Old 7th November 2019, 06:00   #3261  |  Link
dr_ml422
maybe this worked.
https://i.postimg.cc/grTRHxWD/AVSto-DVD-error.png
Please let me know. Thanks manolito.
dr_ml422 is offline   Reply With Quote
Old 7th November 2019, 17:14   #3262  |  Link
manolito
manolito's Avatar
This is a thumbnail which is far too small. For me it is completely unreadable...
Old 7th November 2019, 18:37   #3263  |  Link
videoh
Useful n00b
I clicked the link, it is perfectly readable.
Old 7th November 2019, 20:54   #3264  |  Link
manolito
manolito's Avatar
This is weird...
I use my good old Opera 12 browser, and this is how it looks here:
https://i.postimg.cc/Cdpw4vPR/Opera12.png
In Chrome it is readable.
Old 7th November 2019, 21:13   #3265  |  Link
manolito
manolito's Avatar
@ dr_ml422
It looks like your AviSynth script for the project cannot be opened. The file is located in your local Windows temp folder.
Do you have enough free space on your Windows system drive?
Have you tried to run AVStoDVD as an administrator?
You could try to move your A2D temp folder to a different drive and / or partition. This is done under "Preferences -> Paths".
And the last thing I can think of is to use a different method for extracting the audio, You are using the default "Wavi + Aften" method. Try to change it to "FFmpeg(AviSynth)".
For debugging it would be helpful if you could open your temp folder right after the crash message appears. Then copy the AVS file to a different folder, open it with NotePad and post the content here,
Good luck
manolito
//EDIT//
Don't forget to try to disable your antivirus software temporarily...
And I almost forgot:
Please post your AVStoDVD log file here.
Old 9th November 2019, 03:56   #3266  |  Link
dr_ml422
This never happened before and when I close the command window with the error and proceed with FFMPeg etc... as suggested everything comes out fine. Couldn't find any logs. Probably deleted. I should uncheck that preference to delete them in the main window. I don't know anything about Aften etc... so I just left defaults asis. Is the FFMPeg option better? It says it'll automatically switch to FFMPeg if Temp Wav bigger than 4GB. There's more than enough space as it's my C drive and only my apps and regular associated stuff is there. Maybe it's the type of file being processed, or that I had 2 other encoding jobs happening at the same time? Let me run a solo job and keep the logs. They're in the AVSDVD output folder correct? Thanks.
Old 9th November 2019, 04:47   #3267  |  Link
dr_ml422
Log file for manolito.
Here goes. I couldn't edit yet so I had to reply in another message. Is DVDStyler 64 bit just as good as 32bit? I'm needing a backup app for my DVDs. Thanks.
<11/8/2019 10:16:38 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 8100/8100 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: Suicide Squad (2016)
DVD Menu: Static Menu
Output Folder: C:\Users\Noloc42\Videos\AVStoDVD DVD Output
Delete Temp Assets Files: No
Delete Temp Working Files: No
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
FPS Hard Conversion: 0
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
Video BitRate Min: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (240,240,240)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: G: Slimtype eBAU108 5 L 4L01
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Unload ActiveMovie Library: 0
Adjust DirectShow Filters at runtime: 1
Save General Settings: 0
SYSTEM INFO
Processor Name: AMD Ryzen 5 2600 Six-Core Processor
Operating System: Windows 10 (10.0.18362) 64 bit
User has Admin Rights: YES
Running with Elevated Privileges: NO (3)
Available Output Disc Space: 228 GB
AviSynth is installed: YES (release 2.6.0)
LAV Filters is installed: YES (release 0.74.1)
ffdshow is installed: NO
CODECS REPORT
H.264/AVC: LAV Video Decoder
Xvid: LAV Video Decoder
DivX 4/5/6: LAV Video Decoder
Other MPG4: LAV Video Decoder
DV: LAV Video Decoder
MPEG1: LAV Video Decoder
MPEG2: LAV Video Decoder
AAC: LAV Audio Decoder
MP3: LAV Audio Decoder
MP2: LAV Audio Decoder
AC3: LAV Audio Decoder
TITLE 1 SOURCE FILES
Video: J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.720p.BluRay.x264-[YTS.AG].mp4
Info: AVC - 900 kbps - 1280x534 - DAR 2.399 - 23.976 fps - Progressive - 2:14:33 hours - 193555 frames
Audio 1: J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.720p.BluRay.x264-[YTS.AG].mp4
Info: AAC LC - 132 kbps - CBR - 2 ch - 48000 Hz - 2:14:33 hours (0 ms delay) - Default
