Old 5th March 2018, 23:58   #281  |  Link
candela
Originally Posted by nalor View Post
Hi!
I've added BLURAY to the list of meaningless volumenames - but I don't think it makes sense to add the other names also. Currently there are ~1100 entries in the onlinedatabase and the other titles are not in the list, so I don't think it's really necessary to add them.
Same for the meta-titles - none of them from your list above is in my list and I don't think it's helpful to add such special titles to the list.
When I check the titles in the database I also find a couple that really look meaningless to me - but those are specials that only occur 1 time.
XML creation: changed the behaviour, MetaXML is always created now - but currently I have no plans to allow a manual upload into the online database.
Batchfiles: I will think about it, maybe when the onlinedb is really functional and the synchronisation is correctly working
Automatic GetMeta: will also think about it - but honestly I still don't know why we should collect this data at all?
i've encountered all those labels but not that many times, it doesn't really matter for findvuk, i use the list to know when i should use a manual title instead of metatitle, e.g. _NONAME_ [Nirvana - Nevermind] instead of _NONAME_ (BLU-RAY AUDIO)
xmls could also be posted also on the forum here for example. What happens when XML upload fails (e.g. temp internet problem), how is the data uploaded again without processing the disc again?
(some) of the information allows keys to be derived from other discs, e.g. same MD5 means same MK, even when the movie can be completely different. Also the initial idea was for Relight's database to become a bluray release database on the front end (with keys only in the background). It would be created without requiring manual effort , except for inserting a disc and running findvuk (or any program generating the xml)
candela is online now   Reply With Quote
Old 6th March 2018, 20:47   #282  |  Link
nalor
Originally Posted by candela View Post
problem still exists in version 1.09 for MetaTitles. if the second disc does not have any metatitles, it's using the metatitle from the previous disc
too many bugs nalor, more testing ! better check all the other fields in this scenario
Published 1.10 - but as always: with little to none testing
Old 24th March 2018, 01:48   #283  |  Link
Jdogzz
FindVUK Stalls After Memdump Complete
Hi, I've been using the new version of FindVUK, 1.10, and it currently seems to be stalling on a single disc. Below is the log, and the dump file is available here:
http://www.mediafire.com/file/nrqzte...S_Season_2.dmp
2018-03-23 17:39:26 # 0 # [I] main / legacy /  ----------- FindVUK 1.10 -----------
2018-03-23 17:39:26 # 0 # [I] main / legacy / Operating System: Windows 10
2018-03-23 17:39:26 # 1 # [I] main / legacy / SettingsFile: >C:\Users\myusername\Useful Programs\FindVUK\config\FindVUK.ini<
2018-03-23 17:39:26 # 13 # [I] main / legacy / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-03-23 17:39:26 # 13 # [I] main / legacy / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-03-23 17:39:26 # 13 # [I] main / legacy / Max. ScreenSize 180 x 54
2018-03-23 17:39:26 # 13 # [I] main / legacy / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-03-23 17:39:26 # 13 # [I] main / legacy / M1 - New BufferSize 120 x 9001
2018-03-23 17:39:26 # 13 # [I] main / legacy / Mx2 - New ScreenSize 120 x 50
2018-03-23 17:39:26 # 17 # [I] main / legacy / Information! Passkey detected >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 17:39:26 # 22 # [I] main / legacy / Tested Passkey Version >9.2.1.1< found
2018-03-23 17:39:26 # 22 # [I] main / legacy /  >>> everything should work as expected!
2018-03-23 17:39:26 # 22 # [I] main / legacy / Couldn't read PasskeyLogDir from registry - take the info from the ini file
2018-03-23 17:39:26 # 23 # [I] main / legacy / Information! No MediaPlayer detected!
2018-03-23 17:39:26 # 24 # [I] main / legacy / Information! DVDfab detected >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-23 17:39:26 # 24 # [I] main / legacy / Information! DVDfab MainApp is not valid! >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-23 17:39:26 # 24 # [I] main / legacy / Passkey is preferred and available!
