Old 15th March 2010, 03:13   #1221  |  Link
8ternity
8ternity's Avatar
@8ternity
Let's try to make some order.
About FFmpeg update. You can. But results can be unpredictable: I usually test the updated sw for a while before releasing them into AVStoDVD.
Movie #1 Try #1: from the log file, FFmpeg did not crash, because FFmpeg was not used. There's a problem in decoding video source. Have you installed Haali and ffdshow?
Movie #2 Try #1: yes, ffmpeg+aften had a problem in encoding audio track. Why have you changed from default wavi+aften to ffmpeg+aften as AC3 encoder? If also wavi+aften fails you can try with QuEnc. Many users had success in converting blu-ray audio using QuEnc (right Adub ).
Bye
Hi MRC,
About ffmpeg, i reset to default.
About Try #1: Yes i have ffdshow clsid rev 3316 installed. i have also try rev 3222. Mastroka haali was installed, i was using for ripbot264 all thoes softwares.
Movie #2: I was changed because i was trying to find what's the trouble. I was sucessfully convert over 15 movies in the previous version 2.2.4 but i was let over 2 month to re-use again and have made the update.
Normally with ver 2.2.5 i was using has default but with 2pass with HCencc because the quality video was a little bit more clean has the 1pass with QuENC.
I have reinstall version 2.2.5 and let everything has default but use it in 2pass.
If i have another crashed, i will post log info. After that, i will try my older version 2.2.4 to check if it's an update the trouble.
For info, i was using Windows 7 professional x86 edition.
Thanks for replies.
Old 15th March 2010, 07:30   #1222  |  Link
8ternity
8ternity's Avatar
Hi MRC.
after another tries, here the result and log file.
The conversion has been completed but the exported dvd has no audio.
Here the log file:
<2010-03-14 22:15:27>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: MILLENIUM
DVD Menu: No Menu
Output Folder: G:
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 6000
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: M: SONY DVD RW DRU-V200S 1.60
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: E:\DVD\MILLENIUM.m2ts
Info: AVC - 6355 kbps - 1920x1080 - DAR 1,778 - 24 fps (CFR) - Progressive - 2:32:42 hours - 219907 frames
Audio: E:\DVD\MILLENIUM.m2ts
Info: DTS - 768 kbps - CBR - 48000Hz - 6ch - 2:32:42 hours
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("E:\DVD\MILLENIUM.m2ts", CacheFolder = "G:\TEMP")
Audio = A2DAudioSource("E:\DVD\MILLENIUM.m2ts", CacheFolder = "G:\TEMP")
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3474,7 MB
HCenc Parameters: -ini "G:\TEMP\MILLENIUM_0_MILLENIUM.HCenc.ini"
HCenc ini file:
*INFILE G:\TEMP\MILLENIUM_0_MILLENIUM.avs
*AVSRELOAD
*OUTFILE G:\MILLENIUM_0_MILLENIUM.m2v
*LOGFILE G:\TEMP\MILLENIUM_0_MILLENIUM.HCenc.log
*MAXBITRATE 9000
*BITRATE 3181
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*NOSMP
*PRIORITY IDLE
*WAIT 2
<2010-03-15 01:59:36>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: G:\MILLENIUM_0_MILLENIUM.m2v (3475,9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3201 kbps - 720x480 - DAR 1,778 - 24 fps (CFR) - Progressive - 2:32:42 hours - 219909 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "G:\MILLENIUM_0_MILLENIUM.m2v" -srcfps 24.000 -destfps 29.97 -inplace -bff
<2010-03-15 02:14:07>
END PULLDOWN OPERATIONS
DGPulldown executed on File: G:\MILLENIUM_0_MILLENIUM.m2v (3475,9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3201 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 2:32:42 hours - 219686 frames
START AUDIO DEMUXING OPERATIONS
