Old 13th July 2021, 20:39   #30721  |  Link
spotswood
@cartman0208
So it looks like it converted properly for you, right?
Originally Posted by cartman0208 View Post
Correct, and the output looks pretty normal to me
Originally Posted by CraigWally View Post
Just checked my "Good, Bad and Ugly" - I've definitely got 6 audio channels AC3
Can you post logs, .inf and MediaInfo of the job you did? If it came out correctly then I don't know what to tell you guys. I've tried re-downloading v0.61.22 of BDRB and start over from scratch. I've checked and re-checked my settings over and over. I've posted logs confirming those settings. Every disc I try with a Lossless track gets converted to AC3 Mono. I'm at a loss other than wiping my drive and installing a fresh Windows 10, although other programs performing the same task work perfectly.
As I mentioned before, I can run my Lossless discs I want to convert through other programs first (which I know is not recommended) but it works just fine and they play perfectly in MPC-HC and/or Kodi. So I'll just take the extra step to convert them first before processing in BDRB until the gremlins decide to stop fu**ing with me. Thanks for the replies...
spotswood is offline   Reply With Quote
Old 14th July 2021, 05:54   #30722  |  Link
cartman0208
The relevant mediainfo I already posted.
I'm still one version behind, but that shouldn't matter
ini and log below ... if it helps
[Options]
VERSION=0.61.0.21
ENCODER=1
MODE=0
ENCODE_QUALITY=3
ONEPASS_ENCODING=1
AUTO_QUALITY=0
TARGET_SIZE=23500
NVENC_CAPABLE=1
AUDIO_TO_KEEP=deu;eng;ger;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=1
PGSTOSRT=1
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=50000
AUTO_BURN=2
MOVIEONLY_TYPE=11
ALTCRF=18
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
SOURCE_PATH=V:\FULLDISC\SONIC_THE_HEDGEHOG\
WORKING_PATH=U:\BD-OUTPUT\
SupTitlePath=U:\BD_Rebuilder\Tools\SupTitle\x86\SupTitle.dll
[07.10.21] BD Rebuilder v0.61.21
[00:17:01] Source:  SONIC_THE_HEDGEHOG
  - Input BD size: 37,42 GB
  - Approximate total content: [02:35:52.424]
  - Target BD size: 22,95 GB
  - Windows Version: 6.2 [9200]
  - Quality: Highest (Very Slow), CQM
  - Decoding/Frame serving: NVENCC
[00:17:04] PHASE ONE, Encoding
 - [00:17:04] Processing: VID_00351 (1 of 15)
 - [00:17:04] Extracting A/V streams [VID_00351]
 - [00:22:14] Reencoding video [VID_00351]
   - Rate/Length: 23,976fps, 142.252 frames
 - [00:22:15] Performing CQM Prediction...
   - Analyzing 5,00 15,70 15,30 [15,30]
 - [00:23:36] Encoding using constant quality mode.
 - [00:38:54] Video Encode complete
 - [00:38:54] Processing audio tracks
   - Track 4352 (eng): Keeping original core audio
   - Track 4354 (deu): Keeping original audio
 - [00:38:58] Multiplexing M2TS
 - [00:39:43] Processing: VID_00589 (2 of 15)
 - [00:39:43] Extracting A/V streams [VID_00589]
 - [00:39:53] Reencoding video [VID_00589]
   - Rate/Length: 23,976fps, 2.592 frames
 - [00:39:54] Performing CQM Prediction...
   - Analyzing 5,00 18,85 21,95 [22,02]
 - [00:40:06] Encoding using constant quality mode.
 - [00:40:25] Video Encode complete
 - [00:40:25] Processing audio tracks
   - Track 4353 (deu): Keeping original audio
 - [00:40:25] Multiplexing M2TS
 - [00:40:30] Processing: VID_00590 (3 of 15)
 - [00:40:30] Extracting A/V streams [VID_00590]
 - [00:40:40] Reencoding video [VID_00590]
   - Rate/Length: 23,976fps, 3.210 frames
 - [00:40:41] Performing CQM Prediction...