2018-03-23 17:39:26 # 24 # [I] main / legacy / Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 17:39:26 # 24 # [I] main / legacy / Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2018-03-23 17:39:26 # 25 # [I] main / legacy / KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2018-03-23 17:39:26 # 25 # [I] main / legacy / KEYDB-Backup-Path:    >C:\Users\myusername\Useful Programs\FindVUK\VUKbackup\<
2018-03-23 17:39:26 # 25 # [I] main / legacy / ProcDumpFile:         >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe<
2018-03-23 17:39:26 # 25 # [I] main / legacy /  --- PART 1 --- GET VUK ---
2018-03-23 17:39:26 # 33 # [I] main / legacy / No running application process discovered
2018-03-23 17:39:26 # 34 # [I] main / legacy /  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 17:39:30 # 4262 # [I] main / legacy / Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2018-03-23 17:39:33 # 7275 # [I] main / legacy / Drive opened
2018-03-23 17:39:33 # 7275 # [I] main / legacy / DiscType detected >Blu-ray BDMV<
2018-03-23 17:39:33 # 7276 # [I] main / legacy / Volume Label detected >VGHS_Season_2<
2018-03-23 17:39:33 # 7276 # [I] main / legacy / DriveLetter detected >F<
2018-03-23 17:39:34 # 7982 # [I] main / legacy / Detected CopyProtections AACS >1< BD+ >0<
2018-03-23 17:39:42 # 16201 # [I] main / legacy / DiscID found >C8AB0CEE20B0827D356CDB1E9AEC639AD7E035DC<
2018-03-23 17:39:43 # 17407 # [I] main / legacy / Passkey got VUK - create memdump now!
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>>
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>> ProcDump v8.0 - Writes process dump files
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>> Copyright (C) 2009-2016 Mark Russinovich
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>> Sysinternals - www.sysinternals.com
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>> With contributions from Andrew Richards
2018-03-23 17:39:43 # 17510 # [I] main / legacy /  DUMP >>> [17:39:43] Dump 1 initiated: C:\Users\myusername\Useful Programs\FindVUK\dump\C8AB0CEE20B0827D356CDB1E9AEC639AD7E035DC_VGHS_Season_2.dmp
2018-03-23 17:39:44 # 17711 # [I] main / legacy /  DUMP >>> [17:39:44] Dump 1 writing: Estimated dump file size is 115 MB.
2018-03-23 17:39:44 # 17812 # [I] main / legacy /  DUMP >>> [17:39:44] Dump 1 complete: 116 MB written in 0.3 seconds
2018-03-23 17:39:44 # 18012 # [I] main / legacy /  DUMP >>> [17:39:44] Dump count reached.
2018-03-23 17:39:44 # 18012 # [I] main / legacy / Dump successful! >1<
2018-03-23 17:39:44 # 18012 # [I] main / legacy / DumpProcessToFile - Program >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Useful Programs\FindVUK\dump\C8AB0CEE20B0827D356CDB1E9AEC639AD7E035DC_VGHS_Season_2.dmp"<
2018-03-23 17:39:44 # 18013 # [I] main / legacy / MemDump successfully finished!
Jdogzz is offline   Reply With Quote
Old 24th March 2018, 02:43   #284  |  Link
Jdogzz
FindVUK Stalling After Memdump #2
Happened again. Log and dump file.
http://www.mediafire.com/file/0nqg7c...E_S1_DISC1.dmp
2018-03-23 18:38:25 # 0 # [I] main / legacy / #############################################################################
2018-03-23 18:38:25 # 1 # [I] main / legacy /  ----------- FindVUK 1.10 -----------
2018-03-23 18:38:25 # 1 # [I] main / legacy / Operating System: Windows 10
2018-03-23 18:38:25 # 2 # [I] main / legacy / SettingsFile: >C:\Users\myusername\Useful Programs\FindVUK\config\FindVUK.ini<
2018-03-23 18:38:25 # 12 # [I] main / legacy / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-03-23 18:38:25 # 12 # [I] main / legacy / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-03-23 18:38:25 # 12 # [I] main / legacy / Max. ScreenSize 180 x 54
2018-03-23 18:38:25 # 12 # [I] main / legacy / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-03-23 18:38:25 # 12 # [I] main / legacy / M1 - New BufferSize 120 x 9001
2018-03-23 18:38:25 # 13 # [I] main / legacy / Mx2 - New ScreenSize 120 x 50
2018-03-23 18:38:25 # 18 # [I] main / legacy / Information! Passkey detected >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 18:38:25 # 24 # [I] main / legacy / Tested Passkey Version >9.2.1.1< found
2018-03-23 18:38:25 # 25 # [I] main / legacy /  >>> everything should work as expected!
