Old 29th June 2017, 03:31   #5421  |  Link
Barough
Barough's Avatar
x265 v2.4+89-fa076d29d619 (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.4+89-fa076d29d619
x265 [info]: build info [Windows][GCC 6.3.0][32 bit/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
Old 30th June 2017, 03:25   #5422  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x265.exe 2.4+93-ef8dfbb70dd6
https://forum.videohelp.com/threads/...=1#post2490163
Old 30th June 2017, 09:35   #5423  |  Link
Magik Mark
Guys,
Can you explain the difference between --analysis vs --multipass?
Both are trying to eliminate the work redundancy on multi pass encoding. Why not just have one command for this?
Old 30th June 2017, 10:07   #5424  |  Link
The mysteries of
--[no-]multi-pass-opt-analysis
--[no-]multi-pass-opt-distortion
Multipass {analysis refinement|refinement of qp} cannot be enabled when ‘analysis-save/analysis-load’ option is enabled and both will be disabled when enabled together.
--analysis-reuse-mode <string|int>
--analysis-reuse-file <filename>
--analysis-reuse-level <1..10>
I guess that using an analysis file supersedes several on-the-fly internal calculations a refinement would have used with fixed values not meant to be changed further... I wonder how deep you have to understand the principles of operation in the encoder core, to understand the relations between these two groups of options. You may probably have to be able to read and understand the C sources, at least.
I see the analysis file use rather as a kind of debugging and optimization tool for running dozens of encodings and comparing a lot of statistics, rather than speeding up a casual user's movie conversion.
Old 30th June 2017, 10:23   #5425  |  Link
Magik Mark
Thanks LigH.
It is really difficult to understand these things especially for ordinary folks like me. How I wish someone can explain these through images. I think that is more comprehensible for everyone
Old 30th June 2017, 13:45   #5426  |  Link
Barough
Barough's Avatar
x265 v2.4+96-58b4fa89c42d (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.4+96-58b4fa89c42d
Old 30th June 2017, 18:07   #5427  |  Link
x265_Project
Analysis reuse provides the basic framework for more advanced solutions that we are building on top of / around x265 (in UHDkit). I don't want to go into more detail about all of the use-cases, as we've seen our competition already attempting to our methods. The basic idea is to produce solutions that run faster (for live encoding scenarios) and more computationally efficient (for offline encoding scenarios). These modes are not going to provide any benefit to anyone today who is just using x265 alone. They won't produce higher quality.
Old 3rd July 2017, 16:03   #5428  |  Link
x265 2.4+96-58b4fa89c42d (GCC 7.1.0, Win32+Win64, AIO EXE+DLL only)
merge with stable; several fixes and tweaks
renamed / changed / new CLI options:
   --analysis-reuse-mode <string|int>  save - Dump analysis info into file, load - Load analysis buffers from the file. Default 0
   --analysis-reuse-file <filename>    Specify file name used for either dumping or reading analysis data. Deault x265_analysis.dat
   --analysis-reuse-level <1..10>      Level of analysis reuse indicates amount of info stored/reused in save/load mode, 1:least..10:most. Default 5
   --refine-intra <int>          Enable intra refinement for load mode. Default 0
   --[no-]const-vbv              Enable consistent vbv. turned on with tune grain. Default disabled
Old 6th July 2017, 21:11   #5429  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x265.exe 2.4+97-006c75cf822e
Aruna Matheswaran  committed 006c75c
2017-06-22
Allocate frame threads based on available pool threads
This patch decides #frame-threads based on #pool-threads available. If pools not
specified, #frame-threads will be decided based on detected #CPU-threads.
This patch also decreases #frame-threads allocated for #pool-threads in the
interval (15 - 31) and (>= 32) as there is high run to run variation in bitrate
and SSIM with higher frame threads.With this reduction in #frame-threads there
is ~3-4 % drop in fps with little SSIM improvement for #pool-threads (15 - 31)
and no significant change in performance for #pool-threads (>= 32).
https://forum.videohelp.com/threads/...=1#post2490727
Old 6th July 2017, 23:06   #5430  |  Link
pingfr
2017-06-22
If this is what I think it is, this should tremendously help encoding faster on high-end dedicated servers? Thinking of a SMP machine with like 60 cores, 120 threads, etc?
pingfr is offline   Reply With Quote
Old 7th July 2017, 07:20   #5431  |  Link
The maximum number of threads will still be somewhat limited, due to a limited bitfield width of the core mask. Furthermore, too many threads for one encoder instance don't make sense, will be inefficient because each thread will only "see" a small part of the frame, and the thread sync overhead rises. With a huge number of physical cores, running several instances of the encoder in parallel on a subset of cores each is much more efficient (quality / speed).