Subs 1: J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.EXTENDED.720p.BluRay.x264-SPARKS-RARBG-ShAaNiG-[YTS.AG].srt
Info: SubRip (SRT) - Suicide.Squad.2016.EXTENDED.720p.BluRay.x264-SPARKS-RARBG-ShAaNiG-[YTS.AG].srt
[MediaInfoLib - v18.03.1]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.720p.BluRay.x264-[YTS.AG].mp4", CacheFolder="C:\Users\Noloc42\AppData\Local\Temp", FrameRate=23.976)
Audio = A2DAudioSource("J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.720p.BluRay.x264-[YTS.AG].mp4", CacheFolder="C:\Users\Noloc42\AppData\Local\Temp")
Video = Video.ConvertToYV12()
Video = Video.AddBorders(0,92,0,94)
Video = Video.Spline16Resize(720,480)
#PullDown: using DGPulldown/HCenc to upsize FPS
AudioDub(Video, Audio)
DIRECTSHOW AUDIO MIXER OPERATIONS:
No LAV Filters mixer ON/OFF adjustment required at runtime
Video Encoding Profile: FFmpeg CBR 1-pass
Target Video FileSize: 7696.1 MB
Encoding Parameters: -i "C:\Users\Noloc42\AppData\Local\Temp\Suicide Squad (2016)_Suicide Squad (2016)_1.avs" -threads 12 -aspect 16:9 -c:v mpeg2video -b:v 7997k -minrate 7997k -maxrate 7997k -bufsize 2000k -dc 10 -y "C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016).m2v"
<11/8/2019 10:23:09 PM>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource - DSS2 mod (LAV Filters on)
Created File: C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016).m2v (7696 MB)
Ouput Video Info: MPEG-2 Video - 7997 kbps - 720x480 - DAR 16:9 - 23.976 fps - Progressive - 2:14:33 hours - 193557 frames
Avg Video Encoding Speed: 495 fps
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016).m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
<11/8/2019 10:24:35 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016).m2v (7696 MB)
Output Video Info: MPEG-2 Video - 7997 kbps - 720x480 - DAR 16:9 - 23.976 fps - Progressive (2:3 Pulldown) - 2:14:33 hours - 193557 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\Noloc42\AppData\Local\Temp\Suicide Squad (2016)_Suicide Squad (2016)_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016)_1.ac3"
<11/8/2019 10:27:22 PM>
WARNING! Errors found during Title 1 Audio Track 1 encoding.
Audio filesize is too small (0 MB)
Backup Audio encoding routine (FFmpeg Safe Mode) is starting ...
START FFMPEG (SAFE MODE) AUDIO ENCODING OPERATIONS (Track 1) - Trial 1/2
FFmpeg Parameters: -threads 12 -i "J:\Ready To ConvertXToDVD 7\DCEU Justice League\Suicide Squad (2016) [YTS.AG]\Suicide.Squad.2016.720p.BluRay.x264-[YTS.AG].mp4" -vn -c:a ac3 -ar 48000 -ab 192k -y "C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016)_1.ac3"
<11/8/2019 10:28:15 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Noloc42\Videos\AVStoDVD DVD Assets\Suicide Squad (2016)_Suicide Squad (2016)_1.ac3 (184.8 MB)
Output Audio Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 2:14:33 hours (0 ms delay)
<11/8/2019 10:28:49 PM>
Process aborted during Title 1 SUBS (Track 1) encoding operations.
For Subtitles issues troubleshooting see Help/FAQ/Subtitles section.
Warning! AVStoDVD Project ended with errors.
Log file created by AVStoDVD Release 2.8.8
Old 9th November 2019, 18:58   #3268  |  Link
manolito
manolito's Avatar
Thanks for posting your log...
I cannot see any problems in your AVS2DVD setup, so I can only make an educated guess. The path+filename string in your Wavi commandline is technically correct, but it is awfully long. In theory the command processor can handle a much longer parameter string, but I do not know if Wavi and/or Aften can handle such a long parameter string.
I suppose that Wavi and Aften parse the commandline and put it into a string variable. And this string variable might be limited in length. My recommendation is to put your source file into a folder with a short name plus rename the file itself to a short name. If this works then my suspicion is correct.
And the other option would be to use "FFmpeg (AviSynth)" instead of "Wavi + Aften" as your audio conversion method. According to your log file FFmpeg has no problems with long parameter strings, and at least for current FFmpeg versions the AC3 encoding quality in FFmpeg is even better than in Aften.
Cheers
manolito
Old 10th November 2019, 01:11   #3269  |  Link
dr_ml422
Thank you manolito!
Thanks. I kinda thought the title name had something to do with it as sometimes it would even tell me it couldn't recognize the file. Then I would load it directly in with the Add+ button and it would take. It's been making some really nice outputs and so I need it in my arsenal. Not too many out there except DVDStyler, ConvertXToDVD, and w/e DVDFab has.
