Old 30th March 2020, 22:50   #1601  |  Link
Joekiwi
Just like to say a big thanks to Patman for all your effort
Joekiwi is offline
Old 31st March 2020, 06:21   #1602  |  Link
JKyle
App Digger
JKyle's Avatar
A Simple HDR to SDR Re-encoding Speed Test with Different x264 Builds by Patman
I speed-tested different builds of x264 by Patman in a very similar way to this post.
The source video is the same UHD HDR video from 4kmedia.org and remuxing to mkv is the same.
The only different part is applying ConvertBits and DGHDRtoSDR in the AviSynth script and x264 encoding.
Here's the detail.
■ System Environment
StaxRip : 2.1.0.2
Windows : Windows 10 Home 2004
CPU : Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
■ Source Video
LG: New York HDR
■ Remuxing of the original ts to mkv
ffmpeg -hide_banner -analyzeduration 100M -probesize 50M -i "LG New York HDR UHD 4K Demo.ts" -map 0 -c copy -bsf:a aac_adtstoasc -y "LG New York HDR UHD 4K Demo.mkv"
■ AviSynth Script
LG New York HDR UHD 4K Demo.avs
LoadPlugin("D:\Utilities\StaxRip\Apps\Plugins\Dual\DGHDRtoSDR\DGHDRtoSDR.dll")
LoadPlugin("D:\Utilities\StaxRip\Apps\Plugins\Dual\ffms2\ffms2.dll")
FFVideoSource("D:\Work\tmp\LG New York HDR UHD 4K Demo.mkv", cachefile = "D:\Work\tmp\LG New York HDR UHD 4K Demo_temp\LG New York HDR UHD 4K Demo.ffindex")
#AssumeFPS(25)
Spline64Resize(1920, 1080)
ConvertBits(16)
DGHDRtoSDR(mode="pq",white=2500)
■ Video encoding command line (avs2pipe, x264)
D:\Utilities\StaxRip\Apps\Support\avs2pipemod\avs2pipemod64.exe -y4mp "D:\Work\tmp\LG New York HDR UHD 4K Demo_temp\LG New York HDR UHD 4K Demo.avs" | D:\Utilities\StaxRip\Apps\Encoders\x264\x264.exe --crf 23 --profile high --aq-mode 3 --me umh --direct auto --merange 24 --b-adapt 2 --colorprim bt709 --colormatrix bt709 --transfer bt709 --aud --deblock -1:-1 --demuxer y4m --frames 1806 --output "D:\Work\tmp\LG New York HDR UHD 4K Demo_temp\LG New York HDR UHD 4K Demo_out.h264" -
■ Result (from slowest to fastest)
x264-159-r2991-1771b55-gcc9.3.0
10.83 fps
x264-159-r2991M-1771b55-gcc9.3.0
12.36 fps
x264-159-r2991-1771b55-gcc10.0.1
12.39 fps
x264-159-r2991M-1771b55-gcc10.0.1
12.48 fps
JKyle is offline
Old 31st March 2020, 10:49   #1603  |  Link
Mertiz88
@Joekiwi, thanks for your reply, I think I'll ask this question in Avisynth thread.
@AMED, That's my question. I ask if I can apply any filter without doing enocde again.
Mertiz88 is offline
Old 31st March 2020, 11:26   #1604  |  Link
stax76
stax76's Avatar
are you able to just apply the filter on the software your using for playback?
mpv is the player with the best support for it, it allows:
ffmpeg filters:
https://mpv.io/manual/master/#video-filters
vapoursynth filters:
https://mpv.io/manual/master/#video-filters-vapoursynth
per file configuration:
https://mpv.io/manual/master/#file-s...guration-files
mpv.net supports almost all mpv features.
stax76 is offline
Old 31st March 2020, 17:00   #1605  |  Link
Patman
Patman's Avatar
You're welcome. Currently Stax is here the machine and updates StaxRip quite regularly! A big thanks for that!
Tools for StaxRip | x264 - x265
Patman is offline
Old 31st March 2020, 18:06   #1606  |  Link
Lynx_TWO
Feature request - Ability to encode 720p and 1080p at once after processing?
@Stax and everyone else - So many thanks for this great tool!
Is it possible to implement a feature that would encode a video stream at two different resolutions while only processing once with plugins?
I'd love to the ability to denoise deinterlace, etc. on a 1080p file and then output a stream to 720p and 1080p mp4 file simultaneously with the same CRF settings, audio streams, subtitles, etc. Basically just resizing the processed raw 1080p output to 720p and encode it at the same time it's encoding the 1080p version. Would save a bunch of time and use a multicore system more efficiently I would think, esp. if using x264
Lynx_TWO is offline
Old 1st April 2020, 05:50   #1607  |  Link
Z'Hadum
Why do you not simply create two jobs for this? If you start staxrip two times, you get also your parallel processing....
