Old 3rd July 2021, 11:16   #81  |  Link
Dogway
I checked it yesterday and didn't find an issue. I tested null resize with both default b and c, with 0 and 0.5, and raw source and got no differences.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 3rd July 2021, 12:46   #82  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
BicubicResize optimises out (incorrectly, in my opinion) null resizes. Non-null resizes will reveal the difference. It's very slight, but the defaults do blur.
Old 4th July 2021, 17:24   #83  |  Link
Dogway
I still don't understand, yes, adding a minimal shift shows a difference, it's blurrier:
bicubicresize(1920, 1036, src_left=0.00001, src_top = 0.00001)
If I add catrom coeffs as you suggest it's no blurrier anymore:
bicubicresize(1920, 1036, 0, 0.5, src_left=0.00001, src_top = 0.00001)
But that matches a simple null resize with default values:
bicubicresize(1920, 1036)
Old 4th July 2021, 17:50   #84  |  Link
StainlessS
StainlessS's Avatar
Wonkey,
Didn't you post some example which clearly showed the problem and which stood out like "a sore thumb".
I sometimes post sober.
Old 4th July 2021, 18:57   #85  |  Link
real.finder
what about z_BicubicResize ?
See My Avisynth Stuff
Old 4th July 2021, 19:01   #86  |  Link
wonkey_monkey
Because Avisynth deliberately does nothing when it recognises a null resize. What it should do is produce a slightly blurred clip, for consistency. This code makes the problem obvious by using ridiculous b and c parameters:
version
animate(0,16, "bicubicresize", width,height,4,4,-16.0,-16.0, width,height,4,4,16.0,16.0)
You'll see that the middle frame is not consistent with the rest.
Anyway I really just wanted to make sure you were aware that by using BicubicResize with the default parameters you will (unless your resize happens to be a null one) induce a slight, possibly unwanted, blur.
Old 8th July 2021, 13:00   #87  |  Link
Dogway
Continuing from this post:
@wonkey_monkey: So this is my last attempt at the ternary method. What is wrong about it? The ternary chooses either one or the other, A or C based on the previous comparison which I stored on Q, so I have still 3 elements in the second rightmost comparison.
 +"A C      < Q@ A   AA@ C   CC@ ? Q C   CC@ A   AA@ ? + Z^ "
 +"B D      < Q@ B   BB@ D   DD@ ? Q D   DD@ B   BB@ ? + Z^ "
 +"E G      < Q@ E   EE@ G   GG@ ? Q G   GG@ E   EE@ ? + Z^ "
 +"F H      < Q@ F   FF@ H   HH@ ? Q H   HH@ F   FF@ ? + Z^ "
 +"AA EE    < Q@ AA   A@ EE   E@ ? Q EE   E@ AA   A@ ? + Z^ "
 +"BB FF    < Q@ BB   B@ FF   F@ ? Q FF   F@ BB   B@ ? + Z^ "
 +"CC GG    < Q@ CC   C@ GG   G@ ? Q GG   G@ CC   C@ ? + Z^ "
 +"DD HH    < Q@ DD   D@ HH   H@ ? Q HH   H@ DD   D@ ? + Z^ "
 +"A B      < Q@ A   AA@ B   BB@ ? Q B   BB@ A   AA@ ? + Z^ "
 +"C D      < Q@ C   CC@ D   DD@ ? Q D   DD@ C   CC@ ? + Z^ "
 +"E F      < Q@ E   EE@ F   FF@ ? Q F   FF@ E   EE@ ? + Z^ "
 +"G H      < Q@ G   GG@ H   HH@ ? Q H   HH@ G   GG@ ? + Z^ "
 +"CC EE    < Q@ CC  CC@ EE   E@ ? Q EE   E@ CC   C@ ? + Z^ "
 +"DD FF    < Q@ DD   D@ FF   F@ ? Q FF   F@ DD   D@ ? + Z^ "
 +"BB E     < Q@ BB   B@ E   EE@ ? Q E   EE@ BB   B@ ? + Z^ "
 +"D GG     < Q@ D   DD@ GG   G@ ? Q GG   G@ D   DD@ ? + Z^ "
 +"B C      < Q@ B   BB@ C   CC@ ? Q C   CC@ B   BB@ ? + Z^ "
 +"DD EE    < Q@ DD   D@ EE   E@ ? Q EE   E@ DD   D@ ? + Z^ "
 +"F G      < Q@ F   FF@ G   GG@ ? Q G   GG@ F   FF@ ? + Z^ "
Old 8th July 2021, 13:15   #88  |  Link
wonkey_monkey
The problem is that A writes to AA and C writes to CC (twice) regardless of the result of the ternary, because everything is executed. You're throwing away the actual result of both ternaries by adding them together and dumping them in Z.