Old 10th November 2019, 03:26   #3270  |  Link
dr_ml422
It worked! I also started it with Admin Rights. I used FFmpeg-AviSynth for the audio. Thanks.
Old 10th November 2019, 04:41   #3271  |  Link
manolito
manolito's Avatar
Great!
Glad I could help...
Old 10th November 2019, 05:06   #3272  |  Link
dr_ml422
Now I found a new bug if at all. I can't edit the titles when more than one title is present in a project. It will come up with all the title's names plus the edited name in the Menu after hitting the Menu Wizard. Is there anything I'm missing here?
Ok so now everything went back to normal after restting the menu. One thing is that if you hit save preferences and have the name of your previous DVD in the Label instead of DVD, it will bring that back again unless you change it again. So it's better to just leave it as DVD because one could easily miss that and then have to do it over.
Old 11th November 2019, 20:20   #3273  |  Link
dr_ml422
I have a question. What can I do in preferences etc... so that on startup or just after, I don't get that "I couldn't find so and so drive" popup? I had a burner I took out and it was still searching for it apperently. Do I have to go into settings somewhere and change something? Thanks.
Old 12th November 2019, 01:33   #3274  |  Link
manolito
manolito's Avatar
Three possible solutions I can think of...
Under AVStoDVD preferences -> Authoring/Burning you can try to remove the offending burner from the dropdown list and save the preferences as default.
Or open RegEdit and go to HKCU/Software/AVStoDVD. There is a value "DVDBurningDrive" in the right pane, you can doubleclick it and delete the burner string.
If all this does not work then there is a nifty little tool by Uwe Sieber called DriveCleanup.
https://www.uwe-sieber.de/files/drivecleanup.zip
This tool will remove all non present drives from the device tree of device manager.
Good luck
manolito
Old 4th December 2019, 06:53   #3275  |  Link
dr_ml422
Thanks Manolito, everything is working fine now, especially after switching to FFmpeg for the Audio encoding. The DVDs are really nice, and I noticed that AVStoDVD preserves menu functionality when using the PC to watch it. I couldn't get that with ConvertXToDVD. I'm experimenting with the subtitle output as the regular Tahoma kinda gives a shadow effect. I switched to Bold and will see soon if it looks clearer.
Old 8th December 2019, 15:02   #3276  |  Link
Mike-uk
Originally Posted by manolito View Post
Damn, another report that the A2D preview is not working under Win10...
You are not the first user with this problem. A2D uses the ancient Quartz.dll for the preview, but I never found something that MS has stopped supporting this method under Win10. I am on Win7-64, and I have no problem with the A2D preview. If there is no way to make the preview work, you know that you can specify a different software player for the preview under preferences? Just no editing...
Here is something you could try:
The batch file in the linked archive restores a couple of AviSynth Registry entries which get altered by installing LAV filters. It may or may not help, but it sure does not do any damage.
https://www.sendspace.com/file/l9zgsz
The other file in the archive is VCF2AVS which you need if you want to use the VDub method to edit your source files.
There's only one single A2D developer, and this is MrC. Unfortunately he does only have very limited time lately to work on AVStoDVD, I try to help out with user support as much as I can, but of course my contributions are limited - I am just an informed user, not a developer.
Cheers
manolito
Hi
any update on getting this working ??
the file you linked is no longer available
Mike
also ive noticed the resulting dvd, pretty much all edges are a bit jaggedy ??
Mike-uk is offline   Reply With Quote
Old 8th December 2019, 16:57   #3277  |  Link
manolito
manolito's Avatar
Originally Posted by Mike-uk View Post
Hi
also ive noticed the resulting dvd, straight edges are a bit jaggedy ??
Unfortunately no update to this issue...
I reuploaded my archive, will be available for 30 days:
https://www.sendspace.com/file/vqeuv2
For the jagged edges this could have several reasons. Aliasing caused by downscaling maybe. Could you upload a short sample? There are some blurring filters which can improve aliasing, but I am not really too familiar with this.
Cheers
manolito
Old 8th December 2019, 17:37   #3278  |  Link
Mike-uk
https://ibb.co/84MSMjh
youll prob need to zoom in to see, but edges have slanted lines
Old 8th December 2019, 17:51   #3279  |  Link
manolito
manolito's Avatar
Yes, I really had to zoom in to 500% to notice...
Try some of the Anti-Aliasing filters from here:
http://avisynth.nl/index.php/Externa...#Anti-aliasing
Old 8th December 2019, 18:14   #3280  |  Link
Mike-uk
ok will take a look, its deffo more noticeable on the tv.
im comparing a bluray to dvd, and just the dvd, and the hd-sd converstion you notice the edges
thanks
Mike
[IMG] code is Off
