7th October 2018, 19:32 | #16201 | Link |
ByteShare
The installed version of MKVToolNix doesn't matter, only the files in the "RipBot\Tools\mkvtoolnix" folder. |
9th October 2018, 16:20 | #16204 | Link |
ByteShare
HEVC 2.9+1 Stable is out: http://msystem.waw.pl/x265/
Release notes (not up at the time of this posting): https://x265.readthedocs.io/en/defau...easenotes.html Update, release notes: https://bitbucket.org/multicoreware/...leasenotes.rst Code:
Version 2.9 =========== Release date - 05/10/2018 New features ------------- 1. Support for chunked encoding :option:`--chunk-start and --chunk-end` Frames preceding first frame of chunk in display order will be encoded, however, they will be discarded in the bitstream. Frames following last frame of the chunk in display order will be used in taking lookahead decisions, but, they will not be encoded. This feature can be enabled only in closed GOP structures. Default disabled. 2. Support for HDR10+ version 1 SEI messages. Encoder enhancements -------------------- 1. Create API function for allocating and freeing x265_analysis_data. 2. CEA 608/708 support: Read SEI messages from text file and encode it using userSEI message. Bug fixes --------- 1. Disable noise reduction when vbv is enabled. 2. Support minLuma and maxLuma values changed by the commandline. Last edited by byteshare; 9th October 2018 at 20:16. |
10th October 2018, 01:50 | #16205 | Link | |
Time for another auto update, me thinks |
10th October 2018, 08:15 | #16206 | Link |
FPS help higher power client pc less than lower power sever
Distributed encoding help
Not sure whats going on. encoding dvd ep with denoise x264. My main pc: (the client) 40%-50% cpu getting 18.x FPS. windows 10 fx-8320 16gb ddr3 Radeon rx 580 x 4gb other pc: Hitting 90%-100% cpu getting 30.x FPS. windows 7 fx-6300 8gb ram r7 260x 2gb |
10th October 2018, 09:14 | #16207 | Link |
Also Have a few other things I would like help with.
I am coming from handbrake to this is there anyway to find out how to configure my same settings from there to ripbot? Is there any way when batch job creation to have 2 audio streams. I like to x.x copy stream from my lossless / 5.1, then an 2.0 AAC-LC stream. This makes nice for plex streaming. Seems the limitation is in the fact that it needs to demux before you can mess with the audio settings. How does one turn on deblocking? I would set tune settings in handbrake that turned on deblocking then i would use filter tab deblocking too not sure if they are diffent like pre/post filters. Also last note, the deinterlace seems to round up 24.x to 25 and 29.x to 30. Is this correct or am i messing with something i know nothing about? |
10th October 2018, 10:34 | #16208 | Link | |
How many servers in DE are you using per pc ?? Just keep adding more servers, until you reach cpu 100%. |
10th October 2018, 16:23 | #16209 | Link |
ByteShare
Honestly, neither are that important, since for MKVToolNix it doesn't have updates that should impact RipBot (only if you were actually using it for some specific uses outside of RipBot) and for HEVC the changes shouldn't affect 99% or more of users unless they have more back-end stuff they didn't include in the notes.
10th October 2018, 16:32 | #16210 | Link | |
ByteShare
Personally, I still use an old version of HB to do FDK AAC-HE/LC audio and then use a batch script to mux the audio (from HB), subs from source file (keeps the MKV title info), and the video (from RipBot) at the end into one file. Deblocking in HB isn't that great. Try using the Denoise features, such as MDegrain2, should reduce noise and size without a noticable impact on quality more than any of the HB settings. RipBot uses AVISynth, so you can use any of the RipBot filters or even use outside ones, which is much more powerful than the built-in filters for HB. For Deinterlace, in the settings make sure you have "QTGMC deinterlacer instead of Yadif" checked. QTGMC is much more powerful than any of the deinterlacers in HB and more accurate. With QTGMC in batch, just select "TFF - > 25 FPS/30 FPS" and the filter figures out the rest and should give you the correct frame rate. The only exception is sometimes with variable frame rate files (usually anime) you might need to get the time codes from the original file and mux them back in, but this is very rare to come accross. |
10th October 2018, 19:26 | #16211 | Link | |
Go settings ->main tab "Use multiple processing threads" set value to 0
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
10th October 2018, 19:56 | #16212 | Link | |||
MDegrain2 works nice but slows things down. I have yet to play with naruto in ripbot im sure some setting will work for me, I was just thinking i knew what i needed to do and it was fast in handbrake it had to be much faster with 6 pc on DE. I am getting 170ish FPS atm doing dragon ball. So very nice. I will buying this guy beer for his coding. |
10th October 2018, 20:09 | #16213 | Link |
I do have problems with Deinterlace tho. I set up some stuff to run last night. I have old stuff like Talespin and Ducktales. anyways I used the TFF - > 25 FPS/30 FPS. This worked fine for most of the ducktales stuff but i had 2 issues.
1. the ep's listed as frame rate 24.x FPS, original frame rate 29.x, frame rate mode variable and scan type interlaced would let me set the TFF - > 25 FPS/30 FPS. Some Ep's about half had deinterlacing disabled. There info does not have scan type set as interlaced, and frame rate is 29.xx or 28.x, with original frame rate of 29.970, frame rate mode variable. This are ripped right from the discs. This vides have the interlacing lines when things move so I know they are. How can I deinterlace them if its disabled? 2. I had no issue with deinterlace these videos in handbrake but after deinterlace videos with ripbot the audio is out of sync too. I have tryed the inverse telecine to with and without decimate. I still get audio sync issues. Would like to learn to fix this. The DE make this app so very strong. |
10th October 2018, 20:18 | #16214 | Link |
You will have to first upload some 50-100 MiB sample so we could find solution for your particular files. It is hard to suggest something when we do not have access to you video files.
10th October 2018, 21:54 | #16215 | Link | ||
ByteShare
If you're getting ~170 FPS, IMO you're not compressing it enough or doing enough AVISynth LOL, I don't mind slower FPS (like 30-40) on DVDs for a better video and filesize. Quote:
-I do this via batch files but the command line looks something like this (.bat): Extract: (not sure how to do this via the GUI) Code:
FOR %%A IN (*.mkv) DO "C:\Program Files\MKVToolNix\mkvextract.exe" timecodes_v2 "%%A" "0:%%A_timecodes.txt" Code:
FOR %%A IN (*.mkv) DO "C:\Program Files\MKVToolNix\mkvmerge.exe" -o "%%A-Fixed.mkv" --timecodes "0:%%~dpnA.mkv_timecodes.txt" "%%~A" 2. It worked in HandBrake because it handles frames differently. Last edited by byteshare; 10th October 2018 at 22:01. |
11th October 2018, 23:22 | #16216 | Link |
I think this is a very annoying issue with Ripbot that should be fixed.
https://youtu.be/uxCkIvUdo0M Evidently, if you are converting TV shows, even if you select a particular M2TS file, Ripbot will not default to the playlist you specifically picked (should be assumed from the file name - select the one with the matching name by default). Super annoying. Had to redo everything. Would it be possible to select the correct default if you pick the file manually as shown in the video? |
11th October 2018, 23:59 | #16217 | Link | |
ByteShare
12th October 2018, 09:52 | #16218 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th October 2018 at 11:24. |
12th October 2018, 21:50 | #16219 | Link | ||
Error encoding a few Web-DL
I was converting the Man in the High Castle, and was able to successfully do most, but am having an error with two of them. I have uploaded both log files, can you please tell me where the problem is and if it can be fixed?
14th October 2018, 07:54 | #16220 | Link | |