The stack goes:
A
A, C
(A<C) (followed by a store to Q which does nothing to the stack)
(A<C), A (followed by store to AA which does nothing to the stack)
(A<C), A, C (followed by store to CC which does nothing to the stack)
(A or C) <- result of first "?"
(A or C), Q
(A or C), Q, C (followed by store to CC, does nothing)
(A or C), Q, C, A (followed by store to AA, does nothing)
(A or C), (C or A)
Then you add them together and throw them away into Z.
So that code simplifies to
A @AA C @CC
and that's it.
Old 8th July 2021, 13:34   #89  |  Link
Dogway
As I see it, it was a matter of swap:
A C      < Q@ A   AA@ C   CC@ ? Q C   AA@ A   CC@ ? +
I just want to tell you that your suggestions in this post are flawed, because you can't concatenate two ternaries with no relations between them. You either pop them or do a dumb sum, whichever suits you.
test this and you will get an error:
"A C < A C ? A C < C A ?"
The issue is that poping the stack flushes the previous set variables AA and CC....
EDIT: I saw it.
A C      < Q@ A   C    ? AA@ Q C   A    ? CC@
Old 8th July 2021, 13:41   #90  |  Link
wonkey_monkey
Because there are two items left on the stack, not one. It wasn't intended to be a complete expression, but an answer to "Is a sort operator possible?"
All suggestions leave the values of both A and C on the stack in order.
Old 8th July 2021, 13:55   #91  |  Link
Dogway
That only answers an ideal test scenario of 2 inputs (no need for a sort algo actually) and not what I asked which was a very well defined sorting network of 8 inputs.
One output needs to feed the next and so on in order to work. In your example you are not popping anything, if you did the assumed benefit of Q@ (or R@ in your case) wouldn't work.
This works (very slow):
+"A C   < A  C  ? AA^ A C   < C  A  ? CC^ "
+"B D   < B  D  ? BB^ B D   < D  B  ? DD^ "
+"E G   < E  G  ? EE^ E G   < G  E  ? GG^ "
+"F H   < F  H  ? FF^ F H   < H  F  ? HH^ "
+"AA EE < AA EE ?  A^ AA EE < EE AA ?  E^ "
+"BB FF < BB FF ?  B^ BB FF < FF BB ?  F^ "
+"CC GG < CC GG ?  C^ CC GG < GG CC ?  G^ "
+"DD HH < DD HH ?  D^ DD HH < HH DD ?  H^ "
+"A B   < A  B  ? AA^ A B   < B  A  ? BB^ "
+"C D   < C  D  ? CC^ C D   < D  C  ? DD^ "
+"E F   < E  F  ? EE^ E F   < F  E  ? FF^ "
+"G H   < G  H  ? GG^ G H   < H  G  ? HH^ "
+"CC EE < CC EE ? CC^ CC EE < EE CC ?  E^ "
+"DD FF < DD FF ?  D^ DD FF < FF DD ?  F^ "
+"BB E  < BB E  ?  B^ BB E  < E  BB ? EE^ "
+"D GG  < D  GG ? DD^ D GG  < GG D  ?  G^ "
+"B C   < B  C  ? BB^ B C   < C  B  ? CC^ "
+"DD EE < DD EE ?  D^ DD EE < EE DD ?  E^ "
+"F G   < F  G  ? FF^ F G   < G  F  ? GG^ "
There's no way to reuse the comparison output of R@ or your other optimization suggestions.
Old 8th July 2021, 20:38   #92  |  Link
wonkey_monkey
Isn't there? This seems to work:
A C   < R@ A  C  ?  AA^    R C  A  ? CC^
as does this, which duplicates the comparison result without removing it from the stack and is slightly faster:
A C   < dup A  C  ? AA^    C  A  ? CC^
But anyway, this (which I think was the last of my suggestions, although I may have accidentally deleted my TED Talk) is much faster:
A C min AA^ A C max CC^
And you can squeeze a few more % out with this:
A C dup1 dup1 min AA^ max CC^
Old 11th July 2021, 00:17   #93  |  Link
Dogway
Yes, I don't remember how I tested but it wasn't working at that point. Another option would be to pop out the comparison "A C < R^" but in any case I benchmarked it and barely improved the performance so I went with your min max suggestion. I use dup occasionally but never used dupn, it's not explained in the docs, my guess is it duplicates the n previous element in the stack but this is a guess. Not sure why but it improves performance by 5% so very nice.
