28th April 2019, 09:24 | #6781 | Link | |
x265 CRF 28, veryslow, --no-sao --no-strong-intra-smoothing --deblock -1:-1 More bitrate removes the artifacting. |
28th April 2019, 12:58 | #6782 | Link |
Pig on the wing
In those cases, I had thrown quite a lot of bitrate there. Using CRF18 produced a smaller file than 6900 kbps, which was x264@CRF18. CRF28 is something I'd never use The onion artifacts were visible only in certain frames with very high motion, that's probably why I missed them in my test rounds earlier. I do recall someone complaining that tune grain sometimes did those as well.
28th April 2019, 22:00 | #6783 | Link |
Derek Prestegard IRL
I'd caution against doing too much settings tuning using still frame comparisons, especially when evaluating max CU size (--ctu).
I've spent a lot of time doing this. Using --ctu 32 can indeed produce a sharper / more detailed / less blurred image when looking at single frames - relative to keeping the default (--ctu 64) in some cases. However, the trade-off is typically more blocking, which you're more likely to notice in motion. In other words, an inferior user experience unless you're using very high bitrates. You're kind of performing a brute force non-adaptive psy tuning. x265 will use smaller CUs when it sees fit, you're just forcing it to never consider 64x64, even when coding giant uniform areas. In my opinion, you're typically best off trusting the extensive tuning and testing that MulticoreWare has done, and just using a preset. They set --ctu to 64 starting with --preset veryfast, and keep it that way all the way through placebo. In fact, in looking at the documentation for this parameter: https://x265.readthedocs.io/en/defau...#cmdoption-ctu it appears the only reason they set this to 32 for superfast and lower is that this increases parallelism and can therefore be faster. Do what's right for you, of course Last edited by Blue_MiSfit; 28th April 2019 at 22:02. |
29th April 2019, 14:01 | #6784 | Link |
I got crash when using zone in x265_12bit.
So I tried to use VSEdit to test it and here is result. Here is x265 file: http://msystem.waw.pl/x265/x265-3.0_..._gcc83-AVX2.7z Here is everything else: https://i.imgur.com/FFlFylW.png |
29th April 2019, 16:32 | #6785 | Link | |
Pig on the wing
As you apparently have been testing things quite a lot, do you have any opinion regarding AQ-mode? I'm still quite unsure if the new default of mode 2 is the best general option for film.
29th April 2019, 17:12 | #6786 | Link | |
Lost my old account :(
30th April 2019, 14:11 | #6787 | Link |
x265 v3.0_Au+22-feec4bdf9866 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
https://bitbucket.org/multicoreware/x265/commits/branch/default |
1st May 2019, 21:03 | #6789 | Link |
The cult of personality
I wanted to encode a 10-bit H.264 MKV video (lossless, 30 gb) to HEVC 10-bit... I piped it via ffmpeg but I put this "-pix_fmt yuv420p" instead of this "yuv420p10le"... I suspect this is wrong, but it is the only way it worked. Can you kindly guide me here?
I encoded .vpy file to lossless 10-bit H.264 since my device is slow with the filters I used... so now how to encode the 10-bit .mkv using x265? << I assumed using -pix_fmt yuv420p is wrong. Plus, next time when I want to encode like this (lossless 10-bit H.264 then 10-bit HEVC), should I encode to .yuv/.h264 in x264 (--muxer yuv\raw)? So I can input it directly to x265 without piping?? Here is my command line: Code:
"C:\.....\ffmpeg.exe" -i "C:\....\lossless_H264_video.mkv" -pix_fmt yuv420p -f yuv4mpegpipe - | C:\....\x265_64bit_10bit.exe --y4m --preset slower --crf 17 --ref 6 --rd 6 --psy-rd 1 --ctu 64 --aq-strength 0.8 --output-depth 10 --input-res 1920x1080 - --output "C:\....\ep07_1080p_video_HEVC.hevc" Last edited by ~ VEGETA ~; 1st May 2019 at 21:05. |
1st May 2019, 21:07 | #6791 | Link | |
Where can I find such ffmpeg build for windows? I thought -pix_fmt is to get the input as 10-bit... |
1st May 2019, 21:09 | #6793 | Link | |
"ffmpeg.exe" -i "input.mkv" -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | "x265.exe" --y4m |
1st May 2019, 21:14 | #6794 | Link | |
video: wrapped_avframe, yuv420p10le in cmd so I guess this is ok. what about my other question about better way to encode next time? |
1st May 2019, 21:36 | #6795 | Link | |
filtering + 1st pass + filtering + 2nd pass + .. > filtering + encode to lossless + 1st pass from lossless + 2nd pass from lossless .. But you are encoding CRF, e.g. now instead of filtering + x265 crf you do filtering + x264 lossless + x265 crf. That's slower? |
1st May 2019, 21:46 | #6796 | Link | |
while if I wanna encode 720p only (from horriblesubs tv shows), then yes I go vpy directly without lossless. what do you do for encoding BDs to 1080 and 720? |
1st May 2019, 22:18 | #6797 | Link |
So you encode to multiple resolutions? Ok, then it may make sense to create an intermediate to only do (slow) filtering once.
I think you may save a little bit of time/CPU by saving to uncompressed y4m/yuv instead of encoding x264 lossless as intermediate. But with slow filtering + slow x265 it will probably not make too much of a difference either way. And the size of the file increases so the wear on the HDD/SSD increases. P.S.: ffmpeg allows multiple outputs but I don't know how it affects speed and it may result in HDD fragmentation. I don't. Last edited by sneaker_ger; 1st May 2019 at 22:20. |
1st May 2019, 22:28 | #6798 | Link | |
I encode on a dedicated server so no problem about HDD xD, or so I think. |
1st May 2019, 22:35 | #6799 | Link |
You don't need VirtualDub. vspipe can create y4m files. But yes, unsurprisingly, uncompressed files are bigger than compressed ones...
But again: if you are doing slow filtering and slow x265 encoding the difference between uncompressed or lossless x264 --preset ultrafast intermediate is probably not worth worrying about. If you want to know exactly you have to benchmark it. Last edited by sneaker_ger; 1st May 2019 at 22:38. |
1st May 2019, 22:41 | #6800 | Link | |
ffmpeg -i inputfile.vpy -c:v rawvideo outputfile.yuv Code:
vspipe script.vpy output.raw I will try next time to see how much time will it take. Lossless x264 ultrafast 1080p is about 8 hours. |
