Old 7th June 2010, 18:51   #8541  |  Link
@hasaro
Is it out-of-sync from the start, somewhere in the middle, or does it gradually go out-of-sync? Is it the English track or one of the others?
Old 7th June 2010, 19:06   #8542  |  Link
Kampfwurstwasser
Hi, i always wondered why my CPU is not under full load at the first pass when encoding to a BD25. It's about 35FPS. Is it a decoding issue? I thought that dxva gpu decoding with ffdshow is alot faster than cpu encoding with x264? The 2nd pass is alot slower and all 8 threads are then under full load.
Kampfwurstwasser is offline   Reply With Quote
Old 7th June 2010, 19:14   #8543  |  Link
haznpapo
@ jdobbs
Excellent work All My Titles Work 100%.I have Done Over 100 Titles.Thank You In Advance!!
haznpapo is offline   Reply With Quote
Old 7th June 2010, 19:19   #8544  |  Link
I've noticed the same thing. I'm not sure why, but I have always assumed it was FFDSHOW's frame-serving as well. It'd be nice to speed things up... I'll do a little experimenting.
Old 7th June 2010, 20:06   #8545  |  Link
hasaro
@jdobbs
In the beginning is barely noticeable, but in the end of the movie, he audio is ahead regarding the movement of the mouth in about 1 s. ]I Just check the audio in English not the French.
@hasaro
hasaro is offline   Reply With Quote
Old 8th June 2010, 07:12   #8546  |  Link
tekmobile
Webmaster
Has something changed in regard to Win7 and VC-1 because I have two Win7 64Bit Systems and neither of them will do any VC-1 Streams anymore the last time I had to do a VC-1 Disc I had to do it through a VM running Vista.
 - [06:56:54] Reencoding: VID_00019 (1 of 22)
 - [06:56:54] Collecting video information
   - Rate/Length: 23.976fps, 448 frames
   - Bitrate: 16,715 Kbs
 - [06:56:54] Reencoding: VID_00019, Pass 1 of 1
  - Encode failed.  Retrying.
  - Reached retry limit.  Aborting.
  - BD-Rebuilder v0.34.02 (beta)
  - Windows Version: 6.1 [7600]
  - HAALI Splitter:  Ok
  - FFDSHOW: 3326, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "ffmpeg-mt":  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[07:01:19] - Failed video encode, aborted
tekmobile is offline   Reply With Quote
Old 8th June 2010, 14:26   #8547  |  Link
  - FFDSHOW: 3326, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
Nope. If something has changed it would be on your end. I'd recommend reinstalling the helper apps (including AVISYNTH 2.5.7) and see if that fixes it.
[Edit] I'm running Windows 7 64 bit on my video system with no issues. It is up-to-date with all updates/patches.
Old 8th June 2010, 18:31   #8548  |  Link
ellusian
Any ideas on how to fix the ImgBurn launch/finish issues as posted above?
I tested manually launching the ImgBurn app after creating the 'movie-only' content folder in BD-Rebuilder. Worked fine. Just fails to launch w/in the app as a single 'process'. I'm running BD-Rebuilder and ImgBurn in 'admin' mode, have anti-virus off (only way ImgBurn will launch)...what else should I try/look for. I believe I've attempted w/ UAC all the way off as well. Does the location of either BD-Rebuilder or the ImgBurn app make a difference (BD-Rebuilder is on the desktop; ImgBurn is in the Project folder)?
Thx
UPDATE: Did three more burns, letting it fail and manually initiating the ImgBurn session. On third title, I came back to the computer to find a fully finished session w/ a perfectly burned blu-ray. It's worked ever since (2-3 more titles/sessions). Can't say that I did anything other than a couple of restarts w/ anti-virus off. Now I can even run ImgBurn w/ anti-virus on. Very odd. I'm thinking the various security measures embedded in Win7 and/or my BitDefender 2010 were causing the issue, and somewhere along the line, they created a pref file that recognized ImgBurn as 'OK.' Sigh--at least I'm now working @ %100, even thought I don't know exactly why...
ellusian is offline   Reply With Quote
Old 8th June 2010, 19:20   #8549  |  Link
Thx
Sorry. But unfortunately all I can say is that it works for me and everybody else... so I don't see what I can possibly do from this end to make it work differently on your system.
