Old 13th April 2013, 16:03   #1001  |  Link
bugmen0t
Banned
edit
___
video not loaded on Preset > Compact
(player not responding)
svn2468
Win7 32b
madVR
bugmen0t is offline   Reply With Quote
Old 13th April 2013, 16:45   #1002  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
There are error resilience settings Careful / Compliant / Agggressive in MPC video decoder.
I suppose this mean level a/o sensitivity of corrective stream actions. But what is user impact of more / less corrections ?
Does more corrections mean less impact as more errors is fixed ?
Or does it mean bigger impact as it may ignore or replace some data ?
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
Old 14th April 2013, 12:52   #1003  |  Link
SamKook
Originally Posted by Mercury_22 View Post
"<1min tracks" ?
Sorry it took so long to respond, not all <1min track, but there's quite a few.
Most of them are between 30sec and 4 mins with the occasional 10-17min.
SamKook is offline   Reply With Quote
Old 14th April 2013, 18:10   #1004  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2479 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2479 (Nightly Builds) (Dev. MPC-BE)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 14th April 2013, 19:49   #1005  |  Link
Lord Maius
Italian translation updated (rev.2439)
http://sdrv.ms/ZUDfd5
Lord Maius is offline   Reply With Quote
Old 14th April 2013, 20:01   #1006  |  Link
alexins
MPC-BE DEV
alexins's Avatar
added in rev.2480
Old 15th April 2013, 14:20   #1007  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2484 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2484 (Nightly Builds) (Dev. MPC-BE)
Old 16th April 2013, 16:02   #1008  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2493 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2493 (Nightly Builds) (Dev. MPC-BE)
Old 18th April 2013, 14:49   #1009  |  Link
mindbomb
Question:
is there gonna be any work done on mpc audio renderer?
atm, it doesn't accept multichannel audio or 24 bit audio, and audio persists on pauses.
mindbomb is offline   Reply With Quote
Old 19th April 2013, 01:37   #1010  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by mindbomb View Post
Question:
About issue on pause/seek - try select Shared Mode.
And yes - modify audio renderer in my planes .
Old 19th April 2013, 04:09   #1011  |  Link
mindbomb
shared mode works fine.
one more thing, in options>playback, why is default track preference checked by default?
shouldn't it be forced track preference, if anything?
Old 19th April 2013, 05:13   #1012  |  Link
Aleksoid1978
Default track preference - when enable - MPC-BE use internal logic for select track. If disable - then as is, example LAV have own select track logic.
Old 19th April 2013, 20:35   #1013  |  Link
Reino
Reino's Avatar
As of Rev.2509 the OSD is permanently shown. Enabling/disabling "Show OSD (requires restart)" has no effect. Although Google Translate does a bad job on the Russian translation, most likely Rev.2505 is the culprit.
My hobby website
Reino is offline   Reply With Quote
Old 19th April 2013, 21:40   #1014  |  Link
judelaw
Fixed at rev. 2517;
judelaw is offline   Reply With Quote
Old 19th April 2013, 22:16   #1015  |  Link
isamu
So....is this worth using over Vanilla MPC-HC?
isamu is offline   Reply With Quote
Old 19th April 2013, 22:27   #1016  |  Link
Zulithe
Can i have this installed side-by-side with MPCHC? It uses its own settings?
Zulithe is offline   Reply With Quote
Old 19th April 2013, 22:29   #1017  |  Link
judelaw
Yes, of course
Old 20th April 2013, 07:30   #1018  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
Use "save thumbnails" feature, froze at here, surely related to internal dxva decoder.
Another problem on this H264i file is slow seeking speed, extremely slow... o.O
Jump on the seekbar quickly, mpc-be crashed...
Old 20th April 2013, 10:44   #1019  |  Link
Aleksoid1978
Try this build - http://aleksoid.voserver.net/MPC-BE/mpc-be.exe_2519.7z
Old 20th April 2013, 10:58   #1020  |  Link
wanezhiling
Fixed!