   - Analyzing 5,00 18,90 19,80 [19,80]
 - [00:40:52] Encoding using constant quality mode.
 - [00:41:13] Video Encode complete
 - [00:41:13] Processing audio tracks
 - [00:41:13] Multiplexing M2TS
 - [00:41:17] Processing: VID_00591 (4 of 15)
 - [00:41:17] Extracting A/V streams [VID_00591]
 - [00:41:30] Reencoding video [VID_00591]
   - Rate/Length: 23,976fps, 5.359 frames
 - [00:41:31] Performing CQM Prediction...
   - Analyzing 5,00 19,20 20,70 [20,80]
 - [00:41:42] Encoding using constant quality mode.
 - [00:42:34] Video Encode complete
 - [00:42:34] Processing audio tracks
 - [00:42:34] Multiplexing M2TS
 - [00:42:39] Processing: VID_00592 (5 of 15)
 - [00:42:39] Extracting A/V streams [VID_00592]
 - [00:42:53] Reencoding video [VID_00592]
   - Rate/Length: 23,976fps, 5.768 frames
 - [00:42:54] Performing CQM Prediction...
   - Analyzing 5,00 18,75 [18,75]
 - [00:43:01] Encoding using constant quality mode.
[00:43:11] - Aborted by user request
[10:24:03] Source:  SONIC_THE_HEDGEHOG
- Resuming from previously started job.
[10:24:06] PHASE ONE, Encoding
 - [10:24:06] Processing: VID_00592 (5 of 15)
 - [10:24:06] Reencoding video [VID_00592]
 - [10:24:06] Performing CQM Prediction...
 - [10:24:15] Encoding using constant quality mode.
 - [10:24:56] Video Encode complete
 - [10:24:56] Processing audio tracks
 - [10:24:56] Multiplexing M2TS
 - [10:25:01] Processing: VID_00593 (6 of 15)
 - [10:25:01] Extracting A/V streams [VID_00593]
 - [10:25:15] Reencoding video [VID_00593]
   - Rate/Length: 23,976fps, 5.820 frames
 - [10:25:16] Performing CQM Prediction...
   - Analyzing 5,00 17,95 18,55 [18,55]
 - [10:25:27] Encoding using constant quality mode.
 - [10:26:06] Video Encode complete
 - [10:26:06] Processing audio tracks
 - [10:26:06] Multiplexing M2TS
 - [10:26:11] Processing: VID_00594 (7 of 15)
 - [10:26:11] Extracting A/V streams [VID_00594]
 - [10:26:30] Reencoding video [VID_00594]
   - Rate/Length: 23,976fps, 9.152 frames
 - [10:26:31] Performing CQM Prediction...
   - Analyzing 5,00 18,50 19,50 [19,50]
 - [10:26:44] Encoding using constant quality mode.
 - [10:27:49] Video Encode complete
 - [10:27:49] Processing audio tracks
 - [10:27:49] Multiplexing M2TS
 - [10:27:55] Processing: VID_00595 (8 of 15)
 - [10:27:55] Extracting A/V streams [VID_00595]
 - [10:28:08] Reencoding video [VID_00595]
   - Rate/Length: 23,976fps, 4.972 frames
 - [10:28:08] Performing CQM Prediction...
   - Analyzing 5,00 18,90 20,45 [20,45]
 - [10:28:20] Encoding using constant quality mode.
 - [10:28:54] Video Encode complete
 - [10:28:54] Processing audio tracks
 - [10:28:54] Multiplexing M2TS
 - [10:28:59] Processing: VID_00596 (9 of 15)
 - [10:28:59] Extracting A/V streams [VID_00596]
 - [10:29:06] Reencoding video [VID_00596]
   - Rate/Length: 23,976fps, 680 frames
 - [10:29:06] Performing CQM Prediction...
   - Analyzing 5,00 19,20 19,95 [19,95]
 - [10:29:18] Encoding using constant quality mode.