2018-03-23 18:38:25 # 25 # [I] main / legacy / Couldn't read PasskeyLogDir from registry - take the info from the ini file
2018-03-23 18:38:25 # 26 # [I] main / legacy / Information! No MediaPlayer detected!
2018-03-23 18:38:25 # 26 # [I] main / legacy / Information! DVDfab detected >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-23 18:38:25 # 26 # [I] main / legacy / Information! DVDfab MainApp is not valid! >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-23 18:38:25 # 27 # [I] main / legacy / Passkey is preferred and available!
2018-03-23 18:38:25 # 27 # [I] main / legacy / Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 18:38:25 # 27 # [I] main / legacy / Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2018-03-23 18:38:25 # 27 # [I] main / legacy / KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2018-03-23 18:38:25 # 27 # [I] main / legacy / KEYDB-Backup-Path:    >C:\Users\myusername\Useful Programs\FindVUK\VUKbackup\<
2018-03-23 18:38:25 # 28 # [I] main / legacy / ProcDumpFile:         >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe<
2018-03-23 18:38:25 # 28 # [I] main / legacy /  --- PART 1 --- GET VUK ---
2018-03-23 18:38:25 # 37 # [I] main / legacy / No running application process discovered
2018-03-23 18:38:25 # 37 # [I] main / legacy /  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-23 18:38:29 # 3943 # [I] main / legacy / Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2018-03-23 18:38:32 # 7460 # [I] main / legacy / Drive opened
2018-03-23 18:38:32 # 7460 # [I] main / legacy / DiscType detected >Blu-ray BDMV<
2018-03-23 18:38:32 # 7461 # [I] main / legacy / Volume Label detected >ROME_S1_DISC1<
2018-03-23 18:38:32 # 7462 # [I] main / legacy / DriveLetter detected >F<
2018-03-23 18:38:32 # 7462 # [I] main / legacy / Detected CopyProtections AACS >1< BD+ >0<
2018-03-23 18:38:43 # 18175 # [I] main / legacy / DiscID found >C598D86605F2569D7D3919DA89EE3DF77D24A808<
2018-03-23 18:38:44 # 19281 # [I] main / legacy / Passkey got VUK - create memdump now!
2018-03-23 18:38:44 # 19384 # [I] main / legacy /  DUMP >>>
2018-03-23 18:38:44 # 19384 # [I] main / legacy /  DUMP >>> ProcDump v8.0 - Writes process dump files
2018-03-23 18:38:44 # 19384 # [I] main / legacy /  DUMP >>> Copyright (C) 2009-2016 Mark Russinovich
2018-03-23 18:38:44 # 19384 # [I] main / legacy /  DUMP >>> Sysinternals - www.sysinternals.com
2018-03-23 18:38:44 # 19385 # [I] main / legacy /  DUMP >>> With contributions from Andrew Richards
2018-03-23 18:38:44 # 19385 # [I] main / legacy /  DUMP >>> [18:38:44] Dump 1 initiated: C:\Users\myusername\Useful Programs\FindVUK\dump\C598D86605F2569D7D3919DA89EE3DF77D24A808_ROME_S1_DISC1.dmp
2018-03-23 18:38:44 # 19485 # [I] main / legacy /  DUMP >>> [18:38:44] Dump 1 writing: Estimated dump file size is 115 MB.
2018-03-23 18:38:44 # 19686 # [I] main / legacy /  DUMP >>> [18:38:44] Dump 1 complete: 115 MB written in 0.2 seconds
2018-03-23 18:38:45 # 19886 # [I] main / legacy /  DUMP >>> [18:38:45] Dump count reached.
2018-03-23 18:38:45 # 19887 # [I] main / legacy / Dump successful! >1<
2018-03-23 18:38:45 # 19887 # [I] main / legacy / DumpProcessToFile - Program >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Useful Programs\FindVUK\dump\C598D86605F2569D7D3919DA89EE3DF77D24A808_ROME_S1_DISC1.dmp"<
2018-03-23 18:38:45 # 19887 # [I] main / legacy / MemDump successfully finished!