Old 8th June 2010, 19:49   #8550  |  Link
By-Tor
Hi jdobbs,on the img/burn i've got an issue that under win7 32-bit imgburn will only burn media at a max of 0.2x. wiped system put xp back on writing at 4.1x again very strange
any one else had this?????
p.s. sorry i know this is not a bug with bd rebuilder.
By-Tor is offline   Reply With Quote
Old 8th June 2010, 20:00   #8551  |  Link
Definitely weird. Sounds like a bug in the driver for your specific burner. I'm running two burners on my Windows 7 64 bit system and another on my Windows 7 32 bit system. All are working fine with ImgBurn.
Old 9th June 2010, 01:19   #8552  |  Link
DGenerateKane
Former Kanenite
Originally Posted by Race Guy View Post
Also, (assuming you use ImgBurn) go to:
Tools >> Settings >> Write Page 1 & make sure these are checked:
DVD RAM/BD-RE Fast Write
Prefer Format With Full Cert
Prefer Format Without Spare Areas
Prefer Properly Formatted Discs
Prefer Format Size "Maximum"
I'm not sure how many of those are default? If you don't check "fast write", you'll only burn maybe 1x. With it checked, my LG burns at 2.3x. And, if you don't check "without spare areas" (& maybe "Maximum"??) you'll end up with a disc that is undersize (I think it was 1.5GB??) compared to a BD-R.
Thanks! Prefer Format Size was the only option I needed to change, and it worked!
DGenerateKane is offline   Reply With Quote
Old 9th June 2010, 14:27   #8553  |  Link
DK
DK's Avatar
I experienced an "audio encode error" last night and it seems that AFTEN does not like/accept the special character in the
name of my output directory - cf. the second log.
[02:00:44] BD Rebuilder v0.34.02 (beta)
  - Source:  WUESTENBLUME_BD
  - Input BD size: 30,71 GB
  - Approximate total content: [02:07:39.916]
  - Target BD size: 7,72 GB
  - Windows Version: 5.1 [2600]
  - MOVIE-ONLY mode enabled
- Resuming from previously started job.
[02:00:47] PHASE ONE, Encoding
 - [02:00:47] Reencoding: VID_00000 (1 of 1)
 - [02:00:47] Collecting video information
   - Rate/Length: 24,000fps, 183.838 frames
   - Bitrate: 6.541 Kbs
 - [02:00:47] Reencoding: VID_00000, Pass 1 of 2
 - [04:11:53] Reencoding: VID_00000, Pass 2 of 2
 - [08:48:08] Video Encode complete
 - [08:48:09] Reencoding audio tracks (if req'd)
 - ERROR in attempt to reencode audio (AFTEN) [AUD_00000__4352.AVS]
[08:48:11] - Failed to reencode audio, aborted
I now used Eac3to to convert the DTS stream to AC3 but I did try from the original workfile folder WITH the special character inside its name:
eac3to v3.18
command line: "C:\Programme\eac3to\eac3to.exe" "F:\DVD\wüstenblume\WORKFILES\00000.track_4353.dts" "F:\DVD\wüstenblume\WORKFILES\4353.ac3" -640
DTS, 5.1 channels, 2:07:40, 16 bits, 1509kbps, 48khz
The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
Patching bitdepth to 24 bits...
Decoding with libav/ffmpeg...
Remapping channels...
Encoding AC3 <640kbps> with libAften...
Creating file "F:\DVD\wüstenblume\WORKFILES\4353.ac3"...
The last DTS frame is incomplete and thus gets skipped.  <WARNING>
eac3to processing took 3 minutes, 54 seconds.
Done.
So the question is: could BD RB made to check for any such issues when starting the process or where does libAften differ?
Old 9th June 2010, 15:05   #8554  |  Link
@DK
Sorry, I don't think I understand. Is it the ü in the path that caused it to fail?
Old 9th June 2010, 15:48   #8555  |  Link
santito
batch
i think i found an issue here...
when i do a batch process (2 or more rebuilds).. even if i select the correct audios when i am doing the batch.. the program uses the ones that are selected in the setup
santito is offline   Reply With Quote
Old 9th June 2010, 16:30   #8556  |  Link
DK
DK's Avatar
@DK
Sorry if i wasn't clear enough.
