14th October 2017, 15:57 | #81 | Link |
Looks promising, honestly kind of surprised... I always felt SVP was quite a way ahead of MVTools.
It might just be that to use any kind of MVTools convetion in real time you have to set use awful quality settings, SVP does seem to be better optimised. I would point out that (in my opinion) SVP only comes into its own when the artefact masking is set to maximum (and shader complexity is set to 23). I know InterFrame's default settings don't really bring out the best in SVP in many cases. Also v4 is showing big quality improvements over v3 (while the program's GUI isn't free any more the core SVPflow DLLs are still free to use in scripts). Will do some side by side comparisons shortly. |
24th October 2017, 11:32 | #82 | Link |
I was recently testing FRC in oder to replace Interframe/SVP for editing. I am converting 2K or 4K from 25/29.97 to 50p.
I am looking for the best motion compensation and avoid any object- or frame-blending. The only way to achieve this with FRC was to set output="flow" AND blksize=8. With any larger blocksize, FRC would start to blend moving objects in the frame. Quality="fast" was good enough to replace interframe in most cases. Very good work really! However, I am wondering why I am getting blending free results only with the smallest blocksize and why output="auto" with various other parameter settings leads to blended rather than "morphed" objects in almost any cases. Any ideas ? Last edited by Hotte; 24th October 2017 at 11:35. |
24th October 2017, 16:13 | #83 | Link |
If you want to avoid any artifact masking by blending, skipping or whatever you might want to try the core jm_fps script from here:
https://forum.doom9.org/showthread.p...39#post1800439 FRC is based upon this script with additional artifact masking (which is often beneficial, but sometimes it is not...) Cheers manolito |
24th October 2017, 19:13 | #84 | Link |
Hi guys, I have been using SVP for many years. I now see this thread, looks great. So whats everyone using it with, avisynth or avisynth+. Which gives better performance? I'll give it a go using whatever is recommended parameters to see if my system can handle it vs SVP (Using Interframes Film / Medium settings).
25th October 2017, 20:28 | #86 | Link |
Thanks manolito, this is a good basic script with all the functions I need. Quality is good. The only thing I missed was scene change detection. Do I have to go back to FrameRateConverter to get it ?
Also in your script, blksize determines inframe object movement behaviour. Small blksizes like 8 or 12 will morph, higher blksizes will more and more blend the movement. But in any case small movement will be handled differently than big movement. I understood this is a common concept. Itīs simple to handle with only one parameter to change for different situations. Not bad, really. |
26th October 2017, 00:06 | #87 | Link | |
Soul Architect
Flow = MFlowFps(C, super, bak, fwd, num=NewNum, den=NewDen, blend=false, ml=200, mask=2, thSCD2=255) |
27th October 2017, 19:19 | #88 | Link | |
So is anyone using this in realtime? Trying to get it running in real time here, not sure if its a runner. I'm trying the fast preset first (Using core i7 6700K at 4.5GHZ, GTX 980). I'm running this script via ffdshow which is how I also use SVP.
For ffdshow settings itself, I have it set to "Add ffdshow video source" disabled. Buffer back/ahead set to 0/15. Again this is what works well for SVP. Heres my script so far but its definitely not smooth I assume it needs tweaking to work in ffdshow and maybe the buffer settings in ffdshow arn't optimal. I havn't seen anyone give a full example of use with ffdshow. Quote:
28th October 2017, 04:03 | #89 | Link |
mark0077,
To the best of my knowledge the ffdshow Avisynth section ignores some AviSynth functions, and I'm fairly sure changing the frame rate is one of them. It makes sense, because if you change the frame rate and it in turn changes the duration, the audio won't stay in sync. Plus the renderer or other filters down the line probably need to know the frame rate and changing it might cause issues there. Try putting something simple like ChangeFPS(20,1) in ffdshow's Avisynth section. SVP is probably a different story, but I can't say I've used it for more than 10 seconds. Doesn't it install stuff for controlling it outside of ffdshow? Do you per chance use Potplayer? Many of ffdshow's filters have been borrowed and added to Potplayer, and it should let you change the frame rate. In fact I think it comes with scripts for doing just that. Have a look in Preferences/Video/Avisynth. Last edited by hello_hello; 28th October 2017 at 04:06. |
28th October 2017, 11:06 | #90 | Link |
Thanks hello hello. Actually I use SVP DLLs without any of the additional tray icons or software and I think madVR always says the frame rate is the original rate. Not the converted rate but all still says in sync. I am hoping to replicate the same pattern with FRC. Has anyone used it via ffdshow in real time?
22nd November 2017, 05:46 | #93 | Link |
I can answer that one . In terms of using the GPU for processing, the answer is unfortunately no. For speed, it all depends on how you currently have things set up. If you use the latest (currently rev 2544) 64-bit Avisynth+ with the latest Masktools, MVTools, as well as other filters in your script, it will help with speed quite a bit!
22nd November 2017, 10:43 | #94 | Link | |
Yes, I'm using the latest Avisynth+ (AvisynthPlus-r2544-MT.7z), MaskTools (masktools2-v2.2.10.7z), MVTools (mvtools-v2.5.11.22.zip) and FRC (FrameRateConverter-v1.2.zip) but the speed is still awful - with Preset="slowest", BlendOver=40, SkipOver=140 fps is around 1-1.2 and with Preset="Anime" fps is about 4-6. |
26th November 2017, 20:56 | #96 | Link | |
https://snag.gy/QwAs7F.jpg The internal AviSynth Portable r2508 of MeGUI doesn't support MT though it says that it does (Error message for your reference: Script error: There is no function named 'SetMTMode') so I tried to use AviSynth MT from this post https://forum.doom9.org/showthread.p...09#post1817809, but after some time of processing, encoding is crashed so I decided not to use it and tried AviSynth r2544MT, I don't know why MeGUI doesn't support it and switches to internal portable r2508. Here is my script: Code:
SetMemoryMax(6000) PluginPath = "C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\" LoadPlugin(PluginPath+"FrameRateConverter.dll") LoadPlugin(PluginPath+"mvtools2.dll") LoadPlugin(PluginPath+"masktools2.dll") LoadPlugin(PluginPath+"GRunT.dll") Import(PluginPath+"FrameRateConverter.avsi") <input> <deinterlace> <crop> <denoise> <resize> FrameRateConverter(NewNum=60, NewDen=1, Preset="slow", BlendOver=40, SkipOver=140) Last edited by iG0R; 26th November 2017 at 21:11. |
27th November 2017, 09:32 | #97 | Link | |
The MT error message is quite clear, Avisynth+ does not have a "SetMTMode" function. Multi-threading in AVS+ is implemented differently, see here.
Groucho's Avisynth Stuff |
27th November 2017, 10:47 | #98 | Link | |
Thank you, now I understand what was wrong with AviSynth+. |
27th November 2017, 11:16 | #99 | Link |
Staxrip. I think there's also a 64 bit version of Megui.
Groucho's Avisynth Stuff Last edited by Groucho2004; 27th November 2017 at 12:04. |
27th November 2017, 12:06 | #100 | Link | |
Think Current ver$ of Staxrip support ONLY 64 bit [Win7+). (JFYI)
EDIT: http://staxrip.readthedocs.io/intro.html#about Quote:
http://staxrip.readthedocs.io/search...s&area=default
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th November 2017 at 12:36. |