Old 25th March 2018, 07:38   #285  |  Link
nalor
Hi, how long die you wait in this Situation?
Basically it's waiting for the main playlist to appear in the logfile, i also noticed this can sometimes take up to 5 min.
I think about introducing a max-wait-time and just skip the detection of the main playlist in case it take too long.
Gesendet von meinem E5823 mit Tapatalk
Old 26th March 2018, 13:47   #286  |  Link
Jdogzz
Last night I waited over an hour and saw no change in the status of the program.
Old 26th March 2018, 21:06   #287  |  Link
nalor
Well, this is definitely too long
Please post the passkey-logfile and the findvuk logfile from the same time period.
Thanks!
Old 26th March 2018, 21:12   #288  |  Link
Jdogzz
Passkey log:
DVDFabPasskey 9.2.1.1 (2018/03/25 19:34:55)
 0m 05.07s: opening drive F
 0m 05.07s: opened i/o
 0m 05.08s: got media type 15
 0m 05.72s: got max lba 20221311
 0m 08.22s: got disc type 20
 0m 08.22s: type Blu-ray BDMV
 0m 08.22s: volume label ROME_S1_DISC1
 0m 08.22s: bd set region ?
 0m 08.26s: internal path F:/BDMV/
 0m 08.33s: aacs 1 bd+ 0
 0m 14.28s: got bdmv
 0m 14.29s: got agid 0
 0m 15.37s: sent host cert chal
 0m 15.38s: got drive cert chal
 0m 15.38s: BEC 0
 0m 15.38s: DRIVE_VENDOR 0x0080
 0m 17.09s: got drive key
 0m 17.09s: got host key signature
 0m 17.09s: verified drive signature
 0m 17.09s: verified host signature
 0m 18.99s: sent host signature and key point
 0m 18.99s: got bus key
 0m 19.03s: got volume id
 0m 19.03s: got volume id mac
 0m 19.03s: volume id is correct
 0m 19.03s: got vid
 0m 19.23s: blu-ray C598D86605F2569D7D3919DA89EE3DF77D24A808
 0m 19.84s: cert BEE=0x00 same
 0m 20.35s: D 75228195
 0m 20.36s: selected region B
 0m 20.36s: bd set region B
 0m 20.36s: got vuk
 0m 21.19s: got unit key 7
 0m 21.20s: blupath: demo/bonus disc
 0m 21.37s: Get BluPathData and RRdata
 0m 21.93s: StealthyClone with BluPath
 0m 24.98s: full disc copy/play is supported
 0m 25.05s: got bdmv
 0m 25.05s: got extended bdinfo
 0m 25.05s: opened blu-ray
FindVUK:
2018-03-25 19:34:48 # 0 # [I] main / legacy / #############################################################################
2018-03-25 19:34:48 # 1 # [I] main / legacy /  ----------- FindVUK 1.10 -----------
2018-03-25 19:34:48 # 2 # [I] main / legacy / Operating System: Windows 10
2018-03-25 19:34:48 # 3 # [I] main / legacy / SettingsFile: >C:\Users\myusername\Useful Programs\FindVUK\config\FindVUK.ini<
2018-03-25 19:34:48 # 20 # [I] main / legacy / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-03-25 19:34:48 # 20 # [I] main / legacy / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-03-25 19:34:48 # 20 # [I] main / legacy / Max. ScreenSize 180 x 54
2018-03-25 19:34:48 # 21 # [I] main / legacy / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-03-25 19:34:48 # 21 # [I] main / legacy / M1 - New BufferSize 120 x 9001
2018-03-25 19:34:48 # 21 # [I] main / legacy / Mx2 - New ScreenSize 120 x 50
2018-03-25 19:34:48 # 53 # [I] main / legacy / Information! Passkey detected >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-25 19:34:48 # 55 # [I] main / legacy / Tested Passkey Version >9.2.1.1< found
2018-03-25 19:34:48 # 55 # [I] main / legacy /  >>> everything should work as expected!
2018-03-25 19:34:48 # 56 # [I] main / legacy / Couldn't read PasskeyLogDir from registry - take the info from the ini file
2018-03-25 19:34:48 # 59 # [I] main / legacy / Information! No MediaPlayer detected!
