Old 18th October 2017, 11:57   #1  |  Link
Freedom
Pazera Free MP4 Video Converter
Hi, I need help with software -
http://www.pazera-software.pl/products/mp4-converter/
there are no thread with this one, so I do new, if I do mistake please transfer post.
To the point...
Using FFmpeg in MP4 converter I try do watermark on video:
but command is invalid
I need help
Cheers
Freedom is offline   Reply With Quote
Old 18th October 2017, 12:30   #2  |  Link
sneaker_ger
I don't use the software but the box says "Additional ffmpeg command-line parameters". So I assume Pazera creates most of the command itself and you are only to put some extra things in there.
Try only: -i E:\watermark.png -filter_complex overlay=10:10
But:
- I have never used overlay filter. Don't know if usage is correct in the first place
- I don't know where Pazera will put additional commands. ffmpeg parameter order can be important.
Old 18th October 2017, 13:19   #3  |  Link
Freedom
Hi, it doesnt work
ffmpeg_full_help from pazera directory:
https://pastebin.com/x7iXVADF
Old 20th October 2017, 12:08   #4  |  Link
Gravitator
Хай.
Did you try to talk to the developer?
Gravitator is offline   Reply With Quote
Old 22nd October 2017, 18:05   #5  |  Link
Freedom
Hi, yes of course by mail, but no answear.
Anyone can help? There is portable version, so You dont need install software
Old 8th November 2017, 07:19   #6  |  Link
therube
In the Additional parameters box, you would want something like this:
-i C:\DOC\watermark.jpg -filter_complex "overlay=10:10"
F2 will give you the command line of what you are trying to run.
As I see it, when you are adding parameters, you aren't able to determine where they get added in the command line (sequence), & in this case, they're being added in the wrong place, so the conversion (parsing of the command-line) fails.
Pazera gives you something like:
ffmpeg.exe -y -i "in.avi" -c:v libx264 -r 23.976 -b:v 1694k -threads 2 -preset:v fast -sn -c:a aac -b:a 160k -async 1 -i C:\DOC\watermark.jpg -filter_complex "overlay=10:10" -f mp4 output.mp4
What you need is something (rearranged) like:
ffmpeg.exe -y -i "in.avi" -i C:\DOC\watermark.jpg -filter_complex "overlay=10:10" -c:v libx264 -r 23.976 -b:v 1694k -threads 2 -preset:v fast -sn -c:a aac -b:a 160k -async 1 -f mp4 output.mp4
Not sure how to cause that to happen, in a meaningful way, in Pazera?
therube is offline   Reply With Quote
converter, mkv, mp4, pazera, video
