7th March 2018, 17:08 | #5141 | Link |
Official ways to control the player:
- keyboard and mouse - command line - web interface - MPCAPI_COMMAND (mpcapi.h) If something of this does not work correctly, then tell me exactly what. If there are problems with the playback of the network stream, then try LAV Slplitter Source.
7th March 2018, 19:31 | #5142 | Link | |
EDIT: I enabled UDP/HTTP since I disabled it and now the issues are fixed. So, its an issue with the internal filter used by MPC-BE when playing a HTTP stream. I hope that it is fixed in a later build. EDIT2: Now its back to not working. Last edited by Zero3K; 7th March 2018 at 20:08. |
7th March 2018, 23:44 | #5143 | Link |
just noticed something odd with BE which I've just reinstalled, latest version. When I play a HDR movie it should look washed out as when not used in conjunction with MADVR it doesnt trigger HDR mode on my TV, however when i PLAY HDR movies they look very similar but not quite as good as when I play then in HDR through MADVR, has something been added to MPCBE to convert HDR to SDR as standard, if so how to do turn this off?
edit - found it, if you enable direct 3d and 10 bit mode it reverts back, how long has the EVR custom presenter been able to convery HDR to SDR, is this a recent thing? edit 2 - reinstalled 1.5.0, back to normal, reinstalled latest again, same issue so it started with this version, playbag is also a bit choppy for me so i'm staying on 1.5.0 Last edited by mclingo; 8th March 2018 at 00:27. |
8th March 2018, 04:46 | #5144 | Link | |
I do not understand why you should turn off HDR to SDR conversion for EVR-CP.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 8th March 2018 at 04:49. |
8th March 2018, 09:45 | #5145 | Link |
About chapter markers again. I have one Blu-Ray that is always loaded by BE using the same mpls and chapter markers do not work.
However, MPC-BE also offers (=> navigation) loading another mpls and with this chapter markers show up. Is there a way to 'force' BE to always use the other better playlist ?? |
8th March 2018, 11:05 | #5146 | Link |
MPC-BE load playlist with "longest" duration.
8th March 2018, 11:18 | #5147 | Link |
I am aware of that but MPC-BE lists two different playlists for the same file (same duration) and with the always loaded playlist chapter markers do NOT work - with the other they work.
Why does MPC-BE prefer the 'faulty' playlist ? |
8th March 2018, 12:08 | #5148 | Link |
I switched to internal filters, MPC audio renderer and EVR renderer but no change in File menu still usually freezing, ffdshow is in external but not ticked. I thought it might have something to do with the network location of the recent files but that doesn't seem to be the case. I tried deleting the recent file registry keys, deleting the player folder and reinstalling, unticking the remember recent files option but no change.
8th March 2018, 14:39 | #5149 | Link | |
Although I mostly don't use File menu at all (only if I have to save resynced subtitles), but for me always the network drives freezed it for couple of seconds. (Otherwise I just open files from a file manager or via the android remote.)
8th March 2018, 15:24 | #5150 | Link | |
Assume it does nothing with none HDR material then, is there a performance hit to GPU/CPU? just interested more then anything. |
8th March 2018, 15:36 | #5151 | Link |
Converting HDR to SDR works for HDR streams only.
9th March 2018, 05:29 | #5153 | Link |
Use option "Disable 'Open Disk' menu".
9th March 2018, 09:46 | #5155 | Link | |
9th March 2018, 11:17 | #5156 | Link | |
I think we can make the "Open Disk" menu always active. Then it will slow down when entering "Open Disk", not "File". We will discuss this.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 9th March 2018 at 11:20. |
9th March 2018, 13:38 | #5157 | Link |
Sounds good, I think that's how MPC-HC works (you can take a look).
9th March 2018, 18:34 | #5158 | Link |
I looked at the code. The standard menu does not allow me to do as I wanted.
9th March 2018, 18:43 | #5159 | Link |
I just tried it out, I have 1 network drive, 2 different drives in the laptop and 1 USB drive:
1. wake up the laptop from sleep 2. start MPC-BE without any files 3. hit File menu short time to wait to be opened (~5 sec) 4. close MPC-BE 5. start MPC-BE without any files again 6. hit File menu it instantly opens up So, in my case, the OS (Win8.1) caches that the network drive is available so next time it won't wait for it (confirmed with Total Commander).
10th March 2018, 03:06 | #5160 | Link |
cosmic entity
hy there,
any chance of integrating something like the built in audio switcher in mpchc? The ability to manual set the channels is the only one thing im missing from mpcBE.. It is, for me, the only way to get the rear speaker working when using stereo sources..i like to have them all working when watching stereo sources.. i know its kinda a personal thing, but my soundcard died and the onboard soundcard does not have the option to propper upsample.. im just curíous if you guys think about adding something like this.. anyway, great player and development so far.. greetings |