Yes, the output path name contains that name "Wüstenblume" - the english title is "desert flower".
The full path can be seen n the eac3to log.
And I SUPECT that to be the reason as the next title in the batch queue and all previous conversion did not fail with this audio extraction error.
Or was there a limitation with avisynth concerning path names?
Or am I mistaken and it was just bad luck?
Old 9th June 2010, 16:45   #8557  |  Link
DK
DK's Avatar
Hmmm, misery loves company, doesnt it?
The second title I did shows two problems:
- the original material offers a selection marker in the initial menu
- the converted material does NOT show this marker - cf. attachments.
I am not able to get this full movie back to play beyond the initial menu.
I wouldnt know which further infos I could provide on this issues?
[08:48:17] BD Rebuilder v0.34.02 (beta)
  - Source:  LE_MEPRIS
  - Input BD size: 43,91 GB
  - Approximate total content: [04:48:58.509]
  - Target BD size: 22,66 GB
[08:48:17] PHASE ONE, Encoding
 - [08:48:18] Extracting A/V streams [VID_00079]
 - [08:48:18] Reencoding: VID_00079 (1 of 24)
 - [08:48:18] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29,970fps, 30 frames
 - [08:48:18] Reencoding: VID_00079, Pass 1 of 1
 - [08:48:21] Video Encode complete
 - [08:48:21] Reencoding audio tracks (if req'd)
 - [08:48:21] Multiplexing M2TS
 - [08:48:22] Extracting A/V streams [VID_00003]
 - [08:48:24] Reencoding: VID_00003 (2 of 24)
 - [08:48:24] Collecting video information
   - Rate/Length: 24,000fps, 1.440 frames
 - [08:48:25] Reencoding: VID_00003, Pass 1 of 1
 - [08:49:00] Video Encode complete
 - [08:49:00] Reencoding audio tracks (if req'd)
 - [08:49:00] Multiplexing M2TS
 - [08:49:01] Extracting A/V streams [VID_00002]
 - [08:49:04] Reencoding: VID_00002 (3 of 24)
 - [08:49:04] Collecting video information
   - Rate/Length: 24,000fps, 1.488 frames
 - [08:49:04] Reencoding: VID_00002, Pass 1 of 1
 - [08:49:41] Video Encode complete
 - [08:49:41] Reencoding audio tracks (if req'd)
 - [08:49:41] Multiplexing M2TS
 - [08:49:43] Extracting A/V streams [VID_00036]
 - [08:49:47] Reencoding: VID_00036 (4 of 24)
 - [08:49:47] Collecting video information
   - Rate/Length: 29,970fps, 4.533 frames
 - [08:49:47] Reencoding: VID_00036, Pass 1 of 1
 - [08:50:02] Video Encode complete
 - [08:50:02] Reencoding audio tracks (if req'd)
 - [08:50:02] Multiplexing M2TS
 - [08:50:04] Extracting A/V streams [VID_00082]
 - [08:50:07] Reencoding: VID_00082 (5 of 24)
 - [08:50:07] Collecting video information
   - Rate/Length: 23,976fps, 1.560 frames
 - [08:50:07] Reencoding: VID_00082, Pass 1 of 1
 - [08:50:43] Video Encode complete
 - [08:50:43] Reencoding audio tracks (if req'd)
 - [08:50:43] Multiplexing M2TS
 - [08:50:45] Extracting A/V streams [VID_00083]
 - [08:50:51] Reencoding: VID_00083 (6 of 24)
 - [08:50:51] Collecting video information
   - Rate/Length: 24,000fps, 1.679 frames
 - [08:50:51] Reencoding: VID_00083, Pass 1 of 1
 - [08:52:17] Video Encode complete
