Old 23rd April 2018, 12:26   #6061  |  Link
Bhavnahari
Originally Posted by jlpsvk View Post
Thanks!!! So it won't downscale and upscale video? Only stats? Right? So it's better for retain quality/details or not?
The input video used to generate the analysis file(stats) in "save" encode must be the downscaled version of the video used to encode "load", x265 scales only the analysis data, not the input video.
The refinement techniques are to improve the speed of the encode with similar quality when compared to encoding the high-res video without any prior analysis information. Among the different refinement levels, --refine-inter 3 --refine-intra 4 gives the best quality retention.
Bhavnahari is offline   Reply With Quote
Old 23rd April 2018, 17:21   #6062  |  Link
Loomes
ASRock X299 OC Formula + i9-7940X + Win10 x64 ... no crashing... AVX512 working flawlessly.
Good for you ;P
What is your command line? Are you using ffmpeg?
Loomes is offline   Reply With Quote
Old 24th April 2018, 13:30   #6063  |  Link
jlpsvk
Originally Posted by Loomes View Post
Good for you ;P
No... x265 ... 5 instances at once (RipBot264 Distr. encoding) to penetrate all cores at 100%.
My current command line:
--profile main10 --level-idc 5.1 --output-depth 10 --ctu 32 --amp --vbv-bufsize 160000 --vbv-maxrate 160000 --me star
--max-merge 5 --rc-lookahead 40 --lookahead-slices 4 --gop-lookahead 34 --ref 5 --hdr --hdr-opt --repeat-headers --no-info
--no-deblock --no-sao --no-strong-intra-smoothing --high-tier --asm avx512
jlpsvk is offline   Reply With Quote
Old 24th April 2018, 14:59   #6064  |  Link
This requires a powerful fan ...
Old 24th April 2018, 17:30   #6065  |  Link
jlpsvk
Nope... Noctua NH-D15 keeping it at 63 degrees.
Old 24th April 2018, 17:58   #6066  |  Link
Loomes
That's great but what is your frequency and your AVX offset? Because that's what makes the heat.
Old 24th April 2018, 19:41   #6067  |  Link
jlpsvk
All 14 cores running at 3.7GHz (instead of 3.1 stock).
Old 24th April 2018, 20:24   #6068  |  Link
RieGo
so no AVX512 offset?
i got really weird results while using avx512 and x265:
A) temps don't really go much higher while using avx512, at least on my system
B) AVX512 offset almost doesn't make a difference. i had same performance on 12x 100MHz difference in offset
RieGo is offline   Reply With Quote
Old 24th April 2018, 21:53   #6069  |  Link
Asmodian
Are you sure you are using AVX-512 and not bottlenecked by something else? I could notice even 2x offset (200 MHz), not hugely significant but a reproducible decrease in performance. Temperatures weren't much, if any, higher for me, running AVX2 or AVX512.
If you use something like hwinfo do you notice any cores running at the offset multiplier?
madVR options explained
Old 25th April 2018, 00:03   #6070  |  Link
Ma
In case that the bug is in ffmpeg instead of x265, you can test ffmpeg binaries compiled by VS2015 -- ffmpeg-20180424.7z (without any libs, only for decoding video). I've added also ffmpeg compiled by GCC 7 and GCC 8 with only '-O2' optimize option instead of default '-O3 -fno-tree-vectorize'.
In my Win10/i7 8700 all 3 ffmpeg binaries works (and current Zeranoe builds also works).
Old 25th April 2018, 00:52   #6071  |  Link
Loomes
Thanks a lot, I will do some more tests at the weekend. I have a feeling that it's not x265 or ffmpeg but that there's something wrong with my system. At least my Win10 install is rather fresh, almost vanilla and from an ISO directly downloaded from the Microsoft site. Well, I'll find out!
Old 25th April 2018, 16:30   #6072  |  Link
sdml
Am I correct that all *-refine-* features useful only for multi-pass scenarios?
sdml is offline   Reply With Quote
Old 25th April 2018, 16:31   #6073  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
rd-refine works in crf too
Old 25th April 2018, 16:34   #6074  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm a bit confused as Bhavnahari stated that "refine-inter and refine-intra features may be used with any rate control techniques including ABR, CRF and CQP". Why would you do a 2-step encode in CRF mode to utilize the refining? Shouldn't a normal CRF encode already bring all the quality you can get from your settings with the least amount of time spent on encoding or analysing?
Old 25th April 2018, 19:52   #6075  |  Link
Asmodian
I believe the point is to do much of the analysis on a lower resolution video, then reuse that analysis with the higher resolution while still doing some refinement to fine tune the analysis for the full resolution. This gives a speed boost while also not lowering the quality too much, like simply using the analysis done on the low resolution video directly would.
I am not sure I would do this, but then I tend to run far up the quality/speed curve, e.g. preset veryslow with a few extra options that slow it down even more. It would be interesting to see the speed and quality impacts from using this method compared to slower or faster presets and/or other options.
Old 26th April 2018, 04:23   #6076  |  Link
WhatZit
Basically correct. The idea is to "Analyse once, encode many".
Many of the recent CLI functions added to x265 are there to suit the demands of professional broadcast/OTT content providers, who may wish to create multiple resolution and bitrate copies of any one source.
The practical consumer application of this particular "reuse" functionality would be very niche.
WhatZit is offline   Reply With Quote
Old 26th April 2018, 06:44   #6077  |  Link
jlpsvk
probably Intel is OC-ing itself as it has good thermal conditions. temps with AVX-512 are bit lower in fact on my system.
Old 26th April 2018, 18:48   #6078  |  Link
jlpsvk
x265 crashing on "2nd pass"... (--profile main10 --level-idc 5.1 --output-depth 10 --ctu 32 --amp --vbv-bufsize 160000 --vbv-maxrate 160000 --me star --max-merge 5 --rc-lookahead 40 --lookahead-slices 4 --gop-lookahead 34 --ref 5 --hdr --hdr-opt --repeat-headers --no-info --no-deblock --no-sao --no-strong-intra-smoothing --high-tier --analysis-load c:\stats.dat --analysis-reuse-level 10 --scale-factor 2 --refine-inter 3 --refine-intra 4 --asm avx512)
x265 [warning]: specified frame type (5) at 2091 is not compatible with keyframe interval
any suggestion?
Old 26th April 2018, 18:49   #6079  |  Link
Selur
Selur's Avatar
wild guess: still got free space on c: ? (iirc analysis files etc can get really large)
Old 26th April 2018, 19:18   #6080  |  Link
And: Write access rights in the root of C:? Better use a secondary drive for video processing.