FFmpeg Parameters: -i "E:\DVD\MILLENIUM.m2ts" -acodec copy "G:\MILLENIUM_0_MILLENIUM.ToFix.dts"
<2010-03-15 02:17:23>
END AUDIO ENCODING OPERATIONS
Created File: G:\MILLENIUM_0_MILLENIUM.dts (838,9 MB)
OUTPUT AUDIO INFO: DTS - 768 kbps - CBR - 48000Hz - 6ch - 2:35:26 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "G:\TEMP\MILLENIUM_0_BatchMux.ini"
BatchMux ini file:
-d "G:\MILLENIUM_0\VIDEO_TS"
-mxp "G:\TEMP\MILLENIUM_0_MuxMan.mxp"
-l "G:\TEMP\MILLENIUM_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "G:\MILLENIUM_0_MILLENIUM.m2v"
-vidmode LB
-a1 "G:\MILLENIUM_0_MILLENIUM.dts"
-a1lang fr
-cellfr "G:\TEMP\MILLENIUM_0_MILLENIUM_MuxMan.txt"
-progfr "G:\TEMP\MILLENIUM_0_MILLENIUM_MuxMan.txt"
-chapfr "G:\TEMP\MILLENIUM_0_MILLENIUM_MuxMan.txt"
<2010-03-15 02:22:23>
END DVD AUTHORING OPERATIONS
Created Folder: G:\MILLENIUM_0 (3559,9 MB)
<2010-03-15 02:22:24>
Log file created by AVStoDVD Release 2.2.6
I will try version 2.2.4 to see if it's okay.
Thank You.
Old 15th March 2010, 16:07   #1223  |  Link
ron spencer
DVD Magistrate
Is it possible to NO re-encode audio? On my media server I often make MKVs (movie only) of my BluRays, but I convert all audio to AC-3 448, which is fine for DVD. Can I choose no audio re-code? I did not see this in the options. If not it would be a good option.
thks
ron spencer is offline   Reply With Quote
Old 15th March 2010, 16:54   #1224  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@archaeo
you can change the HCenc matrix in 'Title Edit'/'Video'/'HCenc advanced options', but it resets to MPEG at every new project.
@8ternity
Movie #1 Try #1: what does the Preview Clip window say? It is useful to understand if you have a problem in the directshow decoding chain.
Movie #2 Try #2: Muxman has rejected the kept DTS audio track. Try to re-encode it using QuEnc as AC3 encoder.
@ron spencer
Yes, it is. It is the default option, if the audio track is DVD compliant. See 'Preferences'/'AudioVideo'/'Keep DVD compliant audio'.
Are you really living in the isle of Sodor? Do you know Thomas?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 15th March 2010, 18:59   #1225  |  Link
ron spencer
DVD Magistrate
Ahhhhhhhhhhh.....thank you!!!
You know, I have always wanted someone to pickup that I had "Sodor" listed!!! You are the only one..yes I know Thomas (through my young son)...
Never tried your proggy before...hope it will be fun!!!
Old 15th March 2010, 20:56   #1226  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
So I deserve a hurray from the Fat Controller! My son is a big Thomas & Friends fan too... even if in Italy is not very popular.
I hope you will have fun with A2D. Any improvements suggestions is always welcome!
Bye
MrC
AVStoDVD Homepage
Old 16th March 2010, 01:37   #1227  |  Link
8ternity
8ternity's Avatar
@8ternity
I have uninstall everything and let the avisynth version that your installer, but left ffdshow 3316rev, clsid generic team, left haali matroska too.
I have set as defaut your suggestions and make an preview, it's works! So i just start a new conversion and let you know when it's done if everything is okay.
Thanks for your time
Old 16th March 2010, 01:59   #1228  |  Link
archaeo
Banned
archaeo's Avatar
@archaeo
Bye
Many thanks! And kudos to you for a nice program
archaeo is offline   Reply With Quote
Old 16th March 2010, 04:36   #1229  |  Link
8ternity
8ternity's Avatar
Hello MRC,
After conversion has done, the export movie still have no sound in the builded movie. I've include two logs in this post (job and saved log after project done).