Old 11th July 2021, 13:47   #94  |  Link
wonkey_monkey
dup or dup0 copies the top item, dup1 copies the second (zero-indexed) item. It saves Expr from loading the variable from memory again - the value is already in a register because it's on the stack, so it just copies it to another register. "dup0 dup2" would be equally valid in place of "dup1 dup1" because it doesn't matter which order you copy A and C in; I just thought "dup1 dup1" looked nicer, and could be a tiny bit faster (edit: actually it's surprising a lot quicker).
By using swap (which is a free operation) and carefully tracking what's on the stack, you can eliminate the use of variables entirely and get another 4% speedup* (this assumes you're using pinterf's latest test which allows newlines within Expr):
Expr("
x[-1,1]  x[1,1]  dup1 dup1 min swap2 max
x[0,1]   x[-1,0] dup1 dup1 min swap2 max
x[1,0]   x[0,-1] dup1 dup1 min swap2 max
x[-1,-1] x[1,-1] dup1 dup1 min swap2 max
swap7 swap1 swap3 dup1 dup1 min swap2 max
swap5 swap1 swap3 dup1 dup1 min swap2 max
swap6 swap1 swap2 dup1 dup1 min swap2 max
swap4 swap1 swap7 dup1 dup1 min swap2 max
swap3 swap1 swap2 dup1 dup1 min swap2 max
swap7 swap1 swap2 dup1 dup1 min swap2 max
swap5 swap1 swap6 dup1 dup1 min swap2 max
swap4 swap1 swap3 dup1 dup1 min swap2 max
swap6 swap1 swap3 dup1 dup1 min swap2 max
swap5 swap1 swap4 dup1 dup1 min swap2 max
swap7 swap1 swap5 dup1 dup1 min swap2 max
swap3 swap1 swap4 dup1 dup1 min swap2 max
swap4 swap1 swap5 dup1 dup1 min swap2 max
swap7 Z^ Z^ Z^ Z^ Z^
swap1
Z^
x swap2
clip
Before the line "swap7 Z^ Z^ Z^ Z^ Z^ (where I've left a gap) the stack order is "E HH BB CC D AA FF GG". You can then use swaps and pops to pick out the values you're interested in. In this case, where the final section emulates that median clip thingy, it's BB and GG.
No doubt this will give some people conniptions but there's nothing I can do about that.
A further optimisation would be to delete some of the calculations that don't end up getting used at all, depending on the particular algorithm you're implementing at the time (edit: I orginally wrote 7% speedup above because that was the result of deleting one of the superfluous - for this algorithm - calculations).
Old 11th July 2021, 14:17   #95  |  Link
wonkey_monkey
PS This is about 13x faster (on an AVX2 processor) than you'd get from a non-SIMD C++ plugin - and that's with a fixed kernel size.
Old 11th July 2021, 14:26   #96  |  Link
kedautinh12
Wow, thanks
Old 11th July 2021, 15:30   #97  |  Link
Dogway
Expr("
swap1
Z^
x swap2
clip
Wow, I need time to wrap my head around that. Eager to test it out. I had no idea that variables had an overhead, or that dup was any different. I will try to implement this first on the easier modes and check performance. ex_median() is already 3.7.1+ only so formatting is fine.
About your last suggestion, I'm already doing that, removing the last unneeded operations (didn't find much of a benefit though), or for example remove the final division in variances since it doesn't change the comparison output.
I just updated ExTools with new modes. Fixed bokeh which now is a real ring kernel, I tried to create a new mode to sample a bokeh image values, but this would require absolute coordinates, I tried with resizing to kernel size and then stacking (StackVert/Hor limit seems to be 506) but wasn't what I was expecting. Will think about it in the future.
Added removegrain 17 and 18 to ex_median(), weighted median and weighted percentile, median 5x5, and kuwahara mode. I'm also trying to implement Retinex and a corner detection algo.
Old 11th July 2021, 15:45   #98  |  Link
wonkey_monkey
I was going by the code here which has a few redundancies (e.g. the final values of E, D, and FF are not needed). Eliminating just one (I got a bit lost trying to eliminate more) did make a small but noticeable impact on speed.
Old 11th July 2021, 16:12   #99  |  Link
Dogway
Yes, I eliminated those 2 days ago. I might be able to remove more but I have been more involved in adding new modes and bugfixing. Next versions will be mainly optimizations I guess.
Old 11th July 2021, 17:51   #100  |  Link
wonkey_monkey
By the way how did you come up with that order of min/max swaps in the first place? I can't work out how (for undot2) it determines BB and GG in less than 22 min/max swaps.
avisynth, dogway, filters, hbd, packs