 - [08:52:17] Reencoding audio tracks (if req'd)
 - [08:52:17] Multiplexing M2TS
 - [08:52:18] Extracting A/V streams [VID_00076]
 - [08:52:25] Reencoding: VID_00076 (7 of 24)
 - [08:52:25] Collecting video information
 - [08:52:25] Reencoding: VID_00076, Pass 1 of 1
 - [08:53:49] Video Encode complete
 - [08:53:49] Reencoding audio tracks (if req'd)
 - [08:53:49] Multiplexing M2TS
 - [08:53:51] Extracting A/V streams [VID_00052]
 - [08:53:57] Reencoding: VID_00052 (8 of 24)
 - [08:53:57] Collecting video information
 - [08:53:57] Reencoding: VID_00052, Pass 1 of 1
 - [08:55:19] Video Encode complete
 - [08:55:19] Reencoding audio tracks (if req'd)
 - [08:55:19] Multiplexing M2TS
 - [08:55:20] Extracting A/V streams [VID_00055]
 - [08:55:26] Reencoding: VID_00055 (9 of 24)
 - [08:55:27] Collecting video information
 - [08:55:27] Reencoding: VID_00055, Pass 1 of 1
 - [08:56:42] Video Encode complete
 - [08:56:42] Reencoding audio tracks (if req'd)
 - [08:56:42] Multiplexing M2TS
 - [08:56:43] Extracting A/V streams [VID_00045]
 - [08:56:49] Reencoding: VID_00045 (10 of 24)
 - [08:56:49] Collecting video information
 - [08:56:49] Reencoding: VID_00045, Pass 1 of 1
 - [08:58:15] Video Encode complete
 - [08:58:15] Reencoding audio tracks (if req'd)
 - [08:58:15] Multiplexing M2TS
 - [08:58:17] Extracting A/V streams [VID_00049]
 - [08:58:23] Reencoding: VID_00049 (11 of 24)
 - [08:58:23] Collecting video information
 - [08:58:23] Reencoding: VID_00049, Pass 1 of 1
 - [08:59:45] Video Encode complete
 - [08:59:45] Reencoding audio tracks (if req'd)
 - [08:59:45] Multiplexing M2TS
 - [08:59:46] Extracting A/V streams [VID_00064]
 - [08:59:53] Reencoding: VID_00064 (12 of 24)
 - [08:59:53] Collecting video information
 - [08:59:53] Reencoding: VID_00064, Pass 1 of 1
 - [09:01:17] Video Encode complete
 - [09:01:17] Reencoding audio tracks (if req'd)
 - [09:01:17] Multiplexing M2TS
 - [09:01:18] Extracting A/V streams [VID_00038]
 - [09:01:24] Reencoding: VID_00038 (13 of 24)
 - [09:01:24] Collecting video information
 - [09:01:24] Reencoding: VID_00038, Pass 1 of 1
 - [09:02:48] Video Encode complete
 - [09:02:48] Reencoding audio tracks (if req'd)
 - [09:02:48] Multiplexing M2TS
 - [09:02:49] Extracting A/V streams [VID_00067]
 - [09:02:55] Reencoding: VID_00067 (14 of 24)
 - [09:02:55] Collecting video information
 - [09:02:55] Reencoding: VID_00067, Pass 1 of 1
 - [09:04:12] Video Encode complete
 - [09:04:12] Reencoding audio tracks (if req'd)
 - [09:04:12] Multiplexing M2TS
 - [09:04:13] Extracting A/V streams [VID_00071]
 - [09:04:20] Reencoding: VID_00071 (15 of 24)
 - [09:04:20] Collecting video information
 - [09:04:20] Reencoding: VID_00071, Pass 1 of 1
 - [09:05:45] Video Encode complete
 - [09:05:45] Reencoding audio tracks (if req'd)
 - [09:05:45] Multiplexing M2TS
 - [09:05:46] Extracting A/V streams [VID_00042]
 - [09:05:53] Reencoding: VID_00042 (16 of 24)
 - [09:05:53] Collecting video information
 - [09:05:53] Reencoding: VID_00042, Pass 1 of 1
 - [09:07:13] Video Encode complete