<2010-03-15 20:33:39>
START PROCESS
PROJECT SETTINGS
DVD Menu: No Menu
Output Folder: G:
PREFERENCES
Video Resolution: 0
AC3 Audio Encoder: 2
DVD Audio Format: 0
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Save Log file: 1
Subs:
AVISYNTH SCRIPT
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
HCenc Parameters: -ini "G:\TEMP\MILLENIUM_2_MILLENIUM.HCenc.ini"
HCenc ini file:
*INFILE G:\TEMP\MILLENIUM_2_MILLENIUM.avs
*AVSRELOAD
*OUTFILE G:\MILLENIUM_2_MILLENIUM.m2v
*LOGFILE G:\TEMP\MILLENIUM_2_MILLENIUM.HCenc.log
*MAXBITRATE 9000
*BITRATE 3181
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-03-15 23:10:17>
Created File: G:\MILLENIUM_2_MILLENIUM.m2v (3475,9 MB)
DGPulldown Parameters: "G:\MILLENIUM_2_MILLENIUM.m2v" -srcfps 24.000 -destfps 29.97 -inplace -bff
<2010-03-15 23:24:36>
DGPulldown executed on File: G:\MILLENIUM_2_MILLENIUM.m2v (3475,9 MB)
FFmpeg Parameters: -i "E:\DVD\MILLENIUM.m2ts" -acodec copy "G:\MILLENIUM_2_MILLENIUM.ToFix.dts"
<2010-03-15 23:27:54>
Created File: G:\MILLENIUM_2_MILLENIUM.dts (838,9 MB)
BatchMux Parameters: -arglist "G:\TEMP\MILLENIUM_2_BatchMux.ini"
BatchMux ini file:
-d "G:\MILLENIUM_2\VIDEO_TS"
-mxp "G:\TEMP\MILLENIUM_2_MuxMan.mxp"
-l "G:\TEMP\MILLENIUM_2_MuxMan.log"
-prio LOW
-v "G:\MILLENIUM_2_MILLENIUM.m2v"
-vidmode LB
-a1 "G:\MILLENIUM_2_MILLENIUM.dts"
-a1lang en
-cellfr "G:\TEMP\MILLENIUM_2_MILLENIUM_MuxMan.txt"
-progfr "G:\TEMP\MILLENIUM_2_MILLENIUM_MuxMan.txt"
-chapfr "G:\TEMP\MILLENIUM_2_MILLENIUM_MuxMan.txt"
<2010-03-15 23:32:49>
Created Folder: G:\MILLENIUM_2 (3560 MB)
Saved Log
'20:32:05' AVStoDVD Release 2.2.6 loaded!
'20:32:05' AviSynth 2.5.8 is installed.
'20:32:05' ImgBurn is installed ("C:\Program Files\ImgBurn\ImgBurn.exe").
'20:32:05' New AVStoDVD Project started!
'20:32:23' Current Preferences saved as default.
'20:33:04' MediaInfoLib - v0.7.26 initialized.
'20:33:04' Title 1 "E:\DVD\MILLENIUM.m2ts" added.
'20:33:39' AVStoDVD Project started.
'20:33:39' Title 1 video encoding operations started.
'23:24:36' Title 1 video encoding operations ended successfully.
'23:24:36' Title 1 audio encoding operations started.
'23:27:54' Title 1 audio encoding operations ended successfully.
'23:27:54' DVD authoring operations started.
'23:32:49' DVD authoring operations ended successfully.
'23:32:49' AVStoDVD Project ended successfully.
I really dont know why im not having sound in the exported project.
Did i need to uninstalled all versions of ffdshow, haali, etc. and try the ones included in your installer?
Thank You,
8
Old 16th March 2010, 11:42   #1230  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
When you enter 'Preferences' to select QuEnc as AC3 encoder, go to 'AudioVideo' Tab and toggle off 'Keep DVD compliant audio'. In that way, DTS track will be re-encoded using QuEnc and not retained (and refused by Muxman).
Bye
MrC
AVStoDVD Homepage
Old 16th March 2010, 13:45   #1231  |  Link
8ternity
8ternity's Avatar
@8ternity
Bye
I will try this and let u know today.