2018-03-25 19:34:48 # 59 # [I] main / legacy / Information! DVDfab detected >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-25 19:34:48 # 59 # [I] main / legacy / Information! DVDfab MainApp is not valid! >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-03-25 19:34:48 # 59 # [I] main / legacy / Passkey is preferred and available!
2018-03-25 19:34:48 # 60 # [I] main / legacy / Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-25 19:34:48 # 60 # [I] main / legacy / Passkey-LogFile:      >C:\Users\myusername\Documents\DVDFab Passkey\Log\passkey_internal.log<
2018-03-25 19:34:48 # 60 # [I] main / legacy / KEYDB-Path:           >C:\Users\myusername\AppData\Roaming\aacs\<
2018-03-25 19:34:48 # 60 # [I] main / legacy / KEYDB-Backup-Path:    >C:\Users\myusername\Useful Programs\FindVUK\VUKbackup\<
2018-03-25 19:34:48 # 60 # [I] main / legacy / ProcDumpFile:         >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe<
2018-03-25 19:34:48 # 61 # [I] main / legacy /  --- PART 1 --- GET VUK ---
2018-03-25 19:34:48 # 74 # [I] main / legacy / No running application process discovered
2018-03-25 19:34:48 # 74 # [I] main / legacy /  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2018-03-25 19:34:53 # 4890 # [I] main / legacy / Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2018-03-25 19:34:58 # 9823 # [I] main / legacy / Drive opened
2018-03-25 19:34:58 # 9839 # [I] main / legacy / DiscType detected >Blu-ray BDMV<
2018-03-25 19:34:58 # 9840 # [I] main / legacy / Volume Label detected >ROME_S1_DISC1<
2018-03-25 19:34:58 # 9840 # [I] main / legacy / DriveLetter detected >F<
2018-03-25 19:34:58 # 9942 # [I] main / legacy / Detected CopyProtections AACS >1< BD+ >0<
2018-03-25 19:35:09 # 20804 # [I] main / legacy / DiscID found >C598D86605F2569D7D3919DA89EE3DF77D24A808<
2018-03-25 19:35:10 # 21917 # [I] main / legacy / Passkey got VUK - create memdump now!
2018-03-25 19:35:10 # 22035 # [I] main / legacy /  DUMP >>>
2018-03-25 19:35:10 # 22036 # [I] main / legacy /  DUMP >>> ProcDump v8.0 - Writes process dump files
2018-03-25 19:35:10 # 22036 # [I] main / legacy /  DUMP >>> Copyright (C) 2009-2016 Mark Russinovich
2018-03-25 19:35:10 # 22036 # [I] main / legacy /  DUMP >>> Sysinternals - www.sysinternals.com
2018-03-25 19:35:10 # 22036 # [I] main / legacy /  DUMP >>> With contributions from Andrew Richards
2018-03-25 19:35:10 # 22036 # [I] main / legacy /  DUMP >>> [19:35:10] Dump 1 initiated: C:\Users\myusername\Useful Programs\FindVUK\dump\C598D86605F2569D7D3919DA89EE3DF77D24A808_ROME_S1_DISC1.dmp
2018-03-25 19:35:11 # 22237 # [I] main / legacy /  DUMP >>> [19:35:11] Dump 1 writing: Estimated dump file size is 134 MB.
2018-03-25 19:35:11 # 22739 # [I] main / legacy /  DUMP >>> [19:35:11] Dump 1 complete: 134 MB written in 0.7 seconds
2018-03-25 19:35:11 # 23040 # [I] main / legacy /  DUMP >>> [19:35:11] Dump count reached.
2018-03-25 19:35:11 # 23041 # [I] main / legacy / Dump successful! >1<
2018-03-25 19:35:11 # 23041 # [I] main / legacy / DumpProcessToFile - Program >C:\Users\myusername\Useful Programs\FindVUK\tool\procdump.exe< Parameter > -ma -o DVDFabPasskey.exe "C:\Users\myusername\Useful Programs\FindVUK\dump\C598D86605F2569D7D3919DA89EE3DF77D24A808_ROME_S1_DISC1.dmp"<
2018-03-25 19:35:11 # 23041 # [I] main / legacy / MemDump successfully finished!
