4th August 2009, 02:12 | #581 | Link |
warpsharpened
ffms2-mt-03082009.rar
Svn build as of today (i.e. fixed vc1 decoding, etc...) ffmpeg-mt had one minor update fixing the huff decoding problem (i.e. fixing the mt part instead of me just disabling the threading). Other then that it is the same. Built with: MSVC 2008 (FFMS2) GCC 4.4.0 (ffmpeg and libraries (libfaad, opencore, static pthread)) Last edited by TheRyuu; 4th August 2009 at 10:58. Reason: Missing closing ) |
4th August 2009, 17:12 | #582 | Link |
Hi Guys
I'm trying to open a VC-1 file or M2TS file, but I get a codec error in VirtualDub. My script: LoadPlugin ("C:\Program Files\AviSynth 2.5\plugins\ffms2.dll") FFVideoSource("c:\Test.m2ts") I'm using the build "ffms2-mt-03082009.rar". Thanks |
4th August 2009, 18:00 | #583 | Link |
Professional Code Monkey
Give. Me. A. Sample. Now.
5th August 2009, 15:42 | #584 | Link |
I have indexed a .264 raw file stream with the ffmsindex.exe file and thus created a .ffindex index-file. When I load the .264 video stream and the cache file like this:
FFVideoSource("file.264", cachefile="file.264.ffindex") Edit: Now after a long time, VirtualDub reports "video track is unseekable"... Oh, and by the way, probably a very long-term suggestion (and I know this is really challenging): It would be really extremely great, if FFmpegSource was GPU assisted and not only by Nvidia cards, but also by ATI cards, so the code would have to be in either OpenCL or CUDA and ATI Stream... That would be totally amazing. Last edited by moviefan; 5th August 2009 at 16:14. |
5th August 2009, 17:18 | #585 | Link | |
Now for a refresh in GPU (de)coding. ATI's stream is dead. DEAD. What you call "CUDA" is nvidia only and is using their decoder chip. Looking at the dgdecodeNV stuff I'm not impressed by the limitations at all. Also I hate nvidia so unless someone sends me a good set of SLI cards I'd never bother. OpenCL isn't available yet so good luck with that... The only currently working acceleration built into FFmpeg is more or less linux+nvidia only. I think they're going to add yet another video acceleration API but windows support has never been one of their big strenghts. You're most likely better off investing in a threescoresofcores cpu and using the FFmpeg-mt builds, they're very stable nowadays. Summary: I'd rather make something that works but thanks for asking
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 5th August 2009 at 17:23. |
8th August 2009, 17:05 | #586 | Link |
Another small change with possibly big effects to test... This time it's a fix for the NVOPs found in many xvid files which would throw off linear decoding. It appears to work on all of my test files but it's still possible that some encoders for random reasons write their NVOPs differently, and it may still break in those cases.
http://ivtc.org/new/beta/FFMS2_nvop_fix_test.rar
9th August 2009, 11:09 | #587 | Link |
Could someone please tell me how to use the SWScale function properly?
My avisynthscript looks like this: Code:
LoadPlugin ("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll") FFVideoSource("F:\Dokumente\DVDFab\test.mkv", cachefile="F:\Dokumente\DVDFab\test.ffindex").SWScale(width =1280, height =720, resizer = "SPLINE", colorspace="YV12") Code:
AviSynth script error: SWScale: Context creation failed *blahblah* I looked into the documention: It seems that Swscale needs some input that is called "clip". The Problem is: I have no idea what i meant by this. Thanks for your help
German Boy -> Bad English :stupid: |
9th August 2009, 11:18 | #588 | Link |
Software Developer
"clip" is the implicit first argument of each Avisynth function.