Old 16th March 2010, 19:38   #1232  |  Link
8ternity
8ternity's Avatar
Does exaclty the same thing. No audio on the exporter project.
Old 16th March 2010, 20:10   #1233  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Could you post the log file of this last try?
Bye
MrC
AVStoDVD Homepage
Old 17th March 2010, 00:42   #1234  |  Link
8ternity
8ternity's Avatar
Bye
- Conversion Log
- Saved Log
Conversion Log:
<2010-03-16 08:44:50>
START PROCESS
PROJECT SETTINGS
DVD Menu: No Menu
Output Folder: G:
PREFERENCES
Video Resolution: 0
DVD Audio Format: 0
DVD Audio BitRate: 384
Keep DVD Compliat Audio: 0
Normalize Audio: 0
Save Log file: 1
Subs:
AVISYNTH SCRIPT
HCenc Parameters: -ini "G:\TEMP\MILLENIUM_3_MILLENIUM.HCenc.ini"
HCenc ini file:
*INFILE G:\TEMP\MILLENIUM_3_MILLENIUM.avs
*AVSRELOAD
*OUTFILE G:\MILLENIUM_3_MILLENIUM.m2v
*LOGFILE G:\TEMP\MILLENIUM_3_MILLENIUM.HCenc.log
*MAXBITRATE 9000
*BITRATE 3181
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-03-16 11:21:12>
Created File: G:\MILLENIUM_3_MILLENIUM.m2v (3475,9 MB)
DGPulldown Parameters: "G:\MILLENIUM_3_MILLENIUM.m2v" -srcfps 24.000 -destfps 29.97 -inplace -bff
<2010-03-16 11:35:07>
DGPulldown executed on File: G:\MILLENIUM_3_MILLENIUM.m2v (3475,9 MB)
FFmpeg Parameters: -i "E:\DVD\MILLENIUM.m2ts" -acodec copy "G:\MILLENIUM_3_MILLENIUM.ToFix.dts"
<2010-03-16 11:38:24>
Created File: G:\MILLENIUM_3_MILLENIUM.dts (838,9 MB)
BatchMux Parameters: -arglist "G:\TEMP\MILLENIUM_3_BatchMux.ini"
BatchMux ini file:
-d "G:\MILLENIUM_3\VIDEO_TS"
-mxp "G:\TEMP\MILLENIUM_3_MuxMan.mxp"
-l "G:\TEMP\MILLENIUM_3_MuxMan.log"
-prio LOW
-v "G:\MILLENIUM_3_MILLENIUM.m2v"
-vidmode LB
-a1 "G:\MILLENIUM_3_MILLENIUM.dts"
-a1lang fr
-cellfr "G:\TEMP\MILLENIUM_3_MILLENIUM_MuxMan.txt"
-progfr "G:\TEMP\MILLENIUM_3_MILLENIUM_MuxMan.txt"
-chapfr "G:\TEMP\MILLENIUM_3_MILLENIUM_MuxMan.txt"
<2010-03-16 11:43:46>
Created Folder: G:\MILLENIUM_3 (3560 MB)
Saved Log:
'23:59:11' AVStoDVD Release 2.2.6 loaded!
'23:59:11' AviSynth 2.5.8 is installed.
'23:59:11' ImgBurn is installed ("C:\Program Files\ImgBurn\ImgBurn.exe").
'23:59:11' New AVStoDVD Project started!
'23:59:20' MediaInfoLib - v0.7.26 initialized.
'23:59:20' Title 1 "E:\DVD\2012.m2ts" added.
'23:59:23' DVD Size changed from DVD-5 to DVD-9
'23:59:31' Title 1 "E:\DVD\2012.m2ts" removed.
'23:59:53' MediaInfoLib - v0.7.26 initialized.
'23:59:53' Title 1 "E:\DVD\MILLENIUM.m2ts" added.
'00:01:41' DVD Size changed from DVD-9 to DVD-5
'00:03:01' AVStoDVD Project started.
