Old 9th January 2020, 14:37   #58341  |  Link
mclingo
do you know is this problem occurs for both outputting in HDR format and non HDR format for tone mapping, i'm not outputting in HDR format at the moment due to the AMD BT2020 APi issue.
Old 9th January 2020, 20:08   #58342  |  Link
Alexkral
The switch works the same when outputting in HDR, but the problem with AMD HDR will be the same as well.
Old 11th January 2020, 12:42   #58343  |  Link
Magik Mark
Guys,
Can you see a difference between NGU AA and Nvidia AA? Need you thought on this. Thanks
Sent from my iPhone using Tapatalk
Old 11th January 2020, 13:51   #58344  |  Link
i'm pretty sure everyone can see the difference between an image scaler and an video game anti aliasing algorithm. they are fundamental different.
Old 11th January 2020, 16:04   #58345  |  Link
Siso
Soul Seeker
Siso's Avatar
I read in a few forums that enabling 10 bit (8 bit+frc) in nvidia control panel, could affect madvr's dithering. Is it true, and will it affect a calibration with displaycal?
Old 11th January 2020, 18:39   #58346  |  Link
yes there are settings that effect madVR dithering but you don't have have an option for 8 bit+FRC in NV control center.
and yes your end device could behavior differently when a 10-12 bit signal is send instead of a 8 bit signal but that should be rare very rare. this would effect your calibration.
Old 11th January 2020, 18:59   #58347  |  Link
Siso
Soul Seeker
Siso's Avatar
In short, I'll stay to 8 bit.
Old 11th January 2020, 21:28   #58348  |  Link
No need to quote here, if you're not answering a question (thus notifying them of a reply) and their post is directly above yours, there's no point. You're increasing the thread space for nothing.
Old 13th January 2020, 03:28   #58349  |  Link
shimarin
that’s good to know.
shimarin is offline   Reply With Quote
Old 13th January 2020, 04:35   #58350  |  Link
Personally I find education is most useful when put into practice.
Old 13th January 2020, 04:44   #58351  |  Link
nsnhd
I have now a full 10-bit path madVR-GPU(gtx 1060)-Display(4k monitor). Is there any disadvantage which I have to pay attention to ?
nsnhd is offline   Reply With Quote
Old 13th January 2020, 06:07   #58352  |  Link
No inherent disadvantages, just most panels are better off fed 8-bit.
Old 13th January 2020, 09:35   #58353  |  Link
totalz
This might be off-topic a bit, wondering if I can enable logging by MadVR to help me debug random hdmi signal loss issue. ATM, I cannot pin point the device/component that's causing the problem. Apparently, there's no Windows event to indicate there's a Windows problem, but I can't say I have much confidence in M$ either.
So any advice on debugging the issue is appreciated. HDMI cables are checked, no problem there.
System: Asus P6TD + X5660 + 18GB ram + AMD RX570(4GB)
Setup: Windows 10 x64 (1709)
Display: Samsung Q70R (wLD)
totalz is offline   Reply With Quote
Old 13th January 2020, 09:41   #58354  |  Link
nsnhd
In general, does the extra 2-bit processing affect rendering time, upscaling refinement, artifact removal, HDR tone mapping etc. ? Making them better or worst, regarding madVR, inside the GPU and the display ?
Old 13th January 2020, 10:27   #58355  |  Link
Asmodian
No, madVR always works with 16 bit surfaces internally and using 32 bit math. It dithers to the output bit depth as the very last step.
madVR options explained
Old 13th January 2020, 11:53   #58356  |  Link
nsnhd
So, can I assume that output from madVR is the same, the rest is how the GPU and the display process and output 10-bit.
Old 13th January 2020, 13:17   #58357  |  Link
el Filou
el Filou's Avatar
It's really hard to notice a difference in real content between madVR's 8-bit and 10-bit output especially in motion, so if you do then yes, it's the GPU or the display.
Old 14th January 2020, 07:36   #58358  |  Link
glc650
Originally Posted by tyguy View Post
Does anybody else have issues with frame smoothing where the credit crawl at the end of movies flickers?
I do. Soon as I turn smooth motion off it goes away.
glc650 is offline   Reply With Quote
Old 14th January 2020, 08:00   #58359  |  Link
stefanelli73
I own an AMD 5700XT, but I can't see GEMINI MAN with Madvr tone mapping, even by lowering the CHROMA UPSCALING to CUBIC, I can only see it in hdr pasthrough, where the rendering drops to 12ms ... has someone with my same video card found a solution?
stefanelli73 is offline   Reply With Quote
Old 14th January 2020, 13:03   #58360  |  Link
mclingo
what exactly do you mean you cant see it, if you are just getting a black screen?
