17th August 2017, 22:35 | #44741 | Link | ||||||||
If all else fails, can you try directly connecting the JVC to the PC? Just temporarily, of course. Quote:
Yes, if you're only interested in 23fps/24fps movies and if you use 60hz smooth motion, then custom modes are not of interest for you. Neither is ReClock. |
17th August 2017, 22:39 | #44742 | Link | |
17th August 2017, 22:39 | #44743 | Link | ||||
3D doesn't work for you without FSE? I'm pretty sure it worked for me, the last time I tested it. Although Nvidia is more picky than AMD and Intel. E.g. IIRC, it works with Nvidia only on the primary monitor, but with AMD and Intel also on secondary. Quote:
17th August 2017, 22:43 | #44744 | Link | |
Here's my code: Code:
if ((m_HDR.white_point_x != 0.0) && (m_HDR.white_point_x != 1.0) && (m_HDR.max_display_mastering_luminance > 1.0))" |
17th August 2017, 22:44 | #44745 | Link |
custom mode tutorial:
http://madvr.com/crt/CustomResTutorial.html Also linked in first post of this thread. |
17th August 2017, 22:50 | #44747 | Link | |
Otherwise, the exact same data is being fed to you. It reports a value of 1 nit, which seems to match the broken data.
17th August 2017, 22:52 | #44748 | Link | ||
It would be great if the final tool (custom res tab) allowed to go back to the default timings after further testing. It's not because there is no crash that there cannot be a reason to revert we will only come accross later.
17th August 2017, 22:59 | #44749 | Link | |
You should be able to go back at any time by clicking on the custom mode, then pressing the "delete" button. At least that's how it's supposed to work. |
17th August 2017, 23:23 | #44750 | Link | |
like frame skipping: https://www.testufo.com/#test=frameskipping or a test to check if a TV has a properly working 23p mode. you use the same test and check the brightness of the squares. it should be very obvious on a TV that is doing a 3:2 pullup. |
17th August 2017, 23:39 | #44751 | Link | |
Even with no custom res from the standalone experimental tool, the tab was missing. So I connected the PJ directly to the GPU momentarily, and the tab appeared, so it looks like it doesn't like it when an AVR is in the chain, even if the AVR reports a populated EDID block. I also tried 3D without FSE without an AVR in the chain and without any custom timings, and it definitely doesn't work here. The picture isn't corrupted/with weird colors as earlier, but it's 2D (no 3D at all) even if the OSD reports 3D windowed. Hope this helps!
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 18th August 2017 at 00:41. |
18th August 2017, 00:07 | #44752 | Link |
Thanks for the release madshi.
I did the first optimization run for the 2160p23 resolution. Everything went fine but when using the resolution and the same video file, windowed fullscreen reports a frame repeat every 5 minutes and fullscreen exclusive reports a frame repeat every 65/70 minutes. Clock deviations are the same. Am I missing something ? |
18th August 2017, 00:43 | #44753 | Link |
Edit: Now understand you need to switch to 60 hz before modifying 59 hz otherwise you can't customize a "standard mode" refresh rate.
madshi, thanks for this new version I have a Dell U2417H and modes 50, 59, 60 under the status column are listed as standard modes (the OS reports them). When playing a 23.976 video madvr reports "display 59.933 hz" and "composition rate 59.940 hz". Since I already have these modes listed and not missing, should I further optimize the 59 hz one or is it already perfect? The EDID for 59 hz "results in 59.93939 hz". Just now I played a 23.976 video for 40 minutes uninterrupted resulting in 1 frame repeat every 6.50 minutes. What do you mean by a 59p video? I've never played a 59 fps video in my life :P Thanks for clarifying. Last edited by JarrettH; 18th August 2017 at 06:22. |
18th August 2017, 01:31 | #44754 | Link | |
Thanks, ERIC |
18th August 2017, 01:44 | #44755 | Link |
X Cinema Projectionist NZ
Guys now that Im finally on Adaptive and have everything working perfectly I was wondering about dithering for 4K upscaling BDs...
I have the 1080Ti card and all my rendering times are now very very low. These are my settings: Chroma upscaling NGU sharp high Luma upscaling NGU sharp high render times 15.20ms Dithering is set to Ordered dithering, Should I use something higher like Error diffusion 1 or 2? since my render times are so low? If so which one produces the best image? |
18th August 2017, 02:02 | #44756 | Link |
There is no "best" when it comes to the two error diffusion options. I have been a fan of ED1 on my recent IPS monitors, on my older one I prefered ED2. However, on my new OLED TV I prefer ordered dithering, after a lot of testing. I didn't expect it but I have to believe my eyes.
You need to open it on the TV itself.
madVR options explained |
18th August 2017, 02:32 | #44757 | Link | |
Thanks, ERIC |
18th August 2017, 02:43 | #44758 | Link |
You can backup settings.bin and then reset to test it. I am not sure, it shows up on my TV but I don't have any profiles for displays.
18th August 2017, 04:04 | #44759 | Link |
Getting random crashes of madvr and lock ups of MPC-HC with the new madvr.
Also, deinterlacing doesn't work with the new DX11 renderer. Using NGU for Chroma causes it to crash as well. Didn't try the upscaling as I never use anything but Jinc for all my scaling needs. Last edited by AngelGraves13; 18th August 2017 at 06:12. |
18th August 2017, 04:15 | #44760 | Link |
QB the Slayer
Similar here. PotPlayer + madVR + LAV.... Files in play list play fine, but the player crashes (sometimes it's madVR) as soon as it moves on to the next file. I had to get up off the couch and close everything and restart playback again manually for the next file. I rolled back version and all is working fine again.
QB
