Old 24th January 2019, 03:30   #41  |  Link
videoh
Useful n00b
I'll look into it, Stereodude. Thanks for pointing it out. Can you please give me your cube file? Thank you.
Old 24th January 2019, 21:26   #42  |  Link
Stereodude
It's in this zip file.
http://stereodude.net/LUT.zip
Old 24th January 2019, 23:11   #43  |  Link
videoh
Useful n00b
Got it, thank you.
Can you give me a mediainfo dump on your source file, please? Is it HDR, etc?
Old 24th January 2019, 23:40   #44  |  Link
videoh
Useful n00b
Seems that this was fixed in timecube at some point:
https://forum.doom9.org/showthread.p...30#post1850130
The code link there is broken so I'll try to hunt down the r2 changes.
Old 24th January 2019, 23:48   #45  |  Link
videoh
Useful n00b
Latest code is here:
https://github.com/sekrit-twc/timecube
I'll do a re-port to Avisynth+ starting with this latest code.
Old 24th January 2019, 23:59   #46  |  Link
Stereodude
Got it, thank you.
General
Complete name                            : E:\TempBD\TIM\05\00005.h264
Format                                   : AVC
File size                                : 618 MiB
Overall bit rate mode                    : Variable
Video
Format                                   : AVC
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 4 frames
Maximum bit rate                         : 38.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (24000/1001) FPS
It is FHD directly from a Blu-ray. It is not HDR. It looks very flat. I believe that they shot the footage in C-Log (Canon Log) and didn't bother to grade it. Hence my interest in applying a C-Log to Rec709 3D LUT to it. I'm not sure if it should be fullrange=false or true. I wanted to try both and look at the output visually when I noticed that fullrange=false gave black screen output.
Old 25th January 2019, 00:10   #47  |  Link
videoh
Useful n00b
OK, thanks. As I mentioned, I'll re-port the latest code.
Old 25th January 2019, 21:24   #48  |  Link
videoh
Useful n00b
Rather than upgrade to r2a I ported the fullrange fix only. Here is the revised version:
http://rationalqm.us/hdr/avscube_1.1.rar
Old 26th January 2019, 02:23   #49  |  Link
Stereodude
I get an error on both the x86 and x64 versions.
x64:
'C:/HDTV Tools/avscube/x64/vscube.dll' cannot be used as a plugin for AviSynth.
x86:
'C:/HDTV Tools/avscube/x86/vscube.dll' cannot be used as a plugin for AviSynth.
Old 26th January 2019, 02:42   #50  |  Link
videoh
Useful n00b
Hmm, that's strange. I will look into it. This doesn't happen with my version 1.0 DLL? What version of Avisynth+ are you using?
Old 26th January 2019, 03:00   #51  |  Link
Stereodude
No, the 1.0 version works fine in x64 & x86 (aside from the bug I reported earlier). I have AviSynth+ 0.1 (r2772, MT, x86_64) (0.1.0.0)
Old 27th January 2019, 15:41   #52  |  Link
videoh
Useful n00b
Somehow avscube.dll got excluded from the build after I updated VS 2017. I have fixed it. Please re-download to get the fixed version.
Old 28th January 2019, 01:20   #53  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Tested on WinXP SSE4.1 and it works fine with fullrange=true now.
Thanks again.
Old 28th January 2019, 03:24   #54  |  Link
Stereodude
Seems to be working okay with the updated version. No more black screen and the fullrange switch works.
Old 28th January 2019, 04:57   #55  |  Link
videoh
Useful n00b
Great. Thanks for your testing and for reporting the issue.
Old 27th November 2020, 08:32   #56  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Hi Donald,
I'm resurrecting this topic as it seems to be the only one which is AVSCube related and I'd like to ask you something about it.
I've been using it all the time at work, in production, on my Xeon 28c/56th machines, but I'd like to speed things up a bit as all my server run fairly recent NVIDIA Quadro cards.
