29th July 2018, 23:23 | #3001 | Link | |
It all started using x265 2.8+49 above
I'm using "awarpsharp2" only (AVS) I was thinking maybe changes in x265 parameters Quote:
30th July 2018, 16:26 | #3002 | Link |
It is possible something with x265 has changed. You can try going to a minimal set of x265 settings, something akin to the default profile for x265.
Does this happen very shortly after starting the encode? Or is this something that happens after the encode is well underway? Perhaps it happens at random points? Finally, I know x265 is under relative constant upgrading. Within the past 30 days there have been new releases. In the event they accidentally made a bug in the version you are testing, see if the current version resolves the issue. |
30th July 2018, 23:44 | #3003 | Link |
Thanks for the reply. I'll try to ask in x265 team aswell. I will run more tests and try to figure out which among the switches have been changed
2nd August 2018, 16:31 | #3004 | Link |
A new QSVEnc v3.09 is available but it's the last time I post on this thread until a real developer like Raven take in charge.
I'm under the impression that something happened between Stax and Raven and that conflict led to a temporary - I hope - pause of development for this application. I don't know if it's too early to declare this project dead, but definitely it doesn't look that much alive.
5th August 2018, 02:54 | #3005 | Link |
If Raven is monitoring this list, it would be helpful if we knew if he plans to go forward with the work he started. I know it was some time before someone else took over VirtualDub. Now VirtualDub has forked to VirtualDub 2. Hopefully if Raven doesn't want to continue the project, someone else will eventually take this forward. It simply is too useful to be left to fade away.
6th August 2018, 18:25 | #3006 | Link | |
I needed certain functions in staxrip didn't contain it's why I updated some features and added more filters and cut others that were never used. |
6th August 2018, 18:27 | #3007 | Link | |
The source code on my desktop got corrupted some how, so I had to restart from last code posted on github. The PC I use to program is very old. In the progress of building a new PC. I've been programming in python which has been taking up most of my time. Which is a massive program and everything had to be created from the ground up. Here is my releases for StaxRip: https://github.com/Revan654/staxrip/releases if anyone is interested. I have allot of things I been working on, and I had to do a bunch of search for python to see how it handles certain data types so I could use them properly. I will most likely be updating VS next, since I updated avs allot in staxrip and havn't touched vs yet. I also have one idea what I want to do, I'm not sure if it's possible at this stage or not, I have to do some research on the matter to see. Last edited by Revan654; 6th August 2018 at 18:48. |
6th August 2018, 18:43 | #3009 | Link | |
Staxrip reads the data from mediainfo and then injects it into the program. I've made some changes on that, I just have to find a HDR file to test and see if it works now. *Note* Only "True" HDR files will be supported that uses BT.2020 colorspace. If it uses anything else like P3 or such it will not work. P3 is not part of the HDR colorspace that is supported by the official docs. It should look like this: Colorprim: 2020 Matrix: 2020 NC Transfer: ST. 2084 Range: limited If the above is matched it will autodetect it as HDR source and select the proper VUI settings. |
6th August 2018, 19:57 | #3010 | Link | |
Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0500 cd/m2, max: 1000 cd/m2 |
6th August 2018, 20:06 | #3011 | Link | |
6th August 2018, 20:18 | #3012 | Link | ||
When it comes to P3 and mastering content: Quote:
Proper HDR Metadata in Mediainfo: Proper Metadata inside mkvinfo: |
6th August 2018, 20:51 | #3013 | Link |
The coordinates shown in your mkvinfo screenshot are P3:
https://en.wikipedia.org/wiki/DCI-P3#System_colorimetry My point being is to not be confused by MediaInfo showing "Mastering display color primaries : Display P3". It is "proper" HDR. (Not saying you didn't understand but maybe for others.) |
6th August 2018, 20:58 | #3014 | Link | |
I think your replies are the most detailed in this forum. For me, if you just keep up with the latest versions of the tools inside StaxRip (they are a lot) is enough, if you don't have time for more. I mean real update with all the new functionality of the latest versions added to StaxRip's GUI + bugs fixes. Your last version was around 2 months ago. When do you believe you will be ready for the next one ?
7th August 2018, 03:13 | #3015 | Link |
Good to see you are still here Raven. Interesting you mention about a project in Python. I too am working on a massive project in Python.
As for filters, I rely on mClean and SMDegrain. Both of those also need the PreFetch. Other filters are the IVTC, Yadifmod2 and TDEint. Hard to believe that as old as TDEint is, no other filter can do all the things that one does with interlaced material. If I were to think of something that could be requested it would inclusion of Levels and also GrayScale. I manually add these in, but it would be handy if they were right on the menus. |
7th August 2018, 06:14 | #3016 | Link | |
I don't want to overcrowd the context menu. There also plenty you can add manually if need be. I will likely remove one or two line filters, since that menu is getting a bit crowded. |
7th August 2018, 18:05 | #3017 | Link | |
P3 will be reject by many services and some electronics. Even youtube rejects P3 and only allows 2020 for HDR uploads. Youtube is behind the curve when it comes to support new types of formats and such. |
7th August 2018, 18:07 | #3018 | Link | |
7th August 2018, 18:23 | #3019 | Link | |
--------- mClean is not going anywhere, I personally consider it one top denoisers in avisynth. Along with MCTemporalDenoise. Even though mclean has some issues when using it(Usually black screen when previewing). Right now sure if it's mclean or windows files that create the issues. It looks like the script since the second you disable it everything returns to normal. MCTemporalDenoise script is kind of broken, did tweak it a bit to get it to work. Not sure if it's 100% Fully working yet(My tweaked version hasn't been released). These are all the Filters currently Included and works within StaxRip: |
