Old 16th May 2017, 09:53   #101  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 3.2.7 and ffx264 3.4.1
* Added support for FFmpeg's internal Opus audio encoder
Old 29th May 2017, 09:02   #102  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.8
* Added support for Dynamic HDR10+ JSON files. Requires libx265 to be compiled with Dynamic HDR10+ support
Old 30th May 2017, 12:30   #103  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.2.9
* Bugfix: use an if conditional to set hdr-opt option
* Increase default CRF value to 21
* Tune the default encoding parameters
Old 1st June 2017, 13:01   #104  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.0 and ffx264 3.4.2
* Simplify the scale variable a bit
* Support SMPTE170M colorspace conversion
* Support SMPTE170M for color primaries/matrices/transfers
Old 4th June 2017, 22:41   #105  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.1 and ffx264 3.4.3
* Match software scaler options in config file with the ones inside the script. $SCALER in config file now takes a value between 0 and 9
* Do some basic checking of scaler option when it's set in the config file
Additional for ffhevc
* Further optimizations to the default encoding options
Old 5th June 2017, 04:50   #106  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.2
* Remove redundant software scaler warning and exit in the sws_func() function for the config file
* Added support for the experimental software scaler
* Lower psy-rdoq from 2.5 to 1.5 and psy-rd from 2.5 to 2.0 to eliminate ringing artifacts
* No need to enclose the values of max-cll in quotes
* Removed additional encoder info on max audio channels support
* Added support for software scaler tuning where applicable
* Added example JSON file for Dynamic HDR10+ to the package
* Updated the Makefile
ChangeLog for ffx264 3.4.4
Old 8th June 2017, 15:45   #107  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.3 and ffx264 3.4.5
* Report software scaler set in the config file
* Merge the bicubic and spline scaler tuning code
* Mention for the Lanczos scaler that the scaler tuning value is the filter length and not sharpness
Old 9th June 2017, 09:46   #108  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.4 and ffx264 3.4.6
* New function, video_chars_func(), to detect and display video characteristics like color range/space/transfer/primaries
* Detect and display video resolution if video scaling is enabled
* Detect and display pixel format
Old 10th June 2017, 08:52   #109  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.5 and ffx264 3.4.7
* Replace numbers in array variable char of the video_chars_func() function with the ones from the for loop
* Pipe the ffprobe string to tail -1 to work around issues with some problematic files
* Some small improvements to the video_colorspace_func() function
Old 11th June 2017, 11:05   #110  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.6
* Bugfix: master-display option must be enclosed in quotes to not confuse Bash
Old 13th June 2017, 00:56   #111  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.7 and ffx264 3.4.8
* Bugfix in the video_colorspace_func() function. Wrong value used for the ispace option of the filter. Must be bt2020ncl instead of just bt2020
Old 14th June 2017, 13:11   #112  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.8 and ffx264 3.4.9
* Make software scaler tweaking optional
* Added support for the unsharp filter for sharpen/blur
* Use a colon symbol as separation for input/output color range in the video_colorspace_func() function as to be consistent with the other options. Also set the default to tv:tv
Old 11th July 2017, 12:37   #113  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.3.9 and ffx264 3.5.0
* Support setting the min/max keyframe/IDR intervals
Old 20th July 2017, 19:44   #114  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.0 and ffx264 3.5.1
* Bugfix: use realpath instead of readlink for the OUTPUT var when running in batch mode. Fixes the issue where readlink will follow the full path in case the input is a symlink which may result of encoding files we were not asked to
* Don't print cropped resolution during runtime if batch mode is selected
* Remove check for realpath. It is now required and not optional
Old 23rd August 2017, 10:51   #115  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.1 and ffx264 3.5.2
* Support full chroma input for the software scaler
Old 29th September 2017, 16:43   #116  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.2 and ffx264 3.5.3
* Support setting the output video aspect ratio
Old 22nd October 2017, 18:33   #117  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.3 and ffx264 3.5.4
* Support dialog level normalization for AC3/EAC3 audio
Old 17th November 2017, 17:42   #118  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.4
* Update transfer characteristics: smpte-st-2084 -> smpte2084. Requires latest x265
Old 28th November 2017, 19:35   #119  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.5
* Disable Open GOP and enable header repeating when HDR options are enabled like master display and max-cll
Old 25th December 2017, 11:33   #120  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.4.6 and ffx264 3.5.5
* Initial support for HDR to SDR conversions. Requires FFmpeg to be compiled with the zimg library as it needs the zscale filter https://github.com/sekrit-twc/zimg
Merry Christmas!
