16th September 2008, 23:24 | #2481 | Link | |
I dont care so should you
Sorry I think you are out of luck on the colour change... |
16th September 2008, 23:46 | #2482 | Link |
Any idea how to increase the video quality, I'm using 2-pass and set my bitrate to 300. I compared with Bencos (mencoder GUI), and the quality is better than ripbot (using same bitrate). I like using ripbot because it easy to use and I can do hardsub.
17th September 2008, 00:42 | #2483 | Link | |||
17th September 2008, 15:40 | #2485 | Link |
Got a 264 level question. I pulled down a few of the free HD TV Shows off of iTunes and poking around using mediainfo I saw they were encoded using 3.1 level. For the aTV setting in RB264 is there any benefit using the 3.1 level over the 3.0 level? Glancing through the h264 wiki it looks like the 3.1 level allows more macroblocks/sec and higher bit rate but in terms of what the aTV can actually handle I dont see a benefit but being a curious individual figured I would throw it out to you experts for an answer.
Cheers. |
17th September 2008, 17:51 | #2486 | Link |
I encode for make the video size smaller ^_^ that's why usually I'm using 300 bitrate. Btw any idea how to make DENOISE option work ? I tried for my anime video but it wont encode, I got this error log :
avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'C:\temp\RipBot264temp\job1\job1.avs' |
17th September 2008, 20:14 | #2487 | Link |
I just used RipBot to convert Monsters, Inc from 1440x1040 25 fps to 1920x1080 23.976 fps...it looks & plays smooth, but the audio is way off...is there an easy way to convert a .dts or .ac3 stream that's 25 fps to 23.976 fps? Is there a guide to doing this?
17th September 2008, 20:45 | #2488 | Link | |||
19th September 2008, 00:48 | #2491 | Link |
LOL whatcha' think Atak hes offering to cut half the work out of it... ;-)
I still think its a waste of time to do... What type of monitor do you have JuggaKNot... I recommend a new one with at least 600:1 contrast ratio it will help you see the wording better.. |
19th September 2008, 02:08 | #2492 | Link |
Okay, thanks. Got another problem, though: the AddBorders command is a no-go. I added this to the Preview script:
AddBorders(0, 32, 0, 248) (on a 1920:800p stream). That should give me a nice 1080p resolution, right? Only when I click 'preview', I keep getting this error: "invalid arguments to function AddBorders" Any idea what might be causing it? EDIT: Never mind, solved it. I had forgotten the source. video=AddBorders(video, 0, 32, 0, 248) Does the trick.
Gorgeous, delicious, deculture! Last edited by asarian; 19th September 2008 at 02:45. Reason: Solved |
19th September 2008, 07:28 | #2493 | Link | |
If atak wants it done i'm willing. |
19th September 2008, 09:31 | #2494 | Link | |
Gorgeous, delicious, deculture! |
19th September 2008, 10:08 | #2495 | Link | |
I have 19" LG Flatron L194WT-SF (mat) connected via DVI I see all font without any problems. End of story. Those small fonts have gray color (R:160;G:160;B:160) so as you can see these values are still far away from white (R:255;G:255;B:255). Therefore you should see them quite easily.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th September 2008 at 10:13. |
19th September 2008, 18:21 | #2497 | Link |
I know this has been talked about before, but I couldn't find it. I would like to keep 2 audio tracks for one of my bluray's. The first one is french w/ english sub's and the other is the english audio. Is there any way to do that with ripbot or should I hard encode the french audio w/ english subs w/ ripbot and use tsmuxer to add the english audio?
Thanks |
19th September 2008, 19:55 | #2498 | Link | |
I asked atak, there will be no "2 audio tracks" in ripbot the other way ( might crash ripbot ) edit the audio.bat and mux.bat after adding a job. |
23rd September 2008, 20:21 | #2499 | Link |
@Atak
I'm trying to convert my copy of equilibrium from hddvd to bluray. For some reason when I put it into ripbot a horn blows and says there is only 450 frames. I am using version 1.10.6 and didn't have a problem with version 1.10.5 when I changed it to a bd9. What should I send you to trouble shoot this? Thanks |
24th September 2008, 07:46 | #2500 | Link |
too small
i converted one of my HD DVDS to an MKV with this tutorial: http://forum.doom9.org/showthread.php?t=137128 Sektion 3. So I got a MKV File with 2 Audio Stream and thougt "why not convert it with ripbot?". So I converted them to Bluray. I selected 2 Pass encoding with 8048 Mbits and the Playstation 3 Profile. After 12 hours of encoding I got a Blu-Ray Folder with a M2TS Stream with 800 MB. How is that possible? Did I do s.th. wrong? I am trying it again right now with a fixed size of 8500 MB. Hopefully that will work. Can anyone give me a hint? Regards Last edited by malgates; 24th September 2008 at 13:15. |