Old 16th April 2018, 18:48   #289  |  Link
TTide
Spiderman
Failed to get VUK:
FindVUK log:
2018-04-16 18:39:05 # 0 # [I] main / legacy / #############################################################################
2018-04-16 18:39:05 # 0 # [I] main / legacy / ----------- FindVUK 1.10 -----------
2018-04-16 18:39:05 # 1 # [I] main / legacy / Operating System: Windows 10
2018-04-16 18:39:05 # 1 # [I] main / legacy / SettingsFile: >C:\FindVUK_1.10\config\FindVUK.ini<
2018-04-16 18:39:05 # 3 # [I] main / legacy / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-04-16 18:39:05 # 3 # [I] main / legacy / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-04-16 18:39:05 # 3 # [I] main / legacy / Max. ScreenSize 240 x 72
2018-04-16 18:39:05 # 3 # [I] main / legacy / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-04-16 18:39:05 # 3 # [I] main / legacy / M1 - New BufferSize 120 x 9001
2018-04-16 18:39:05 # 3 # [I] main / legacy / Mx2 - New ScreenSize 120 x 50
2018-04-16 18:39:05 # 8 # [I] main / legacy / Information! No Passkey detected!
2018-04-16 18:39:05 # 8 # [I] main / legacy / Information! No MediaPlayer detected!
2018-04-16 18:39:05 # 8 # [I] main / legacy / Information! DVDfab detected >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-04-16 18:39:05 # 12 # [I] main / legacy / Tested DVDfab Version >10.0.4.8< found
2018-04-16 18:39:05 # 12 # [I] main / legacy / >>> everything should work as expected!
2018-04-16 18:39:05 # 13 # [I] main / legacy / Preferred application >PassKey< is not available
2018-04-16 18:39:05 # 13 # [I] main / legacy / DVDfab is available!
2018-04-16 18:39:05 # 13 # [I] main / legacy / DVDfab-MainFile: >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-04-16 18:39:05 # 14 # [I] main / legacy / DVDfab-LogFile: >C:\Users\gamer\Documents\DVDFab10\Log\dvdfab_internal.log<
2018-04-16 18:39:05 # 14 # [I] main / legacy / DVDfab-CloseAtTheEnd: >1<
2018-04-16 18:39:05 # 14 # [I] main / legacy / KEYDB-Path: >C:\Users\gamer\AppData\Roaming\aacs\<
2018-04-16 18:39:05 # 14 # [I] main / legacy / KEYDB-Backup-Path: >C:\FindVUK_1.10\VUKbackup\<
2018-04-16 18:39:05 # 14 # [I] main / legacy / ProcDumpFile: >C:\FindVUK_1.10\tool\procdump.exe<
2018-04-16 18:39:05 # 14 # [I] main / legacy / --- PART 1 --- GET VUK ---
2018-04-16 18:39:05 # 19 # [I] main / legacy / No running application process discovered
2018-04-16 18:39:05 # 19 # [I] main / legacy / >> Start it now >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-04-16 18:39:05 # 130 # [I] main / legacy / Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2018-04-16 18:39:42 # 36610 # [I] main / legacy / Drive opened
2018-04-16 18:39:42 # 36610 # [I] main / legacy / DiscType detected >Blu-ray BDMV<
2018-04-16 18:39:42 # 36610 # [I] main / legacy / Volume Label detected >SPIDER-MAN_HOMECOMING<
2018-04-16 18:39:51 # 45589 # [I] main / legacy / DriveLetter detected >E<
2018-04-16 18:39:55 # 49717 # [I] main / legacy / Detected CopyProtections AACS >1< BD+ >0<
2018-04-16 18:40:17 # 72382 # [I] main / legacy / DiscID found >7D59A39FA63D6A6DC5C302FADB082083138BC166<
2018-04-16 18:40:19 # 73999 # [I] main / legacy / DVDfab application reported error during decryption
2018-04-16 18:40:19 # 74000 # [I] main / legacy / ERROR! Decryption error detected - please reinsert Bluray!
