22nd December 2008, 02:22 | #3481 | Link |
Great program Atak, but would it be possible to have a mode that lets you select multiple files for batch processing using the same settings? Its just a bit painstaking to have to load each file one at a time for conversion
:₪(¦[Ðєςąץєd.ςєłł]¦)₪:™ |
22nd December 2008, 07:38 | #3484 | Link |
well,
i used ripbot to make a 27GB movie (with a AC3 audio track) to fit ina 25GB blank bluray disc. I set "2-pass", locksize 23000MB and i left bluray profile 4.0. Video = perfect Audio = perfect "BUT Very LOW" i mean the sound level is very low! maybe i had to set profile 4.1? some suggestion pls? thx! |
22nd December 2008, 20:48 | #3485 | Link | |
Note: If you leave the audio set to xx.COPY STREAM the audio will be extremely quiet on playback. Be sure to choose the best (highest bitrate) audio stream for the desired language and set the bitrate to 448kbps at the most. 640kbps would not playback on my AppleTV. For the video set the bitrate to 6860kbps, 2-pass mode, autocrop and resize to HD-READY 1280x720. 6860kbps is the maxium rate that AppleTV would support once the audio was muxed into the final file. I have tested this over and over and have made many non-compatiable files. I would waste your time on type to gain a few extra bits. Apple's support says that 5000kbps is the maximum bitrate and this is only a safe limit placed by Apple in order so they dont get any backlash from consumers. Use the MKV container and encode your file. My Core2 DUO 3.0GHz takes about 8 hours to encode a typical 100min movie. Now I move the large MKV file to my Mac and use Quicktime to finish the job. On the Mac make sure you have Perian installed. This allows the Mac to "comprehind" the AC3 audio. Open up the MKV file in Quicktime (this will take a few minutes to load). DO NOT PLAY the file once loaded. Now save the file as a MOV. File / Save As. The file can now be loaded into iTunes and played on the AppleTV. The AppleTV (with firmware 2.3) will note on the screen that the movie is a HD movie by playing a HD logo next to the title. Note: Tagging the MOV file will support all the same tags as the M4V counterpart with the exception of the MPAA rating. Loosing the MPAA rating logo was a tradeoff for me in order to have an HD movie with Dolby 5.1 sound. Note: Use can also add an AAC track to the MOV file by using Quicktime. This will allow you to keep a single copy of the movie in the event you have a second and/or third AppleTV (like I do) that is not connected to an audio receiver. The second/third AppleTV is in our master bedroom and the kids play room. |
23rd December 2008, 03:01 | #3489 | Link |
Does anyone know if the recent PS3 updates have changed codecs that no longer support AAC audio with mp4?
Some of the Early Blurays I converted with ripbot to mp4 no longer play audio on my PS3. They worked fine several months ago??? I only make AVCHD's now. Last edited by jamd1; 23rd December 2008 at 03:03. |
23rd December 2008, 10:05 | #3491 | Link | |
Anyhow, I would have loved to quickly set up a bunch of movies to encode over my vacation....and let her rip! |
23rd December 2008, 10:07 | #3493 | Link | |
23rd December 2008, 13:21 | #3494 | Link |
Why doesnt RipBot DO anything, just skips to complete, I know someone asked it before but cant find the post...
I would use ripbot to add black borders to 1920x816 or similar movies to achieve standard blu-ray resolution... |
23rd December 2008, 13:41 | #3495 | Link | |
http://forum.doom9.org/showthread.ph...10#post1222910
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 23rd December 2008 at 14:47. |
23rd December 2008, 21:06 | #3497 | Link |
Instead of Copy stream select AC3 640 kbps
23rd December 2008, 21:13 | #3498 | Link |
I've been using RipBot264 (latest version 1.11.5?) recently, creating mkv's of a few movies from my collection. Just recently a problem occurred and it doesn't seem to go away. I've been using the guide posted on videohelp.com to create the mkv's and normally Pass 1 takes 2.5-3.5 hours and Pass 2 takes anywhere from 8-11 hrs, depending on size, length, frames, etc. Anyway, recently I started encoding The Incredible Hulk and instead of taking a few hours for Pass 1, it only took 30 mins. I looked back and it was only giving me 20-30 kbps and about 100 fps. I don't know what happened here, but I also tried encoding Blood Diamond and the same issue came up. Any help would be appreciated.
By the way, I have been using the High@L4.1 profile with 5 Ref frames (no other changes to the profile), if that helps. Last edited by wolfbane5; 23rd December 2008 at 22:14. |
23rd December 2008, 21:20 | #3499 | Link | |
Do you get picture in Preview?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 23rd December 2008 at 21:28. |
23rd December 2008, 22:12 | #3500 | Link |
Yes, I do get picture in preview. I'm a bit of a quality nut, hence the 5 Ref frames. Any more than 5, the quality difference is marginal. I've been creating 720p rips, not 1080p just to clarify. Guess I forgot to mention that in my previous post. :S
