Old 2nd March 2017, 12:25   #1801  |  Link
Magik Mark
Originally Posted by Ma View Post
Did you make 1 pass by different version of x265? Could you paste log file from 1 pass and 2 pass?
http://chopapp.com/#e86f177o
Old 2nd March 2017, 13:04   #1802  |  Link
Ma
@Magik Mark: Thanks for log file. It looks like there is something wrong with first pass. x265 complains about input file.
I've checked your options and it works, but the 'x265_analysis.dat' file is in current working directory -- you specify '--stats' option but not '--analysis-file' option.
My first impression is that it is StaxRip issue with reading/decoding video.
Old 2nd March 2017, 16:33   #1803  |  Link
stax76
stax76's Avatar
Originally Posted by IntelHEVC View Post
Profile 10 Bit and Color-Range BT2020 for UHD
The QSVEncC help doesn't contain '2020', you can find the mail address of rigaya on his blog.
http://rigaya34589.blog135.fc2.com/b...tegory-10.html
Testing build 1.4.0.5 and it appears the keyboard shortcuts in Preview are non-functional. I know I could use the left and right arrow keys to move forward and backward, and I feel sure the up and down arrows moved forward and backward in larger units. In rev 1.4.0.5 none of the keys seems to do anything.
New build is available, in can be considered RC.
You mean the x265 command line is incorrect? Can you elaborate? I've not changed something in this area in months.
Since Mark said it only happens sometimes I would guess it has to do with AviSynth multi-threading and there is little I can do, it would probably also happen when the batch file StaxRip generates is run outside of StaxRip.
Old 2nd March 2017, 16:35   #1804  |  Link
NikosD
Don't forget to add in your first page the addition of AMD H.265 encoder.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 2nd March 2017, 16:44   #1805  |  Link
stax76
stax76's Avatar
I've reset it now, staxrip moves the old video encoder profiles to a backup sub menu.
Old 2nd March 2017, 16:45   #1806  |  Link
NikosD
No, I meant here, the first page of this thread
Old 2nd March 2017, 16:52   #1807  |  Link
stax76
stax76's Avatar
ah, changed that too, thanks.
Old 2nd March 2017, 20:36   #1808  |  Link
Ma
x265 command line is OK, but a bit danger. If you make multiple encoding at the same time with analysis file, it will be a problem (all encoding use the same file).
If StaxRip works now:
IF '--pass' option THEN
    add option '--stats "output_file_name.stats"'
FI
it could/should work like this:
    IF '--multi-pass-opt-analysis' OR '--multi-pass-opt-distortion' option THEN
        add option '--analysis-file "output_file_name.analysis"'
    FI
FI
Old 2nd March 2017, 23:13   #1809  |  Link
Magik Mark
Thanks Ma for clarifying. I hope stax can incorporate that to the new build
Old 2nd March 2017, 23:45   #1810  |  Link
Magik Mark
FI
    FI
FI
If I'm not mistaken, I think this is also the issue with hybrid since "--multi-pass" CLI has been introduced
Old 3rd March 2017, 07:13   #1811  |  Link
slushay
please help. staxsrip gives an error "cuvid: Parsed header too large!"
please help. staxsrip gives an error at the stage of video encoding. More precisely the error causes the decoder. I tried all the available options.
Error:
Encoding using NVEncC 3.06 x64 failed with exit code: 1 (0x1)
failed to init decoder.
script:
C:\Users\Andrey\Downloads\StaxRip-x64\Apps\NVEncC\NVEncC64.exe --cqp 18:20:22 --codec h265 --output-depth 10 --lookahead 32 --qp-init 1 --max-bitrate 30000 --aq --output-buf 128 -i D:\temp\temp.mkv -o D:\temp\temp_temp\temp_out.h265
slushay is offline   Reply With Quote
Old 3rd March 2017, 09:55   #1812  |  Link
stax76
stax76's Avatar
@Ma
Thanks for the clarification.
@Mark
It will be fixed in the next build.
@slushay
You can report it to rigaya, is mail address is on his blog.
Old 3rd March 2017, 11:21   #1813  |  Link
slushay
thanks
@slushay
Thank you for your program. I use myself and recommend to friends.
It is now writing a letter to rigaya.
Old 3rd March 2017, 12:36   #1814  |  Link
Alexander
Hello Frank,
A few other apps need to be updated
x264 v.2762
MediaInfo v.0.7.93
FFmpeg v.3.2.2
DGIndexNV v.2053
Qaac v.2.62
L-Smash-Works (avs) v.924
Java v.121
Alexander is offline   Reply With Quote
Old 3rd March 2017, 14:40   #1815  |  Link
NikosD
Hello again.
I don't know how hard is it to add in your Media Info tool just one more column.
It's called "Color primaries" and it has a value of BT.2020 when the clip is HDR.
I can see that property in "tree" mode.
Old 4th March 2017, 20:26   #1816  |  Link
lotnybartek
NikosD can you tell me what might be the best way to encode 1080i recorded tv channel with many fast motions? Source file is: *.ts, around 6.686 kb/s, 2h long, 6,5GB. I need to produce smaller size file maintaining good quality.
In your opinion, what is the best choice in terms of encoding scheme: LA-VBR Lookahead, VBR only, LC-ICQ (which preset - 17? file is too large), maybe QVBR? Bitrate would be 4.000 kb/s.
I got Intel Core i7-6820HQ.
Barty
lotnybartek is offline   Reply With Quote
Old 4th March 2017, 20:29   #1817  |  Link
NikosD
From all of my tests using QSVEnc I had decided that plain ICQ even with no lookahead was totally fine.
You could try --scene-change (but not with ICQ IIRC) and lookahead, but I was happy with plain ICQ.
Old 4th March 2017, 20:39   #1818  |  Link
lotnybartek
Thank you. One more thing, source is 1080i, it's 50fps, target is 25fps. Do you think that I can maintain 50fps after encoding? Is it worth it? It'll double the file size Am I right?
Old 4th March 2017, 20:42   #1819  |  Link
NikosD
Are you going to convert your interlaced file to progressive ?
Then I think you can't avoid the 50fps to 25fps conversion.
But IIRC, QSVEnc supports interlaced encoding and you could leave it interlaced at 50fps
Old 4th March 2017, 22:44   #1820  |  Link
lotnybartek
Yes, 50 fps to 25.
I'm wondering about one thing. If source is 50fps 6700 kb/s, so If I divide fps by 2, Can I also divide bitrate by 2 ? Afterall, I'm encoding half of the source fps - so I should get similar quality.
