Old 28th August 2019, 21:16   #6781  |  Link
Zathor
2911 [OneClick]             fixed an error when switching profile settings. Bug #946
2910 [Updater]              added support for Visual C++ 2019 redist files
2909 [OneClick]             fixed not applying "automatic deinterlacing" filters. Bug #945 (regression of 2887)
Old 29th August 2019, 00:10   #6782  |  Link
Zetti
Good to see you back Zathor.
With some of the newest versions of DGIndexNV, the Crop option is grayed out.
Old 29th August 2019, 00:30   #6783  |  Link
tebasuna51
tebasuna51's Avatar
Work for me (DGIndexNV 2053.169), check the 'Nvidia Crop & Resize' in the image, add Crop and Resize in I/O tab, and in Script tab is reflected fine, example:
DGSource("D:\Temp\test.dgi", ct=24, cb=24, cl=0, cr=0, rw=720, rh=384)
Old 29th August 2019, 09:34   #6784  |  Link
Zetti
I was tired, i meant of course the Deinterlacer option.
Old 30th August 2019, 01:15   #6785  |  Link
tebasuna51
tebasuna51's Avatar
You are right, even after execute 'Analyse' and detected like 'Interlaced' the Nvidia Deinterlacer remains grayed out.
Old 30th August 2019, 05:01   #6786  |  Link
imsrk48
imsrk48's Avatar
[Feature Request] Add Option for Keep Screen on During Encoding.
Sent from my LG-M700 using Tapatalk
imsrk48 is offline   Reply With Quote
Old 3rd September 2019, 06:58   #6787  |  Link
imsrk48
imsrk48's Avatar
[BUG] MeGUI Not Supporting MJPEG Codec.
Please Fix This and If MJPEG Not Supported in MeGUI Please Support That.
Old 3rd September 2019, 10:20   #6788  |  Link
Support for encoding or for decoding?
Decoding MJPEG is supported. Either via AviSource, if you installed a VfW codec in your Windows, or via indexer (both FFMS2 and L-SMASH Works use libav cores).
Encoding to MJPEG AVI is not quite the main purpose of MeGUI, it is not a very efficient codec. I doubt many people would chose MJPEG to encode a video copy of a cinematic movie from a DVD or Blu-ray source. To produce an AVI with MJPEG video, using e.g. VirtualDub2 is a lot more convenient.
Old 9th September 2019, 13:20   #6789  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Originally Posted by zetti View Post
good to see you back zathor.
+1 .
LouieChuckyMerry is offline   Reply With Quote
Old 9th September 2019, 13:31   #6790  |  Link
imsrk48
imsrk48's Avatar
Okay Sir Thanks
Old 26th September 2019, 18:52   #6791  |  Link
Barough
Barough's Avatar
MediaInfo v19.09 (https://mediaarea.net/en/MediaInfo/Download/Windows)
x265 v3.2 (https://forum.doom9.org/showpost.php...postcount=7053)
Old 27th September 2019, 13:01   #6792  |  Link
imsrk48
imsrk48's Avatar
MeGUI Taking too Much time to Opening or Encoding AAC DD5.1 (ADTS codec)
Old 27th September 2019, 14:07   #6793  |  Link
tebasuna51
tebasuna51's Avatar
Please put your log like this:
---[NoImage] LoadPlugin("C:\Portable\MeGUI64\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavAudioSource("D:\Test\AudioD\Samples\ac3\6a321.ac3")
---[NoImage] # detected channels: 6
---[NoImage] # detected channel positions: 3/2/0.1
---[NoImage] return last
--[Information] [27/09/2019 15:02:32] Command line used: --ignorelength --threading -V 100 - -o "{0}"
--[Information] [27/09/2019 15:02:32] AviSynth script environment opened
--[Information] [27/09/2019 15:02:33] Script loaded
--[Information] [27/09/2019 15:02:33] Output Decoder
---[Information] [27/09/2019 15:02:33] Channels: 6
---[Information] [27/09/2019 15:02:33] Bits per sample: 32
---[Information] [27/09/2019 15:02:33] Sample rate: 48000
--[Information] [27/09/2019 15:02:33] Job command line: C:\Portable\MeGUI64\tools\qaac\qaac.exe --ignorelength --threading -V 100 - -o "C:\tmp\6a321_new.m4a"
--[Information] [27/09/2019 15:02:34] Process started
--[Information] [27/09/2019 15:02:34] Standard output stream
--[Information] [27/09/2019 15:02:34] Standard error stream
---[Information] [27/09/2019 15:02:34] qaac 2.68, CoreAudioToolbox 7.10.9.0
---[Information] [27/09/2019 15:02:34] 6a321_new.m4a
---[Information] [27/09/2019 15:02:34] AAC-LC Encoder, TVBR q100, Quality 96
---[Information] [27/09/2019 15:02:34] 961536/-1 samples processed in 0:00.546
---[Information] [27/09/2019 15:02:34] Overall bitrate: 93.8726kbps
---[Information] [27/09/2019 15:02:34] Optimizing...done
--[Information] [27/09/2019 15:02:35] MediaInfo
Old 28th September 2019, 07:34   #6794  |  Link
imsrk48
imsrk48's Avatar
I'm unable to post .log files using Tapatalk app
Old 29th September 2019, 12:28   #6795  |  Link
imsrk48
imsrk48's Avatar
How Buddy?
Old 30th September 2019, 00:01   #6796  |  Link
tebasuna51
tebasuna51's Avatar
How Buddy?
Check in your ...\megui\logs\ folder.
Old 30th September 2019, 02:54   #6797  |  Link
imsrk48
imsrk48's Avatar
that's not my question I'm asking how to upload .log file via Tapatalk app
Old 30th September 2019, 07:58   #6798  |  Link
Why Tapatalk? Can't you use a normal PC web browser? Or is your PC where MeGUI runs "offline", not connected to the internet?
Old 30th September 2019, 08:00   #6799  |  Link
imsrk48
imsrk48's Avatar
Yes that is runs offline but this time i have connected net
Old 3rd October 2019, 05:25   #6800  |  Link
imsrk48
imsrk48's Avatar
Sir I Want to Post My Log File But I Don't Know where to do this in web browser