I guess this patch will support the execution of several instances, each limited to a subset of cores, by allocating threads based on the limited amount of cores in each separate pool, as if there was only a CPU with fewer cores, thus avoiding too many threads in the sum of all instances.
Old 7th July 2017, 07:29   #5432  |  Link
sneaker_ger
Did we read the same text?
To me it means:
15 - 31 threads: 3% to 4% slower
>= 32 threads: +/- 0%
Old 7th July 2017, 09:37   #5433  |  Link
Pradeep's patch review note before committing was: "The improvements in quality seem to justify the change."
Quite imaginable to me: Fewer threads reduce the speed a bit, but increase the quality. And beyond a threshold of threads, saturation effects of the thread management may be the bottleneck, I guess.
Old 7th July 2017, 17:30   #5434  |  Link
Barough
Barough's Avatar
x265 v2.4+99-3160e1a0cc5f (MSYS/MinGW, GCC 7.1.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.4+99-3160e1a0cc5f
x265 [info]: build info [Windows][GCC 7.1.0][32/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
Merge with default; prep for v2.5
Old 7th July 2017, 23:29   #5435  |  Link
pingfr
In layman's terms, does that implies this patch merged in not only increases encoding speed but the overall resulting quality as well or am I getting confused here?
Old 7th July 2017, 23:41   #5436  |  Link
It slows down speed for some thread/core configurations but increases quality.
Old 7th July 2017, 23:46   #5437  |  Link
pingfr
So quality increase (visual subjectivity is subjective) at equal bitrate pre-patch but at a 3-4% speed decrease cost, correct?
Old 8th July 2017, 02:56   #5438  |  Link
burfadel
Depending on configuration. Actual difference also includes any filters used. The figures aren't given as 'you will receive', if figures weren't given people would be questioning how much.
Old 8th July 2017, 09:40   #5439  |  Link
Let me explain more verbosely how I imagine that. (If I am wrong, don't hesitate to correct me. Understanding x265 frame threading constraints is hard.)
Let's imagine you have a dual socket mainboard, each of your two CPU's has 16 cores (maybe logical due to HT). So the whole system will report 32 cores overall.
You decide to run two instances of x265 at the same time, each with a thread pool of 16, to run distinctly on either CPU.
Before this patch, the number of frame threads depended on the number of cores in the whole system, so it was calculated in relation to the number 32.
After this patch, the number of frame threads will depend on the capacity of each separate thread pool, thus be calculated in relation to the number 16. In addition, it reduces them a bit more, as the developers discovered that even fewer threads in this range, compared to the previous calculation of the optimal number, has an advantage.
Of course this means fewer frame threads. That will slow down the calculation a bit. But before, x265 may have been less efficient, because it spawned too many threads for the limited pool (causing more synchronization overhead than necessary) and with a smaller scope each ("seeing" less of the whole neighborhood of the currently encoded slice, finding less candidates to reduce redundancy).
After this patch, the number of frame threads will match the size of the limited thread pool better, there is less thread synchronization, and each frame thread can have a wider scope, encoding more efficiently by finding better inter-coding candidates in a further distance. (At least the second half of this statement may be misunderstood.)
_
P.S. - a quote from the docs:
Over-allocating frame threads can be very counter-productive. They each allocate a large amount of memory and because of the limited number of CTU rows and the reference lag, you generally get limited benefit from adding frame encoders beyond the auto-detected count, and often the extra frame encoders reduce performance.
Doesn't really explain the reason for a potential quality limitation due to over-allocation, though...
Old 8th July 2017, 12:48   #5440  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
x264 and x265 coding are really problematic with new CPU with multiple core like "threadripper" or "skylake-X". x264 and x265 are unable to make encoding at 100% for CPU charge for 2K or even for 4K with 16C/32T or more.
@ x265 team
Not possible to create a new encoding mode in x265 with multiple instance for better threading compatibility?
Use for exemple high lookahead buffer for make frame type decision and open new instance coding at each new Iframe (will be IDR).
This mode imply certainely high frame buffer but if you have "threadripper" or "skylake-X" CPU, you must have at least 16 GB for RAM or more.
This mode imply just Closed GOP and perhaps short GOP (60 frames maximum) to minimize frame buffer.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
