Old 24th August 2019, 08:17   #3281  |  Link
stax76
stax76's Avatar
Can I ask why does StaxRip keep complaining that my Avisynth plugins directory is missing? It is not missing and present in both Staxrip's directory and in my Program Files folder. I have also tried installing the provided installer as suggested, with the same results.
There was a bug, it happened when VapourSynth was used, I think it was fixed before the last stable version 2.0.3.0 was released.
Also, recently all my encodes have been erroring out with the following:
Video encoding using x265 3.1 failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Incorrect function.
I'm encoding with x265, and I have verified that the encoded file is fine actually. This results in me needing to manually mux the .hevc with the audio file which is annoying...
I would guess it's a x265 issue, people who use the command line, batch files or other apps might not notice this, staxrip does not tolerate error exit codes for x265 however. Please try 2.0.3.0, it uses a new x265 build compiled by Wolfberry. If the error persists post the x265 command line or better the full log file.
Old 24th August 2019, 09:35   #3282  |  Link
aegisofrime
Hi, can confirm that the first mentioned bug is fixed with 2.0.3.0. Thanks!
As for the second part, I have tried to reduce my encoding job to the simplest possible, just feeding a file with ffms as input to a very simplified x265 setting.
I will be happy to post the full log file. To avoid cluttering everyone else, log file on following Pastebin link:
https://pastebin.com/mjCEy7QE
One thing though, I did notice that during x265 encoding there's a complain about "The system cannot find the path specified.". Not sure as to the cause of this, it might be one faulty PATH environment variable on my system, which I'm trying to narrow down at the same time.
aegisofrime is offline   Reply With Quote
Old 24th August 2019, 18:19   #3283  |  Link
aegisofrime
Hi all,
I managed to resolve that error on my own.
As it turns out, it was related to cmd.exe showing "The system cannot find the path specified"
I followed the following thread and it turns out I had a rogue registry key in my command processor autorun pointing to a file that didn't exist:
https://superuser.com/questions/7273...path-specified
Deleting the autorun key solved it.
It's unlikely that anyone else will encounter the same issue as me, but I work in IT and I believe in documenting such stuff just in case it helps someone else.
Old 13th September 2019, 22:40   #3284  |  Link
lordalibaski
what happened here then?
Hi guys
Just had another weird issue I used staxrip to convert this file
Format                         : MPEG-PS
File size                      : 4.27 GiB
Duration                       : 2 h 45 min
Overall bit rate mode          : Variable
Overall bit rate               : 3 683 kb/s
Writing library                : encoded by TMPGEnc Authoring Works 4 Version. 4.0.12.42
Video
Format                         : MPEG Video
Format version                 : Version 2
Format profile                 : Main@Main
Format settings, BVOP          : Yes
Format settings, Matrix        : Custom
Format settings, GOP           : Variable
Bit rate mode                  : Variable
Bit rate                       : 3 386 kb/s
Maximum bit rate               : 8 000 kb/s
Width                          : 720 pixels
Height                         : 480 pixels
Display aspect ratio           : 4:3
Frame rate                     : 29.970 (30000/1001) FPS
Standard                       : NTSC
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 0.327
Time code of first frame       : 00:00:00:00
Time code source               : Group of pictures header
Stream size                    : 3.92 GiB (92%)
Writing library                : TMPGEnc Authoring Works 4 Version. 4.0.12.42
Color primaries                : BT.601 NTSC
Transfer characteristics       : BT.601
Matrix coefficients            : BT.601
Audio
ID                             : 189 (0xBD)-128 (0x80)
Format                         : AC-3
Format/Info                    : Audio Coding 3
Format settings, Endianness    : Big
Muxing mode                    : DVD-Video
Bit rate mode                  : Constant
Bit rate                       : 224 kb/s
Channel(s)                     : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 48.0 kHz
Frame rate                     : 31.250 FPS (1536 SPF)
Bit depth                      : 16 bits
Stream size                    : 266 MiB (6%)
Service kind                   : Complete Main
This is the outcome it ended up bigger than the original
General
Complete name                  : D:\Rock America-02.1-.mp4
Format                         : MPEG-4
Format profile                 : Base Media
Codec ID                       : isom (isom/avc1)
File size                      : 4.88 GiB
Overall bit rate               : 4 211 kb/s
Encoded date                   : UTC 2019-09-12 21:34:12
Tagged date                    : UTC 2019-09-12 21:34:12
Writing application            : StaxRip 2.0.4.2
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High 10@L3
Format settings, CABAC         : Yes
Format settings, RefFrames     : 4 frames
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Bit rate                       : 4 017 kb/s
Maximum bit rate               : 11.6 Mb/s
Width                          : 720 pixels
Height                         : 480 pixels
Original display aspect ratio  : 4:3
Frame rate mode                : Constant
Standard                       : NTSC
Color space                    : YUV
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.388
Stream size                    : 4.66 GiB (95%)
Writing library                : x264 core 157 r2969 d4099dd
Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=15 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4017 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date                    : UTC 2019-09-12 21:35:47
Color range                    : Limited
Color primaries                : BT.470 System M
Audio
Format                         : AC-3
Codec ID                       : ac-3
Bit rate                       : 192 kb/s
Maximum bit rate               : 203 kb/s
Bit depth                      : 16 bits
Stream size                    : 228 MiB (5%)
Language                       : English
Encoded date                   : UTC 2019-09-12 21:35:42
I converted it with Vidcoder and the file size is 1.5GB in size! so whats happening?
