Old 22nd November 2013, 00:11   #261  |  Link
colinhunt
Originally Posted by videofan3d View Post
Minor update FRIM 1.16 is available.
Thank you. Any chance you could implement an option to use software decoding and hardware encoding in FRIMTranscode?
Old 22nd November 2013, 00:23   #262  |  Link
HWK
HWK's Avatar
Originally Posted by colinhunt View Post
Anyone know if there's a way to tell FRIM to start encoding from a specific frame number?
Originally Posted by Cedvano View Post
Demux with split option in TsMuxer. The only way I know.
Tsmuxer doesn't support split option when demux is activated.
Old 22nd November 2013, 00:24   #263  |  Link
videofan3d
1. you can try to use par-file (example):
-sw -i::h264 input.avc -o::sink
-hw -i::source -o::h264 output.avc
2. FRIM was so far compiled on Windows 7 and I didn't have a chance to test it on Intel Graphic card in -hw mode.
In near future I expect to have access to I7 Haswell so I'll check also -hw mode myself and try to figure out what's going on there.
videofan3d is offline   Reply With Quote
Old 22nd November 2013, 00:25   #264  |  Link
Cedvano
Mux with split and Demux it.
FRIMTranscode GUI 1.03(b)
version 1.03(b)
- Add Hardware acceleration option
- Add FRIMTranscode 1.16
- some minors corrections.
Edit: Please re-download it because an option have change (-n become -length)
Cedvano is offline   Reply With Quote
Old 22nd November 2013, 00:38   #265  |  Link
Jdobbs, I am just curious how soon one may expect 3D support. Just rough timeline will do for know.
I'm going to be going away for the Thanksgiving holiday starting Friday, so that will delay it. I don't think it will be too terribly difficult (given the fact that FRIM and TSMUXER is carrying most of the load). But since I'll have to do some testing before release, I'd guess mid-December. Maybe earlier if I get a real groove going.
Old 22nd November 2013, 00:45   #266  |  Link
Cedvano
Thanks in advance for your work !
Old 22nd November 2013, 00:47   #267  |  Link
HWK
HWK's Avatar
ok, thanks for info and have happy thanksgiving and in the mean time I will continue to run test and keep posted if I come across something interesting.
Old 22nd November 2013, 01:05   #268  |  Link
colinhunt
version 1.03(b)
Thank you for this. However, the output is useless if -hw is used for both decode and encode. If you have the time and the inclination, perhaps you could alter the Hardware acceleration is such a way that decoding is done in software and -hw is used for encode only?
Old 22nd November 2013, 01:11   #269  |  Link
Just remembered, I'm not leaving until Saturday. So I'll get some of it done tomorrow.
Old 22nd November 2013, 01:12   #270  |  Link
Sharc
I seem to get occasional glitches with FRIMTranscode.exe. Has anyone else experienced this? It happens with full length movies, you may not get it with short test clips.
The safest way seems still to be with FRIMDecode / FRIMEncode via pipes.
Old 22nd November 2013, 01:13   #271  |  Link
colinhunt
Wow, this parameter file seems to be working:
-sw -i::mvc left.264 right.mvc -o::sink
-hw -i::source -o::mvc hw_sink_outcombined.264 -vbr 22000 48000 -profile high -level 4.1 -u 5 -l 6 -cpbsize 3750 -n 500 -gop 24 4 0 O
It reports this while running:
MFX SOFTWARE Session 0 API ver 1.7 parameters:
Input  video:   AVC
Output video:   to child session
MFX dll:        C:\Users\xxxxxxxxxx\encoders\libmfxsw32.dll
MFX HARDWARE Session 1 API ver 1.7 parameters:
Input  video:   from parent session
Output video:   AVC
MFX dll:        C:\Users\xxxxxxxxxx\encoders\libmfxhw32.dll
Session 0 was NOT joined with other sessions
WARNING: partial acceleration
Session 1 was NOT joined with other sessions
Ohhkay, I should probably have put the "-n 500" on the decoder line...
Old 22nd November 2013, 01:18   #272  |  Link
videofan3d
Please note that -n has been renamed to -length ! (which is more self-explanatory - see Release notes )
Old 22nd November 2013, 01:22   #273  |  Link
colinhunt
I'm still on FRIMTranscode 1.15 - you're too quick!
Ooh, v1.16 reports more data:
Session 0:
Media SDK impl          SOFTWARE (C:\Users\xx\encoders\libmfxsw32.dll)
Media SDK version       1.7
Memory type             system
Input  video            AVC
Source picture:
  Resolution            1920x1088
  Crop X,Y,W,H          0,0,1920,1080
Frame rate              23.976
Output video            (to child session)
Session 1:
Media SDK impl          HARDWARE (C:\Users\xx\encoders\libmfxhw32.dll)
Memory type             d3d
Input  video            (from parent session)
Output video            AVC
Destination picture:
Frame rate              23.976
Bitrate control         VBR
  avg,maximum           30000,48000
GOP structure:
  GOP length            24
  I-/P-frame distance   4
  IDR-frame interval    0
  GOP type              Opened
Num of slices           8
Target usage            3
Nice!
Old 22nd November 2013, 01:29   #274  |  Link
colinhunt
That sounds a wee bit worrying.
Old 22nd November 2013, 01:34   #275  |  Link
Is there a way to force i-frames at certain points for chaptering?
Old 22nd November 2013, 01:37   #276  |  Link
colinhunt
Is still normal?
Transcoding finished
MFX session 0 transcoding passed
Processing time: 57.71 sec
Number of processed frames: 1000
MFX session 1 transcoding passed
Processing time: 58.42 sec
Number of processed frames: 500
This was with "-length 1000".
Old 22nd November 2013, 01:39   #277  |  Link
Sharc
Hmmm....... yes. I got it in two cases now (version 1.15 still).
Old 22nd November 2013, 01:40   #278  |  Link
Cedvano
Only with Stereoscopic Player, not with TMT6.
For me, I think is SP.
Old 22nd November 2013, 01:49   #279  |  Link
Sharc
Ahhh.... so there is hope ....
Old 22nd November 2013, 01:50   #280  |  Link
colinhunt
Interesting. Using the ::sink solution mentioned earlier, I can use "-level 4.1" and -labrc options together without transcoder errors. Or perhaps that collision was somehow fixed in v1.16.
encoders, mvc
