Old 19th February 2017, 20:28   #161  |  Link
Daemon404
Binaries for 1.1 are in the OP.
Somehow I'm not dead.
Daemon404 is offline   Reply With Quote
Old 19th February 2017, 23:29   #162  |  Link
KingLir
Thanks! Can't build on macOS, getting this after autogen and configure:
$ make
CXX src/core/compat.lo
CXX src/core/d2v.lo
CXX src/core/decode.lo
src/core/decode.cpp:450:45: warning: 'codec' is deprecated
[-Wdeprecated-declarations]
if (dctx->fctx->streams[i]->codec->codec_type == AVMEDIA...
/usr/local/Cellar/ffmpeg/3.2.4/include/libavformat/avformat.h:893:21: note:
'codec' has been explicitly marked deprecated here
AVCodecContext *codec;
src/core/decode.cpp:491:13: warning: 'avcodec_decode_video2' is deprecated
avcodec_decode_video2(dctx->avctx, out, &av_ret, &dctx->inpkt);
/usr/local/Cellar/ffmpeg/3.2.4/include/libavcodec/avcodec.h:4812:5: note:
'avcodec_decode_video2' has been explicitly marked deprecated here
int avcodec_decode_video2(AVCodecContext *avctx, AVFrame *picture,
/usr/local/Cellar/ffmpeg/3.2.4/include/libavcodec/avcodec.h:1578:16: warning:
'convergence_duration' is deprecated [-Wdeprecated-declarations]
typedef struct AVPacket {
/usr/local/Cellar/ffmpeg/3.2.4/include/libavcodec/avcodec.h:1630:13: note:
'convergence_duration' has been explicitly marked deprecated here
int64_t convergence_duration;
src/core/decode.cpp:510:25: warning: 'avcodec_decode_video2' is deprecated
int r = avcodec_decode_video2(dctx->avctx, out, &av_ret...
6 warnings generated.
CXX src/vs/applyrff.lo
src/vs/applyrff.cpp:192:36: error: expected expression
data->fields.push_back({ i, Progressive });
src/vs/applyrff.cpp:193:36: error: expected expression
src/vs/applyrff.cpp:196:40: error: expected expression
src/vs/applyrff.cpp:197:40: error: expected expression
src/vs/applyrff.cpp:200:44: error: expected expression
src/vs/applyrff.cpp:201:44: error: expected expression
src/vs/applyrff.cpp:207:36: error: expected expression
data->fields.push_back({ i, tff ? Top : Bottom });
src/vs/applyrff.cpp:208:36: error: expected expression
data->fields.push_back({ i, tff ? Bottom : Top });
src/vs/applyrff.cpp:211:40: error: expected expression
9 errors generated.
KingLir is offline   Reply With Quote
Old 20th February 2017, 03:30   #163  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
New version works great!
I have to remind myself to take care when filenames contain spaces.
Cary Knoop is offline   Reply With Quote
Old 20th February 2017, 12:56   #164  |  Link
jackoneill
unsigned int
jackoneill's Avatar
9 errors generated.
Oops. Try this:
make clean && ./configure CXXFLAGS='-std=c++11' && make
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 20th February 2017, 13:07   #165  |  Link
KingLir
Originally Posted by jackoneill View Post
Oops. Try this:
Thanks! Works.
Old 20th May 2018, 22:17   #166  |  Link
sl1pkn07
Pajas Mentales...
this is ok with the latest ffmpeg 4?
diff --git a/src/core/d2v.hpp b/src/core/d2v.hpp
index f87b1a0..ecdae78 100644
--- a/src/core/d2v.hpp
+++ b/src/core/d2v.hpp
@@ -68,7 +68,7 @@ static const int idct_algo_conv[8] = {
     FF_IDCT_AUTO,
     FF_IDCT_AUTO,
     FF_IDCT_AUTO,
-    FF_IDCT_XVIDMMX,
+    FF_IDCT_XVID,
     FF_IDCT_SIMPLEMMX
diff --git a/src/core/decode.cpp b/src/core/decode.cpp
index b563697..11a0fef 100644
--- a/src/core/decode.cpp
+++ b/src/core/decode.cpp
@@ -242,12 +242,6 @@ decodecontext *decodeinit(d2vcontext *dctx, int threads, string& err)
     /* Set the thread count. */
     ret->avctx->thread_count = threads;
-     * Enable EMU_EDGE so that we can use buffers that are
-     * not padded by 32 pixels.
-    ret->avctx->flags |= CODEC_FLAG_EMU_EDGE;
     /* Use refcounted frames. */
     ret->avctx->refcounted_frames = 1;
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 2nd June 2018, 21:31   #167  |  Link
sl1pkn07
Pajas Mentales...
done in upstream
Old 24th July 2018, 23:35   #168  |  Link
lansing
Can this plugin works with D2VWitch to index video like this so I can skip a step?
core.d2v.Source(r"my_video.ts")
Also I have problem opening d2v made by dgindex when the video path in the d2v is non English because the dgindex d2v is in ANSI encoding instead of utf-8.
