Old 26th October 2019, 12:24   #4941  |  Link
manolito
manolito's Avatar
Sorry, no, I can't...
Since I do not use any 64-bit software which uses AviSynth, I only have the 32-bit version of AVS+ installed. I also have no desire to maintain additional plugin folders for the 64-bit plugins. My 32-bit plugins are good and fast enough for me, 2 plugin folders (plugins and plugins+) are enough for me.
And last but not least 1 of my computers has a 32-bit only CPU, and I want identical AVS setups on all my machines.
manolito is offline
Old 27th October 2019, 16:37   #4942  |  Link
Reel.Deel
Originally Posted by manolito View Post
The AviSynth main page at avisynth.nl still points to the latest GitHub pinterf Avisynth+ r2772 version instead of the current page for version 3.40.
Could someone please consolidate the links?
Done.
1st post on this thread also needs to be updated.
Reel.Deel is offline
Old 27th October 2019, 23:27   #4943  |  Link
manolito
manolito's Avatar
manolito is offline
Old 28th October 2019, 00:24   #4944  |  Link
filler56789
SuperVirus
filler56789's Avatar
Yes, a moderator should do that, because ultim's last Activity = 3rd July 2019 09:11 :–/
filler56789 is offline
Old 28th October 2019, 10:19   #4945  |  Link
tebasuna51
tebasuna51's Avatar
A temporal EDIT is done.
tebasuna51 is offline
Old 3rd November 2019, 19:00   #4946  |  Link
stax76
stax76's Avatar
I would like to request AviSynth+ 3.4.0 without vcredist, it's too big to distribute with staxrip.
stax76 is offline
Old 3rd November 2019, 21:17   #4947  |  Link
qyot27
qyot27's Avatar
I've uploaded a plain 7z portable for 3.4.0 (well, technically, r2925 built from master, but the extra commit* only touched the READMEs, it's still otherwise-identical to 3.4). I also removed the GCC archive since videohelp still was (or, is at this time of writing) pointing at it as a 'portable' even when that was not the intention.
*the other's just the merge commit for that one change
qyot27 is offline
Old 4th November 2019, 00:05   #4948  |  Link
stax76
stax76's Avatar
staxrip requires the install version of avisynth (and vapoursynth).
stax76 is offline
Old 4th November 2019, 06:04   #4949  |  Link
real.finder
Originally Posted by qyot27 View Post
A C++ wrapper over a standard C API (tp7 mentioned this as the goal for AviSynth+'s future API development, but it obviously never happened), or a C++ wrapper around an incompatible C++ ABI? The former is what I usually see suggested, not the latter.
why not both? or for now C++ wrapper around an incompatible C++
See My Avisynth Stuff
real.finder is offline
Old 16th November 2019, 19:32   #4950  |  Link
Stereodude
IMHO, your edit could be clearer. Someone is going to click on the first link inside your edit and think that's what they need when those are actually the old ones.
My opinion is it should be something like this:
[MODERATOR EDIT:]
Current branch as of November 2019:
The pinterf fork was integrated in main line like AviSynth+ 3.4.0
Download and sources: From GitHub
Older superseded branch/fork:
[Download: From GitHub (use version with vc_redist when installing for the first time)
Sources: https://github.com/pinterf/AviSynthPlus]
[END MODERATOR EDIT]
Stereodude is offline
Old 18th November 2019, 10:26   #4951  |  Link
pinterf
I still have to work on the documentation. Unfortunately the bundled one generated from the rst files is hopelessly behind the actual changes which was done in Avisynth+. At least the content in avisynth.nl is more or less correct and up-to-date, but the latest changes I have made since december 2018, which appeared in 3.4.0, so there changes and additions are not refreshed there. E.g. the new Layer syntax and parameters.
pinterf is offline
Old 20th November 2019, 15:02   #4952  |  Link
Can somebody upload AviSynthPlus_3.4.0_Portable.7z somewhere outside those terrible github servers? I can't even download it. It just stops at random point.
Atak_Snajpera is offline
Old 20th November 2019, 15:13   #4953  |  Link
Interesting. I had similar issues with AdoptOpenJDK. But github releases are hosted in the Amazon cloud, they can push. If it doesn't go through, maybe your ISP throttles to blackmail Amazon to pay for better throughput? At least that's what they thought about Deutsche Telekom.
So, for statistics: What's your route?
And try to download at a different daytime. Late night in US / early morning in EU still got me 2 MB/s when they throttled. Then, another day, the throttling was not active, and I got 8 MB/s in the early EU evening which used to be the worst time with throttling.
LigH is offline
Old 20th November 2019, 15:21   #4954  |  Link
You might be right because downloading through my smartphone using LTE works super fast. If I switch to my wi-fi and use my cable ISP then everything just stops. I have no issues with other servers. Just that bloody github...
Old 20th November 2019, 15:58   #4955  |  Link
real.finder
happen to me also but you have to download them one by one to give all speed to only one since there are no Resume-able Downloads, and also you can try JDownloader which can Resume Downloads in most cases
Old 20th November 2019, 16:04   #4956  |  Link
Next attempt... aaaaaaaaaand it stopped!
I almost feel like in 99 when I had that 56k modem...
Old 20th November 2019, 16:15   #4957  |  Link
StainlessS
StainlessS's Avatar
VideoHelp is actually providing a zip file GCC version as portable version, here [DO NOT DOWNLOAD Portable version]:- https://www.videohelp.com/software/AviSynth-Plus
I reported the post with this message (limited in length), so hopefully it will be removed as an option from the VH post.
Link to AviSynth+ 3.4.0 Portable, NOT portable version, is GCC compiled version & cause major probs for most users.
The target zip has been removed/moved on github because videohelp pointing to it but you provide the actual zip so still a prob.
EDIT: Damn, I also just posted this post as a review in VH thread, unfortunately different bulletin board type code required, and it swallowed some of the quote,
ie the message I reported, and I cannot edit it.
I sometimes post sober.
StainlessS is offline
Old 22nd November 2019, 10:06   #4958  |  Link
@Atak_Snajpera: Your ISP is to be blamed here, or the one which controls a backbone yours depends on. Further down in your route, on a regional or national range. So complain to your ISP, and register issues in public issue portals. Also notify github about it, but remember, they don't take the blame.
LigH is offline
Old 22nd November 2019, 13:28   #4959  |  Link
StainlessS
StainlessS's Avatar
Just checked, VideoHelp now hosting current AviSynth+ 3.4.0 Portable 7z file. [SHA-1 matches that on Github].
Old 26th November 2019, 11:08   #4960  |  Link
jpsdr
Tested with VDub2 (x86 & x64) 43943 and avs 3.40.
This works :
a0=colorbars(width=1920,height=1080,pixel_type="yv12").trim(0,9).ConvertBits(16).ConverttoYUV444()
a1=a0
StackVertical(a0,a1)
ConvertBits(8)
this doesn't :
a1=a0
#ConvertBits(8)
My github.
jpsdr is offline