You're a developer, you know CUDA, you made many hardware accelerated plugins, are you tempted even just a little bit to make this CUDA accelerated as well?
Old 15th September 2021, 21:32   #57  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I know that we all took this as granted, but just to reassure everyone, I made a simple test for Cube() with the identity matrix.
Test1:
#Indexing
video=LWLibavVideoSource("Z:\YUV_pattern-2fr.v210-14-2020PQ.mov")
audio=BlankClip(length=1, channels=8, audio_rate=48000, fps=25)
AudioDub(video, audio)
#From 4:2:2 10bit to 4:2:2 16bit planar
ConvertBits(16)
#From 4:2:2 16bit planar Narrow Range to RGB Planar 16bit Narrow Range
z_ConvertFormat(pixel_type="RGBP16", colorspace_op="2020:2020:2020:limited=>rgb:2020:2020:limited", dither_type="none", resample_filter="Spline64")
Test2:
#Indexing
ConvertBits(16)
#From PQ to HLG with 16bit precision
Cube("Z:\IDENTITY.cube", fullrange=true)
I called "Test1" as noLUT and "Test2" as IdentityMatrix.
Now, since anything times the identity matrix returns itself and therefore applying it or not shouldn't change anything (unless linear algebra and my whole life is a lie xD), I expected Test1 and Test2 to be the same, so I did:
noLUT=ImageSource("\\mibctvan000\Ingest\MEDIA\temp\Test4_PQ_Avisynth_no_LUT_no_dithering_RGBP16.tiff").ConverttoYUV444()
IdentityMatrix=ImageSource("\\mibctvan000\Ingest\MEDIA\temp\Test6_PQ_Avisynth_IdentityMatrix_no_dithering_RGBP16.tiff").ConverttoYUV444()
StackHorizontal(noLUT, IdentityMatrix)
TurnRight.Histogram.TurnLeft #luma
and indeed it returned:https://i.imgur.com/YFBVZTn.png
and since I couldn't see differences at first glance, I tried with Subtract:
Subtract(noLUT, IdentityMatrix)
which shouldn't have been returning differences, in fact: https://i.imgur.com/3UTpdiB.png
So I thought: Uhm, maybe it's just my eyes but I can't see any difference, let's try with SSIM and...
noLUT=ImageSource("\\mibctvan000\Ingest\MEDIA\temp\Test4_PQ_Avisynth_no_LUT_no_dithering_RGBP16.tiff").ConverttoYUV420().ConvertBits(bits=8, dither=-1)
IdentityMatrix=ImageSource("\\mibctvan000\Ingest\MEDIA\temp\Test6_PQ_Avisynth_IdentityMatrix_no_dithering_RGBP16.tiff").ConverttoYUV420().ConvertBits(bits=8, dither=-1)
SSIM(noLUT, IdentityMatrix, "results.csv", "globalSSIM.txt", lumimask=1, scaled=1)
returned Y=1.0000, U=1.0000, V=1.0000
so a perfect score, which means that the two are exactly the same: https://i.imgur.com/uxznR68.png
so I can confirm that Cube() works as expected.
The reason why I've made this test is to be 100% sure as I've been having some stuff processed through an analyzer and although the result was... "fine", there were some slight variations from how it should have been, so I was trying to find one function to blame but apparently it's not Cube() eheheheheh.
Anyway, I think it was worth sharing to reassure everyone that the function is mathematically correct and does what it's supposed to do.
Old 20th January 2022, 05:07   #58  |  Link
StvG
@videoh, can you add support for passing frame properties when they are available?
StvG is offline   Reply With Quote
Old 20th January 2022, 05:37   #59  |  Link
kedautinh12
Latest ver timecube i think avs ver don't port it
Old 20th January 2022, 13:19   #60  |  Link
videoh
Useful n00b
Sure, I'll work on that today.
3dl, cube, hdr, lut, sdr