If you call Foobar().SWScale(...), then "clip" will be the return value of Foobar(), so you don't need to set "clip" explicitly here. Of course you could also do it like this: c = Foobar() SWScale(clip = c, ...) However I'm getting the same "SWScale: Context creation failed" error when trying to use SWScale(). Not sure what it means...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th August 2009 at 12:49. |
9th August 2009, 15:34 | #589 | Link |
"SWScale: Context creation failed" is the generic unknown error message and it was caused by trying to pass incorrect flags to it. I'll post another test version with the fix once I finish implementing the last part of the RFF flag support. (I hate force film, do you?)
12th August 2009, 01:31 | #590 | Link |
A new test version for you. No opencore-amr compiled in this time though. No ffmsindex.exe either because it needs to be updated too.
http://ivtc.org/new/beta/FFMS2_rff_test.rar The main news are RFF flag support. This means you can now throw away DGDecode for most encoding purposes and DGAVCSource if you're encoding from the mkv or mp4 containers. The new setting is called rffmode where 0=ignore flags, 1=honor pulldown flags and 2=force film. (don't use force film, instead use tfm(d2v=...) or something, maybe I'll add fake d2v writing some day) It also changes the behavior on indexing when errors are encountered when decoding audio to possibly be more compatible. There should be no change in behavior for completely correct files. The FFPP and SWScale avisynth filters also have a bug fixed that would cause them to not work or use other settings than specified. TEST IT AND REPORT THE RESULTS ON YOUR FAVORITE VOB OR FILE WITH AUDIO THAT WOULDN'T INDEX BEFORE.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 12th August 2009 at 01:46. |
13th August 2009, 20:43 | #592 | Link | |
What happens if you use TFM(d2v=...) and honor pulldown flags is that it will take its matches from the d2v. Only in the irregular ntsc portions (or portions where the match using the field suggested by the d2v is horribly bad, I assume) will it revert to good old field matching. Combine with TDecimate and you have something that can properly handle slight irregularities. What happens with force film is that you ignore every single pulldown flag when creating the output. Instead you just check to see if you need to duplicate or drop a frame as encoded in the source to keep the total number of frames intact. The result is that one single "interlaced" frame/orphaned field in the source will almost unconditionally be present in all its eye cancer glory. Force film is just there to make it feature complete. Never use it if you have a choice. Also, my implementation can handle frame duplication and tripling unlike the DG tools (just a small note, I've never seen a stream that actually does it).
14th August 2009, 16:11 | #593 | Link |
I had downloaded FFMpeg binaries from Google Code Downloads link. I copied .dll's, .exe and .avsi to \Avisynth\Plugins\ folder, i get error Avisynth is not installed make sure it is installed first, and same error if i copy them into \windows\system32 folder except for .avsi file. Can i get help here if i have to make it work? i am using DSS() and i was adviced to use FFVideoSource() instead of DSS(). Thanks Avinash |
15th August 2009, 14:01 | #594 | Link |
Step 1: Include all relevant information
Step 2: Hope that someone cares I have no idea what you did but it's not right. Stop putting random things in system32. What says avisynth isn't installed? Did you even install avisynth?
15th August 2009, 21:12 | #595 | Link |
hi,
Thanks for the reply. I have Avisynth installed and is working fine. I downloaded FFMS from this link http://ffmpegsource.googlecode.com/f...ce-2.00b10.rar I opened archive and copied ffms2.dll and ffmsindex.exe from archive and copied it to Avisynth\plugins folder, but when i say FFVideoSource("Media_File_Name") or FFMpegSource2() i get error saying saying "there is no function named" for both the functions Then i copied ffms2.avsi i try to use above functions FFVS() or FFMs2(), i get avisynth not installed error, but it is. Then i put the ffms2.dll and ffmsindex.exe in \windows\system32 folder thought it would help, but i got the same error messages as above. I hope i am clear in explaining. Thanks, Avinash |
15th August 2009, 21:24 | #599 | Link | |
I don't like to export things as strings, there's always one more formatting option you have to add. It's material for ffms2.avsi if anything. The missing \ has been fixed in the RFF test already.
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 15th August 2009 at 21:27. |