'00:03:01' Title 1 video encoding operations started.
'02:55:48' Title 1 video encoding operations ended successfully.
'02:55:48' Title 1 audio encoding operations started.
'02:59:04' Title 1 audio encoding operations ended successfully.
'02:59:04' DVD authoring operations started.
'03:04:42' DVD authoring operations ended successfully.
'03:04:42' AVStoDVD Project ended successfully.
'08:44:50' AVStoDVD Project started.
'08:44:50' Title 1 video encoding operations started.
'11:35:07' Title 1 video encoding operations ended successfully.
'11:35:07' Title 1 audio encoding operations started.
'11:38:24' Title 1 audio encoding operations ended successfully.
'11:38:24' DVD authoring operations started.
'11:43:46' DVD authoring operations ended successfully.
'11:43:46' AVStoDVD Project ended successfully.
Old 17th March 2010, 12:07   #1235  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I fear that you have toggled off 'keep dvd compliant audio' but you have not refreshed your project. I suggest you to:
- Start AVStoDVD
- Change Preferences (save as default, if you wish)
- Add input files
- Verify in 'Title Edit'/'Audio' that 'keep dvd compliant audio' is off
- Start to encode
Bye
MrC
AVStoDVD Homepage
Old 18th March 2010, 02:51   #1236  |  Link
8ternity
8ternity's Avatar
I've try, samething.
Now i really don't know what to do.
Is there a program can be incompatible or create an confusion with AVStoDVD ?
Old 20th March 2010, 00:41   #1237  |  Link
ron spencer
DVD Magistrate
I am getting an error with audio (from a HD mkv I made with AC3 448).
Error says
Getchannel: Attempted to request a channel that did not exist:
line is:
Video = DirectShowSource("U:\MEDIA\High Def Movies\test.mkv", fps=23.976, convertfps=true, audio=false)
Audio = DirectShowSource("U:\MEDIA\High Def Movies\test.mkv", video=false)
Audio = Audio.GetChannel(1,3,2,5,6,4)
Video = Video.Spline64Resize(720,480)
Old 20th March 2010, 01:24   #1238  |  Link
mpucoder
@8ternity: Can you post the MuxMan log (G:\TEMP\MILLENIUM_3_MuxMan.log)? I'm curious as to why the audio is not being muxed, as 768kbps DTS is acceptable (unless the channel assignments are not SD_DVD)
mpucoder is offline   Reply With Quote
Old 20th March 2010, 13:40   #1239  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@ron spencer
AVStoDVD uses a directshow approach to decode media file. So the user has to setup its decoding filters (like ffdshow) correctly: in this situation you are trying to decode/encode a 5.1 channels audio, so your filter output mixer must be set properly. If you are using ffdshow it must be set: 3/0/2+LFE.
AVStoDVD usually takes care of that, assuming you have installed ffdshow. The user has to do it manually when: a) there is another AC3 filter or b) QuEnc is used. I think b) is your case, because there is the GetChannel(1,3,2,5,6,4) call. In fact QuEnc has a channels mapping bug that must be handled with GetChannel.
Concluding:
1. Use ffdshow as AC3 filter and Wavi+Aften as AC3 encoder: no need to setup mixer
or
2. Use any AC3 filter or QuEnc as AC3 encoder: setup mixer before start AVStoDVD project
@mpucoder
If 8ternity did not select to keep temporary files, then the MuxMan log is gone. Anyway he is not the only user that is complaning about DTS track rejects.
I fear that, since FFmpeg throws out a lot of error messages during DTS demux, that audio tracks are somehow bad or badly muxed.
Thanks for your fantastic MuxMan.
Bye
MrC
AVStoDVD Homepage
Old 20th March 2010, 18:04   #1240  |  Link
ron spencer
DVD Magistrate
thanks!!!
what are those temp files made in C:\ ?
they are named like:20_16_28_59
and contain:
CMpeg4Splitter::BreakConnect() Enter
[IMG] code is Off