2018-04-16 18:40:19 # 74001 # [I] main / legacy / --- PART 2 --- GET MKBrev AND VALIDATE VUK ---
2018-04-16 18:40:19 # 74002 # [I] main / legacy / AACS folder on disc is not accessible - close DVDfab now!
2018-04-16 18:40:19 # 74021 # [I] main / legacy / There are >1< DVDfab processes running
2018-04-16 18:40:30 # 84709 # [I] main / legacy / Friendly closing of C:\Program Files (x86)\DVDFab 10\DVDFab.exe< didn't succeed - kill it unfriendly now
2018-04-16 18:41:01 # 115758 # [I] main / legacy / WARNING! Couldn't reach folder :\AACS within 30 seconds (but carry on to search - stop with ESC)
TTide is offline   Reply With Quote
Old 16th April 2018, 20:17   #290  |  Link
candela
When UHD decryption was added in the beginning of April, they started blocking old versions of MediaPayer/Passkey/DVDFab to get keys for "newer" (somewhere v50+) MKBv versions. So you cannot use FindVUK anymore for such discs.
Old 16th April 2018, 20:21   #291  |  Link
nalor
You're right - just noticed it myself ...
Old 14th May 2018, 17:03   #292  |  Link
harmankardon
Okay, new member here, tried a new bluray (Ver 63) was able to get VUK key from the manual method using dvdfab 10.9 but requires the host certificate and processing keys to play
Are there any way to get the required keys and certificate files from either dvdfab or makemkv, both of which allowed me to rip the bluray, with the latest versions?
harmankardon is offline   Reply With Quote
Old 14th May 2018, 18:23   #293  |  Link
candela
Unless the disc requires bus encryption you don't need a host cert. And you never need a processing key if you have the VUK. So probably you don't have a VUK. Maybe a unit key since as far as I could tell, DVDFab 10.8 no longer uses VUK. So doubtful you can get a VUK from 10.9
Old 19th May 2018, 17:48   #294  |  Link
Piyoko
So if I understood things correctly, there is currently no way to decrypt new/unsupported discs "on your own" so to speak? The only option is to get one application or other, submit the disc info and wait until the developer feels like releasing an update with support for it?
Piyoko is offline   Reply With Quote
Old 19th May 2018, 18:03   #295  |  Link
nalor
Will soon release a new version that support the most current dvdfab passkey version to get at least UnitKeys to decrypt discs.
Kudos to @candela who discovered the UnitKeys in memory and told me about it
Basically the UnitKeys are as good as the VUK - so at least for me it's as good as before
I'm currently finishing the synchronization feature with the online db - when this is working as expected I'll release the new version.
So please give me another 1-2 weeks and I will be ready
Old 13th June 2018, 15:13   #296  |  Link
harmankardon
Hey any updates on a new release?
Old 15th June 2018, 20:12   #297  |  Link
nalor
I'm still on it - in case I don't manage to finish within the next couple of days I'll post my current version without working synchronisation.
Old 16th June 2018, 03:12   #298  |  Link
harmankardon
No worries, release it when you are ready, I was only curious on progress
Thanks for all the work you are doing
Old 9th August 2018, 02:48   #299  |  Link
EncryptedEggs
Getting a relatively new Bluray tomorrow, hoping that Passkey will still do its trick, though I should be well beyond 30 days from when the trial began...(fingers crossed)...Has anyone found a way to get the VUK without being dependent on Passkey?
EncryptedEggs is offline   Reply With Quote
Old 10th August 2018, 00:48   #300  |  Link
EncryptedEggs
No dice!
I had Passkey 8285, but the trial has run out. I tried Passkey 9230, but the software tells me that I need a new version of Passkey for that disc. I downloaded the latest Passkey, 9317, and it does decrypt the disc. However, FindVUK says that "Starting with Passkey 9.2.1.2 the VUK is not available in memory any longer!" So now I can't use FindVUK here to get the key. And now my trials have started for those later two versions.
Random questions:
  • Is there a way to re-set DVDFab trial period?
  • Anywhere I can download other versions of DVDFab Passkey?
  • Has anyone found ways to get the keys from software other thank DVDFab? For example, my PowerDVD did an AACS keys update when I put this new disc in.
  • Any progress on this new FindVUK version that you say will work with the newer DVDFabs?
Thanks for your hard work.