 - [10:29:24] Video Encode complete
 - [10:29:24] Processing audio tracks
 - [10:29:24] Multiplexing M2TS
 - [10:29:28] Processing: VID_00597 (10 of 15)
 - [10:29:28] Extracting A/V streams [VID_00597]
 - [10:29:40] Reencoding video [VID_00597]
   - Rate/Length: 23,976fps, 5.095 frames
 - [10:29:40] Performing CQM Prediction...
   - Analyzing 5,00 18,55 19,70 [19,70]
 - [10:29:52] Encoding using constant quality mode.
 - [10:30:29] Video Encode complete
 - [10:30:29] Processing audio tracks
 - [10:30:29] Multiplexing M2TS
 - [10:30:34] Processing: VID_00598 (11 of 15)
 - [10:30:34] Extracting A/V streams [VID_00598]
 - [10:30:45] Reencoding video [VID_00598]
   - Rate/Length: 23,976fps, 3.575 frames
 - [10:30:45] Performing CQM Prediction...
   - Analyzing 5,00 18,05 18,40 [18,42]
 - [10:30:56] Encoding using constant quality mode.
 - [10:31:21] Video Encode complete
 - [10:31:21] Processing audio tracks
 - [10:31:21] Multiplexing M2TS
 - [10:31:25] Processing: VID_00599 (12 of 15)
 - [10:31:25] Extracting A/V streams [VID_00599]
 - [10:31:39] Reencoding video [VID_00599]
   - Rate/Length: 23,976fps, 5.426 frames
 - [10:31:39] Performing CQM Prediction...
   - Analyzing 5,00 18,70 22,10 22,75 [22,75]
 - [10:31:55] Encoding using constant quality mode.
 - [10:32:35] Video Encode complete
 - [10:32:35] Processing audio tracks
 - [10:32:35] Multiplexing M2TS
 - [10:32:40] Processing: VID_00600 (13 of 15)
 - [10:32:40] Extracting A/V streams [VID_00600]
 - [10:32:53] Reencoding video [VID_00600]
   - Rate/Length: 23,976fps, 2.505 frames
 - [10:32:53] Performing CQM Prediction...
   - Analyzing 5,00 18,15 18,75 [18,75]
 - [10:33:06] Encoding using constant quality mode.
 - [10:33:26] Video Encode complete
 - [10:33:26] Processing audio tracks
 - [10:33:26] Multiplexing M2TS
 - [10:33:31] Processing: VID_00601 (14 of 15)
 - [10:33:31] Extracting A/V streams [VID_00601]
 - [10:33:38] Reencoding video [VID_00601]
   - Rate/Length: 23,976fps, 1.844 frames
 - [10:33:39] Performing CQM Prediction...
   - Analyzing 5,00 18,95 20,00 [20,00]
 - [10:33:51] Encoding using constant quality mode.
 - [10:34:10] Video Encode complete
 - [10:34:10] Processing audio tracks
 - [10:34:10] Multiplexing M2TS
 - [10:34:15] Processing: VID_00602 (15 of 15)
 - [10:34:15] Extracting A/V streams [VID_00602]
 - [10:34:19] Reencoding video [VID_00602]
   - Rate/Length: 23,976fps, 144 frames
   - Bitrate: 2.187 Kbs
 - [10:34:20] Reencoding: VID_00602, Pass 1 of 2
 - [10:34:23] Reencoding: VID_00602, Pass 2 of 2
 - [10:34:23] Video Encode complete
 - [10:34:23] Processing audio tracks
 - [10:34:23] Multiplexing M2TS
[10:34:28]PHASE ONE complete
[10:34:28]PHASE TWO - Rebuild Started
 - [10:34:28] Rebuilding BD file Structure
[10:34:59] - Encode and Rebuild complete
[10:34:59] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - SONIC_THE_HEDGEHOG folder removed.
[10:55:00] JOB: SONIC_THE_HEDGEHOG finished.
Old 14th July 2021, 06:59   #30723  |  Link
spotswood
[QUOTE=cartman0208;1947519]The relevant mediainfo I already posted.
Your example is not what I am describing. It doesn't look like you are re-encoding the Atmos track but keeping the CORE AC3 track as shown above in BOLD which does not need to be re-encoded. The log should show that the Atmos track is being re-encoded as in my log below. Please run the job again and set up BDRB to re-encode the Atmos track to AC3 and post the results. Thanks for your help.
