any help is greatly appreciated!
Thanks in advance,
Jason
frodawgg is offline   Reply With Quote
Old 29th April 2016, 08:40   #7954  |  Link
zorro101
Hi
I have 10 folders with 25 files 1280x720 h264 per folder (.mkv but i can simply convert to .m2ts)
can I make the menu that show 10 folders (or images) and after click on one folder show the 25 files (or image)?
all without re-encode
thanks
best regards
zorro
zorro101 is offline   Reply With Quote
Old 30th April 2016, 09:05   #7955  |  Link
Music Fan
You can try to set correctly the title menu and the chapter menu, but I don't remember if you can choose the number of images per page.
Old 3rd May 2016, 08:32   #7956  |  Link
zorro101
I'll try!
thanks
best regards
Old 12th June 2016, 17:36   #7957  |  Link
thetrooper23
Question
Hello, sorry for my poor english.
i try to make my own menu for Muliavchd.
but, i can only choose one file in JPG in the "Background Image"
i made 3 jpg (set up, chapters and menu) but how can i say to multiavchd to choose the good jpg ?
and second question... how can i change the langage in the pop-up menu ?
Thanks in advance !
very friendly.
thetrooper23 is offline   Reply With Quote
Old 26th June 2016, 15:38   #7958  |  Link
veggav
Quick question, when you have m2ts ready for the blu-ray and it can fit into a BD25, did anyone found a way to avoid convertions?
No matter what I do MultiAVCHD keep re encoding my files while they fit perfectly fine into a BD25.
veggav is offline   Reply With Quote
Old 26th June 2016, 16:38   #7959  |  Link
Music Fan
Is it a standard resolution ?
You can also make AVCHDs without re-encoding with tsMuxer but without menus.
Old 27th June 2016, 15:10   #7960  |  Link
Capsbackup
Under the Author tab, set the value higher in General to avoid the transcoding.
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
