3rd February 2016, 01:04 | #804 | Link |
Stax a new milestone in x265 has been released. Maybe its time to update. Thanks for the great work!
3rd February 2016, 06:41 | #805 | Link |
Hello Frank.
It's been exactly two months since your last update of StaxRip (03/12/2015) A lot of new versions of apps have been released that you include in your StaxRip release and a few bugs have been mentioned, too. Your project seems a little bit abandoned. Is everything OK ? Are you still interested in this project ? Thanks!
3rd February 2016, 10:56 | #806 | Link |
I am starting to worry about Stax76.........
Question for stax76, why does staxrip (currently using StaxRip_x64_2015-12-03) use ffmpeg as decoder when x265 preset is being used? I selected DSS2 as 'Source Filter' with lavfilter (copy back dxva) set as preferred directshow. So by right, Lavfilter should be used as the decoder instead of ffmpeg? |
4th February 2016, 03:14 | #808 | Link |
Only piping? I don't think so....because normally, gpu-z should reports gpu usage (since the source can be dxva accelerated).
Hmm....if only there is a way to add -hwaccel dxva2 to ffmpeg when x265 preset is being used.... |
7th February 2016, 17:34 | #809 | Link |
Hi everybody,
the last weeks I could only spent little time for StaxRip, I should have more time in 3-5 weeks and try to catch up then. small update: https://github.com/stax76/staxrip/wi...ment-Changelog
7th February 2016, 19:36 | #811 | Link |
The following vapoursynth plugins could be updated:
- fmtconv (latest release is v17) - havsfunc v21 - knlmeans 7.3.0 - mvtools v10 - nnedi3 v.8 - vlsmashsource r859 Vapoursynth is now at release 31, and could be updated as well Moreover, using Vapoursynth 29 and above, staxrip preview is broken (and "View in external player" too). Maybe because VS now uses zimg instead of SWscale |
7th February 2016, 20:28 | #812 | Link | |
Thank you for the work you made. I love this software. I looked forward to the update. You forgot or not have time to make qaac and MediaInfo update. thank you again |
20th February 2016, 03:53 | #819 | Link |
I have using this for a few years now and find it good. Just one question, why when using Nvidia GPU does it still take ~ hr to convert a 6gig file?
I know that a commercial product uses Nvidia GPU, and can convert same file with same output filesize and quality in less than 5 minutes. I may have the wrong end of the stick here, and my painted on eyes may have missed an obvious setting. Willing to be educated on correct settings. |
20th February 2016, 06:52 | #820 | Link | |