[07/06/21] BD Rebuilder v0.61.22
[09:51:52] Source:  THE_GOOD_THE_BAD_AND_THE_UGLY_00800
  - Input BD size: 39.98 GB
  - Approximate total content: [02:58:36.622]
  - Target BD size: 22.95 GB
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), 1-Pass VBR
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[09:51:52] PHASE ONE, Encoding
 - [09:51:52] Processing: VID_01559 (1 of 1)
 - [09:51:52] Extracting A/V streams [VID_01559]
 - [10:00:01] Reencoding video [VID_01559]
   - Rate/Length: 23.976fps, 256,942 frames
   - Bitrate: 15,731 Kbs
 - [10:00:01] Reencoding: VID_01559, Pass 1 of 1
 - [10:22:50] Video Encode complete
 - [10:22:50] Processing audio tracks
[10:23:09]PHASE ONE complete
[10:23:09]PHASE TWO - Rebuild Started
 - [10:23:09] Rebuilding BD file Structure
[10:23:43] - Encode and Rebuild complete
[10:23:43] JOB: THE_GOOD_THE_BAD_AND_THE_UGLY finished.
[07/06/21] Checking System Settings
  - BD-Rebuilder v0.61.22
  - Working Path Free Space: 157.42GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - X264:  Ok
  - X265:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[07/06/21] Systems Settings Check complete
Old 14th July 2021, 07:02   #30724  |  Link
spotswood
Can you also post the relevant logs, .inf and MediaInfo from your GB&U job? Thanks for your help...
Old 14th July 2021, 08:24   #30725  |  Link
cartman0208
So what should the original audio track look like?
I think you did not post pre-encode mediainfo.
I can then try to find the same from my collection
Old 14th July 2021, 13:22   #30726  |  Link
MrVideo
MrVideo's Avatar
Unless I am missing something, why would you want to re-encode to AC3 when extracting the core is the easier and better route?
Old 14th July 2021, 21:10   #30727  |  Link
spotswood
As MrVideo mentions in his quote below, discs with TrueHD/Atmos just extract the core AC3 which is what yours did correctly, my mistake. If you have one, try a disc with a DTS-MA or LPCM track and post your results, thanks.
You are right, my bad. I was thinking BDRB did the same thing as it does with a non-TrueHD/Atmos track, by re-encoding to AC3...
Here's my pre-encode MediaInfo of my GB&U disc:
General
Complete name                  : N:\\\BDMV\PLAYLIST\00800.mpls
Format                         : Blu-ray Playlist
File size                      : 570 Bytes
Duration                       : 2 h 58 min
Overall bit rate mode          : Variable
Overall bit rate               : 0 b/s
Video
Menu ID                        : 1 (0x1)
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings                : CABAC / 4 Ref Frames
Format settings, CABAC         : Yes
Format settings, Reference fra : 4 frames
Codec ID                       : 27
Bit rate mode                  : Variable
Maximum bit rate               : 35.0 Mb/s
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
format_identifier              : HDMV
Source                         : 01559.m2ts
Audio #1
Menu ID                        : 1 (0x1)
Format                         : DTS XLL
Format/Info                    : Digital Theater Systems
Commercial name                : DTS-HD Master Audio
Muxing mode                    : Stream extension
Codec ID                       : 134
Channel(s)                     : 6 channels
Channel layout                 : C L R Ls Rs LFE
Sampling rate                  : 48.0 kHz
Frame rate                     : 93.750 FPS (512 SPF)
Bit depth                      : 24 bits
Compression mode               : Lossless
Language                       : English
Source                         : 01559.m2ts
Audio #2
Menu ID                        : 1 (0x1)
Format                         : AC-3
Format/Info                    : Audio Coding 3
Commercial name                : Dolby Digital
Codec ID                       : 129
Bit rate mode                  : Constant
Bit rate                       : 192 kb/s
Channel(s)                     : 1 channel
Channel layout                 : C
Frame rate                     : 31.250 FPS (1536 SPF)
Compression mode               : Lossy
Stream size                    : 245 MiB
