31st March 2018, 13:58 | #27181 | Link | |
The only way to get around this would be for me to write an interpreter for the instruction sequence in the DVD -- and that is way beyond what I'd intended in the import function. What I do in this instance is look at the times for the episodes on the original, and then compare them to those on the import menu. I then reorder them from the menu if they are out of sequence. Last edited by jdobbs; 31st March 2018 at 14:00. |
31st March 2018, 17:11 | #27182 | Link | |
Great suggestion - I'll keep an eye on that going forward. I appreciate the feedback. |
31st March 2018, 19:06 | #27183 | Link |
@jdobbs previously i was using software base mode to do my 3D processing. I've just enabled the iGPU (6700k) on my system to see if hardware encoding (quicksync) makes any difference. Do i need to set any options in the ini file to go from sw to hw?
which settings do you recommend on a 6700k? Software enc/dec, software enc, hw dec? Hardware enc/software dec? Hw enc & dec? How do you force hw? FRIM_SW_DECODE=0 FRIM_SW_ENCODE=0 results in good decode but failed encode, so does 0/1. Removing both starts encoding but at 12FPS, i don't think it's doing hardware based encoding Last edited by Ch3vr0n; 31st March 2018 at 19:45. |
31st March 2018, 21:27 | #27184 | Link | |
1st April 2018, 10:49 | #27186 | Link |
@Ch3vr0n
I did my experiments and went the same way. I have the I7 4790K and I'm stuck with 12fps. HW DECODE / ENCODE with frim would certainly run much faster. If I find out something new, I will report this here. Perhaps there has to be a new entry in the hidden options text like FRIM_HW_DECODE=1 and FRRIM_HW_ENCODE=1. @jdobbs Would that be possible? Last edited by kufo; 1st April 2018 at 10:51. |
1st April 2018, 11:17 | #27187 | Link | ||
From HIDDENOPTS.txt
1st April 2018, 12:43 | #27189 | Link | |
To force HW use FRIM_xxx=0, if it detects the iGPU it will use hardware |
1st April 2018, 13:26 | #27192 | Link | |
All the settings do is change the FRIM command line to/from "-sw" and "-hw". For it to work, the system has to be configured to support HW encoding and have the proper drivers. That's about it. BD-RB's involvement in that process is minimal. Is there a bios setting for the gpu maybe? I'm using FRIM v1.25 by default in BD-RB. If you can't get it to work, maybe try downloading a newer FRIM version (with the DLLS). Beware, though, I'm not sure what changes have been made of if it will even work. Last edited by jdobbs; 1st April 2018 at 13:45. |
1st April 2018, 14:22 | #27193 | Link |
the bios iGPU has been enabled yes, CloneBD for example detects QuickSync (where it previously didn't). Ah well, guess i need more tinkering. Latest intel drivers are installed, if you can point me to the place to grab frim i'll take a look
** edit ** found them on https://www.videohelp.com/software/FRIM updated to 1.27 FRIM_SW_DECODE=0 FRIM_SW_ENCODE=0 results in what i earlier said a "pause" of 10-15sec when encoding is about to start and then "failed" DECODE=0 and ENCODE=1 = fail DECODE=1 and ENCODE=0 = fail removing BOTH entries, encoding starts at the "normal" 10-12FPS i'm outta idea's. Even did multiple googles and they all say something like "connect to VGA" for the iGPU at some point. Problem: there's no such option in windows 10 Last edited by Ch3vr0n; 1st April 2018 at 16:31. |
1st April 2018, 16:55 | #27194 | Link |
@ Ch3vr0n: RE: i'm outta idea's.
I have the same 6700K and I get BD_Rebuilder FRIM running at 88 FPS by using this in my config.ini file. Options] VERSION=0.50.0.24 ENCODER=0 MODE=0 ENABLE_TEST=1 BLANK_THRESHOLD=0 MIN_PLAYLIST_MINS=03 MIN_M2TS_SIZE=5 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=24350 FORCE_ENCODE=0 FRIM_SW_DECODE=1 FRIM_SW_ENCODE=0 PRIORITY_CLASS=2 ... Also intel has a pretty good program on their website to automatically find updated drivers for your motherboard and CPU at ( https://downloadcenter.intel.com/ ) and click on "Get Started" to download the Intel® Driver & Support Assistant (Intel® DSA) program. It will check all your intel stuff. I use it occasionally but I uninstall it after I use it to keep it from running every startup. Hope this helps. |
1st April 2018, 17:41 | #27196 | Link |
Tried 1/0, fails to start encoding. Decodes fine. No idea what the PRIORITY one is but can't find it in hiddenopts. You've got a GPU installed too like i do (GTX 1080)? Already running latest drivers. That's the first thing i did after enabling the igpu in the bios. Setting SW_DECODE to 1 and leaving the other one out works too, but at the "normal" software FPS.
No overclocking is going on btw. Last edited by Ch3vr0n; 1st April 2018 at 17:46. |
1st April 2018, 18:10 | #27197 | Link |
RE: No idea what the PRIORITY one is?
I think it's under "Setting" and "Encoder Settings", where you can choose "Normal, Idle, or High". I have mine set at High. RE: No overclocking is going on btw. I have mine overclocked with a 47 multiplier all cores btw. Have you looked under device manager to see if you have a second "greyed" out monitor listed? I think you have to hook up and run the monitor on the integrated graphics connector at least once for it to enable Quicksync, or at least that's what I had to do with my old 2600K. |
1st April 2018, 21:12 | #27198 | Link |
No greyed out ones listed. Just 2 standard "General PnP-Display". But i believe you're wrong on the last part. Elby's CloneBD can utilise QuickSync just fine (hw decoding and encoding) WITHOUT any display hooked up to the onboard hdmi.
2nd April 2018, 22:17 | #27200 | Link |
I recommend you uninstall and reinstall the LAV filters or FFDSHOW (or both depending on what you have installed). Make sure they are ONLY the versions listed in the first post of this thread. Sometimes other software installs can override them and cause sync issues. Other versions can also cause sync issues.