Thanks for any advice.
lordalibaski is offline   Reply With Quote
Old 14th September 2019, 02:56   #3285  |  Link
stax76
stax76's Avatar
Hi, I think we will need to see the full log file, use pastebin.com.
Old 14th September 2019, 12:27   #3286  |  Link
lordalibaski
Full log file on what stax? the only time I have ever seen staxrip create a log file is when it fails!
Old 14th September 2019, 12:46   #3287  |  Link
stax76
stax76's Avatar
It's in the temp/work folder which you can go to with:
Tools > Folder > Working
The name is:
*_staxrip.log
Also try the log viewer:
Tools > Log File
There is also a log file history:
Tools > Folder > Log Files
Old 14th September 2019, 20:58   #3288  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Need the Logfile from Vidcoder, so i can say, why your staxrip encode is bigger. I think, Vidcoder uses other values in the settings. Use you 2pass encoding with bitrate 4 017 in Vidcoder, too?
-QfG- is offline   Reply With Quote
Old 14th September 2019, 22:08   #3289  |  Link
lordalibaski
Got the one from staxrip
https://pastebin.com/m8UMpmPB
Old 15th September 2019, 12:59   #3290  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
U using 2 pass with a defined bitrate.
x264.exe --pass 2 --bitrate 4017
Your original file has a bitrate from 3386. Change your bitrate lower, or better use a quality based encoding method, for example CRF20 and a slow preset.
Old 15th September 2019, 14:21   #3291  |  Link
lordalibaski
I never even noticed that until I read the log file where is the option to stop it from doing 2 pass? I can't find it...thanks.
No worries found the option.
Old 26th September 2019, 01:07   #3292  |  Link
leo5111
i have been using staxip with a 1070ti for nvida x265, but my friend has a vega 56 does the h265 look any good or does it stink compared to the nvidia one? and if amd is good what are settings for 1080p h265? for my nvidia im using 9000 cbrhq
leo5111 is offline   Reply With Quote
Old 26th September 2019, 16:29   #3293  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Use x265 for best quality encodes. NVENC has lower quality then x265.
Old 3rd October 2019, 04:23   #3294  |  Link
Magik Mark
Guys,
How do you PROPORTIONATELY change the aspect ratio of the image? I'm getting squeezing look of the image. I want something that will shrink the image proportionately
Sent from my iPhone using Tapatalk
Old 3rd October 2019, 09:28   #3295  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
if your source is a progressive video from BD/UHD, the correct AR is 1:1 (x264/x265 --sar 1:1). Also set this sar if you crop and/or resize your movie.
Old 5th October 2019, 09:37   #3296  |  Link
NikosD
I'm afraid using Turing's HEVC encoder this is no longer true...
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 31st October 2019, 13:55   #3297  |  Link
katzenjoghurt
Hey ho!
Hm... in the past there was a place to download builds of the betas.
Is there one for the most current versions?
edit: Nevermind. Found it. https://staxrip.readthedocs.io/intro.html#download
Old 11th December 2019, 06:12   #3298  |  Link
deepfrayder
Staxrip Jerky Playback video Output
I'm selecting output x264, ffmpeg mp4 with 2 passes, Preset: Medium (Default) I got output "Jerky Playback" video in result. I've downloaded Staxrip latest version and tried again with said settings but same "Jerky Playback" video output.
Appreciate any advise/suggestions for this problem.
deepfrayder is offline   Reply With Quote
Old 11th December 2019, 12:28   #3299  |  Link
tebasuna51
tebasuna51's Avatar
@deepfrayder, cross post is not allowed in this forum.
You must select the staxrip version used, the staxrip here or the 2.0 revant654.
Also you must say something about the source used, better if you upload a sample.
Old 22nd February 2020, 17:14   #3300  |  Link
unmei220
Hi.
I'm using StaxRip 2.0.4.0 on a Windows 8.1 PC and with a CPU without AVX2 instructions. I'm getting a "System exception - Illegal Instruction" as soon as I try to enable QTGMC Medium.
The two errors in question are:
(C:\StaxRip-x64-2.0.4.0-stable\Apps\Plugins\avs\QTGMC\QTGMC.avsi,line 882)
(C:\StaxRip-x64-2.0.4.0-stable\Apps\Plugins\avs\QTGMC\QTGMC.avsi,line 639)
I already replaced "dfttest.dll" with the AVX version included in the 7z inside the folder, but obviously I'm missing something else. I'm not using StaxRip 2.0.6.0 because it doesn't include a 7z with an AVX version inside the DFTTest folder.
Any idea what the problem might be?
unmei220 is offline   Reply With Quote