Language                       : English
Service kind                   : Complete Main
bsid                           : 6
Dialog Normalization           : -31
Dialog Normalization           : -31 dB
compr                          : 5.74
compr                          : 5.74 dB
dynrng                         : 5.60
dynrng                         : 5.60 dB
acmod                          : 1
lfeon                          : 0
dialnorm_Average               : -31
dialnorm_Average               : -31 dB
dialnorm_Minimum               : -31
dialnorm_Minimum               : -31 dB
dialnorm_Maximum               : -31
dialnorm_Maximum               : -31 dB
dialnorm_Count                 : 800
compr_Average                  : 1.76
compr_Average                  : 1.76 dB
compr_Minimum                  : -8.52
compr_Minimum                  : -8.52 dB
compr_Maximum                  : 6.02
compr_Maximum                  : 6.02 dB
compr_Count                    : 761
dynrng_Average                 : 2.24
dynrng_Average                 : 2.24 dB
dynrng_Minimum                 : -8.34
dynrng_Minimum                 : -8.34 dB
dynrng_Maximum                 : 5.88
dynrng_Maximum                 : 5.88 dB
dynrng_Count                   : 792
format_identifier              : AC-3
Source                         : 01559.m2ts
And post-encode MediaInfo of GB&U:
General
Complete name                  : C:\Users\eM-SSD\Videos\1080p_HEVC\THE_GOOD_THE_BAD_AND_THE_UGLY\\BDMV\PLAYLIST\00000.mpls
File size                      : 694 Bytes
Overall bit rate               : 1 b/s
Video
Menu ID                        : 1 (0x1)
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main 10@L4.1@High
Codec ID                       : 36
Bit rate                       : 15.2 Mb/s
Color space                    : YUV
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.307
Stream size                    : 19.0 GiB
Color range                    : Limited
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
Source                         : 00000.m2ts / 00000.m2ts
Audio
Menu ID                        : 1 (0x1)
Format                         : AC-3
Codec ID                       : 129
Bit rate                       : 640 kb/s
Channel layout                 : C
Stream size                    : 818 MiB
Language                       : English
bsid                           : 8
acmod                          : 1
lfeon                          : 0
dialnorm_Count                 : 1
SamplingCount_Source           : General_Duration
Duration_Source                : General_Duration
Old 14th July 2021, 22:46   #30728  |  Link
cartman0208
Done.
Luckily I had a small enough Bluray still on disk (despite Bruce Willis a terrible movie) so I didn't have to reencode the video.
Log:
[07.14.21] BD Rebuilder v0.61.21
[23:33:24] Source:  10_MINUTES_GONE
  - Input BD size: 21,50 GB
  - Approximate total content: [01:56:50.473]
[23:33:32] PHASE ONE, Encoding
 - [23:33:32] Processing: VID_00003 (1 of 3)
 - [23:33:32] Extracting A/V streams [VID_00003]
 - [23:37:04] Reencoding video [VID_00003]
 - [23:37:05] Keeping original video (no reencode)
 - [23:37:05] Processing audio tracks
   - Track 4352 (deu): Reencoding audio to AC3...
   - Track 4353 (eng): Reencoding audio to AC3...
 - [23:40:27] Multiplexing M2TS
 - [23:41:31] Processing: VID_00004 (2 of 3)
 - [23:41:31] Extracting A/V streams [VID_00004]
 - [23:41:37] Reencoding video [VID_00004]
 - [23:41:37] Keeping original video (no reencode)
 - [23:41:37] Processing audio tracks
 - [23:41:37] Multiplexing M2TS
 - [23:41:42] Processing: VID_00012 (3 of 3)
 - [23:41:42] Extracting A/V streams [VID_00012]
 - [23:42:00] Reencoding video [VID_00012]
 - [23:42:00] Keeping original video (no reencode)
 - [23:42:00] Processing audio tracks
 - [23:42:01] Multiplexing M2TS
[23:42:07]PHASE ONE complete
[23:42:07]PHASE TWO - Rebuild Started
 - [23:42:07] Rebuilding BD file Structure
[23:42:49] - Encode and Rebuild complete
[23:42:49] Writing BD structure to ISO file
 - 10_MINUTES_GONE folder removed.