Old 25th July 2018, 12:24   #169  |  Link
jackoneill
unsigned int
jackoneill's Avatar
That would be nice. It's on my to do list.
That's unlikely to be fixed in any way. Does DGIndex have a feature you need that D2V Witch doesn't have?
Old 25th July 2018, 15:02   #170  |  Link
lansing
Yeah I know this is a dgindex problem that have been existed since the beginning. I just wanna see if it would be easy enough to fix it on this end.
Old 25th July 2018, 16:44   #171  |  Link
ChaosKing
You don't have to use the full path in d2v. Just uncheck "Use full paths" in options in dgindex and only the file name will be stored.
Old 25th July 2018, 21:34   #172  |  Link
lansing
The problem is still there if my file name is non English.
Old 26th July 2019, 09:57   #173  |  Link
lansing
I'm trying to stress my new Ryzen 3900x with this filter, but I was never able to get cpu utilization over 25%. And setting threads count to 10 is 200fps faster than leaving it at auto, is there something wrong?
Old 17th July 2021, 15:28   #174  |  Link
Selur
Selur's Avatar
Trying to build d2vwitch using:
### d2vwitch
if echo "$args" | grep -q -i -w -E 'all|d2vwitch'
then
  mkdir build
  cd build
  top="$PWD"
  export PATH="$top:$PATH"
  export PKG_CONFIG_PATH="$top/libs/lib/pkgconfig"
  git clone --depth 1 https://github.com/dubhater/D2VWitch
  git clone --depth 1 https://github.com/FFmpeg/FFmpeg
  git clone --depth 1 https://github.com/vapoursynth/vapoursynth
  build_nasm
  cd FFmpeg
  ./configure --prefix="$top/libs" \
    --enable-gpl \
    --enable-version3 \
    --disable-encoders \
    --disable-muxers \
    --disable-outdevs \
    --disable-programs \
    --disable-doc \
    --disable-debug \
    --disable-xlib \
    --disable-sdl2 \
    --extra-cflags="-ffunction-sections -fdata-sections"
  make $MAKEFLAGS
  make install
  cd ../D2VWitch
  autoreconf -if
  vapoursynth_CFLAGS="-I../vapoursynth/include" \
  vapoursynth_LIBS=" " \
  LDFLAGS="-Wl,--gc-sections" \
  ./configure
  make $MAKEFLAGS
  strip d2vwitch
  cp -f d2vwitch ../..
  cd ..
  cat <<EOL >../d2vwitch-sources.txt
$(git -C D2VWitch rev-parse HEAD)
$(git -C vapoursynth rev-parse HEAD)
$(git -C FFmpeg rev-parse HEAD)
EOL
  cd ..
  rm -rf build
fi
see: https://github.com/Selur/HybridDeploy
problem is, the build stops at:
checking for vapoursynth... no
configure: error: Package requirements (vapoursynth) were not met:
No package 'vapoursynth' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables vapoursynth_CFLAGS
and vapoursynth_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Any idea what am I missing? This did work before,..
Cu Selur
Old 18th July 2021, 20:00   #175  |  Link
jackoneill
unsigned int
jackoneill's Avatar
I think you need to put something that is not whitespace in vapoursynth_LIBS. „-L.” should be harmless.
Old 19th July 2021, 04:48   #176  |  Link
Selur
Selur's Avatar
Thanks for the suggestion, but using "-L." sadly didn't change much:
+ cd ../D2VWitch
+ autoreconf -if
configure.ac:17: installing './compile'
configure.ac:10: installing './config.guess'
configure.ac:10: installing './config.sub'
configure.ac:6: installing './install-sh'
configure.ac:6: installing './missing'
Makefile.am: installing './depcomp'
+ vapoursynth_CFLAGS=-I../vapoursynth/include
+ vapoursynth_LIBS=-L.
+ LDFLAGS=-Wl,--gc-sections
+ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for grep that handles long lines and -e... /bin/grep
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for _LARGEFILE_SOURCE value needed for large files... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
full log: https://rentry.co/wwf6b
it stops with the same error.
Cu Selur
Old 21st July 2021, 20:38   #177  |  Link
jackoneill
unsigned int
jackoneill's Avatar
  cd ../D2VWitch
  autoreconf -if
  ./configure
Perhaps you need a backslash on the empty line as well. Or just put the assignments and the call to configure on the same line. (And use vapoursynth_LIBS="-L.")
Old 22nd July 2021, 15:33   #178  |  Link
Selur
Selur's Avatar
cd ../D2VWitch
   autoreconf -if
   vapoursynth_CFLAGS="-I../vapoursynth/include" vapoursynth_LIBS="-L." LDFLAGS="-Wl,--gc-sections" ./configure
   make $MAKEFLAGS
get's me further but still fails, see: https://paste.ee/p/7KJ4O
Old 23rd July 2021, 16:04   #179  |  Link
jackoneill
unsigned int
jackoneill's Avatar
I guess it's time to update that code to match the changes in ffmpeg.
Old 12th October 2021, 10:35   #180  |  Link
Jukus
https://github.com/dwbuiten/d2vsource/issues/48
Jukus is offline   Reply With Quote
d2v, dgindex, vapoursynth