Z'Hadum is offline
Old 1st April 2020, 07:34   #1608  |  Link
chipsteps
How can we set "chromaloc-top = 2" and "chromaloc-bottom = 2", "scenecut-bias = 0.05"
I set it, but look in the info section "chromaloc-top = 1" and "chromaloc-bottom = 1", "scenecut-bias = 0.00"
Help me! Thank you very much! (StaxRip Ver: 2.0.8.0)
chipsteps is offline
Old 1st April 2020, 16:56   #1609  |  Link
shodan5000
Why is it that Vapoursynth scripts crash anytime time I have a video file with an apostrophe anywhere in the name? Avisynth scripts do not do this.
shodan5000 is offline
Old 1st April 2020, 19:40   #1610  |  Link
Patman
Patman's Avatar
I think there is no possibility to set these values. Scenecut-bias used 0.5 steps and chromaloc can general be set without the options bottom or top.
Patman is offline
Old 1st April 2020, 22:28   #1611  |  Link
AMED
AMED's Avatar
What version of StaxRip are you running. I'm pretty sure this was fixed after 2.0.6.0 stable.
for now all you need to do is
open StaxRip, right click in the VS filters section and select profiles.
and change this
[Source]
Automatic = # can be configured at: Tools > Settings > Source Filters
AVISource = clip = core.avisource.AVISource(r'%source_file%')
d2vsource = clip = core.d2v.Source(r'%source_file%')
DGSource = clip = core.dgdecodenv.DGSource(r'%source_file%')
ffms2 =
    clip = core.ffms2.Source(r'%source_file%', cachefile=r'%source_temp_file%.ffindex')
    #clip = core.std.AssumeFPS(clip, None, 25, 1)
LibavSMASHSource =
    clip = core.lsmas.LibavSMASHSource(r'%source_file%')
LWLibavSource =
    clip = core.lsmas.LWLibavSource(r'%source_file%', cachefile=r'%source_temp_file%.lwi')
Manual = # shows filter selection dialog
to this
[Source]
AVISource = clip = core.avisource.AVISource(r"%source_file%")
d2vsource = clip = core.d2v.Source(r"%source_file%")
DGSource = clip = core.dgdecodenv.DGSource(r"%source_file%")
ffms2 =
    clip = core.ffms2.Source(r"%source_file%", cachefile=r"%source_temp_file%.ffindex")
LibavSMASHSource =
    clip = core.lsmas.LibavSMASHSource(r"%source_file%")
LWLibavSource =
    clip = core.lsmas.LWLibavSource(r"%source_file%", cachefile=r"%source_temp_file%.lwi")
A Man Eating Duck
AMED is offline
Old 2nd April 2020, 11:26   #1612  |  Link
shodan5000
I'm using version 2.1.0.1 but went ahead and tried your fix. It worked. Thank you very much. Maybe there was some old code that made its way back into that beta version?
Old 2nd April 2020, 12:24   #1613  |  Link
JKyle
App Digger
JKyle's Avatar
That's why you need to reset(restore) the profiles whenever you suspect there's old trash in them.
JKyle is offline
Old 2nd April 2020, 17:15   #1614  |  Link
shodan5000
I never knew that. Thanks for the tip.
Old 2nd April 2020, 21:10   #1615  |  Link
chipsteps
thank you very muck! So chromaloc customizations are the default and can't be manually set?
Old 3rd April 2020, 00:09   #1616  |  Link
AMED
AMED's Avatar
Did you use the same settings directory from a previous version of StaxRip when you started using v2.1.0.1?
A Man Eating Duck
AMED is offline
Old 3rd April 2020, 00:24   #1617  |  Link
Atlantis
AviSynth+ 3.5.1 released.
Atlantis is offline
Old 3rd April 2020, 05:12   #1618  |  Link
JKyle
App Digger
JKyle's Avatar
@Stax
Just FYI, there's a small typo in the x264 Options window (2.1.0.2 Beta).
As you know, HDR(high dynamic range) is not HRD(hypothetical reference decoder), which is equal to VBV(video buffering verifier).
Plz fix this in order to prevent confusion.
JKyle is offline
Old 3rd April 2020, 19:12   #1619  |  Link
Zetti
MediaInfo v20.03 is released.
Zetti is offline
Old 4th April 2020, 05:04   #1620  |  Link
stax76
stax76's Avatar
2.1.0.3 Beta
- new: check added that blocks source files with too long path or filename. A setting
       that allows to change the limit exists and there is also a explanation as tooltip:
       In theory Windows supports paths that are longer than 260 characters, in reality
       neither Windows, nor the .NET Framework or the used tools have full long path support.
- new: in order to support unicode the command line based encoder used by XviD uses
       now cmd.exe directly without creating a batch file. This command line based encoder
       is not only useful for XviD but can be used for any command line based encoder
- new: very basic SVT-AV1 encoder support added
- update: MediaInfo 20.03
- update: AviSynth 3.5.1
- update: ffmpeg N-97107-g33c106d411-g72be5d4661+2-gcc9.3.0 Patman
- fix: 2 reported typos
https://staxrip.readthedocs.io/intro.html#download
stax76 is offline