[23:44:08] JOB: 10_MINUTES_GONE finished.
Before:
General
Complete name                            : V:\FullDisc\10 MINUTES GONE\BDMV\STREAM\00003.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 18.0 GiB
Duration                                 : 1 h 36 min
Overall bit rate                         : 26.7 Mb/s
Maximum Overall bit rate                 : 48.0 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format settings                          : CABAC / 2 Ref Frames
Format settings, Reference frames        : 2 frames
Codec ID                                 : 27
Maximum bit rate                         : 30.2 Mb/s
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : DTS XLL
Codec ID                                 : 134
Bit depth                                : 16 bits
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : DTS XLL
Codec ID                                 : 134
Bit depth                                : 16 bits
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
After:
General
Complete name                            : U:\BD-Output\10_MINUTES_GONE\BDMV\STREAM\00003.m2ts
Format                                   : BDAV
File size                                : 16.5 GiB
Overall bit rate                         : 24.6 Mb/s
Maximum Overall bit rate                 : 35.5 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Codec ID                                 : 27
Bit rate                                 : 22.3 Mb/s
Bits/(Pixel*Frame)                       : 0.449
Stream size                              : 15.0 GiB (91%)
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Bit rate                                 : 640 kb/s
Channel layout                           : L R C LFE Ls Rs
Stream size                              : 441 MiB (3%)
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Bit rate                                 : 640 kb/s
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
IMO a normal result ... I have no Idea what could be different on your side.
Old 15th July 2021, 20:12   #30729  |  Link
spotswood
Done... Luckily I had a small enough Bluray still on disk (despite Bruce Willis a terrible movie) so I didn't have to reencode the video. IMO a normal result ... I have no Idea what could be different on your side.
I have no idea either. Thanks for testing...
Old 16th July 2021, 00:14   #30730  |  Link
@spotswood
It looks like there are two audio channels on the original. The second one says:
Bit rate                       : 192 kb/s
Channel layout                 : C
Any chance that your settings (e.g. language) is telling BD-RB to keep the second (mono) one?
Old 16th July 2021, 05:05   #30731  |  Link
spotswood
@spotswood
Bit rate                       : 192 kb/s
Channel layout                 : C
Yes, I saw that too and thought it might be the culprit, but it's the original mono track from the movie which I de-selected. If you look at the pre-encode MediaInfo in my post above it shows:
Audio #1
Menu ID : 1 (0x1)
Format : DTS XLL
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 192 kb/s
Channel layout : C
...and post encode:
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Channel layout : C
BDRB is definitely re-encoding the DTS-MA track since it has the same ID #4352. The original Mono track has ID #4353 and is not included since I de-selected it. I did Atomic Blonde which doesn't have a Mono track that I'll post below...
Old 16th July 2021, 05:25   #30732  |  Link
spotswood
OK, here's Atomic Blonde. I would normally keep this DTS-X 7.1 track, but am using this as an example:
MediaInfo Pre-Encode:
General
File size                      : 578 Bytes
Duration                       : 1 h 54 min
Video
Menu ID                        : 1 (0x1)
Format                         : AVC
Codec ID                       : 27
Maximum bit rate               : 34.0 Mb/s
Color space                    : YUV
Bit depth                      : 8 bits
Source                         : 00246.m2ts
Audio #1
Menu ID                        : 1 (0x1)
Format                         : DTS XLL X
Codec ID                       : 134
Channel(s)                     : Object Based
Channel layout                 : Object Based
Language                       : English
Source                         : 00246.m2ts
BDRB .inf:
[Status]
LABEL=ATOMIC_BLONDE
VERSION=v0.61.22
SOURCE_SIZE=35696302080
SOURCE_VIDEO_SIZE=35696302080
TARGET_SIZE=24641536000
REDUCTION=.690310608218609
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=4
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00246]
AUDIO=1000
PGS=10000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24641536000
RATE=25786
NSIZE=0
FLINK=0
MLINK=0
BDRB Log:
[07/14/21] BD Rebuilder v0.61.22
[11:27:24] Source:  ATOMIC_BLONDE_00800
  - Input BD size: 33.24 GB
  - Approximate total content: [01:54:44.294]
[11:27:24] PHASE ONE, Encoding
 - [11:27:24] Processing: VID_00246 (1 of 1)
 - [11:27:24] Extracting A/V streams [VID_00246]
 - [11:32:37] Reencoding video [VID_00246]
   - Rate/Length: 23.976fps, 165,058 frames
   - Bitrate: 25,786 Kbs
 - [11:32:37] Reencoding: VID_00246, Pass 1 of 1
 - [11:48:09] Video Encode complete
 - [11:48:09] Processing audio tracks
[11:48:14]PHASE ONE complete
[11:48:14]PHASE TWO - Rebuild Started
 - [11:48:14] Rebuilding BD file Structure
[11:48:52] - Encode and Rebuild complete
 - WORKFILES folder removed.
