Old 29th August 2014, 20:35   #20921  |  Link
mparade
Could not create AVS file
Just got this error message while using FFVideoSource.
After changing back to DirectShow the problem was solved.
[08.29.14] BD Rebuilder v0.48.03 (beta)
[21:13:00] Source: MONSTERS_INC
- Input BD size: 0,21 GB
- Approximate total content: [03:08:10.362]
- Target BD size: 46,26 GB
- Windows Version: 6.1 [7601]
- MOVIE and MENUS mode enabled
- Resize: SD to HD 1080 enabled
- Quality: Ultra High Quality (Extremely Slow), CRF
- Output folder: E:\BD-RB\
- Decoding/Frame serving: FFVideoSource
- Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[21:13:00] PHASE ONE, Encoding
- [21:13:01] Blanking: VID_00045 (66 of 95)
- [21:13:01] Processing: VID_00031 (67 of 95)
- [21:13:01] Extracting A/V streams [VID_00031]
- [21:13:18] CreateAVS() 00000
[21:13:26] - Could not create AVS file
Old 30th August 2014, 01:49   #20922  |  Link
I'm confused. 67 of 95? Did you edit out 1-65? I understand if you did, as it would be ridiculously long, but I just want to be sure.
It has to be some syntax error in an area rarely hit to die in that routine... I wish I had more to go on.
Old 30th August 2014, 02:30   #20923  |  Link
gonca
My imagination or did the input size read as 0.21 GB?
Old 30th August 2014, 04:25   #20924  |  Link
Looks like it to me. Something is wrong. But if it worked with DirectshowSource is should work with FFVideoSource.
Old 30th August 2014, 09:01   #20925  |  Link
mparade
Yes, I did. I was in edit mode just for testing purposes.
Here are some additional information I got from BD-RB:
"Couldn't open input file in HIDE mode!" error window appeared during"completing remainder of indexing.."
"BD Rebuilder experienced an error Create AVS () 00000" error condition window appeared.
"special" hidden options were in use:
IVTC_SELECTION=1
IVTC_TELECIDE=1
The source is hard telecined.
I hope these help.
Old 31st August 2014, 13:15   #20926  |  Link
brunchto
I've an error with ffmsindex.exe. with "The matrix".
encoding seems ok (mkv ok), but, i've got this error:
streams are VC1, iso mounted for network share
[11:28:38] BD Rebuilder v0.48.03 (beta)
[11:28:38] BEGIN - BATCH SEQUENCE
[11:28:38] PROCESSING BATCH FILE [127]
[08/31/14] BD Rebuilder v0.48.03 (beta)
[11:28:39] Source:  THE_MATRIX_00000
  - Input BD size: 26,49 GB
  - Approximate total content: [02:16:17.961]
  - Windows Version: 6.2 [9200]
  - Mode: MKV, Intact Video, Intact Audio
[11:28:39] PHASE ONE, Encoding
 - [11:28:39] Processing: VID_00000 (1 of 1)
 - [11:28:39] Extracting A/V streams [VID_00000]
 - [11:42:50] Reencoding video [VID_00000]
 - [11:42:50] Keeping original video (no reencode)
 - [11:42:50] Processing audio tracks
   - Track 4354 (fra): Keeping original audio
[11:42:50]PHASE ONE complete
[11:42:50]PHASE TWO - Rebuild Started
 - [11:42:53] Building ALTERNATE OUTPUT Structure
[11:50:03] - Encode and Rebuild complete
 - WORKFILES folder removed.
[11:50:03] JOB: THE_MATRIX finished.
in addition (not related), the last time i tried, there where a problem with batch backup and angle selection.
http://forum.doom9.org/showthread.ph...28#post1682228
angle selection works in direct backup, but not in batch (not stored in MAIN_MPLS_ANGLE which stays =0) .
bruno
brunchto is offline   Reply With Quote
Old 31st August 2014, 15:31   #20927  |  Link
@brunchto
Interesting... I have "The Matrix" so I tried it. The reason it doesn't affect the output is because you have "Intact Video" selected and FFVideoSource is never actually used. I'll look and see what I can find as to why ffmsindex.exe is crashing on that title. I ran it from the command line and get no indication other than the O/S "crash" popup.
I'll look at the referenced batch problem.
[Edit] By increasing the verbosity level of ffmsindex.exe I am now at least getting some error messages -- it seems to be related to one or more of the subtitles in the stream.
Old 31st August 2014, 16:31   #20928  |  Link
andref4
Cloudy 2 3D full Backup works now with 0.48.02!!
