Old 8th March 2019, 16:42   #55221  |  Link
Alexkral
This comparison was supposed to be between the UB9000 vs. madVR HDR -> HDR using shaders vs. madVR HDR -> SDR using shaders. All of your HDR images are showing HDR passthrough.
If you use shaders and output in HDR format, gamut mapping will be applied. The user who started this discussion was complaining about desaturation when outputting in an HDR format. HDR -> SDR looks color accurate in your last post. Maybe is it less sharp in a couple of the comparisons.
What I'm saying is that the desaturation is because of madVR's gamut mapping, so I'm comparing madVR's HDR -> SDR using shaders and gamut mapping, with pixel shaders with the BT.2390 EETF and a simple transform matrix. All the images starting with "BT.2390" are the result of pixel shaders running on MPC-HC with the EETF and a transform matrix. I don't think that taking HDR screenshots is posible so I don't know how do you want to compare anything with madVR HDR -> HDR using shaders by means of screenshots.
Old 8th March 2019, 17:23   #55222  |  Link
Warner306
You would have to use a camera to make that comparison. I'm not sure if a phone camera is good enough. Using BT.2390 wouldn't be a good comparison with madVR's tone mapping because it is far more complicated than BT.2390 alone.
Gamut mapping is making a tradeoff between luminance and saturation. The less saturation, the more luminance and the more detail, but obviously the less color you have. Excessive desaturation is not supposed to be an issue.
Old 8th March 2019, 18:04   #55223  |  Link
KoKlusz
@Alexkral
MadVR's tonemapping goal is fidelity to the source, not to create the most pleasing image. The reason why explosions in Fury Road look desaturated like that is because that's how it would looked like on 10k nits BT2020 display.
KoKlusz is offline   Reply With Quote
Old 8th March 2019, 18:21   #55224  |  Link
Alexkral
Well of course you can always complicate it and try to make it better, you can add gamut mapping, integrate it with the tonemapping, add detail management, etc. I can't know everything madVR is doing. But the thing is that a very simple approach like this is more than comparable, sometimes even better. For example, it has always been said that doing the EETF in ICtCp gives more quality, and I agree, but here you can see how a very simple RGB EETF with BT.2020 clipping looks better. Of course I'm the first to admit that this is an exception. So at the end, trying to balance luminance and saturation is obviously the more wise, but not always the best.
Old 8th March 2019, 18:38   #55225  |  Link
KoKlusz
It may look subjectivity better, but it's not objectively better since it shows different image compared to what was encoded on disc. In other words, it's not faithful to the source.
Old 8th March 2019, 19:01   #55226  |  Link
iron2000
Questioning User
Recently there some sort of flipping static noise whenever madVR is used.
No noise if I switch to EVR.
The noise does not stop, it occurs throughout the whole of the video length.
I use MPC-HC, I have the seekbar and the black bar autohide.
If I pause the video its all quiet but if I trigger the hidden seekbar there will be that static noise.
The noise follows the mouse as it triggers and leave the trigger area for the seekbar, noise and no noise.
8 Pro x64 | i5-3470 | 8GB ram | GT430 | Xonar DX | MPC-HC x86
iron2000 is offline   Reply With Quote
Old 8th March 2019, 21:27   #55227  |  Link
Asmodian
This is called coil whine, it is a weird and annoying hardware defect that manifests with very specific loads.
madVR options explained
Old 8th March 2019, 21:44   #55228  |  Link
Manni
If you use NGU, try to change the level. For example, I get an audible coil whine with NGU High but it goes down significantly with NGU Med.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 8th March 2019, 22:04   #55229  |  Link
maxkill
Better is in the eye of the beholder. There is no right or wrong. Some people like a accurate representation of 'how it was meant to look' with as little deviation from this as possible while others prefer filters that change the image to make it more colorful or what have you.
maxkill is offline   Reply With Quote
Old 8th March 2019, 22:15   #55230  |  Link
yok833
I have an LG OLED 2017 and i would like to know if the last experimentals builds of madvr and measurment file can improve the tone mapping of my tv or is it only reserved for videoprojector ?
What would be the right "min target / real display peak nits" for me ? Do I need tick "output video in HDR format" ?
In the settings of my tv do I need to turn off the "dynamic contrast" to let the madvr tone mapping do is job ?
Many thanks for your precious advices !!!
yok833 is offline   Reply With Quote
Old 8th March 2019, 22:29   #55231  |  Link
tp4tissue
tp4tissue's Avatar
If it's following the Mouse, it's not Coil whine.
It's CPU whine or GPU whine.
If you have a delidded chip, you can poke the core with a thin wooden stick while it's running (with whine), and hear the pitch of the whine change.
That's how they diagonse capacitor /coil whine in psus.
There's nothing one can do about it. piezoelectric effect
The noise can also dump into the analog audio out if you're using them.
For PC audio it's always best to use Optical. Or some sort of hdmi/usb setup with galvanic isolation. (which really just uses opto-couplers, which is essentially optical)
Ghetto | 2500k 5Ghz
Old 8th March 2019, 22:38   #55232  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by mandarinka View Post
Well, the name (eNVY) and the font/color used gave me an idea that if it is a processing box for non-HTPC use, then it might be software running on Tegra hardware - Shield TV (does it have HDMI in tho?) or more likely the newer Tegra modules. They have some GPU power and also lots of neural network acceleration for upscaling use. Not a cheap hardware though, similarly to FPGAs. (What do I win if true? )
So it's going to be a premium android app for the Shield ?
I'd buy it in a heart-beat if Madshi can turn the Shield into a 4K 3DLut box.
Ghetto | 2500k 5Ghz
Old 8th March 2019, 23:15   #55233  |  Link
Stan
I have a small situation here and I narrowed it down to madvr
To repro:
Have a multi monitor setup
Open a movie on a secondary display
Full-screen it
Press Shift+Win+Arrow Left
The video moves to the other screen but freezes, every other display output is frozen as well, only the mouse cursor still moves.
madvr settings: https://i.imgur.com/4srk471.png
Stan is offline   Reply With Quote
Old 8th March 2019, 23:36   #55234  |  Link
working totally fine here.
do you have more informations like different resolution refresh rate and stuff like?
Old 8th March 2019, 23:39   #55235  |  Link
tp4tissue
tp4tissue's Avatar
To repro:
Full-screen it
Doing stuff like that freezes ALOT of programs.
Ghetto | 2500k 5Ghz
Old 8th March 2019, 23:51   #55236  |  Link
Stan
Resolution is 1080p on both, refresh rate is 60/50 hz.
Old 9th March 2019, 05:12   #55237  |  Link
i got a system freeze when moving from 1080p60 to 1080p120 screen with your setting.
>if< the source for the freeze is madVR not one of the other possible candidates it should be fixed ASAP in my opinion.
i will try to create a debug log but that'S not a lot of fun when you have to freeze your system.
Old 9th March 2019, 09:06   #55238  |  Link
iron2000
Questioning User
I too think this is it
I opened the casing while the video is going and heard it.
I turned it down to low but still hear it.
Ordered an external sound card, hope it will be better.
Thanks for the replies
Old 9th March 2019, 12:52   #55239  |  Link
madjock
Unsure how a sound card will fix this if you can hear it inside the case tbh.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65"
Old 9th March 2019, 13:48   #55240  |  Link
maxkill
lmao