[11:48:52] JOB: ATOMIC_BLONDE finished.
MediaInfo Post-Encode:
General
Complete name                  : C:\Users\eM-SSD\Videos\1080p_HEVC\ATOMIC_BLONDE\\BDMV\PLAYLIST\00000.mpls
File size                      : 526 Bytes
Video
Menu ID                        : 1 (0x1)
Format                         : HEVC
Codec ID                       : 36
Bit rate                       : 25.5 Mb/s
Color space                    : YUV
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.512
Stream size                    : 20.4 GiB
Audio
Menu ID                        : 1 (0x1)
Format                         : AC-3
Codec ID                       : 129
Bit rate                       : 640 kb/s
Channel layout                 : C
Stream size                    : 525 MiB
Language                       : English
bsid                           : 8
acmod                          : 1
lfeon                          : 0
dialnorm_Count                 : 1
So once again BDRB is re-encoding the main DTS-MA track ID #4352 to AC3 Mono, no doubt about it. I don't know what else to do. As I mentioned, I don't mind the extra step to re-encode selected titles to AC3 prior to processing with BDRB, but would rather figure out what the problem is. If anyone else can chime in with any suggestions please feel free. Thanks for any help.
Old 16th July 2021, 06:59   #30733  |  Link
cartman0208
Would you share your bdrebuilder.ini?
Old 16th July 2021, 20:59   #30734  |  Link
spotswood
Here ya go...
[Options]
VERSION=0.61.0.22
ENCODER=1
MODE=3
ENCODE_QUALITY=3
ONEPASS_ENCODING=2
AUTO_QUALITY=0
NVENC_CAPABLE=1
TARGET_SIZE=23500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=3
AVCHD=0
REMOVE_WORKFILES=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=1
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=20480
MOVIE_ONLY_LOOP=0
ENABLE_TEST=1
ENABLE_BLANKING=1
BLANK_THRESHOLD=1800
MULTIPROCESS=1
BEEP_SOUNDFILE=C:\Windows\Media\tada.wav
UHD_CONVERT_ENABLE=1
UHD_ALL_MODE=1
MOVIEONLY_TYPE=0
UHD_V3_MODE=1
FORCE_NOENCODE=0
[Paths]
DGIndexNV=C:\Users\eM-SSD\Downloads\dgdecnv2053v228\x32 Binaries\DGIndexNV.exe
DGDecNV=C:\Users\eM-SSD\Downloads\dgdecnv2053v228\x32 Binaries\DGDecodeNV.dll
SOURCE_PATH=N:\
WORKING_PATH=C:\USERS\EM-SSD\VIDEOS\1080P_HEVC\
Old 17th July 2021, 09:33   #30735  |  Link
cartman0208
Here ya go...
You have "Do not reencode AC3" enabled ... did you try to uncheck that box?
Old 17th July 2021, 19:58   #30736  |  Link
Ok. I just did a disc with a source audio track that was DTS-HD XLL. Here is the MEDIAINFO result on the output:
Audio
Format                                   : AC-3
Duration                                 : 3 h 6 min
Bit rate                                 : 640 kb/s
Channel positions                        : Front: L C R, Side: L R, LFE
Bit depth                                : 16 bits
Stream size                              : 854 MiB (100%)
I'll try a couple other discs... but I'm (at least on this disc) not seeing the issue.