 - [09:07:13] Reencoding audio tracks (if req'd)
 - [09:07:13] Multiplexing M2TS
 - [09:07:14] Extracting A/V streams [VID_00058]
 - [09:07:21] Reencoding: VID_00058 (17 of 24)
 - [09:07:21] Collecting video information
 - [09:07:21] Reencoding: VID_00058, Pass 1 of 1
 - [09:08:41] Video Encode complete
 - [09:08:41] Reencoding audio tracks (if req'd)
 - [09:08:41] Multiplexing M2TS
 - [09:08:43] Extracting A/V streams [VID_00061]
 - [09:08:50] Reencoding: VID_00061 (18 of 24)
 - [09:08:50] Collecting video information
 - [09:08:50] Reencoding: VID_00061, Pass 1 of 1
 - [09:10:10] Video Encode complete
 - [09:10:10] Reencoding audio tracks (if req'd)
 - [09:10:10] Multiplexing M2TS
 - [09:10:12] Extracting A/V streams [VID_00031]
 - [09:10:19] Reencoding: VID_00031 (19 of 24)
 - [09:10:19] Collecting video information
   - Rate/Length: 29,970fps, 9.928 frames
 - [09:10:19] Reencoding: VID_00031, Pass 1 of 1
 - [09:10:48] Video Encode complete
 - [09:10:48] Reencoding audio tracks (if req'd)
 - [09:10:48] Multiplexing M2TS
 - [09:10:50] Extracting A/V streams [VID_00035]
 - [09:11:14] Reencoding: VID_00035 (20 of 24)
 - [09:11:14] Collecting video information
   - Rate/Length: 29,970fps, 25.960 frames
 - [09:11:14] Reencoding: VID_00035, Pass 1 of 1
 - [09:12:41] Video Encode complete
 - [09:12:41] Reencoding audio tracks (if req'd)
 - [09:12:41] Multiplexing M2TS
 - [09:12:48] Extracting A/V streams [VID_00033]
 - [09:13:26] Reencoding: VID_00033 (21 of 24)
 - [09:13:26] Collecting video information
   - Rate/Length: 29,970fps, 56.680 frames
 - [09:13:26] Reencoding: VID_00033, Pass 1 of 1
 - [09:16:17] Video Encode complete
 - [09:16:17] Reencoding audio tracks (if req'd)
 - [09:16:17] Multiplexing M2TS
 - [09:16:26] Extracting A/V streams [VID_00032]
 - [09:17:37] Reencoding: VID_00032 (22 of 24)
 - [09:17:37] Collecting video information
   - Rate/Length: 29,970fps, 94.360 frames
 - [09:17:37] Reencoding: VID_00032, Pass 1 of 1
 - [09:22:14] Video Encode complete
 - [09:22:14] Reencoding audio tracks (if req'd)
 - [09:22:14] Multiplexing M2TS
 - [09:22:32] Extracting A/V streams [VID_00034]
 - [09:23:43] Reencoding: VID_00034 (23 of 24)
 - [09:23:43] Collecting video information
   - Rate/Length: 29,970fps, 109.605 frames
 - [09:23:43] Reencoding: VID_00034, Pass 1 of 1
 - [09:29:35] Video Encode complete
 - [09:29:35] Reencoding audio tracks (if req'd)
 - [09:29:35] Multiplexing M2TS
 - [09:29:54] Extracting A/V streams [VID_00000]
 - [09:37:24] Reencoding: VID_00000 (24 of 24)
 - [09:37:24] Collecting video information
   - Rate/Length: 24,000fps, 148.690 frames
   - Bitrate: 23.922 Kbs
 - [09:37:24] Reencoding: VID_00000, Pass 1 of 2
 - [11:20:19] Reencoding: VID_00000, Pass 2 of 2
 - [14:44:31] Video Encode complete
 - [14:44:31] Reencoding audio tracks (if req'd)
 - [14:44:31] Multiplexing M2TS
[14:58:04]PHASE ONE complete
[14:58:04]PHASE TWO - Rebuild Started
 - [14:58:04] Rebuilding BD file Structure
[14:58:32] - Encode and Rebuild complete
[14:58:32]JOB: LE_MEPRIS finished.
