8th October 2014, 03:22 | #21522 | Link | |
Passed Newbie Inquisition
{212690fb-83e5-4526-8fd7-74478b7939cd} which refers to the Microsoft DTV-DVD codec. it is selected (h264). Last edited by MajorEvent; 8th October 2014 at 03:32. |
8th October 2014, 04:15 | #21526 | Link |
Excellent. With that confirmation, jdobbs knows he's on the right track now and I'm sure he'll be able to implement a fix soon and bring back LAVFilters. I bet he hates having to re-edit the first page so soon again
8th October 2014, 04:20 | #21527 | Link |
MajorEvent
Just rename the audio and video decoders as stated here http://www.makeyoutubevideo.com/disa...eodecoder.html and re install LAV. Check with GraphStudio |
8th October 2014, 04:28 | #21528 | Link | |
8th October 2014, 07:39 | #21529 | Link | |
Using Graphstudionext on an .m2ts source: 32-bit: connects to LAV video {EE30215D-164F-4A92-A4EB-9D4C13390F9F} and LAV audio 64-bit: connects to DTV-DVD {212690FB-83E5-4526-8FD7-74478B7939CD} and LAV audio @jdobbs: The registry values for the preferred codecs {96B9D0ED-8D13-4171-A983-B84D88D627BE} {04FE9017-F873-410E-871E-AB91661A4EF7} My OS is Windows 7/64bit Last edited by Sharc; 8th October 2014 at 08:33. |
8th October 2014, 09:21 | #21530 | Link |
There are also tools to override the preferred filter without entirely breaking it by disabling it on a file level, ie this: http://www.codecguide.com/windows7_p...er_tweaker.htm
I've pondered before if I should make the LAV installer set its decoders as the preferred decoders, however it may break stuff in some applications, which is why I didn't do that (ie. TV playback in WMC usually breaks), and most competent players have their own functions to prefer filters over the Microsoft ones.
8th October 2014, 13:25 | #21532 | Link | |
I'm guessing that may be the key. I'll see if I can create a new installer for LAVFilters that sets the values -- and see if it works to fix the issue on MajorEvent's system (since he hasn't modified it yet). Last edited by jdobbs; 8th October 2014 at 13:30. |
8th October 2014, 14:41 | #21533 | Link | ||
@nevcairiel: Thank you for checking in on our problem. I had a feeling you would and you should know it's appreciated. |
8th October 2014, 15:21 | #21534 | Link | |
If not I can modify BD-RB to manually change the preferred settings at startup (like I do for FFDSHOW) -- but that way is kind of a cludge since I have to ask the user to run BD-RB as Administrator the first time it is run. [Edit] Never mind. I got the customized installer working... Last edited by jdobbs; 8th October 2014 at 22:48. |
8th October 2014, 16:01 | #21536 | Link | |
Two ini file changes I just noticed.. ENCODE_QUALITY=2 (when it was running slow) vs ENCODE_QUALITY=0 (when it was fast). And ONEPASS_ENCODING=0 (when it was slow) vs ONEPASS_ENCODING=2 (when fast). Based on a thread discussing on ENCODE_QUALITY=X, I'm thinking that is the difference. Its possible I missed settings -> Encoder -> Auto Quality, and maybe the default HQ was selected instead? (I'm guessing because when I look at the ini with AUTO Quality, the value is 0, when HQ is selected, the value is 2, and 2 is supposed to be slower). |
8th October 2014, 17:00 | #21537 | Link | |
1. If you have selected a specific quality setting -- it is used. 2, If you have selected "Automatic" then "High Quality (Default)" is used That's because automatic quality only applies to encodes that have a target selected (BD-5, BD-9, BD-25, BD-50, or custom). A setting of "2" translates as "High Quality (Default)" and would definitely be slower than "0" which is "Good (Very Fast)" -- but it would also usually result in a smaller file (while maintaining the same quality) in CRF mode. As for ONPASS_ENCODING -- it doesn't apply to ALTERNATE encodes but it would make a huge difference on a standard movie-only backup. BTW, if you aren't doing something else on the computer, IDLE and NORMAL priority would likely result in the same time. Priority only matters when processes are competing for resources. Last edited by jdobbs; 8th October 2014 at 17:15. |
8th October 2014, 18:39 | #21538 | Link | |
Using an old ATI Radeon HD5670 videocard. AVC decoding is selected (h264). Windows 7 x64 Pro SP1 is installed. Last edited by Glarioo; 8th October 2014 at 18:54. |
8th October 2014, 18:50 | #21539 | Link |
It seems there's a solution coming for LAV out of sync.
Run "Hachi" last night and it was perfectly in sync using LAV filters (0.62.0). Source Video: MPEG-2, 1920x1080. Audio: DTS-HD High-Res audio. Output: MKV Container, 1920x1080, 640Kbs DD5.1. Last edited by Glarioo; 8th October 2014 at 19:03. |
8th October 2014, 22:46 | #21540 | Link |
@MajorEvent
Please download and install LAVFilters using this customized installer that sets the preferred entry in the registry, and let me know if it solves the out-of-sync issue. I'd appreciate it if you can let me know as soon as possible. Thanks. Last edited by jdobbs; 8th October 2014 at 22:49. |