Old 17th July 2021, 20:33   #30737  |  Link
Just did another one. Input:
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD / AC-3
Format profile                           : TrueHD+Atmos / TrueHD / AC-3
Codec ID                                 : 131
Bit rate mode                            : Variable / Constant
Bit rate                                 : 640 kb/s
Maximum bit rate                         : 9 858 kb/s
Channel(s)                               : Object Based / 8 channels / 6 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            :  / 48.0 kHz / 48.0 kHz
Bit depth                                : 16 bits
Delay relative to video                  : -1 ms
Output:
Audio
Format                                   : AC-3
Duration                                 : 2 h 2 min
Bit rate                                 : 640 kb/s
Bit depth                                : 16 bits
Stream size                              : 559 MiB (100%)
For anyone who wants to test this, I added:
AUDIO_AMPLIFY=1.0
to the INI file. This forces BD-RB to reencode (to a volume of 1.0x the original) instead of keeping the 640Kbs core audio.
 - [13:20:30] Processing: VID_00003 (1 of 1)
 - [13:20:31] Processing audio tracks
The bottom line is that it is doing exactly what it is supposed to do.
Now I'm going to load spotswood's INI and try it again.
Old 17th July 2021, 21:00   #30738  |  Link
Ok. Using spotswood's INI settings, BD-RB kept the original core audio (it didn't reencode). Using the same source as my last post, the output looks like this:
Audio
Format                                   : AC-3
Bit rate                                 : 640 kb/s
Bit depth                                : 16 bits
Next I will add AUDIO_AMPLIFY=1.0 in order to force reencoding of the audio track (I may also have to change the SETUP setting that says "Do not reencode AC3")
@spotswood
Are you sure this INI is the one you used? If so, why is your log showing a reencode while mine isn't? One other thing... have you tried using MEDIAINFO on the output M2TS instead of the MPLS, just to see if it reports something different (it doesn't on mine)?
[EDIT]
Ok. Now I did it with AUDIO_AMPLIFY set and "Do not reencode AC3" unchecked:
Audio
Format                                   : AC-3
Bit rate                                 : 640 kb/s
Bit depth                                : 16 bits
Looks good to me...
Old 17th July 2021, 22:00   #30739  |  Link
spotswood
Problem Solved!
@spotswood
Yes, I'm sure. I'm guessing in your second example BDRB is just pulling the core AC3 track from the TrueHD track, no reencode needed. In your first example the disc has a DTS-MA track that requires reencoding to AC3.
Anyway, I'VE FIXED THE PROBLEM! I mentioned before that I had started over and re-downloaded and unzipped a fresh v0.61.22 of BDRB leaving everything stock w/o adding any hidden options etc. but the same problem persisted.
Since running the System Settings Check showed everything to be fine, I didn't think to reinstall the helper programs, namely AviSynth. So after reinstalling v2.60 and trying again, voila! The lossless tracks are properly being reencoded to AC3 5.1@640 like they're supposed to. Something must have corrupted my AviSynth installation, I don't know, but after reinstalling it everything is fine now.
What a relief! I was going crazy and really didn't want to wipe my drive and do a fresh W10 install. I apologize again for sending everyone trying to help (namely jdobbs) on a wild goose chase. I feel so stupid that I didn't think to reinstall everything (troubleshooting 101). Whole carton of eggs on face. If I post with what I think is a bug in the future, just ignore me. I'll figure it out eventually...
Old 17th July 2021, 22:08   #30740  |  Link
spotswood
Yes, with or without it didn't make a difference. This option is checked by default and I've always left it that way. It doesn't seem to make a difference either way. The only options I change depending on the job are "Do not convert DTS to AC3" (when keeping the DTS core), and "Keep HD audio for BD25 intact" (self explanatory and only for 7.1 tracks, personal preference). Thanks again for trying to help. When in doubt, reinstall everything!