[Status]
LABEL=LE_MEPRIS
VERSION=v0.34.02 (beta)
SOURCE_SIZE=47143428438
SOURCE_VIDEO_SIZE=46304163840
TARGET_SIZE=24326963200
REDUCTION=.507248088598678
RESIZE_1080=0
AUDIO_TO_KEEP=deu;eng;
SUBS_TO_KEEP=deu;eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
QUICK=1
ENCODE_STEP=0
COMPLETED=24
REBUILD_COMPLETE=1
[00079]
AUDIO=0
PGS=000011
M2TS_TARGET=623306
NSIZE=18432
FLINK=0
MLINK=0
[00003]
AUDIO=
PGS=
M2TS_TARGET=58883760
NSIZE=26167296
FLINK=0
MLINK=0
[00002]
AUDIO=
PGS=
M2TS_TARGET=69695011
NSIZE=30314496
FLINK=0
MLINK=0
[00036]
AUDIO=0
PGS=0
M2TS_TARGET=90242308
NSIZE=50153472
FLINK=0
MLINK=0
[00082]
AUDIO=1
PGS=
M2TS_TARGET=96528354
NSIZE=66330624
FLINK=0
MLINK=0
[00083]
AUDIO=0
PGS=
M2TS_TARGET=183520118
NSIZE=43763712
FLINK=0
MLINK=0
[00076]
AUDIO=1
PGS=
M2TS_TARGET=185841935
NSIZE=58939392
FLINK=0
MLINK=0
[00052]
AUDIO=0
PGS=
M2TS_TARGET=185845052
NSIZE=43763712
FLINK=0
MLINK=0
[00055]
AUDIO=0
PGS=
NSIZE=43763712
FLINK=0
MLINK=0
[00045]
AUDIO=0
PGS=
M2TS_TARGET=185860634
NSIZE=43763712
FLINK=0
MLINK=0
[00049]
AUDIO=0
PGS=
M2TS_TARGET=185888683
NSIZE=43763712
FLINK=0
MLINK=0
[00064]
AUDIO=0
PGS=
M2TS_TARGET=185957247
NSIZE=43763712
FLINK=0
MLINK=0
[00038]
AUDIO=0
PGS=
M2TS_TARGET=185972829
NSIZE=43763712
FLINK=0
MLINK=0
[00067]
AUDIO=0
PGS=
NSIZE=43763712
FLINK=0
MLINK=0
[00071]
AUDIO=0
PGS=
NSIZE=43763712
FLINK=0
MLINK=0
[00042]
AUDIO=0
PGS=
M2TS_TARGET=185975946
NSIZE=43763712
FLINK=0
MLINK=0
[00058]
AUDIO=1
PGS=
NSIZE=58939392
FLINK=0
MLINK=0
[00061]
AUDIO=1
PGS=
M2TS_TARGET=185982179
NSIZE=58939392
FLINK=0
MLINK=0
[00031]
AUDIO=0
PGS=11000
M2TS_TARGET=204026901
NSIZE=64253952
FLINK=0
MLINK=0
[00035]
AUDIO=0
PGS=011000
M2TS_TARGET=519049098
NSIZE=363589632
FLINK=0
MLINK=0
[00033]
AUDIO=0
PGS=01100
M2TS_TARGET=1162232792
NSIZE=441606144
FLINK=0
MLINK=0
[00032]
AUDIO=0
PGS=01100
M2TS_TARGET=1881581418
NSIZE=802443264
FLINK=0
MLINK=0
[00034]
AUDIO=0
PGS=01100
M2TS_TARGET=2194250633
NSIZE=1022650368
FLINK=0
MLINK=0
[00000]
AUDIO=0000
PGS=110000110001
M2TS_TARGET=20005715626
RATE=23922
NSIZE=19416145920
FLINK=0
MLINK=0
And problem number two is: there is absolutely NO audio stream!
Checked with tsmuxer as well as playing just the m2ts file.
According to the log audio was processed but there is no stream in the m2ts nor in the workfiles folder.
Old 9th June 2010, 19:27   #8558  |  Link
gamete
WHen the bluray disk have two angles with the same duration,what i selected?
sorry for my bad english
gamete is offline   Reply With Quote
Old 9th June 2010, 19:42   #8559  |  Link
zeon
0.34.02 telling me to upgrade to latest version on my xp machine yet goes into my vista machine no prob,both machines have recently been reformatted all other apps have been installed any help appreciated
TIA
zeon is offline   Reply With Quote
Old 9th June 2010, 21:26   #8560  |  Link
raspi2
it's normal, jdobbs has an expiration on the app since it is BETA. he doesn't want an out of date app being used, especially in testing. just go grab the most up to date.
raspi2 is offline   Reply With Quote
