Old 6th September 2012, 17:07   #41  |  Link
kolak
Will it be possible to do something like virtual file system?
http://forum.doom9.org/showthread.php?t=133313
Old 6th September 2012, 17:24   #42  |  Link
active1
thanx! i'll try it now
stupid question: what is the advantage of VapourSynth over Avisynth MT?
active1 is offline   Reply With Quote
Old 6th September 2012, 18:12   #43  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I suppose so. You could probably reuse quite a bit of the sourcecode so replacing avisynth as the backend should be quick. Or so my 15 second survey of the sourcecode tells me.
VapourSynth may one day have all its threading issues fixed. I'm not so optimistic about avisynth mt...
And with that I return to my debugger.
Old 6th September 2012, 22:16   #44  |  Link
Rumbah
The site seems to be down, is there another way to download it?
Rumbah is offline   Reply With Quote
Old 6th September 2012, 22:30   #45  |  Link
sneaker_ger
http://www.mediafire.com/?64s562ufwy8x7fp (Windows r2)
Old 6th September 2012, 22:35   #46  |  Link
Myrsloik
Myrsloik's Avatar
Not for the moment, no. I will make a third release once it's back up. I guess you get what you pay for... and I pay $1.78/month.
Anyway, have some performance comparisons from r3 while you wait:
Avisynth 2.5.8
$ time avs2yuv.exe test.avs - > NUL
test.avs: 640x368, 24000/1001 fps, 5000 frames
real    1m23.680s
user    0m0.000s
sys     0m0.015s
VapourSynth r3:
$ time /c/Python32/python.exe test.py > NUL
real    0m23.753s
user    0m0.015s
sys     0m0.000s
Script:
import vapoursynth as vs
import sys
core = vs.Core(threads=4)
core.avs.LoadPlugin(path='ffms2.dll')
core.avs.LoadPlugin(path='mvtools2.dll')
ret = core.avs.FFVideoSource(source='possible rule 6 violation.avi', threads=0)
ret = core.std.Trim(clip=ret, first=10000, length=5000)
src = ret
c = core.avs.MSuper(c1=src)
b1v = core.avs.MAnalyse(c1=c, delta=1, isb=False)
f1v = core.avs.MAnalyse(c1=c, delta=1, isb=True)
b2v = core.avs.MAnalyse(c1=c, delta=2, isb=False)
f2v = core.avs.MAnalyse(c1=c, delta=2, isb=True)
ret = core.avs.MDegrain2(c1=src, c2=c, c3=b1v, c4=f1v, c5=b2v, c6=f2v)
ret.output(sys.stdout, y4m=True)
Old 7th September 2012, 00:43   #47  |  Link
active1
wow, vapoursynth is really awesome!
thank you Myrsloik
Q: can i load avsi scripts with it?
can you explain 'why' a little?
Old 7th September 2012, 07:15   #48  |  Link
hajj_3
because there has been virtually no development on avisynth for ages. Vapoursynth is already good and judging by the speed of changes i'm sure we'll have a great version ready within a few months with lots of added features.
Old 7th September 2012, 11:13   #49  |  Link
Myrsloik
Myrsloik's Avatar
The website has stopped sleeping. R3 has been released. It has greatly improved avisynth plugin compatibility and many other fixes. Most notably mvtools works perfectly now so someone crazy could try porting the QTGMC script.
Next on the list is probably adding more things related to frame properties so they can become useful, including a port of ffms2.
Old 7th September 2012, 12:27   #50  |  Link
-Vit-
I've been thinking about the QTGMC port, if I get some time this weekend I'll have a go.
-Vit- is offline   Reply With Quote
Old 7th September 2012, 12:56   #51  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Not working...
Keiyakusha is offline   Reply With Quote
Old 7th September 2012, 13:05   #52  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by Keiyakusha View Post
Not working...
\ is the escape character for python strings, just like in C.
Either write path=r'c:\blah.dll', path='c:/blah.dll' or path='c:\\blah.dll' to make it work as expected.
Old 7th September 2012, 13:11   #53  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Oh yes, this way it works... Sorry.
Old 7th September 2012, 13:27   #54  |  Link
-Vit-
I get problems encoding through y4m to x264 with core threads at anything other than 1. Affects any source. Can post scripts if you wish, but it's just a pass-through python script (FFVideoSource) & generic x264 settings. Get errors like this and encode terminates early (usually after a few frames, but a non-deterministic #):
y4m [error]: bad header magic (82848485 <=> àääéé)
y4m [error]: bad header magic (41524682 <=> éFRAM)
Thread count on FFVideoSource works fine. No problems so far experimenting with 1 core thread.
Old 7th September 2012, 13:40   #55  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Seems to be related to how x264 reads the stuff, if output it to a y4m file or switch x264 to avconv/ffmpeg, it will work :s
(Chikuzen had this problem last night)
[I'm human, no debug]
Old 7th September 2012, 17:30   #56  |  Link
-Vit-
Same problem with ffmpeg. Fine with core threads = 1. If core threads is anything else then it encodes only a few frames (final frames become offset to the right), no error message shown in ffmpeg. Seems like a threading issue to me.
Old 7th September 2012, 21:02   #57  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Yeah, in that case it's a threading/output-related issue. At least Myrs is already debugging it.
Old 8th September 2012, 04:58   #58  |  Link
wOxxOm
Oz of the zOo
What is the easiest way of making vapoursynth case-insensitive for filter and parameter names (I mostly write everything in lowercase) ?
Last edited by wOxxOm; 8th September 2012 at 06:02. Reason: moved other technical questions to Myrsloik's thread.
wOxxOm is offline   Reply With Quote
Old 8th September 2012, 05:23   #59  |  Link
TheFluff
Excessively jovial fellow
Originally Posted by wOxxOm View Post
What is the easiest way of making vapoursynth case-insensitive for filter and parameter names (I mostly write everything in lowercase)?
Python function and variable names are always case sensitive; that's a language thing and not something VS gets to decide. Probably the simplest way of making it possible to write everything in lowercase would be write some metaprogramming magic that generates all-lowercase wrappers for all the methods on the VS core object.
TheFluff is offline   Reply With Quote
Old 8th September 2012, 06:01   #60  |  Link
wOxxOm
Oz of the zOo
  1. What are 'format' and 'yuvrange' and is it possible to mimick spline16/36/64resize with Spline(clip:clip;width:int:opt;height:int:opt;format:int:opt;yuvrange:int:opt;) ?
  2. Is it possible to specify float numbers for the area to be resized like in avisynth's resize filters which have cropXXXX parameters?
  3. What is the syntax of 'Lut' and 'Lut2' functions?
  4. Is it possible to implement positional parameters so that instead of Spline(c1=myvideonode,width=1280,height=720) it'd be spline(myvideonode,1280,720) ?
  5. It would be nice to have a callback in 'output' function with current frame number and coded frame size so that it could be used in a custom gui for progress reporting
speed, vaporware, vapoursynth