I have backuped the complete cloudy 2 3D Blu-Ray to HDD (over 60GB because ssif Folder) and did a full backup from HDD and not from the Blu-Ray.
And now the backup works and after 7:34min the german intro starts!
The only thing I don't understand is:
if I make a full 3D BD25 backup with bd-rebuilder from the original Blu-Ray or mounted iso, bd-reb encodes 5 Videos and the movie crashes after 7:34min.
if I make a full 3D BD25 backup from the "Cloudy 2" Folder on HDD, bd-reb encodes 6 Videos and the movie plays fine and starts with the german Intro after 7:34min.
regards
andref4 is offline   Reply With Quote
Old 1st September 2014, 13:20   #20929  |  Link
brunchto
I've tested with re-encoding (to 1280mkv) and i've an error on encoding with FFsource. re-encoding seems to work if i select frim.
Old 1st September 2014, 15:28   #20930  |  Link
Ch3vr0n
Previewing doesn't work (on MPEG-4 (AVC) streams). Disc: Divergent
Error:
LoadPlugin: unable to load "C:\Program Files (x86)\BD_Rebuilder\tools\fromsource.dll"
(C:\Temp\WORKFILES\MPC_VIEW.AVS, line 2)
Works fine using 48.02
Old 1st September 2014, 16:09   #20931  |  Link
Error:
I just tried an AVC stream on my system and it previewed fine? It didn't really say "fromsource" did it? I just looked through the code and couldn't find that anywhere.
Old 1st September 2014, 16:22   #20932  |  Link
Ch3vr0n
well it refuses on my end with 48.03 nothing changed except replacing the folder contents with that of the zip by copy/paste&replace. Copying the folder to like C:\ root doesn't help. Same trying a different ISO. Same thing reading directly from optical drive. Swap to 48.02. Problem solved on both iso reading and optical drive.
Old 1st September 2014, 16:48   #20933  |  Link
Look in the "tools" folder and see if "frimsource.dll" exists.
Old 1st September 2014, 17:17   #20934  |  Link
Can someone else please confirm that previewing of AVC sources works on their system with v0.48.03?
Old 1st September 2014, 17:18   #20935  |  Link
Is it possible you have another version of libmfxsw32.dll in your path somewhere?
Old 1st September 2014, 17:22   #20936  |  Link
Sharc
No problem with preview here with v0.48.03.
Edit:
Oooops, I just tried again, and strange enough:
- Previewing from the Quick-Play Menu Title Editor is smooth
- Previewing from the Stream Tab in the main window starts, then gets gradually choppy (dropping frames until almost no frame updates happen) .
Edit2:
It's the MPC_View.avs using frimsource which makes the problem
The preview.avs using directshowsource is ok.
Old 1st September 2014, 17:30   #20937  |  Link
omegaman7
omegaman7's Avatar
Finally downloaded 4803. Chose Cabin in the woods as random. Attempted to preview very first (00001) video. "File not found." At least I think that's what it said. I cannot repeat the problem, because I attempted the same video on 4802, and it worked. And now 4803 works every time :S VERY weird...
Old 1st September 2014, 17:39   #20938  |  Link
Ch3vr0n
my path somewhere? What path? Where? Never heard of that dll file till now. Inspect.exe reports everything as ok. I didn't change anything, only replaced existing content.
[09/01/14] Checking System Settings
- BD-Rebuilder v0.48.03 (beta)
- Windows Version: 6.0 [6002]
- Working Path Free Space: 244,94GB
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[09/01/14] Systems Settings Check complete
and looks like i'm not the only one with the issue. The weird thing is that their is a 10sec "timer" that progresses, there's just no video except that error message
Old 1st September 2014, 18:10   #20939  |  Link
CV91913
Works fine on 48.03 on my Win 7 64 system. Don't know if the OS version matters but the problem system seems to be running an older version of Windows.
CV91913 is offline   Reply With Quote
Old 1st September 2014, 18:33   #20940  |  Link
I may have to reconsider this whole thing and go back to Directshow as the default. Too bad. A large percentage of all the BD-RB issues reported are due to other software interfering with or intercepting Directshow, and the problems go away with re-installation of HAALI and FFDSHOW... and I could have made an install package that is independent of any other installations.
I'll spend some more time trying to work out the FFVideoSource() issues and then decide on future direction.
@CV91913
I'll do some checking, but now that you mention it I think I remember that there is a minimum O/S version required by FRIMSource. I'll have to check it.
