Old 19th March 2020, 19:40   #1541  |  Link
ENiGMA59
Hi ,
i search add automated lines in staxrip at each encodage , i use line in cmd not automated
line :
C:\>"C:\ffmpeg.exe" -i "C:\Input\input.mkv" -c copy -bsf:v 'filter_units=remove_types=6' "C:\Output\output.mkv"
thanx for reps
ENiGMA59 is offline
Old 20th March 2020, 09:11   #1542  |  Link
almanteka
hi! why when i use the single file option to add a video file the StaxRip window is filled with the data from the video and audio and i can make changes to the job before is started? and when is in a batch when i select a job from tools > jobs the window remain empty and i can't change anything before the job is started? the only visible change is the window title!
almanteka is offline
Old 20th March 2020, 15:16   #1543  |  Link
stax76
stax76's Avatar
In StaxRip you first change the setting and afterwards add files for batch processing which will immediately create batch jobs.
I don't know if these jobs can be modified afterwards and I don't recommend trying it.
stax76 is offline
Old 20th March 2020, 15:55   #1544  |  Link
ukmark
With batch jobs, you first set up how you want to process the files and then select your batch. The settings you have in place will be applied to all files in that batch.
You can exclude individual files (untick them when you are presented with the job list). This method assumes that all files in the batch are to be processed exactly the same.
ukmark is offline
Old 20th March 2020, 18:43   #1545  |  Link
almanteka
thanks for your replies @stax76 and @ukmark! is there is a way to add multiple files as individual jobs without using batch? maybe an script? i'm using the same template for the files, but some files needs cropping, in others the audio files are undetermined and not correctly selected! i know that adding the files one by one fulfill what i'm looking for, but that takes time! thanks in advance for any suggestions!
Old 20th March 2020, 21:51   #1546  |  Link
almanteka
is there is any issue with MediaInfo Folder View? with StaxRip-x64-2.0.8.0-stable it don't populate the media info!
EDIT:
ok, found out the problem is MediaInfo, changed the MediaInfo.dll to v0.7.96 and populates correctly!
Old 21st March 2020, 13:20   #1547  |  Link
stax76
stax76's Avatar
This will break things! Maybe I redo it from scratch using PowerShell Out-GridView, try this:
Get-Process | Out-GridView
Data should also be cached because it's painful slow.
stax76 is offline
Old 21st March 2020, 16:27   #1548  |  Link
bin.n2f
hi
how i can solve this problem
System.ArgumentOutOfRangeException: Value to add was out of range
bin.n2f is offline
Old 21st March 2020, 17:47   #1549  |  Link
almanteka
more info on how to proceed using powershell is appreciate it! thanks!
Old 21st March 2020, 17:49   #1550  |  Link
stax76
stax76's Avatar
Generally if there is a bug in any app you visit the website and look for the support instructions:
https://github.com/staxrip/staxrip#support
In case of staxrip these instructions need some work, there should be log file, please post it to pastebin.com
edit:
I've changed the issue template on the tracker but still needs some work.
https://github.com/staxrip/staxrip/issues/new/choose
You have to wait until the app/script is finished, so far I have only 10 lines, it will be about 500 and I code very slow with PowerShell.
stax76 is offline
Old 21st March 2020, 21:31   #1551  |  Link
almanteka
ok, i was thinking that i need to do something for powershell to populate the mediainfo folder list. will wait to test it out! thanks!
Old 22nd March 2020, 03:09   #1552  |  Link
stax76
stax76's Avatar
@almanteka
I've uploaded a fix for the MediaInfo folder view bug.
A small project of mine is Get-MediaInfo which allows requesting single MediaInfo properties via PowerShell. This could be expanded into a full PowerShell MediaInfo solution in the future and be integrated or merged with MediaInfo.NET. We'll see but it's nothing that will happen soon because I've still much to learn about PowerShell.
StaxRip 2.1.0.1 Beta (all tools included):
https://github.com/staxrip/staxrip/b...r/Changelog.md
https://staxrip.readthedocs.io/intro.html#download
stax76 is offline
Old 22nd March 2020, 08:20   #1553  |  Link
almanteka
@almanteka
i can confirm that the mediainfo folder view is workin at v2.1.0.1 Beta! thanks!
Old 23rd March 2020, 14:34   #1554  |  Link
Mzvasturbo
StaxRip 2.0.8.0 x265 [warning]: --dhdr10-info disabled. Enable HDR10_PLUS in cmake.
StaxRip 2.0.6.0 works ok with HDR10+.
Mzvasturbo is offline
Old 23rd March 2020, 16:52   #1555  |  Link
Patman
Patman's Avatar
pls download one of the newer versions from my sig "staxrip tools"
Tools for StaxRip | x264 - x265
Patman is offline
Old 24th March 2020, 01:01   #1556  |  Link
almanteka
just a suggestion for future versions of StaxRip: add the total count of jobs in the jobs window, something like the pict below! not the same, but a way to know how many jobs are still pending! thanks!
Old 24th March 2020, 12:02   #1557  |  Link
Taurus
Taurus's Avatar
@stax76:
There is a new version of dfftest (v1.9.5) from pinterf.
https://forum.doom9.org/showpost.php...postcount=5265
Works reliable on my side.
There is a msvc and a clang version, both in 32bit and 64bit.
And even a msvc_xp version foor the old hardcore users
I have only tested the 64bit msvc version.
Hope this helps.
Edit: the clang version seems to be a little bit faster (dont count on me, no numbers...)
Taurus is offline
Old 24th March 2020, 12:16   #1558  |  Link
Groucho2004
Does one have to be old to use it? For adults only I presume?
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 24th March 2020, 15:50   #1559  |  Link
Taurus
Taurus's Avatar
Nice one
Taurus is offline
Old 24th March 2020, 17:15   #1560  |  Link
Taurus
Taurus's Avatar
...and another update.
Pinterf is really busy this time.
There is a dfttest ver_1.9.6.
https://forum.doom9.org/showpost.php...postcount=5268
Works reliable inside StaxRip, tested the clang version this time.
Solo, in qtgmc, smdegrain, etc.
Bye
Taurus is offline
